Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > UFST
Old 03-05-2017, 09:13   #16 (permalink)
Member: 2590772
Thanks Meter: 10
App: UFSx (HWK) Control Panel v 2.3.0.7 by SarasSoft
CPU: GenuineIntel
Platform: Windows NT 6.1 (Build 7601 Service Pack 1)
Versions: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30
C:\Program Files (x86)
C:\Program Files (x86)\Common Files
Nokia Path not Found, Set to: C:\Program Files (x86)\Nokia\Phoenix
C:\Users\Easy\Desktop
C:\Users\Easy\AppData\Roaming\Microsoft\Windows\St art Menu\Programs
Can't open internet URL. InternetOpenURL failed!
Old 03-06-2017, 16:22   #17 (permalink)
Member: 635202
Thanks Meter: 10
hi
CPU: GenuineIntel
you tell your all user if server is down,or is maintenance .
you can open sever for user need this for Job. (FOR ORIGINAL USER ) i work with this box a lontime.
Power Flasher after i have Buy HWK now UFST. thank you best regard
The Following User Says Thank You to sultantechgsm For This Useful Post:
Old 03-08-2017, 11:05   #18 (permalink)
Member: 977592
Old 03-08-2017, 14:56   #19 (permalink)
rajeshbahri's Avatar
Member: 108747
Sonork: 100.108643
Thanks Meter: 655
same problem here
Old 03-08-2017, 18:02   #20 (permalink)
Member: 2541457
sir my ufst is not workin because ufs panal is not open problem cant connect internet url so please give mi solution
Old 03-09-2017, 03:59   #21 (permalink)
Member: 1778446
Thanks Meter: 34
same problem here Can't open internet URL. InternetOpenURL failed!
Old 03-11-2017, 02:49   #22 (permalink)
Member: 2176033
Thanks Meter: 5
i have ufs turbo..panel is...
CPU: GenuineIntel
C:\Program Files
C:\Program Files\Common Files
Nokia Path not Found, Set to: C:\Program Files\Nokia\Phoenix
C:\Users\ungka\Desktop
C:\Users\ungka\AppData\Roaming\Microsoft\Windows\S tart Menu\Programs
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>404 Not Found</title>
</head><body>
<h1>Not Found</h1>
<p>The requested URL /bybis/tatata.php was not found on this server.</p>
<p>Additionally, a 404 Not Found
error was encountered while trying to use an ErrorDocument to handle the request.</p>
</body></html>
Wrong Panel Software, Install Latest !
Server Error: 2
The Following 2 Users Say Thank You to arip jumaing For This Useful Post:
Old 03-12-2017, 04:30   #23 (permalink)
Member: 2176033
Thanks Meter: 5
today server online....thanks admin..
UFST Boot v1.2 (c)SarasSoft 2012, Id: 54 4D 1 0
UFST Core v1.3 (c)SarasSoft 2013, Sn:
HID: CA2F3CAD47600079, HWK: A1.04-PRO1
SID: EB929AAA6BDA167ED2F45261025DBF6EED690B32
XID: 287E8815FBA86CEACED57D978CA28155D37FF71C
LIC: True
BoxStat : Ok
Firmware: Ok
Your IP: 125.167.184.33
Support: Account Ok
Old 03-12-2017, 05:41   #24 (permalink)
Member: 2085670
Thanks Meter: 35
CPU: GenuineIntel
Platform: Windows NT 6.1 (Build 7600 )
C:\Program Files
C:\Users\Asif\Desktop
C:\Users\Asif\AppData\Roaming\Microsoft\Windows\St art Menu\Programs
Last Server Update: 2016/03/30
Active Panel Version: 2.3.0.7
Ftd: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30
Box: 1 Location: 802 Serial: TMA11011966
UFST Core v1.3 (c)SarasSoft 2013, Sn: 11011966
HID: C6A2A10C41600075, HWK: A1.04-PRO1
SID: 3226C728366D6BDBF1F1CDFDD1BDC5B799A68869
XID: 2E8B3031153A4A1775A98D59B7D388A0CEC5B457
LIC: True
None Authorised Copy of Software Detected, Reinstall
HWK: NOT AUTHORISED, Update Box
Bad IX: 1111
Failed: 102
Your IP: 39.52.174.44
Support: Account not Exists
Something Wrong, Try to Use [Update Box]
User Id not Allowed
LIC: True
Bad IX: AB11
Failed: 102
User Id not Allowed
LIC: True
BOOT: TM UFST Boot v1.2 (c)SarasSoft 2012
Firmware: Ok
REST: Ok
UFSx: UFST, USB S/N: 11011966
NVML: Ok
BOOT: UFST Boot v1.2 (c)SarasSoft 2012
CORE: UFST Core v1.3 (c)SarasSoft 2013
SERN: 11011966
LIC5: True
BOXK: 1
LIC: True
Authentication successfull.
