Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 2 / iPhone 3G / iPhone 3GS
Old 03-05-2010, 12:38   #31 (permalink)
Member: 216088
Thanks Meter: 43
can u pls guide me when i choose "Don't Search, I will choose the driver to install"
where can i find
"Apple Mobilde Device (iboot driver)" ??
in pc i cant find it
Old 03-06-2010, 05:31   #32 (permalink)
Member: 216088
Thanks Meter: 43
can any one tell where should i locate iboot driver in pc.. as i cant find it..
Old 03-06-2010, 05:49   #33 (permalink)
VODAFONES's Avatar
Member: 747968
Sonork: 100.1621353
Thanks Meter: 444
un install your itunes
restart
run old itunes
remove and restart again
run new version of itunes
and connect your usb to other usb slot
now ur iphone didnt ask driver anymore
Old 03-06-2010, 09:07   #34 (permalink)
powerplay83's Avatar
Member: 753732
Thanks Meter: 252
did you install New_PC_Studio_1.4.0.IK1 for Samsung on your PC?
if yes you have to uninstall New_PC_Studio_1.4.0.IK1 and restore your PC to the point before first installing of New_PC_Studio_1.4.0.IK1.
New samsung PC Suite blocked iphone driver. thats all...
look here...
http://forum.gsmhosting.com/vbb/show...22#post5355222
Old 03-06-2010, 09:32   #35 (permalink)
Member: 631990
Thanks Meter: 5
no solution yet for 3.1.3.
Old 05-17-2010, 17:18   #36 (permalink)
Member: 1303912
Thanks lankan - it works
Old 06-19-2010, 10:18   #37 (permalink)
Member: 31246
Thanks Meter: 54
when it asks driver, select :
no, for this time
install from a list or on epecified emplacement
here select :
not search. i want to choose the pilot to install.
and it will give its drivers. select it and all will works.
Originally Posted by rjs398 View Post
i have same problem i format my pc twice but very next day ..apple mobile device recovery mode driver problem please any expert help me out
__________________________________________________ _____________
Proofreading
SEO Copywriting
Old 09-08-2010, 14:17   #38 (permalink)
Gabiunlock's Avatar
Member: 710759
Sonork: No
Thanks Meter: 329
Originally Posted by lankan View Post
Go to Device Manager and you have a listing of all your hardware components
Plug in your iPhone. Now you will see 2 listings that say something like "Apple Recovery" Mode in YELLOW, right-click, then click "uninstall", you need to do this to both, they should disappear now.
Next, you will expand the "Universal Serial Bus Adapters" at the bottom, which will give you a long listing, and look for the USB related devices. Look for "USB Composite Device" in this listing.
This is the tricky part because everybody is going to have different hardware from different manufacturers and the listing is going to be called something different but if you can figure out which are your USB ports then you are in business!
You will see 2 "USB Composite Device" choose the first one and right-click the "USB Composite Device" and click "Update Driver" Choose " Install from a list or specific location (Advanced) and click Next on the next screen choose "Don't Search, I will choose the driver to install" and click Next and you will see 2 drivers listed and choose "Apple Mobilde Device (iboot driver) "and install. If you don't see 2 drivers listed then CANCEL and choose the second "USB Composite Device" and follow the above instructions and choose "Apple Mobilde Device (iboot driver) " to install. It should work now perfectly.
Let me know if it works for you. Thanks!
tis solution is real and fast thank you
Old 11-30-2011, 22:57   #39 (permalink)
simplex's Avatar
Member: 59797
Thanks Meter: 76
Working 100%
I was just about to format my PC !!!
thanks man!
Old 11-25-2013, 06:10   #40 (permalink)
aiz
Member: 482685
Thanks Meter: 7
apple recvery MODE drivers...
1 go to device Manager
2 right click on apple recvery Mode driver
3 update driver on your copmputer
recvery%20usb%20drivers
Old 12-15-2013, 01:59   #41 (permalink)
Member: 455693
Thanks Meter: 48
mr lankan
tku mr.lankan
Old 04-12-2014, 08:14   #42 (permalink)
Member: 2166484
Good afternoon Sir. I also had this problem, after update my iPhone 4 and getting to recovery/sync in progress something pop-up telling "Unable to install driver......" then my iPhone stuck in a screen appearing itunes logo with a USB cord towards it. There's also a pop-up message in itunes " error 40xx?" then itunes dosen't detect my device anymore. Also when I try to uninstall that "apple recovery mode" in yellow, it doesn't disaapear. It always appears that "apple mobile device(recovery mode) not found".
badly need urgent help Sir.
Old 04-13-2014, 14:47   #43 (permalink)
Member: 2167264
Thank You Lankan :D
spent about two days trying to fix drivers this was the only method that work thanks me you have my full and upmost respect <3
Old 11-20-2016, 16:32   #44 (permalink)
Member: 1985008
Thanks Meter: 70
yes iphone recovery driver here bro...1000% done..
connect iphone itune mode then just install this driverpack and open driverpack first click install apple recovery driver...use this iam twsting
http://drivers.drp.su/Vendor/Apple/A...Allx64-drp.exe
plz thank button
Old 12-13-2016, 10:34   #45 (permalink)
Member: 1097964
Thanks Meter: 159
what if phone stuck in recovery mode?
Apple Mobile Device Recovery Mode driver fernandesx iPhone 2 / iPhone 3G / iPhone 3GS 6 04-21-2020 13:34
iphone recovery mode Amarbir iPhone 2 / iPhone 3G / iPhone 3GS 8 08-21-2008 16:28
apple iphone recovery mode tajinder iPhone 2 / iPhone 3G / iPhone 3GS 2 04-19-2008 07:50
i phone recovery mode driver Yuvi HTC & PDA WM( With Touchscreen) 2 11-15-2007 11:52
Page generated in 0.21667 seconds with 9 queries
