09-25-2010, 07:30 | #1 (permalink) |
No Life Poster Join Date: Aug 2006
Member: 337450 Status: Offline Thanks Meter: 718 | iPhone 3G Error 3194 When Restoring! (Solution) So I'll restore this phone to repeat the process of jailbreak and unlock, but Sadly enough, for you guys who wanted to erase or restore your iPhone 3G into iOS 4 using iTunes 9.2 will be out of luck, since Apple is no longer signing the version 4.0 anymore. Instead if you insist on restoring your iPhone 3G into iOS 4.0 instead of 4.1, you’ll have error 3194 on iTunes. [img]http://1.bp.********.com/_jzFOOHRsqBM/TJ2QotEE5VI/AAAAAAAAAxk/hd6_5peYQrQ/s400/error+3194+1.png[/img] This is unfortunate, you can not upgrade your iPhone 3G officially, but. You can still restore it unofficially. Basically when iTunes showing “Verifying with Apple bla…”, that means iTunes is checking for signature from Apple’s signature server. And guess what, Apple no longer sign your iOS 4.0 firmware which makes your device is not eligible for restore, unless you update with iOS 4.0.1, this is one way for apple to force its customer to upgrade into the latest firmware, so all hacks will be eliminated if one is provided in Apple’s latest firmware version. Now, we can bypass this signature checking when iTunes contacting Apple by changing the server from Apple’s Signature Server into Cydia’s clone of Apple Server. Now here's the STEPS to be you to restore the same OS in your iPhone 3G! It’s easy (for Windows): 1. Fired up your cmd.exe, and make sure you have administrator privileges. 2. Type this is: CD \WINDOWS\SYSTEM32\DRIVERS\ETC 3. Type this: edit hosts 4. Add this to the last line: 74.208.10.249 gs.apple.com 5. Restart your iTunes. 6. Put your iPhone 3G in recovery mode, by turn off the device first and pull the plug from your PC. Then press Home Button and connect your iPhone into your PC, then wait until the Recovery Icon shows up (iTunes icon with cable above it). 7. Now, restore your iPhone with your firmware iOS 4.0 (in windows using Shift + Restore, in mac using Options + Restore) 8. Voila, it will be restored succesfully, it’s fully working on my iPhone 3G. You should notice the number 4 step is the bypass server, by pointing Apple Authentication domain into Cydia’s Server IP Address, this is trivial in unix, and thankfully, we can do this in Windows. On Mac, it’s the same, except for the cmd.exe and the cd thing should be into /etc/hosts… Enjoy your Jailbreak Restore… Here are some screen cap while editing and restoring: [img]http://1.bp.********.com/_jzFOOHRsqBM/TJ2SEinAbBI/AAAAAAAAAxo/V4wUmPhR4g4/s400/error+2.png[/img] [img]http://1.bp.********.com/_jzFOOHRsqBM/TJ2TBCEjxxI/AAAAAAAAAxw/QQ2H5OFms6A/s320/error5.png[/img] [img]http://1.bp.********.com/_jzFOOHRsqBM/TJ2Tv1moPnI/AAAAAAAAAx0/e0VXq0H35gQ/s320/error6.png[/img] After those process, I use redsn0w_win_0.9.5b5-3, then the NO WIFI unlock for iOS 4.0 that can be search all over the net! |
The Following 17 Users Say Thank You to yobb For This Useful Post: |
09-25-2010, 11:26 | #4 (permalink) | |
No Life Poster Join Date: May 2009 Location: PUNJAB
Member: 1024766 Status: Offline Sonork: GSM MASTERS Thanks Meter: 226 | Quote:
ya its work but who save shsh blobs on saurik server... | |
10-06-2010, 10:04 | #8 (permalink) |
Banned Join Date: Dec 2007
Member: 644210 Status: Offline Thanks Meter: 74 | iphone 3g is always be supported by that solution... but what we need is the solution for 3gs and iphone 4... can't downgrade even with modified host and tinyumbrella.. nay new solution?> |
10-07-2010, 03:26 | #9 (permalink) | |
Freak Poster Join Date: Jan 2005 Location: Tunisia Age: 43
Member: 108951 Status: Offline Thanks Meter: 26 | Quote:
i was can't restore Iphone 3gs to any firmware...n thank u yobb u help me its work now | |
The Following User Says Thank You to omarfilali For This Useful Post: |
10-09-2010, 10:28 | #12 (permalink) |
No Life Poster Join Date: Mar 2010
Member: 1263932 Status: Offline Thanks Meter: 181 | Contains many wrong and correct information. You can downgrade 3G phones always, no need for shsh, but just not through iTunes; you need to use redsn0w. iTunes since 9.2 checks for correct shsh (not the 3G), so you can circumvent this check by not using iTunes. Remember that this does NOT work for 3GS; 3GS phones will check shsh to install firmware, so you need shsh backup on Cydia to downgrade. For both you cannot downgrade baseband to unlock; we're talking about jailbreak only. Error 3002 means you pressed Update instead of Restore button. |
10-12-2010, 03:55 | #15 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: TOKYO JAPAN Age: 43
Member: 747968 Status: Offline Sonork: 100.1621353 Thanks Meter: 444 | Quote:
The Following User Says Thank You to VODAFONES For This Useful Post: |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
My 5110 v5.11 have a strange error.., it resets it self every 60second | luuk | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 24 | 08-11-2006 15:29 |
HEX for CLIP to restore Factory Defaults | X-Shadow | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-28-2000 15:59 |
The multiple errors of Winlock ... ??? | Genata | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-20-1999 19:12 |
error (1002) simlock3.dll winopen | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-28-1999 15:57 |
