05-02-2009, 13:27 | #1 (permalink) |
Freak Poster Join Date: Oct 2004 Location: 03453007200
Member: 86994 Status: Offline Sonork: 100.1584487 Thanks Meter: 124 | Ipone 3g stucks on apple logo my iphone stucks om apple logo after reseting(erase all) option its not going in recovery mode and also not connecting with pc try to power off and on still same situation also not connecting with itune. thnx br Qaiser |
05-02-2009, 18:02 | #2 (permalink) |
Freak Poster Join Date: Jan 2007 Location: barbados
Member: 423897 Status: Offline Thanks Meter: 4 | connect phone to pc , open itunes , hold down power button and home button at the same time, release power button about 3 seconds after apple logo disapears and continue to hold home button until itunes discovers phone in recovery mode. Restore using iphone firmware |
05-03-2009, 00:41 | #3 (permalink) |
No Life Poster Join Date: Feb 2009
Member: 961957 Status: Offline Sonork: Jabber: [email protected] Thanks Meter: 641 | Open up the windows time app (double click the clock icon in the taskbar) hold the top power button and main (home) button on the iphone down for exactly 10 seconds then let go of the top power button and continue holding the main button for another 10 seconds then let go of both iTunes will connect in DFU (recovery mode) now hold shift and choose the firmware you wish to install |
05-03-2009, 11:09 | #4 (permalink) | |
Member: 86994 Status: Offline Sonork: 100.1584487 Thanks Meter: 124 | Quote:
already tried bro but no success one more thing that when i connect it with pc sometimes it shows battery sign with charging so still no luck | |
05-03-2009, 12:23 | #5 (permalink) | |
Member: 961957 Status: Offline Sonork: Jabber: [email protected] Thanks Meter: 641 | Quote:
If you follow the DFU procedure correctly, (connect to usb then hold home + power exactly 10 sec, then let go of power button but continue holding main button exactly 10 sec, then let go) itunes will load Apple USB recovery drivers, from there you can perform a restore, Usually the problem is not following the DFU procedure correctly. Check windows is picking the device up by clicking start -> run then type devmgmt.msc and see if it listed as an entry there, you may also want to check the connection on the iphones dock port | |
The Following User Says Thank You to Gecko_UK For This Useful Post: |
iphone 3g stuck on apple logo pleaase help | Maxblack71 | iPhone 2 / iPhone 3G / iPhone 3GS | 5 | 03-24-2010 15:58 |
3g stuck on apple logo | Ped | iPhone 2 / iPhone 3G / iPhone 3GS | 1 | 01-08-2010 11:31 |
Apple 3g Iphone 8GB Stuck on Apple logo | ansari123 | iPhone 2 / iPhone 3G / iPhone 3GS | 4 | 11-18-2009 01:29 |
iphone 3g stuck on apple logo | kasim | iPhone 2 / iPhone 3G / iPhone 3GS | 1 | 02-11-2009 18:24 |
