Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 2 / iPhone 3G / iPhone 3GS
Old 02-19-2013, 08:06   #1 (permalink)
Member: 1885163
iPhone 3gs No WiFI, No IMEI, No BlueTooth
can anyone know about this problem?
everyday i try to fix this problem but i can't see anyone can fix this problem?
i hope here in this forum site who can fix this. thanks a lot!
Old 02-19-2013, 08:45   #2 (permalink)
unlock.mk's Avatar
Member: 1671934
Thanks Meter: 246
You can try to update to firmware 6.1 via iTunes. If that doesnt help than, there is possibility that you have bricked baseband, that happining when someone tries to update baseband to 6.15 on newer manufactured 3gs phones. And there is no solution yet for this.
Old 02-19-2013, 08:51   #3 (permalink)
Member: 1885163
i will try to update sir. but while im trying to update my iphone in itune i got error but im trying to update my 4.1 to 4.2.1 what should i do?
now i got error 11 while im updating my 4.1 to 4.2.1.
Old 02-19-2013, 09:07   #4 (permalink)
Member: 1567913
Sonork: 100.1617419
Thanks Meter: 6
not possible to restore imei you use only ipod
The Following User Says Thank You to crescentcell For This Useful Post:
Old 02-19-2013, 09:07   #5 (permalink)
melgsm's Avatar
Member: 629039
Sonork: 100.112945
Thanks Meter: 847
Is ur iphone = 8gb
if yest check with iphoneyeta if ur phone have new baseband ic
say good bye for ur iphone baseband damaged
Old 02-19-2013, 09:40   #6 (permalink)
bgreat's Avatar
Member: 727235
Thanks Meter: 1,210
brother ur imei has cruppeted
Old 02-21-2013, 17:00   #7 (permalink)
Member: 404153
my phone, bluetooth not open, same error
Old 02-23-2013, 06:57   #8 (permalink)
Member: 1849251
Sonork: 100.1623754
Thanks Meter: 2
iphone chip corrupted
Old 02-23-2013, 07:00   #9 (permalink)
Crazy Poster
Member: 1342171
Sonork: none
Thanks Meter: 11
the only way to revive your phone is to change baseband chips
your phone is newbootrom and not safe to flash baseband
The Following User Says Thank You to .:MaKLoy:. For This Useful Post:
Old 02-23-2013, 11:54   #10 (permalink)
Member: 1888042
i did it too to my iphone 3gs 8gb and no, there is no way to fix it, only to chage chips :/
Old 03-07-2013, 09:12   #11 (permalink)
Member: 1079917
Sonork: 100.1663316
Thanks Meter: 48
my iphone 3gs 16gb,water damag imei,wifi,bluetooth corrupted.plz help me
Old 03-07-2013, 10:05   #12 (permalink)
sjd012's Avatar
Member: 1835240
Sonork: 100.1624260
Thanks Meter: 26
ithink..,hardware sulotion bro....
Old 03-07-2013, 16:16   #13 (permalink)
Member: 1481043
Sonork: arslankhan124
Fix damaged iPad Baseband on iPhone 3GS iOS 5.0.1 no carrier no activation
Old 03-07-2013, 16:17   #14 (permalink)
Member: 1481043
Default How to: Fix damaged iPad Baseband on iPhone 3GS iOS 5.0.1 no carrier no activation
Hi Guys
If you have an iPhone 3GS with an iPad baseband 06.15.00 and you restored over iTunes to stock firmware iOS 5.0.1your baseband got damaged and you have no possibility to activate your iPhone or you installed ultrasn0w and you dont get any Carrier working!
This is the fix guys!!
(If anyone posted that topic before, plz pardon me).
Plz take the time to read carefully several times!!
You need an iOS 4.1 restore.ipsw, the firmware for 3GS
You need an iOS 5.0.1 restore.ipsw
You need redsn0w 0.9.5b5
You need sn0wbreeze 2.9.1 for creating a cfw
Latest iTunes Version
iReb r5 from ih8sn0w's website
It's highly recommended to shut of User-Control, (the darn thing that pops up evry time you start a system relevant program), your Firewall and any Antivirus or Internet- Security-Program off or to the lowest security level there is!!
Plz copy all downloaded files to ONE directory! i recommend "Desktop"!!
All files must be unpacked!!
There should be NO SIM-Card in the Device!!
1. Put you Device in DFU mode like shown in any tut on youtube
2. Open iTunes, if it didnt pop up by itself and hold SHIFT+ click on Restore on Win or ALT+ click on Restore on Mac for installing the firmware 4.1.
3. After Restore is done, you have to start redsn0w 0.9.5b5 as administrator (Win 7 and Vista) and compatible to Win XP SP3
4. resn0w wants you to select the firmware 4.1 you previously downloaded.
5. If you have newere bootrom, say "Yes" in next window.
6. redsn0w identifies the firmware-> Next
7. redsn0w works
8. Next step you get many options but you DESELECT everything but: "Install iPad Baseband"
9. If youre sure to do this, warnings are all over the place, do it and install it.
Ok, now your iPhone is on iOS 4.1 and you cant use 5.0.1?
No!!
Plz create a CFW iOS 5.0.1 via sn0wbreeze 5.0.1 WITHOUT iPad BB in Expert Mode and i recommend you don't set a checkmark on "Activate the iPhone" for hacktvation cause you can't get Push and other features without Activation via iTunes and a valid SIM card!
Installing iOS 5.0.1 as long as it is still signed:
1. Clean your hosts from any entry with "....gs.apple.com" if you ever worked with TinyUmbrella by copying "hosts" from "C-Windows-Sysrem32-drivers-etc" to your desktop, rename it "hoststiny" and make a backup of it by creating a folder named "hoststiny" and copy the file into that folder.
Then you rename "hoststiny" on desktop to "hosts" and open it with windows editor or notepad++ and delete any entries with "...gs.apple.com" and the remaining rows and save it without choosing .txt as appendix.
Rename it hosts
Save it and delete the "hosts" in "etc". Copy the "hosts" from desktop to "etc".
Restart your Computer!!!!
2. Now connect your iPhone, shut it off (lol) and put in DFU mode
3. Run iReb r5 as Admin (right-click)
4. Start iTunes and say Ok for Restore and hold "SHIFT" + click "Restore".
5. Install iOS 5.0.1 named "sn0wbreeze..iPhone...3GS...5.0.1....restore.i psw" LOCATED on your DESKTOP. (!!!DON'T INSTALL THE STOCK FIRMWARE iPhone 2,1....5.0.1...restore.ipsw!!!)
6. If your restore finished successfully, plz activate your iPhone via SIM and activate your Wi-Fi connection, start Cydia and accept any complete update.
7. Plz press on "Search" and install "ultrasn0w" and reboot your Device!
Put in your SIM Card and enjoy
Carrier and network on 5.0.1.
Old 03-07-2013, 16:32   #15 (permalink)
Member: 1834434
Thanks Meter: 9
change Baseband IC. it is hardwear prb 100%
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.30543 seconds with 7 queries
