03-28-2008, 20:36 | #1 (permalink) |
Major Poster Join Date: Jan 2006 Location: pakistan Age: 39
Member: 221419 Status: Offline Thanks Meter: 7 | help me " iphone with broken battery points" thanx in advance |
03-29-2008, 08:45 | #2 (permalink) |
Member: 221419 Status: Offline Thanks Meter: 7 | the layout for the iPhone circuit Hi, Well I got apple battery from a local store, and opened my iPhone, but unfortunately i messed up alot of things, i plucked the battery, without nowing that i will damage the circuit, as you can see the bellow images, i have spent more then 10 hours continuous to solve the problem. Let me explain it to you guys. This picture shows the battery wires connected to board, i messed these. http://www.imageuploadpub.com/images/63736toupload1.jpg The picture bellow explains my findings on the circuit I hope it will give idea to some one. http://www.imageuploadpub.com/images/33736toupload2.jpg Red is positive wire, white is negitive, (at least i think that) and black is ground, the real horror began when i come to know, that negitive point is only in the size of the needle head, I tried and short circuited it so many times, and heated that with my soldering machine. Now the current situation is like this, i didnt attached the white wire (unable to get its details, and its so small that can solder that) red and black are attached, my iPhone some times says that battery is finished and does not work, and some times, it works, but when it works it says WIFI is disabled, and SIM card system not activated, please contact apple support.Which i surly know I cant. I really need to fix my iPhone and looking on net, maybe some of these details are helpful to someone. BUT PLEASE BE CAREFUL AND TRY CUTTING THE WIRES BEFORE REPLACING THE BATTERY. |
03-29-2008, 09:02 | #3 (permalink) |
Member: 221419 Status: Offline Thanks Meter: 7 | iPhone communication board Hey, check this image ... http://www.imageuploadpub.com/images/360121105010l.jpg We have traced the red and black wires, but we are unable to trace the white wire, any body can help us by telling us the next point for white wire, so we can attach that. |
10-12-2008, 21:01 | #7 (permalink) |
Insane Poster Join Date: Apr 2006 Location: Columbus, Ohio, USA
Member: 261323 Status: Offline Thanks Meter: 3 | Hey fellas! Got sofar two iphones with the same problem. The wise solding point is goofed up! Any one can help! Thanks |
The Following User Says Thank You to gsmboutiqueinfo For This Useful Post: |
08-23-2009, 23:28 | #11 (permalink) |
Junior Member Join Date: Aug 2009
Member: 1103277 Status: Offline Thanks Meter: 0 | Does anyone have a translation for this picture or advice on how to fix an iphone 2G that has the white and black battery terminals disconnected from the circuit board? The red wire is still connected. |
08-24-2009, 00:02 | #12 (permalink) | |
No Life Poster Join Date: Nov 2005 Location: CHILE
Member: 196727 Status: Offline Thanks Meter: 419 | Quote:
br nafg | |
08-24-2009, 00:27 | #13 (permalink) |
Member: 1103277 Status: Offline Thanks Meter: 0 | The pads (terminals )for the black and white wire have been pulled of the circuit board. The white wire is actually soldered onto the board without the terminal right now and it seems to be working. I would think that without the terminal on the board the white wire might not stay on very good and wanted to know how to jump it. |
Help me " infinity team " | mbiborna | Infinity-Box | 5 | 03-18-2010 12:27 |
help me my dreambox is broken | backhor | DreamBox | 3 | 11-11-2008 14:18 |
Plz Help Me Lg Kg 195 Warning Battery | ali125 | LG | 0 | 08-30-2008 17:20 |
can nay one help me unlock iphone | ahmertelecom | iPhone 2 / iPhone 3G / iPhone 3GS | 2 | 11-08-2007 17:27 |
A2618 with broken battery connector area | Chuk | Hardware Repair by brands | 1 | 01-18-2002 01:05 |
