10-31-2013, 06:53 | #5 (permalink) | |
No Life Poster Join Date: Oct 2010 Location: India Age: 31
Member: 1713856 Status: Offline Sonork: Uninstalled Thanks Meter: 4,500 | Quote:
1)fastboot,goto useful tool and then goto hack tab and there you will see imei repair option.. 2)CWM,below hack tool there is cwm option you can try that too... | |
11-13-2013, 11:50 | #8 (permalink) |
Junior Member Join Date: Aug 2013
Member: 2003887 Status: Offline Thanks Meter: 6 | I have a htc one m7 with hboot 1.54, OpenRecovery-TWRP-2.6.3.3-m7.img and s-off status via Rumrunner, do you think I can change imei to my htc one? or you need other information to tell me if I can do it?i can do it only using ir-key? if is it possible only via ir-key can you say me step by step how can do. |
11-13-2013, 14:01 | #9 (permalink) | |
No Life Poster Join Date: Mar 2004 Location: IRAN - tehran
Member: 60103 Status: Offline Sonork: 108841 Thanks Meter: 1,328 | Quote:
08-08-2014, 12:53 | #13 (permalink) |
No Life Poster Join Date: Sep 2005 Location: London, UK
Member: 178513 Status: Offline Thanks Meter: 109 | Htc one m7 htc m7_ul imei problem Hello friends, i have HTC One M7_UL Boot Unlocked, Super CID, Root, S-OFF i have try many times to change the IMEI, if i do it from fast boot ( HBOOT) ok, i can change it and i can read the new IMEI too, after i reboot in normal mode i can see the same OLD IMEI, so the change don't come... strange, i have try from command line too. Here are phone details. What is wrong? Model: m7_ul SN: FA382W904481 Biuld Ver.: 4.4.2 Base Band: 4T.27.3218.14 FCC ID: PN0710000 Build number: 5.11.401.10 Boot loader: 1.57.0000 CID: 11111111 Build ID: 0.5 KOT49H Product name: htc_europe Product Code: htc IMEI in HBOOT: 111111111111111 IMEI in normal mode: *******53493742 Strange.... |
08-10-2014, 15:53 | #14 (permalink) | |
Junior Member Join Date: Jul 2013
Member: 1988296 Status: Offline Sonork: 100.1656132 Thanks Meter: 0 | Quote:
write in cmd "fastboot oem writeimei imeinumber " | |
08-10-2014, 16:06 | #15 (permalink) |
Member: 178513 Status: Offline Thanks Meter: 109 | Hello, thnx for the suggestion, I have specified below that I have try ... Not work. Inviato dal mio HTC One utilizzando Tapatalk |
The Following User Says Thank You to Albelektronik For This Useful Post: |
