Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > UFST
Old 08-22-2017, 16:16   #841 (permalink)
ddilshod93's Avatar
Member: 2082192
Sonork: not
Thanks Meter: 1,119
Alcatel 6045Y (Idol 3-5.5 LTE) FRP Reset done!
Alcatel 6045Y (Idol 3-5.5 LTE) at Auto Select Flash Port [SAHARA] {Reset FRP}
QDL USB Com: Vid_05c6&Pid_9008 (COM30)
SAHARA VERS: 2
SAHARA PROG: prog_emmc_firehose_8936_alc.mbn
FHPROG SZFT: 4096
FHPROG SZTT: 16384
FHPROG SPTT: 16384
FHPROG XSIZ: 4096
FHPROG VERS: 1
FHPROG PLTF: 8936
FHPROG MEMT: eMMC
FHINFO PAR0: 30535680 x 512 Sectors (14.56 GB)
FHINFO PAR1: 8192 x 512 Sectors (4 MB)
FHINFO PAR2: 8192 x 512 Sectors (4 MB)
FHPROG PART: EFI GPT
FHPROG PRTY: 1
FHREST DONE: Ok
Reset FRP Done in: 00:11.350 (2)
The Following 4 Users Say Thank You to ddilshod93 For This Useful Post:
Old 08-22-2017, 20:35   #842 (permalink)
Member: 2214802
Sonork: 100.112534
Thanks Meter: 28
inf x557
MTK MT6580 (eMMC) at USB Auto Select [MTK] {Reset FRP}
BR USB Com: Vid_0e8d&Pid_2000
DA Agent : MTK_AllInOne_DA.bin
BR ComPort: COM63
BR Asic Id: MT6580 [0000]
BR Asic Sw: 8A00 CA00 0000 0000
DA Version: MTK_AllInOne_DA_v3.3001.00.00
PR MMC CID: 70010045484143453801055C9B2BB3AF [EHACE8]
PR Version: 4.2 [0x9C] (7) MT6580
eMMC BOOT1: 0x0000000000400000 [4.194.304]
eMMC BOOT2: 0x0000000000400000 [4.194.304]
eMMC RPMB : 0x0000000000400000 [4.194.304]
eMMC USER : 0x0000000390000000 [15.300.820.992]
eMMC CID : 70010045484143453801055C9B2BB3AF [EHACE8]
ERAM Size : 0x0000000040000000 [1.073.741.824]
IRAM Size : 0x0000000000020000 [131.072]
UNICAL ID : 400E36BE87E70551642D7018789D664E
PMT (GPT) Found : 23 Partition Entries
Reset FRP Done in: 00:06.190
DA Shutdown Done, Disconnect Cable
The Following 2 Users Say Thank You to gsm4soltan3 For This Useful Post:
Old 08-23-2017, 10:02   #843 (permalink)
Member: 2185549
Thanks Meter: 535
worlds first n910t3 frp reset first falsh aboot from
File: COMBINATION_TMB_FA44_N910T3UVU3EPH4_TMB3EPH4_52366 31_REV00_user_mid_noship_MULTI_CERT.tar.md5
Partition: ABOOT, Image: aboot.mbn, Size: 0x00148F48 (1.28 MB)
Flash Write Done: 00:01.560
Restart Done
then do frp by adb
Samsung SM-N910T3 (Note4 TMB-FRP) at USB [ADB] {Reset FRP}
daemon started successfully * 221ec259 device
Goto "Backup and reset" Menu and make "Factory data reset
The Following 2 Users Say Thank You to ferouz kassim For This Useful Post:
Old 08-26-2017, 01:03   #844 (permalink)
Member: 35335
Sonork: 1593963
Thanks Meter: 21
Samsung J5 J500FN remove frp Success
Samsung SM-J500FN (J5 LTE NFC) at USB (COM53) [MODEM] {Enter Flash}
MODEMCON: OK
FLASHMOD: OK
Samsung SM-J500FN (J5 LTE NFC) at USB (COM34) [LOKE FLASH] {Write Flash}
PLATF: LOKE 00020000
PIT Read Done: 00:00
PIT Backup Saved as: SM-J500FN_Read.pit
No Partition Info for Image: j5nlte_eur_open.pit, in COMBINATION_OXA_FA51_J500FNXXU1APL1_OXA1APL1_CL883232_QB11967006_REV00_user_mid_noship_MULTI_CERT.tar.md5
Warning, Pit Image: j5nlte_eur_open.pit Skipped, Use [Re-Part.] Option with Pit Image
File: COMBINATION_OXA_FA51_J500FNXXU1APL1_OXA1APL1_CL883232_QB11967006_REV00_user_mid_noship_MULTI_CERT.tar.md5
Partition: ABOOT, Image: aboot.mbn, Size: 0x00128ECC (1.16 MB)
