11-28-2018, 05:48 | #1 (permalink) |
No Life Poster Join Date: Sep 2012 Location: Mahoba
Member: 1810159 Status: Offline Thanks Meter: 256 | Oppo A83 Format userdata Error BR USB Com: Vid_22d9&Pid_0006 (Oppo Preloader) DA Agent : DA_OPPO_F5_1.bin BR ComPort: COM114 BR Asic Id: MT0690 [0000] Alias: MT6763 BR Asic Sw: 8A00 CA01 0001 0000 BR Secured: 05 [SBC DAA] DA AgentId: SAA91A0C4C83687559 DA Version: MTK_AllInOne_DA_v3.3001.2017/09/22.09:22. Authentication Need BROM Boot (With Vol Keys) BR_RUN_D5 Error: -1 -2 Possible not Valid DA Agent BR_BOOT Error: -15 Select Correct Auth File using [Auth] Button Boot in BROM Mode with VOL Keys Pressed Format Flash Failed: -15 DA_SHUTDOWN Error: -1 Last USB Exception: 0x0002 The system cannot find the file specified. Var OPPO-A83 (A83 LTE DS CPH1729) at USB Auto Select [MTK] {Format Flash} BR USB Com: Vid_22d9&Pid_0006 (Oppo Preloader) DA Agent : DA_OPPO_F5_1.bin BR ComPort: COM114 BR Asic Id: MT0690 [0000] Alias: MT6763 BR Asic Sw: 8A00 CA01 0001 0000 BR Secured: 05 [SBC DAA] DA AgentId: SAA91A0C4C83687559 DA Version: MTK_AllInOne_DA_v3.3001.2017/09/22.09:22. Authentication Need BROM Boot (With Vol Keys) BR_RUN_D5 Error: -1 -2 Possible not Valid DA Agent BR_BOOT Error: -15 Select Correct Auth File using [Auth] Button Boot in BROM Mode with VOL Keys Pressed Format Flash Failed: -15 DA_SHUTDOWN Error: -1 Last USB Exception: 0x0002 The system cannot find the file specified. Var OPPO-A83 (A83 LTE DS CPH1729) at USB Auto Select [MTK] {Format Flash} BR USB Com: Vid_22d9&Pid_0006 (Oppo Preloader) DA Agent : DA_OPPO_F5_1.bin BR ComPort: COM114 BR Asic Id: MT0690 [0000] Alias: MT6763 BR Asic Sw: 8A00 CA01 0001 0000 BR Secured: 05 [SBC DAA] DA AgentId: SAA91A0C4C83687559 DA Version: MTK_AllInOne_DA_v3.3001.2017/09/22.09:22. Authentication Need BROM Boot (With Vol Keys) BR_RUN_D5 Error: -1 -2 Possible not Valid DA Agent BR_BOOT Error: -15 Select Correct Auth File using [Auth] Button Boot in BROM Mode with VOL Keys Pressed Format Flash Failed: -15 DA_SHUTDOWN Error: -1 Last USB Exception: 0x0002 The system cannot find the file specified. |
11-28-2018, 06:08 | #2 (permalink) |
Product Supporter Join Date: Nov 2002 Location: usd Age: 64
Member: 17804 Status: Offline Sonork: 100.27310 Thanks Meter: 1,075 | Here need BROM Boot: BR USB Com: Vid_0e8d&Pid_0003 (BROM) so boot with VOL Keys pressed and be sure [Preloader Boot] Option is unticked |
The Following User Says Thank You to Sha For This Useful Post: |
11-28-2018, 07:12 | #4 (permalink) | |
No Life Poster Join Date: Jul 2015 Location: India
Member: 2421242 Status: Offline Sonork: 100.1614558 Thanks Meter: 700 | Quote:
If u have good skill open handset find tp & short,try again if no luck, otherwise look 4 another solution | |
