Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > UFST
Old 03-12-2017, 22:26   #31 (permalink)
Member: 910453
Sonork: 454552
Originally Posted by yurii-62 View Post
Software>Check Server>Install >>Check Box OK....
Support: Account not Exists
Wrong Instalation, Try to Use [Install] in Software Page
User Id not Allowed
Old 03-13-2017, 06:59   #32 (permalink)
Member: 1019757
Thanks Meter: 9
tady trbo also done thanks them saras soft
Old 03-13-2017, 19:35   #33 (permalink)
beo_tech's Avatar
Member: 222999
Thanks Meter: 75
Support: Bad HID, Cannot Access Support
REST: Ok
UFSx: UFS3 SarasSoft, USB S/N: 77238
NVML: Ok
BOOT: UFxBoot V2.2 (c) SarasSoft 2003.
CORE: UFS_USB V2.8 (c) SarasSoft 2007.
SERN: 77238
LIC5: True
BOXK: 0
UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10
UFS_USB V2.8 (c) SarasSoft 2007., Sn: 77238
HWK Preset 2 Error: 00, -4
HID: , HWK: NOT CONNECTED 00
Fatal: Bad HWK Module
BOX: CORRUPTED or MANIPULATED
Old 03-22-2017, 06:56   #34 (permalink)
Member: 1675051
Thanks Meter: 19
Hello. Can uFs Turbo be installed on a PC on which Twister HWK is installed
Old 04-06-2017, 09:17   #35 (permalink)
Member: 2108563
Thanks Meter: 19
Box: 1 Location: 8466 Serial: TMA11487286
UFST Boot v1.2 (c)SarasSoft 2012, Id: 54 4D 1 0
UFST Core v1.3 (c)SarasSoft 2013, Sn: 11505462
BOOT: TM UFST Boot v1.2 (c)SarasSoft 2012
Firmware: Ok
Fatal SECURITY Error, Need Repair Box, Contact Distributor
NO SOLUSI
BOX IS DEAD
SELLER WILL NOT ACCEPT
AND CAN NOT HELP
Old 07-02-2017, 04:54   #36 (permalink)
Member: 2476261
Sonork: 1674003
Thanks Meter: 9
App: UFSx (HWK) Control Panel v 2.3.0.7 by SarasSoft
Ftd: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30
Box: 1 Location: 0 Serial: TMA13155331
Boot Id: 54 4D
Box Login Failed
Bad IX: ABCD
Failed: -102
HID Number Corrupted, Try to Use [Update Box]
Boot Id: 54 4D
Box Login Failed
BOOT: EMPTY MCU
Fatal BOOT1 Error, Need Repair Box, Contact Distributor
Old 12-13-2017, 20:29   #37 (permalink)
Member: 2476261
Sonork: 1674003
Thanks Meter: 9
saras, voces are dirty with the user and the reseller, it is not possible ..
I sold the box and need to install for my client, the server is off for more than a week, and you do not care about the user?
Old 01-02-2018, 18:52   #38 (permalink)
Member: 2672353
Can't open internet URL. InternetOpenURL failed!
Old 01-08-2018, 13:01   #39 (permalink)
Member: 2263412
Thanks Meter: 90
CPU: GenuineIntel
Platform: Windows NT 6.2 (Build 9200 )
Versions: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30
C:\Program Files (x86)
C:\Program Files (x86)\Common Files
Nokia Path not Found, Set to: C:\Program Files (x86)\Nokia\Phoenix
C:\Users\Pink Trimeine\Desktop
C:\Users\Pink Trimeine\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
None of Boxes Selected or Active
Use [Check Box] in Hardware Page
Old 01-17-2018, 21:40   #40 (permalink)
m4m
Member: 126208
Thanks Meter: 52
Old 01-19-2018, 18:01   #41 (permalink)
Member: 2741886
Old 01-25-2018, 16:13   #42 (permalink)
Member: 2093809
Thanks Meter: 3
BOXESSARAS service weak server always damaged always in sleep
The Following User Says Thank You to Hicham-swiri For This Useful Post:
Old 02-03-2018, 10:52   #43 (permalink)
SinanElektronik's Avatar
Member: 92779
Thanks Meter: 16
The Following User Says Thank You to SinanElektronik For This Useful Post:
Old 02-28-2018, 06:50   #44 (permalink)
Member: 2809978
Sonork: WWW.SONOROK.COM
Thanks Meter: 3
Old 02-28-2018, 08:10   #45 (permalink)
Member: 575256
Thanks Meter: 34
make control pnel 2.3.08 brooo
Page generated in 0.18646 seconds with 8 queries
