01-27-2014, 12:05 | #1 (permalink) |
No Life Poster Join Date: Mar 2009 Location: SAUDI ARABIA
Member: 998872 Status: Offline Sonork: jan143 Thanks Meter: 295 | iphone 3g activatation problem pls help |
01-27-2014, 14:32 | #3 (permalink) |
No Life Poster Join Date: Dec 2010 Location: [pujab haryana]
Member: 1481018 Status: Offline Sonork: 100.165460 Thanks Meter: 222 | first check ur set is unlocked 3gs update Till 6.1v after flash conect wifi and bypass id and activate if prob conect me send iem i tell u phn locked or unlocked |
The Following 2 Users Say Thank You to Sukh007 For This Useful Post: |
01-31-2014, 07:08 | #4 (permalink) |
Junior Member Join Date: Feb 2011 Location: ali pur m.garh
Member: 1517626 Status: Offline Thanks Meter: 8 | try restore 6.3 with i tune then jailbreak with 6.0.1 with redsnow then its will be ok |
The Following User Says Thank You to farhanstar For This Useful Post: |
01-31-2014, 07:20 | #5 (permalink) |
Member: 1517626 Status: Offline Thanks Meter: 8 | 3gs 6.1.3 untethered jailbreak & unlock 1) Restore your device with 6.1.3 2) Jailbreak 2.1) Open redsn0w_win_0.9.15b3 2.2) Go to extra 2.3) Go to select ipsw 2.4) Select iPhone2,1_6.0_10A403_Restore 2.5) Back 2.6) Jailbreak 2.7) Next, follow the instructions to enter dfu mode 2.8) Check install cydia & install ipad baseband (do not update baseband on new security phones) 2.9) Wait until jailbreak done 3) There will be no cydia in your device 3.1) Open redsn0w_win_0.9.15b3 3.2) Go to extra 3.3) Go to select ipsw 3.4) Select iPhone2,1_6.0_10A403_Restore 3.5) Go To Just boot 3.6) Follow the instructions to enter dfu mode 4) after device on u can see cydia 5) Open Cydia. 6) Click the "Changes" tab in the footer. 7) Press the "Refresh" button in the top left corner. 8) After "Reloading Data", perform a search for "p0sixspwn" (the O is a zero). 9) Tap Install. 10) After installing p0sixspwn your device is untethered 11) Install ultrasnow 1.2.8( u can use iphone yeta,repo666.ultrasn0w.com or iphone folders any other methodes) 12) Restart your device enjo |
02-02-2014, 03:47 | #6 (permalink) | |
Member: 998872 Status: Offline Sonork: jan143 Thanks Meter: 295 | Quote:
02-02-2014, 04:07 | #8 (permalink) | |
Junior Member Join Date: Oct 2007 Location: Philippines
Member: 602056 Status: Offline Thanks Meter: 4 | Quote:
try to put an ORIGINAL SIMCARD to activate or try to use redsnow to activate note: download links are all over the internet USE SEARCH BUTTON | |