Upgrade client is up-to-date.
Upgrade process completed.
None of Boxes Selected or Active
Use [Check Box] in Hardware Page
LIC: True
Bad IX: AB1D
Failed: 100
Wrong Instalation, Try to Use [Install] in Software Page
User Id not Allowed
LIC: True
Bad IX: AB1D
Failed: 100
User Id not Allowed
Old 03-12-2017, 06:28   #25 (permalink)
Member: 1414572
Thanks Meter: 19
BK-MOBILE.....
User Id not Allowed
Software>Check Server>Install >>Check Box OK....
Old 03-12-2017, 07:21   #26 (permalink)
alishams123's Avatar
Member: 811264
Sonork: 100.1638656
Thanks Meter: 232
yes is good news
server is back and is online
thanx UFS team
Old 03-12-2017, 09:42   #27 (permalink)
Member: 1019757
Thanks Meter: 9
but my ufs turbo problem not solved
server faild = support error
Authentication stage error: Server reported error: No more upgrade logs. Please contact your reseller!
Old 03-12-2017, 09:44   #28 (permalink)
Member: 1591394
Thanks Meter: 553
wait 72h and try again
Old 03-12-2017, 12:14   #29 (permalink)
Member: 1414572
Thanks Meter: 19
chsaleem5..
If you try not to solve the problem after 72 hours
Probably box-HWK, the issue of the software problem, restore and try again ..
Old 03-12-2017, 17:17   #30 (permalink)
Member: 1414572
Thanks Meter: 19
Originally Posted by yurii-62 View Post
BK-MOBILE.....
Box: 1 Location: 81 Serial: 96****
UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10
UFS_USB V2.8 (c) SarasSoft 2007., Sn: 96***
HID: 4576AC*******, HWK: A1.04-PRO1
LIC: True
Your IP: 5.138.106.82
Support: Account Ok
REST: Ok
UFSx: UFS3 SarasSoft, USB S/N: 96******
NVML: Ok
BOOT: UFxBoot V2.2 (c) SarasSoft 2003.
CORE: UFS_USB V2.8 (c) SarasSoft 2007.
SERN: 96***
LIC5: True
BOXK: 0
HID: 4576A**********, HWK: A1.04-PRO1
LIC: True
Box: 1 Location: 81 Serial: 96******
UFS_USB V2.8 (c) SarasSoft 2007., Sn: 96****
HID: 4576A*********, HWK: A1.04-PRO1
LIC: True
Bad IX: AB1D
Failed: 100
Support: Account Ok
UFS_USB V2.8 (c) SarasSoft 2007., Sn: 9*****
HID: 4576*************, HWK: A1.04-PRO1
LIC: True
Bad IX: AB1D
Failed: 100
Support: Account Ok
Found Items to Install: 1
Installed: 1 Item(s) Time: 00:00.187
No Items to Install
Software Authorised
Box: 1 Location: 81 Serial: 96*********
HID: 4576***********, HWK: A1.04-PRO1
LIC: True
BoxStat : Ok
Support: Account Ok
Page generated in 0.36667 seconds with 8 queries
