iphone 2g no service after unlock - URGENT Hello im having 2 iphone 2g in hand i use itune 8.0.2 and update to 2.2.1 i follow this intruction to unlock http://www.iclarified.com/entry/index.php?enid=1880 after process done sucessfully i hv no network/no service, emergency is working well.... any solution plz????? |
rest network setting |
i have reset netwrk setting and reset all also problem still here, any solution??? |
check the modem version bro! |
it means unlocking process wasnt completed successfully or nt executed at all:-) |
br;) |
2g all version supported what was the 1st ver installed in dont upgrade 1.02 to direct 2.2.1 upgread 1.02 to 2.0 and 2.0 to 2.2.1 then no prob thanx |
Thanks for ur help HERE IPHONE INFO after update/unlock: modem 04.05.04_g version 2.2.1 any solution i can try??? |
just tray to restor first and Jailbreak again maby it will help u |
try to jailbreak it.then reset network setting then restart again put your simcard then try again if still the same try to put other simcard. |
re hello can you xplain me how can i downgrade to 1.1.4 ??? and which itune version i need to do that?? i hv already dwload 1.1.4 Thanks |
just downgrade to 2.2 then make jailbreak & unlock & post result all will be ok then put sim card without pin code if no service again make reset network settings while the simcard inside & wait untill u have network & if u can test it in another network it will be good for u thanks mony_valley |
After Restore U Got Error And U Phone Will Stuck On Recovery Mode Open Ziphone 3.0 And Choose (Normal Mode) UIphone Will Be In Normal Mode Use Kiphone To Erase U Basband Then Restore It To Any Version And JailBreak&Unlock U Iphone IF The PropleM Software 100% Phone Will Repair :) B.R, Shedeed |
REGARDS |
