01-01-2010, 13:57 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: punjab Age: 42
Member: 478791 Status: Offline Thanks Meter: 52 | hi all i need little help |
01-04-2010, 10:29 | #3 (permalink) |
Member: 478791 Status: Offline Thanks Meter: 52 | Resolution Check to see if the issue still occurs after doing each step: Deauthorize and reauthorize your computer Before attempting these steps, transfer all iTunes Store and App Store content on the device to your computer. Then, use the following steps to deauthorize and reauthorize your computer: Connect your device to a computer and open iTunes. In iTunes, select your device in the left-hand column and then click the Applications tab. Verify that Sync Applications is checked. Choose Store > Deauthorize Computer from the menu bar. Enter your iTunes Store account and password, and then click Deauthorize. Click Sync in the lower-right to sync your device. When prompted, select Don't Authorize. This will remove all applications and other iTunes Store content from the device. Note: You may see this prompt more than once. Select Don't Authorize each time. When the sync is complete, choose Store > Authorize Computer from the menu bar. Enter your iTunes Store account and password, and then click Authorize. Sync your applications and content from iTunes to the device. Find more information about iTunes authorizations. in i tunes showing solution for that but it needs account how can i do that .....plz help wbr varun |
Hi all iam need help for n73!!! | romka21 | Nokia Base Band 5 ( BB-5 ) | 1 | 11-13-2008 02:51 |
hi all i need nvm file for u 830 plz help urgent | unlock_solution | VygisToolbox | 7 | 09-05-2008 22:51 |
Hi all , I need your help | Bad King | Nokia Multimedia | 0 | 03-13-2007 18:28 |
hi all i need new flash T630 and Z600 and all new | jalal1 | Cruiser Suite | 2 | 09-17-2004 19:59 |
Hi All I Need Some Help To ... | iyass | Nokia Hardware & Hardware Repair | 6 | 03-03-2003 02:58 |
