Tajammul | 09-19-2019 17:16 | Oppo A83 (CPH1827)OFP File Extract & Flash & Password & FRP Lock Removed Done BY UFST Oppo A83 (CPH1827) OFP File Extract & Flash & Password Lock Removed Done BY Android UFST ( Its Beta Test So Dont Ask EXE We Announce Official Release After TEST ) . . . Code:
Image File: CPH1827_11_A.24_190213_a82c3dab_EXP.ofp
Image Size: 5.380.575.188
Image Type: Oppo Flash Pack
Proj. Name: 180405
DAA_AUTH_FILE Saved as: auth_sv5.auth
EFUSE_CONFIG Saved as: 17031-efuse_oppo6763.xml
EFUSE_INI Saved as: Efuse.ini
Projectconfig.xml Saved as: Projectconfig.xml
all-in-one-signature.bin Saved as: all-in-one-signature.bin
boot Saved as: boot.img
cache Saved as: cache.img
lk Saved as: lk.bin
lk2 Saved as: lk.bin
logo Saved as: logo.bin
md1dsp Saved as: md1dsp.img
md1img Saved as: md1rom.img
oppo_custom_17307 Saved as: oppo_custom_17307.img
oppo_custom_17309 Saved as: oppo_custom_17309.img
oppo_custom_17310 Saved as: oppo_custom_17310.img
oppo_custom_17381 Saved as: oppo_custom_17381.img
preloader Saved as: preloader_oppo6763_17101.bin
recovery Saved as: recovery.img
scatter Saved as: MT6763_Android_scatter.txt
spmfw Saved as: spmfw.bin
sspm_1 Saved as: tinysys-sspm.bin
sspm_2 Saved as: tinysys-sspm.bin
system Saved as: system.img
system.sig Saved as: system.sig
system_internal.sig Saved as: system_internal.sig
tee1 Saved as: trustzone.bin
tee2 Saved as: trustzone.bin
userdata Saved as: userdata.img
userdata.sig Saved as: userdata.sig
userdata_internal.sig Saved as: userdata_internal.sig
Partitions Configuration Saved as: PartitionNames.cfg
Extracted and Saved: 30 Files
Path: G:\CPH1827_11_A.24_190213_a82c3dab_EXP\CPH1827_11_A.24_190213_a82c3dab_EXP\CPH1827_11_A.24_190213_a82c3dab_EXP_EX\ Extract File Flash Code:
Var OPPO-A83 (A83 LTE DS CPH1729/1827) at USB Auto Select [MTK] {Write Flash}
Scatter : MT6763_Android_scatter.txt
BR USB Com: Vid_0e8d&Pid_0003 (BROM)
DA Agent : DA_OPPO_F5_1.bin
BR ComPort: COM67
BR Asic Id: MT0690 [0000] Alias: MT6763
BR Asic Sw: 8A00 CA01 0001 0000
BR ME_ID : 4C66BFC66C304C96B471D264D53A6E8D
BR Secured: E5 [SBC DAA]
DA AgentId: SAA91A0C4C83687559
DA Version: MTK_AllInOne_DA_v3.3001.2017/09/22.09:22.
Auth File : Oppo_F6_auth_sv5.auth
Auth FiId : SABE4D915BCF9C36BF
DA ProtVer: 4
PR DlagVer: 1.0
PR BootMod: brom
EMI PreLdr: preloader_oppo6763_17101.bin
EMI TagVer: 30
EMI Config: Ok
DA Asic Id: MT0690 [8A00 CA01 0001 0000 0000]
eMMC BOOT1: 0x0000000000400000 [4.194.304] 4 MB
eMMC BOOT2: 0x0000000000400000 [4.194.304] 4 MB
eMMC RPMB : 0x0000000000400000 [4.194.304] 4 MB
eMMC USER : 0x00000003A3E00000 [15.634.268.160] 14.56 GB
eMMC CID : 150100514536334D420637A1064B750F [QE63MB]
ERAM Size : 0x0000000080000000 [2.147.483.648] 2 GB
IRAM Size : 0x0000000000040000 [262.144] 256 KB
UNICAL RID: B94B5AE79E90F752995AB831A98ACA85
DA USBconf: high-speed
PGPT Found: 43 Partition Entries
SGPT Found: 43 Partition Entries
Partitions to Flash: 1 (9.26 GB)
SET_ALL_SIGN Error: -4 all-in-one-signature.bin C0010004
Set External Signature: userdata.sig
Write userdata 1 GB, Done in: 00:33.587 (Sparsed)
Write Done in : 00:35.096
DA Shutdown Done, Disconnect Cable |
