10-14-2011, 07:49 | #16 (permalink) | |
Freak Poster Join Date: Mar 2004
Member: 60474 Status: Offline Thanks Meter: 658 | Quote:
10-14-2011, 09:44 | #17 (permalink) |
No Life Poster Join Date: Dec 2001 Location: Prussia
Member: 7844 Status: Offline Thanks Meter: 182 | Ur video shows ur on 4.3.3 and u got shsh backed up of other versions ... this can be easily done if u have SHSH dump of 4.3.3 on ifaith . so ur video proves nothing . |
10-14-2011, 10:03 | #18 (permalink) |
Member: 60474 Status: Offline Thanks Meter: 658 | yes thats true but see that images showing i am checking available shsh with my ECID number even you can check it..thanks because ifaith will save shsh to he server..thanks buddy |
10-14-2011, 10:08 | #19 (permalink) |
Major Poster Join Date: Feb 2005 Age: 46
Member: 117193 Status: Offline Thanks Meter: 5 | Like i said with this metod i did manage to restore my iphone 3gs to lower version. But i have following problem: - i can turn it on only with redsn0w JUST BOOT TETHERED, othervise its on recovery mode with black screen - when i turn it on after few minutes iphone turn itself off and goes to recovery/dfu mode again so i cant turn it on again. In that mode i cant even boot it no more with redsn0w till i open it and disconnect its mainboard from battery for few seconds. I f i dont do that when i go to Just boot tethered i have only white screen after its turned on. |
10-14-2011, 10:14 | #20 (permalink) |
Member: 7844 Status: Offline Thanks Meter: 182 | ok i didnt know ifaith would save shsh to tinyumbrella ,,, ok so ur solution doesnt work great caz after few mins fone would go off ... so i assume in those minutes u have u can dump shsh and build a custom firmware and restore it without having any problems ? |
10-14-2011, 10:57 | #21 (permalink) |
Member: 117193 Status: Offline Thanks Meter: 5 | i tried, but somehow my iphone is not detected in tinyumbrella altough itunes sees it normally. with ifaith there is some error on thirs stage of saving shsh (i dont remember what that third option was). i have Cydia on it now, do yout think that i can via Cydia now save shsh and try to restore it again with custom firmware? |
10-14-2011, 11:58 | #24 (permalink) |
Member: 117193 Status: Offline Thanks Meter: 5 | i belive i now have my iphone 3gs problem SOLVED and here is how i manually saved my shsh in tinyumbrella. On iFaith i saw some errors on black screen and among that also saw ECID numbers, so i wrote it down and enter it in TinyUmbrella. Beside that i belive there are other options to find ECID number After that i put y iphone in DFU mode with redsn0w, started TSS server on tinyumbrella and restore it again to 4.1 version for which i had shsh saved. I restored ti succesfully and my iphone right after that turned on. I tried restarting it and goes ok. P:S: Yes, ia had y baseband changed before to 6.15 |
10-04-2012, 05:07 | #25 (permalink) |
Junior Member Join Date: Oct 2012
Member: 1820017 Status: Offline Thanks Meter: 0 | Thanks Dude Bro this worked I'm on 3.1.3 i only had blobs for 4.1 and 5.1.1 you saved me i have saved blobs for all firmwares available for my device now i can downgrade my iPhone 3gs anytime THANK YOUUUUUUUU :c ool: |
10-04-2012, 05:18 | #26 (permalink) |
Guest
Posts: n/a
Member: | 3gs no need Tinyumbrella and redsnow just use ireb pot ur phone in duf mod and restore with iPhone2,1_4.1_8B117_Custom_Restore it 100% done host file 10000000000000000% working pyright (c) 1993-1999 Microsoft Corp. # # This is a sample HOSTS file used by Microsoft TCP/IP for Windows. # # This file contains the mappings of IP ad******* to host names. Each # entry should be kept on an individual line. The IP address should # be placed in the first column followed by the corresponding host name. # The IP address and the host name should be separated by at least one # space. # # Additionally, comments (such as these) may be inserted on individual # lines or following the machine name denoted by a '#' symbol. # # For example: # # 102.54.94.97 rhino.acme.com # source server # 38.25.63.10 x.acme.com # x client host 127.0.0.1 localhost |
10-04-2012, 05:41 | #27 (permalink) | |
No Life Poster Join Date: Jul 2007
Member: 547368 Status: Offline Thanks Meter: 254 | Quote:
UNLOCKING ALL NOKIAs WITHOUT OPENING!! | J | Main Sales Section | 0 | 08-16-2000 09:53 |
Need 3210 5.31 software without opening phone, can exchange for: | igor_m | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-23-2000 13:38 |
Nokia 6110 without net. couldnīt call 911 either! | DennisT | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 05-09-2000 11:37 |
Have seen Nokia 6150's SPUnlocked + IMEI Change without and cables!! | KingOfKingston | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 03-12-2000 12:45 |
Impossible without TDF-4? | BiG | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-22-1999 22:32 |
