11-06-2009, 00:42 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: uk
Member: 508100 Status: Offline Sonork: 1600934 Thanks Meter: 189 | Solution Fix evertin(gps,youtube,wifi )after unlocking via blackran Post Jailbreak fixes
FIX my everything(gps,youtube) 1.) On your iPhone home-screen, tap on the Cydia icon. 2.) If Cydia prompts you for updates, install them all. 3.) In Cydia, tap on the “Manage” tab at the bottom of the screen. 4.) Tap on the “Sources” button. 5.) Tap on the “Edit” button in the top right corner of the screen and then tap the “Add” button in the top left corner. 6.) Type in http://cydia.iphoneil.net and then tap “Add Source“. 7.) Now tap on the “Done” button in the top right corner of the screen. 8.) Tap on the “Search” tab on the bottom of the screen and type in “pushfix“. 9.) Select “pushfix” from the list of search results and then tap “Install” in the top right corner of the screen and then tap “Confirm WIFI fiX 1.) On your iPhone home-screen, tap on the “Settings” icon. 2.) In the Settings menu, tap on “General“. Scroll to the bottom of the General menu. 3.) In the General menu, tap on “Reset“. Then tap “Reset Network Settings“. 4.) Reboot your iPhone/iPod Touch by holding down the sleep/wake button and sliding to turn off works like a charm thanks geohot for inventing blackran |
The Following 5 Users Say Thank You to 00aa For This Useful Post: |
11-07-2009, 00:47 | #6 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2003 Location: gsmcity Age: 44
Member: 21296 Status: Offline Thanks Meter: 328 | Wi-Fi fix is not working at all, still no working solution for that problem, hoping that somebody can find the solution for this problem!!! |
about no wifi after unlock 3.1.2 , please read here. | kaholukkk | iPhone 2 / iPhone 3G / iPhone 3GS | 3 | 11-27-2009 02:05 |
solution:Jaibreak and wifi problem after unlocking 3gs blackran | 00aa | iPhone 2 / iPhone 3G / iPhone 3GS | 12 | 11-09-2009 03:37 |
If you get no Wifi after unlocking 3.1.2.... | Burnt Cobba | iPhone 2 / iPhone 3G / iPhone 3GS | 4 | 11-04-2009 23:32 |
Fix Losing sig fault after Unlock 7600 | wearephones | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 02-25-2004 05:02 |
Samsung V200 problems after unlock via codes | G0dX | Trident/AGERE Platform | 2 | 07-18-2003 11:10 |
