Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 2 / iPhone 3G / iPhone 3GS
Old 01-19-2010, 10:55   #16 (permalink)
babalsingh's Avatar
Member: 1024766
Sonork: GSM MASTERS
Thanks Meter: 226
insataal windows again xp 2000..
Old 01-19-2010, 11:08   #17 (permalink)
sokolibrahimi's Avatar
Member: 239956
Thanks Meter: 68
Wink
not need to reformat you pc with new fesh copy but all you need is, if you have installed the lateset samsung pc suite (Samsung New PcSuite) you need to restore your pc to the point before intallation of this pcsuite because if you just remove the pc suite the problem will not be solved this is why you need to restore your pc....
Best Regardss.....
The Following 2 Users Say Thank You to sokolibrahimi For This Useful Post:
Old 01-19-2010, 16:29   #18 (permalink)
Member: 739410
Thanks Meter: 88
Best Regardss.....
means samsung new pcsuite is troubling ???
Old 01-20-2010, 05:29   #19 (permalink)
Member: 216088
Thanks Meter: 43
does anyone get the solution by removing samsung new pc suite...? pls guide...
Old 01-28-2010, 02:44   #20 (permalink)
Member: 898376
Sonork: ----
Thanks Meter: 11
i tried but did not work for me.
what is the solution what to do. any expert ??????????////
Old 01-29-2010, 21:22   #21 (permalink)
Member: 110006
Thanks Meter: 19
I think it is not the computer i have the same problem wen i put another phone it wors perfect so it is a problem with the phone
Old 02-02-2010, 11:04   #22 (permalink)
Member: 239956
Thanks Meter: 68
no man the problem is Samsung New PCSuite restore your pc to the point before installation of this pc sute.....100% Solution
Old 02-03-2010, 06:27   #23 (permalink)
totalmanish's Avatar
Member: 336192
Thanks Meter: 55
had the same problem tried on other pc 100% ok.............
Old 02-03-2010, 08:20   #24 (permalink)
irfanboss's Avatar
Member: 256247
Thanks Meter: 444
use latest version of i tunes sol ur poblem
Old 02-03-2010, 12:30   #25 (permalink)
Member: 882699
Thanks Meter: 8
try diffrent usb or diffrent computer ,, that works for me best of luck ....
Old 02-14-2010, 21:49   #26 (permalink)
Member: 738738
gk
Hi, I try restore my iphone 2g with OS 3.0 in my PCs, with many OS, with many cables, in last itunes and other, but I put device in Recovery mode and driver no install. In DFU mode driver install ok, but in step with white scream again need instal this driver and no work. Please help me, Iphone was ok, only need restore.
pls guide how to solve this problem ?
format system and re stall xp and install itunes automaticly take driver tasted by gk
Old 02-14-2010, 21:52   #27 (permalink)
Member: 738738
gk
Old 02-14-2010, 22:14   #28 (permalink)
Registered User
Member: 514340
Thanks Meter: 68
Go to Device Manager and you have a listing of all your hardware components
Plug in your iPhone. Now you will see 2 listings that say something like "Apple Recovery" Mode in YELLOW, right-click, then click "uninstall", you need to do this to both, they should disappear now.
Next, you will expand the "Universal Serial Bus Adapters" at the bottom, which will give you a long listing, and look for the USB related devices. Look for "USB Composite Device" in this listing.
This is the tricky part because everybody is going to have different hardware from different manufacturers and the listing is going to be called something different but if you can figure out which are your USB ports then you are in business!
You will see 2 "USB Composite Device" choose the first one and right-click the "USB Composite Device" and click "Update Driver" Choose " Install from a list or specific location (Advanced) and click Next on the next screen choose "Don't Search, I will choose the driver to install" and click Next and you will see 2 drivers listed and choose "Apple Mobilde Device (iboot driver) "and install. If you don't see 2 drivers listed then CANCEL and choose the second "USB Composite Device" and follow the above instructions and choose "Apple Mobilde Device (iboot driver) " to install. It should work now perfectly.
Let me know if it works for you. Thanks!
The Following 23 Users Say Thank You to lankan For This Useful Post:
Old 02-24-2010, 19:37   #29 (permalink)
green bird's Avatar
Member: 109163
Thanks Meter: 75
Thanks Its working.. Thank you
Old 03-02-2010, 16:16   #30 (permalink)
.:*CHENNAI GSM*:.'s Avatar
Member: 8587
Thanks Meter: 4
Yes atlast after some five to six hours of struggle it worked your way.
But why did this happen ??
It was working perfectly till the day before and it did not work today.
Did all I can like uninstalling, installing, Ccleaning "N" times
Tried uninstalling all other devices drivers like Nokia, SE, Samsung blah blah blah.....
It worked I am happy but if you can enlighten what went wrong and how it went wrong...
It will be great...
Apple Mobile Device Recovery Mode driver fernandesx iPhone 2 / iPhone 3G / iPhone 3GS 6 04-21-2020 13:34
iphone recovery mode Amarbir iPhone 2 / iPhone 3G / iPhone 3GS 8 08-21-2008 16:28
apple iphone recovery mode tajinder iPhone 2 / iPhone 3G / iPhone 3GS 2 04-19-2008 07:50
i phone recovery mode driver Yuvi HTC & PDA WM( With Touchscreen) 2 11-15-2007 11:52
Page generated in 0.24757 seconds with 9 queries
