06-25-2009, 18:07 | #1 (permalink) |
Junior Member Join Date: Jun 2009
Member: 1060335 Status: Offline Thanks Meter: 0 | can not use ULTRASN0W to unlock iphone 3g OS 3.0 i got iphone 3g updated to 3.0 JB using redsnow and used cydia to install ultrasn0w... i got no service .. i also tried to install ultrasn0w without wifi and i got this message iphuc 0.6.1 with tab completion. >> By The iPhoneDev Team: nightwatch geohot ixtli warren nall mjc operator Unsupported iTunesMobileDevice.dll Version ee0000 15 notification: iPhone attached. CFRunLoop: Waiting for iPhone. AMDeviceStartService 'com.apple.afc2': 0 shell: Reading script. Writing 22240 bytes, 0 bytes remain Writing 680 bytes, 0 bytes remain Writing 662 bytes, 0 bytes remain Writing 223 bytes, 0 bytes remain >> Shell could not recover. Exiting. Then I Tried to restore my Iphone to 2.2.i but i got error ! Thanks in advance ^^ |
06-25-2009, 18:16 | #2 (permalink) |
Freak Poster Join Date: Mar 2006
Member: 240946 Status: Offline Thanks Meter: 10 | I did this myself today with no problems at all I did the shift and restore (hold down shift whilst pressing restore) together in itunes, shut down itunes, use redsn0w, then unltrasn0w. At first i didn't get any network but you switch off your phone then switch it on again and it should then work.... |
06-25-2009, 20:49 | #5 (permalink) |
Freak Poster Join Date: Aug 2008 Location: cpr-orlando.com
Member: 843747 Status: Offline Thanks Meter: 40 | Make sure the 3G is turned off, i had the same problem so i started all over.. Funny what you over look when you are used to just running through the steps.. |
06-25-2009, 21:14 | #7 (permalink) | |
Member: 1060335 Status: Offline Thanks Meter: 0 | Quote:
I appreciate your help, thanks | |
06-25-2009, 22:10 | #8 (permalink) |
Member: 843747 Status: Offline Thanks Meter: 40 | Follow these directions step 1)Restore phone with 3.0(when done close itunes) you will need itunes 8.2 step 2)Jailbreak with redsn0w step 3)update cydia (i use wi-fi) step 4)add ultrasn0w in cydia and install just adding the repo line dosent unlock it you will need make sure after you add the repo666.untrasn0w.com you uncheck the edit button and then install it or it will never work step 5)turn off 3g in the network settings step 6)insert your sim card and restart the phone(wait) you should have service within 20 seconds or so *************************edited******************* ** Last edited by cpr.orlando; 06-25-2009 at 22:15. |
The Following User Says Thank You to cpr.orlando For This Useful Post: |
06-26-2009, 20:21 | #9 (permalink) | |
Finally my Iphone is back to life | |