Partition: SBL1, Image: sbl1.mbn, Size: 0x000453FC (277 KB)
Partition: RPM, Image: rpm.mbn, Size: 0x0002DDB4 (183.43 KB)
Partition: QSEE, Image: tz.mbn, Size: 0x0007F18C (508.39 KB)
Partition: QHEE, Image: hyp.mbn, Size: 0x00016100 (88.25 KB)
Partition: APNHLOS, Image: non-hlos.bin, Size: 0x00CA8700 (12.66 MB)
Partition: sec, Image: sec.dat, Size: 0x000002AC (684 Bytes)
Partition: BOOT, Image: boot.img, Size: 0x009E7900 (9.9 MB)
Partition: RECOVERY, Image: recovery.img, Size: 0x00ACB900 (10.8 MB)
Partition: SYSTEM, Image: system.img.ext4, Size: 0x29F7A10C (671.48 MB)
Partition: PERSIST, Image: persist.img.ext4, Size: 0x0042607C (4.15 MB)
Partition: PERSDATA, Image: persdata.img.ext4, Size: 0x0042A07C (4.16 MB)
Partition: MODEM, Image: modem.bin, Size: 0x02C88700 (44.53 MB)
Partition: CACHE, Image: cache.img.ext4, Size: 0x0059C0D0 (5.61 MB)
Flash Write Done: 01:41.859
Restart Done
Samsung SM-J500FN (J5 LTE NFC) at USB [ADB] {Reset FRP}
daemon started successfully * c9e9d088 device
Goto "Backup and reset" Menu and make "Factory data reset"
None of Diags Ports Selected
MODEMCON: OK
FLASHMOD: OK
No Partition Info for Image: j5nlte_eur_open.pit, in CSC_DBT_J500FNDBT1BPL1_CL9979482_QB11756974_REV00_user_low_ship_MULTI_CERT.tar.md5
File: AP_J500FNXXU1BQA3_CL8935060_QB12323320_REV00_user_low_ship_MULTI_CERT.tar.md5
Partition: BOOT, Image: boot.img, Size: 0x00AFA110 (10.98 MB)
Partition: RECOVERY, Image: recovery.img, Size: 0x00C4E110 (12.3 MB)
Partition: SYSTEM, Image: system.img.ext4, Size: 0x76E03B0C (1.86 GB)
Partition: USERDATA, Image: userdata.img.ext4, Size: 0x480C3CA0 (1.13 GB)
File: BL_J500FNXXU1BQA3_CL8935060_QB12323320_REV00_user_low_ship_MULTI_CERT.tar.md5
Partition: ABOOT, Image: aboot.mbn, Size: 0x00142820 (1.26 MB)
Partition: SBL1, Image: sbl1.mbn, Size: 0x00045AF4 (278.74 KB)
Partition: RPM, Image: rpm.mbn, Size: 0x0002E044 (184.07 KB)
Partition: QSEE, Image: tz.mbn, Size: 0x0007C23C (496.56 KB)
Partition: APNHLOS, Image: non-hlos.bin, Size: 0x00B84700 (11.52 MB)
File: CP_J500FNXXU1BPL5_CL8935060_QB11891045_REV00_user_low_ship_MULTI_CERT.tar.md5
Partition: MODEM, Image: modem.bin, Size: 0x02CA4700 (44.64 MB)
File: CSC_DBT_J500FNDBT1BPL1_CL9979482_QB11756974_REV00_user_low_ship_MULTI_CERT.tar.md5
Partition: CACHE, Image: cache.img.ext4, Size: 0x00D040DC (13.02 MB)
Partition: HIDDEN, Image: hidden.img.ext4, Size: 0x014850DC (20.52 MB)
Flash Write Done: 06:48.685
Restart Done
The Following 2 Users Say Thank You to dferry_ie For This Useful Post:
Old 08-26-2017, 20:54   #845 (permalink)
Hacker84's Avatar
Member: 789804
Sonork: 100.1591611
Thanks Meter: 147
LG X CAM K580H FULL RESET FRP BY UFST
LG K580H (X Cam) at Auto Select Flash Port [LG FLASH 69] {Reset FRP}
DL MODE : 2
DL REQM : 5
DL MODEL: LG-K580H
DL SWVER: K58010a
DL IMEI : 357884-07-000000-0
LF MODEL: LG-K580H
LF SERNO: LGK5806975Z99S
LF SWVER: LGK580HAT-00-V10a-732-101-FEB-09-2017+3
LF MINOS: MiniOS 3.0
LF OSVER: 6.0
LF IMEI : 357884-07-000000-0
LF DVPID: SM05S170118002708
LF SOCTY: mt6753
LF CABLE: 910K
Reset FRP Done in 00:09.889
LEAVE
LAF Command Interface Closed
Br.
