06-25-2020, 20:14 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: huanuco-peru
Member: 1168673 Status: Offline Sonork: 100.1638333 Thanks Meter: 235 | frp motorola xt2015-2 fail UFST Boot v1.2 (c)SarasSoft 2012, Id: 54 4D 1 0 UFST Core v1.3 (c)SarasSoft 2013, Sn: 12917568 HID: 7FD50540466000CC, HWK: A1.04-PRO1 SID: 3FEAA9C1C7F60CEBE0E37983A1F2E4FC0B5111FA XID: 17354F34265DDF8F6A5C784D33C01BF02EFEDC50 Licence: True Motorola XT2015-2 (Moto G8 Play LTE DS Lima) at USB Auto Select [MTK] {Reset FRP} MTK Flash Port not Found: Vid_0e8d&Pid_2000 Vid_0e8d&Pid_0003 Motorola XT2015-2 (Moto G8 Play LTE DS Lima) at USB Auto Select [MTK] {Reset FRP} BR USB Com: Vid_0e8d&Pid_2000 (Preloader) DA Agent : MTK_AllInOne_DA.bin BR ComPort: COM33 BR Asic Id: MT0788 [0000] Alias: MT6771 BR Asic Sw: 8A00 CA00 0000 0000 BR Secured: 05 [SBC DAA] DA AgentId: SABAB1470D512FC946 DA Version: MTK_AllInOne_DA_v3.3001.2019-11-06.22:49_491164. BR_RUN_D5 Error: -1 -1 Possible not Valid DA Agent BR_BOOT Error: -15 Select Correct Auth File using [Auth] Button Boot in BROM Mode with VOL Keys Pressed Reset FRP 0 Failed: -15 DA_SHUTDOWN Error: -1 Last USB Exception: 0x0002 El sistema no puede encontrar el archivo especificado. Motorola XT2015-2 (Moto G8 Play LTE DS Lima) at USB Auto Select [MTK] {Reset FRP} BR USB Com: Vid_0e8d&Pid_2000 (Preloader) DA Agent : MTK_AllInOne_DA.bin BR ComPort: COM33 BR Asic Id: MT0788 [0000] Alias: MT6771 BR Asic Sw: 8A00 CA00 0000 0000 BR Secured: 05 [SBC DAA] DA AgentId: SABAB1470D512FC946 DA Version: MTK_AllInOne_DA_v3.3001.2019-11-06.22:49_491164. BR_RUN_D5 Error: -1 -1 Possible not Valid DA Agent BR_BOOT Error: -15 Select Correct Auth File using [Auth] Button Boot in BROM Mode with VOL Keys Pressed Reset FRP 0 Failed: -15 DA_SHUTDOWN Error: -1 Last USB Exception: 0x0002 El sistema no puede encontrar el archivo especificado. Motorola XT2015-2 (Moto G8 Play LTE DS Lima) at USB Auto Select [MTK] {Reset FRP} BR USB Com: Vid_0e8d&Pid_2000 (Preloader) DA Agent : MTK_AllInOne_DA.bin BR ComPort: COM33 BR Asic Id: MT0788 [0000] Alias: MT6771 BR Asic Sw: 8A00 CA00 0000 0000 BR Secured: 05 [SBC DAA] DA AgentId: SABAB1470D512FC946 DA Version: MTK_AllInOne_DA_v3.3001.2019-11-06.22:49_491164. BR_RUN_D5 Error: -1 -1 Possible not Valid DA Agent BR_BOOT Error: -15 Select Correct Auth File using [Auth] Button Boot in BROM Mode with VOL Keys Pressed Reset FRP 0 Failed: -15 DA_SHUTDOWN Error: -1 Last USB Exception: 0x0002 El sistema no puede encontrar el archivo especificado. |
