02-22-2009, 00:17 | #151 (permalink) |
Insane Poster Join Date: Feb 2009
Member: 977901 Status: Offline Thanks Meter: 12 | i don't know if it makes sence to replace the configfiles aftere MuscleNerds explanation. @nass83 I think they mean mobile terminal. Guess you know whats a terminal. @MuscleNerd many thanks, that destroyed my hope, but as i've mentioned I already thought that they check the version. So this could be an approach. Don't know, how to find the hole to access the cpu, but maybe it would be easier to manipulate the new baseband file! " IS THE VERSION YOU SENT ME LESS THAN THE VERSION I'M RUNNING?" So, we have to give the old 02.28.00 baseband the identity of the new 02.30.03 firmware!?! If i understand you right, the CommCenter arrange the communication between the baseband and the modem? So which procedure is asking for the version of the baseband? The CommCenter? no? It has to be the Updater? (the apple updater) I mean, if you had 02.28.00 on your phone and done the upgrade to 02.30.00 apple has to put the new version for the baseband on the phone? It is not a hardware solution. I think there are three posible ways: 1.) The one MuscleNerd told about, which means a enormous knowledge of system programming. 2.) The manipulation of the application that updates the baseband 3.) Or the direct manipulation of the new baseband, to make the asking for the version answering with yes. I don't know, if the baseband file i have realy the original baseband file, so is there a possibility to read out the baseband version? I have a 02.28.00 running on an other phone. |
02-22-2009, 00:23 | #152 (permalink) |
Member: 977901 Status: Offline Thanks Meter: 12 | sorry i've forgotten to ask. I've heard there are two cpu's, one for the bootloader and one for the baseband? And i didn't downloaded and installed the var files (mentioned in the tuto) because they want me to put it under the path .../audio And i don't need any kind of file in the directory /audio to manipulate the baseband. |
02-22-2009, 00:47 | #153 (permalink) | |
Junior Member Join Date: Sep 2007
Member: 578886 Status: Offline Thanks Meter: 78 | Quote:
A woman's orgasm doesn't trick the baseband into downgrading itself. The only other files in their "solution" besides the woman orgasms are the stock Apple BBUpdaterExtreme and baseband files, which follow the rules I described above. Notice that their own video shows them at baseband 02.30 after their "solution" is run. | |
02-22-2009, 00:52 | #154 (permalink) | ||||
02-22-2009, 06:34 | #156 (permalink) |
Banned Join Date: Feb 2007
Member: 447548 Status: Offline Thanks Meter: 83 | yeah did it!! got names noticed by posting FAKE and then got GOOD members banned and original programmers name dragged in mud.. yeah did it too. jeerked off to erotic sound files |
The Following User Says Thank You to platinumLA For This Useful Post: |
02-22-2009, 09:11 | #157 (permalink) | |
No Life Poster Join Date: Jan 2004
Member: 51125 Status: Offline Thanks Meter: 1,435 | Quote:
100% FAKE TSAMBA method. Will leave your Iphone with NO NETWORK!! 100% TESTED - NOT WORKING!! ITS FAKE. YOU HAVE BEEN WARNED | |
02-22-2009, 13:40 | #159 (permalink) |
Member: 977901 Status: Offline Thanks Meter: 12 | @Nass83 You first have to jailbreak your phone to get cydia. Then open cydia ->search >"mobileterminal" -> install. You also need openssh to access your phone from your computer. But pay attention, this is an ssh connection to your phone. You should use this only, if you know what you are doing! @maximbelov and platinumLA. So you've really overidden your sound files??? But you just have to copy the var.rar file into you UISounds directory! So with ssh you can remove the file. Not if you've overriden the whole directory! OK. I copied it (UISounds) to my computer, but its a file with 2,2MB and i can't attache it. If you need it tell me. (or get it back by doing the Update with iTunes) @MuscleNerd sorry, i've tried to install minicom, but i have problems with setting it up. Always, when i try to give the paths, i can't use the cursor. It's always jump out and i haven't find a possibility to save my settings. And i'm not sure, if i really deleted the firmware,if so, is it still possible to use AT commands to check the modem? sorry for my stupid question, but does minicom communicates directly with the modem or with the firmware? I thought, without firmware i can't connect to the modem??? I mean i send a command to the modem and the firmware on it is answering??? While googlin tonight, i found there is a cmd to set the firmware number. So i would try to give the firmware the old (lower) number 02.28.00 and then i would try to flash the 02.28.00 by the apple Updater. As i told, I'm not a hacker, but i would like to use my phone. And i'm now very interested, because i saw there is a unix/linux OS running on the phone. And i think now MuscleNerds way is the only way that gives us the possibility to access the modem firmware. By AT commands. But first i have to know how to setup minicom and how to use it. (last time i access a modem directly with AT commands is 3 years ago) For all: The procedure in this tuto makes my phone very insable!!! It has no network! It restarts every 3 minutes and i'm not sure if that stops after i put the new firmware on it. The only way would maybe to take the official update by itunes and then you're back on 02.30.00 firmware, hmm... Thats not really a solution...but an approach... |
The Following User Says Thank You to Geronino For This Useful Post: |
02-22-2009, 15:35 | #160 (permalink) |
Junior Member Join Date: Feb 2009
Member: 978388 Status: Offline Thanks Meter: 0 | Now, I probably messed up. Cause: The iPhone does recognize my simcard. Yet all i'm getting is a small vertical stripe and 3 dots (or little horizontal stripes ). It does'nt search for my carrier and flightmode does'nt help either, unless I depress it a 100 times. Then it searches for a minute or so and then says no service. Any tips? I'll try again 2night, gotta go too work now. |
02-22-2009, 15:52 | #161 (permalink) |
Super Moderator Join Date: Jan 2006 Location: [Egypt, Alex]
Member: 224065 Status: Offline Sonork: 100.1577902 Thanks Meter: 7,930 | 2. Do quickPwn2.2 procedures (U must know it by now, else, start from reading howto unlock/jailbreak the Iphone thru quickpwn)phone is in DFU btw. 3. unlock using yellowsnow Iphone can't be unlocked CUZ YellowSnow CAN'T UNLOCK 2.30 Even who did this thread Is posting Fake solutions Or maybe copy &Paste without testing NOT WORKING FAKE If it's succefully Downgraded iphone should Preview Baseband version Stop Spam :@ |
02-22-2009, 15:55 | #162 (permalink) | |
Member: 224065 Status: Offline Sonork: 100.1577902 Thanks Meter: 7,930 | Quote:
The LUCK SOLUTION IS HERE REFILL ur luck &Try it | |
02-22-2009, 15:59 | #163 (permalink) |
Member: 224065 Status: Offline Sonork: 100.1577902 Thanks Meter: 7,930 | ok to end this sm 1 tried it &WORKED POST complete screenshot for Phone with baseband version &Displayed full network in 1 Screen shot |
Welcome india the great gpg tma+spy machine+polar box+unloc iphone 2.30.03 x-sim+pump | chiragsp_codes | Main Sales Section | 0 | 04-24-2009 06:51 |
