how to log in whatsapp iphone 4 i have iphone 4 but cant sign in to whatsapp i need help |
try installing gb whatsapp it works well on ios |
ok let me try thanks |
Please try to sign into iOS account and install another and retry |
WhatsApp on iPhone 4 |
WhatsApp for iPhone requires iOS 8.0 or Upgrade. iPhone 4 support iOS 7.1.2 so you won’t be able to download and install it from App Store. |
login to ios account and try again |
Simply go to the phone and download watspp and login in to your phone number |
WhatsApp no longer supports the iPhone 4, as it requires iOS 10 or later to run, and the iPhone 4 can only run up to iOS 7.1.2. This means that you won't be able to sign in to WhatsApp on your iPhone 4. If you need to use WhatsApp, you will need to upgrade to a newer iPhone model that supports iOS 10 or later. Some older iPhone models that support iOS 10 include the iPhone 5, iPhone 5s, and iPhone SE. Alternatively, you can use WhatsApp Web on your computer's web browser to access your WhatsApp account and send messages to your contacts. To do this, simply go to WhatsApp and scan the QR code with your iPhone's camera. Then, follow the prompts to sign in to your account and start using WhatsApp on your computer. |
I'd be happy to help you with signing in to WhatsApp on your iPhone 4. However, please note that WhatsApp officially ended support for iPhone 4 and older devices starting from February 1, 2020. Anyway, have you tried updating your software? If not, I think that should fix your problem. |
iPhone 4 was first unveiled on June 7, 2010. 12 years ago. It runs iOS 4 to 7. |
I just think they have the same login as the other iphone. |
As long as you follow the process, I don’t see any part of you struggling. I do think that QR Code functionality is not supported there yet but it’s good. |