Unlocker84
The Following 2 Users Say Thank You to Hacker84 For This Useful Post:
Old 08-28-2017, 14:21   #846 (permalink)
Member: 2532428
Thanks Meter: 40
MICROMAX Q4202 FRP RESET DONE !
MicroMax Q4202 (Video 3 LTE DS) at Auto Select Flash Port [SAHARA] {Reset FRP}
QDL USB Com: Vid_05c6&Pid_9008 (COM81)
SAHARA VERS: 2
SAHARA PROG: prog_emmc_firehose_8909_ddr_mmx.mbn
FHPROG SZFT: 4096
FHPROG SZTT: 131072
FHPROG SPTT: 1048576
FHPROG XSIZ: 4096
FHPROG VERS: 1
FHPROG PLTF: 8909
FHPROG MEMT: eMMC
FHINFO PAR0: 15269888 x 512 Sectors (7,28 GB)
FHPROG PRTY: 0
FHREST DONE: Ok
Reset FRP Done in: 00:05.999 (1)
Br.
UFST Best
The Following 3 Users Say Thank You to BootYa For This Useful Post:
Old 08-28-2017, 15:39   #847 (permalink)
Member: 2185549
Thanks Meter: 535
Alcatel 5023F (Pixi 4 Plus Power 3G DS) at USB Auto Select [MTK] {Reset FRP}
DA Agent : DA_SWSEC.bin
BR ComPort: COM3
DA Version: MTK_AllInOne_DA_v3.3001.2017-06-20.16:16
PR MMC CID: FE014E50314A39354B124AABC778538F [P1J95K]
eMMC BOOT1: 0x0000000000200000 [2.097.152]
eMMC BOOT2: 0x0000000000200000 [2.097.152]
eMMC RPMB : 0x0000000000200000 [2.097.152]
eMMC USER : 0x00000001D3000000 [7.834.959.872]
eMMC CID : FE014E50314A39354B124AABC778538F [P1J95K]
UNICAL ID : 8F5EFE4485D9A3301E9915D83C5A25E1
PMT (GPT) Found : 24 Partition Entries
Reset FRP Done in: 00:05.741
The Following 3 Users Say Thank You to ferouz kassim For This Useful Post:
Old 08-28-2017, 17:58   #848 (permalink)
Member: 2185549
Thanks Meter: 535
Lenovo K53a48 (K6 Note LTE DS) at USB (COM42) [DIAGS] {Gen.Settings}
OFFLMODE: OK
MDMVERSN: Nov 15 201609:30:52Aug 24 201602:00:008937.gen
MDMBUILD: MPSS.JO.1.2.c2-00099-8937_GENNS_PACK-1
NV IMEI1: 864001-03-411465-5
NV IMEI2: 864001-03-411466-3
NV BTID : 7C46:85:3C1665
NV WIFI : 6516:40:85467C
NV SERNR: Empty
Gen.Settings Write Done: 2 Item(s)
Lenovo K53a48 (K6 Note LTE DS) at USB (COM42) [DIAGS] {Factory Info}
OFFLMODE: OK
NV IMEI1: 359881-12-364598-8
NV IMEI2: 359881-12-364596-2
NV SERNR: Empty
Old 08-30-2017, 18:44   #849 (permalink)
Member: 2185549
Thanks Meter: 535
Sony D5103 (Xperia T3 LTE Seagull) at USB Auto Select [S1] {Write Flash}
Files to Flash: 14
USB DEV : SEMC [USB\VID_0FCE&PID_ADDE\5&868e399&0&4]
BL VERS : S1_Boot_MSM8x26_LA1.0_1021
BL PKTSZ: 0x00010000
BL IMEI : 354805-06-315450-8
BL ROOTS: ROOTABLE
TA MODEL: D5103
TA DEVSN: YT910W5A1B
TA CDVER: 1285-3447_R7B
TA SWVER: 1280-7649_18.1.A.2.25
TA FLVER: GLOBAL-LTE_18.1.A.2.25
Loader Boot Done in 00:00.380
FL VERS : LOADER_RELEASE_MSM8X26_31_AID_4
FL PKTSZ: 0x00080000
FL IMEI : 354805-06-315450-8
TA MODEL: D5103
TA S1VER: 1274-7024 S1_Boot_MSM8x26_LA1.0_1021
TA FTIME: 2017-08-30 19:37:05
AT PLFRT: B77943D5B24F7012CB12EB2FF857C69EAA6518C0E58957AA70 C0B0590E1F3BCA
AT OTLCK: LOCKED
AT OTDAT: 01000400
AT IDCOD: 109180E1
S1 CNFIG: PRECOMMERCIAL_009180E1(6)
Writing File: amss_fs_1.sin
File Write Done in 00:00.300 + 00:00.270
Writing File: amss_fs_2.sin
File Write Done in 00:00.280 + 00:00.240
Writing File: amss_fsg.sin
File Write Done in 00:00.310 + 00:00.260
Writing File: cache.sin
