11-30-2010, 06:28 | #62 (permalink) |
Freak Poster Join Date: Nov 2008
Member: 906993 Status: Offline Thanks Meter: 15 | hi solution is here u try write 3.1.3 firmware on it will give error dont worry now u will try to write 4.0 firmware it will give error again but after few minunes fon will revive automatically 100% checked 2 mobiles 3g |
11-30-2010, 20:55 | #64 (permalink) |
Junior Member Join Date: Nov 2010
Member: 1454820 Status: Offline Thanks Meter: 13 | from 1015 to 1611 my phone is on iOs 4.0 - base band 6.15 - im trying to install custome firmware 4.2.1 (with BB 6.15) but keep getting the 1015 error hmm so i tried doing this 1)first i put in DFU state using redsnow 2) Then using iREB i put it in green screen state (which is ment to make sure custom firmware can be loaded 3) tried installing the firmware again in itunes and this time instead of 1015 error i get 1611 error hmm any ideas on that then ? |
11-30-2010, 23:17 | #65 (permalink) |
Freak Poster Join Date: Oct 2008 Location: dominican republic
Member: 874313 Status: Offline Sonork: polocell Thanks Meter: 37 | Originally Posted by sysek hm. 1. put iPhone on DFU mode (YouTube - How To: iPhone DFU Mode - MacComm.tv) 2. open iTunes 3. you will recive message, that your iphone is in recovery mode 4. shift + restore, pick 4.1 fw (you can download from here Download iOS Firmware) 5. wait for restore, then will be error 1015 6. your iPhone will in Recovery Mode, download Tinyumbrella (The Firmware Umbrella - TinyUmbrella) and kick out from recovery mode. 7. Then put again to DFU mode, restore with 4.2.1 and you have. thanks it works like a charm |
The Following User Says Thank You to polocell For This Useful Post: |
12-01-2010, 00:02 | #66 (permalink) |
Freak Poster Join Date: Feb 2008 Location: Rock&Roll City
Member: 715333 Status: Offline Thanks Meter: 19 | same problem,error 1015,under stuck recovery,no one can say just downgrade to 4.1 coz 4.2.1 has baseband requirement.. is this easy for you to downgrade?no one can tell if the BB gets up to 6.15 unless springboard is open and check the BB in the settings .many solution render..if others says working fine... well its your luck if you got it ... but others, are just fooling around.we need a proof.not as fairy tale story |
12-01-2010, 21:44 | #68 (permalink) |
No Life Poster Join Date: Jul 2009 Location: Los Angeles, CA
Member: 1081371 Status: Offline Thanks Meter: 720 | Ok Guys Since I Dont Have 4.0/4.1 FW I Downgraded To 3.1.3 And Yeah It Gave Me Error 1015 But After That I Use TinyUmbrella To Kick Device Recovery Mode...And Run Redsn0w To Jailbreak Hope I Help U Guys... |
12-01-2010, 21:56 | #69 (permalink) | |
Member: 1454820 Status: Offline Thanks Meter: 13 | Quote:
1)DFU via redsnow 2)install 4.1 via tunes - get 1015 error 3)unblock via tinyumbrella phone reboot and goes to firmware apple loading screen - does a strange apple install screen like firmware updgrade then onto apple stock activation screen for me becuase i have USA phone in UK 4)redsnow jailbreak using 4.1 5) rebooted and its fixed - feewwwww had me stuck for a few days so eh in the end im back to 4.1 with 6.15 base band but at least i can unlock my phone and it works yehhh lol give it a few days and i might try and install stock 4.12 using the same method as my base band is 6.15 i dont need to use the custom firmware anymore just stock | |
The Following 2 Users Say Thank You to acid90 For This Useful Post: |
12-02-2010, 09:38 | #70 (permalink) | |
well i do something different - but i dont think it mattered jus part4) i tried the "boot phone tethered" option first and it just seems to say on the pineapple screen so then i just continued from part 4 and it just worked. | |
12-02-2010, 09:54 | #71 (permalink) | |
No Life Poster Join Date: Jun 2004 Location: lebanon Age: 45
Member: 68311 Status: Offline Thanks Meter: 34 | Quote:
12-02-2010, 09:57 | #73 (permalink) | |
Freak Poster Join Date: Dec 2002 Age: 51
Member: 19190 Status: Offline Thanks Meter: 28 | Quote:
after follow your method, my iphone 3G now is ios 4.1 and the BB is 6.15, but i cannot kick it out of recovery mode, now it stay in recovery mode always... what should i do now? | |
The Following User Says Thank You to alex yong For This Useful Post: |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
