12-21-2009, 23:47 | #1 (permalink) |
Junior Member Join Date: Dec 2009
Member: 1189137 Status: Offline Thanks Meter: 0 | iPhone 3G...Not Turning On I recently purchased an iPhone 3G with the knowledge it would not turn on. It appeared that the LCD was damaged, so I assumed an easy fix. However, when I opened the phone I noticed that the sticker on the mainboard was tampered. I took out the motherboard, checked the connections and reattached everything....still not turning on. I think I need a new battery, but I am not sure. Is there anything else that is not a critical, that could be causing this problem? Thanks for any help |
12-22-2009, 00:40 | #4 (permalink) |
Junior Member Join Date: Dec 2005
Member: 206656 Status: Offline Thanks Meter: 1 | The phone was on while you opened it? When I did that I had to replace the battery... You could try to charge it with an external powersupply. Had some problems with another iphone and that worked for me. That phone also didn't charge or turn on |
12-22-2009, 00:44 | #5 (permalink) | |
Member: 1189137 Status: Offline Thanks Meter: 0 | Quote:
when i opened it, power may have been flowing from the battery, and who knows what the original owner did. i realize a battery replacement is necessary, but I want to be sure it's nothing major | |
12-22-2009, 09:13 | #6 (permalink) |
Freak Poster Join Date: Aug 2008
Member: 848265 Status: Offline Sonork: 123 Thanks Meter: 17 | yes, if i know maybe with software. not with hardware! if with software, solution: -your pc must connect with internet -connect your iphone with pc using USB -open itune (latest version) when itune appear, it show dialog: your iphone can't connect to iphone store and then you click ok than click restore button for restore a new firmware. thanks. www.sevensday.com |
12-22-2009, 09:50 | #7 (permalink) |
No Life Poster Join Date: Jun 2003 Location: kinshasa, D.R.C. Age: 59
Member: 31246 Status: Offline Thanks Meter: 54 | if your battery is charged, press the center button with the power button at the same time, and wait for 15 secondes. if it's a soft trouble, your phone will swith on, if not check ther hard part. |
12-22-2009, 12:23 | #8 (permalink) | |
Member: 206656 Status: Offline Thanks Meter: 1 | Quote:
Hold 10 sec. the home and powerbutton, then release the power button while still holding the home button. If Itunes pop ups with a restore, try to restore it. If you get a 1600 or 1601 error after serveral tries then it's probably the battery. Well in my case it was the battery. You can try to recharge the battery with another power supply then the iphone itself Maybe this topic is helpfull http://forum.gsmhosting.com/vbb/showthread.php?t=884846 | |
12-22-2009, 16:32 | #9 (permalink) |
Member: 1189137 Status: Offline Thanks Meter: 0 | I tried plugging it into itunes and put it into DFU mode...still nothing I saw it may be my computer (i have a PC) I don't have access to a mac, but I'll try another PC I pulled the trigger on a new battery and LCD |
12-25-2009, 15:36 | #11 (permalink) |
Member: 206656 Status: Offline Thanks Meter: 1 | Just connect an external power supply 3.7v to the + and - If you have the battery in front of u with the contact pointing above then the outer left is + and the outer right is - |
12-26-2009, 20:10 | #12 (permalink) |
Member: 1189137 Status: Offline Thanks Meter: 0 | is it outer left and outer right when the contact points are in front of me or when the contact points are across the battery and in the opposite configuration? also how long should i hold them there to get a decent charge? Thanks for all the help!!! |
12-28-2009, 02:36 | #13 (permalink) | |
Freak Poster Join Date: Apr 2007
Member: 496243 Status: Offline Thanks Meter: 42 | Quote:
(1), Hold down the Home button only and connect to itunes for 15-20 sec and see if itune can detect it, (2), connect to itune, Hold both power and home for 10 sec, release the power button and still hold down the home for a while, sometimes it take 25 sec or more and see if itune can detect it Regards | |
01-06-2010, 08:19 | #14 (permalink) |
Junior Member Join Date: Jan 2010
Member: 1199475 Status: Offline Thanks Meter: 0 | First, change your battery full; Then check and power button and flex, it's fragile, you might need to change one if it's damaged. Then the power ic... ------------------------------------------------------------------------------------------------- http://www.*********.com/user/product.asp?cata=369 |
03-07-2010, 15:30 | #15 (permalink) |
Junior Member Join Date: Nov 2009 Location: shenzhen, China
Member: 1159344 Status: Offline Thanks Meter: 1 | RE: iPhone 3G...Not Turning On You can try to get it repaired, once you have to change any part you can choose from http://trait-tech.com/catalog/IpodIp...s/iPhoneParts/ hope your Phones goes well. |
iPhone 3G only turns on with charger connected!! | SoSimple | iPhone 4 / iPhone 4S | 61 | 12-21-2013 00:36 |
iPhone 3G wont turn on | yolmen | iPhone 2 / iPhone 3G / iPhone 3GS | 0 | 01-30-2010 03:31 |
iPhone 3G not operator logo on 3.1.2 version | mosaubre22 | iPhone 2 / iPhone 3G / iPhone 3GS | 0 | 10-20-2009 12:26 |
iPhone 3G don't turn on | Mikki83 | iPhone 2 / iPhone 3G / iPhone 3GS | 15 | 07-13-2009 17:58 |
T610, turn off, but not turn on..... | PaPiTo | Sony Ericsson Hardware Repair | 0 | 01-20-2005 23:05 |