File Write Done in 00:00.860 + 00:00.770
Writing File: elabel-D5103-row_201408081000.1_18.1.A.2.25.sin
File Write Done in 00:02.100 + 00:01.990
Writing File: fotakernel.sin
File Write Done in 00:01.650 + 00:01.641
Writing File: kernel.sin
File Write Done in 00:01.600 + 00:01.600
Writing File: modem.sin
File Write Done in 00:06.660 + 00:06.651
Writing File: partition-image.sin
File Write Done in 00:00.030 + 00:00.010
Writing File: system.sin
File Write Done in 02:35.503 + 02:37.618
Writing File: userdata.sin
File Write Done in 00:20.378 + 00:20.579
Writing File: cust-reset.ta
File Write Done in 00:00.080
Writing File: fota-reset.ta
File Write Done in 00:00.070
Shut Down Ok
All Done in 06:40.642
Old 09-03-2017, 12:19   #850 (permalink)
ddilshod93's Avatar
Member: 2082192
Sonork: not
Thanks Meter: 1,119
Alcatel 5015D (Pop 3-5 3G DS) FRP Reset done!
Alcatel 5015D (Pop 3-5 3G DS) at USB Auto Select [MTK] {Reset FRP}
BR ComPort: COM97
PR MMC CID: 150100513732534D4200B601D37D2391 [Q72SMB]
eMMC RPMB : 0x0000000000080000 [524.288]
eMMC USER : 0x00000001D2000000 [7.818.182.656]
eMMC CID  : 150100513732534D4200B601D37D2391 [Q72SMB]
UNICAL ID : D8A9D4264CD3C06E95653F7318049511
PMT (GPT) Found : 26 Partition Entries
Reset FRP Done in: 00:08.433
The Following 2 Users Say Thank You to ddilshod93 For This Useful Post:
Old 09-04-2017, 10:02   #851 (permalink)
Member: 35335
Sonork: 1593963
Thanks Meter: 21
Samsung J500FN Reset FRP in Flash Mode
Flashed aboot and boot. ADB FRP did not work so tried in flash mode worked perfect here is log
Thanks team
Samsung SM-J500FN (J5 LTE NFC) at USB (COM12) [LOKE FLASH] {Write Flash}
No Partition Info for Image: j5nlte_eur_open.pit, in COMBINATION_OXA_FA51_J500FNXXU1AOF8_OXA1AOF8_CL674999_QB5418872_REV00_user_mid_noship_MULTI_CERT.tar.md5
File: COMBINATION_OXA_FA51_J500FNXXU1AOF8_OXA1AOF8_CL674999_QB5418872_REV00_user_mid_noship_MULTI_CERT.tar.md5
Partition: ABOOT, Image: aboot.mbn, Size: 0x001289AC (1.16 MB)
Partition: BOOT, Image: boot.img, Size: 0x009E6100 (9.9 MB)
Flash Write Done: 00:02.170
Restart Done
List of devices attached * daemon not running. starting it now on port 5037 * ADB server didn't ACK * failed to start daemon * error: cannot connect to daemon: No error error: cannot connect to daemon: No error
* daemon not running. starting it now on port 5037 *  * daemon started successfully *  error: unknown host service  error: unknown host service
Can not Connect ADB, Enable USB Debugging:
Settings > Applications > Development
daemon started successfully * ** daemon still not running error: cannot connect to daemon: No error error: cannot connect to daemon: No error
* daemon not running. starting it now on port 5037 *  * daemon started successfully *  ** daemon still not running  error: cannot connect to daemon: No error  error: cannot connect to daemon: No error
Samsung SM-J500FN (J5 LTE NFC) at USB (COM15) [LOKE FLASH] {Reset FRP}
Cannot Enter ODIN Mode: 0
Samsung SM-J500FN (J5 LTE NFC) at USB (COM15) [MODEM] {Enter Flash}
MODEMCON: OK
FLASHMOD: OK
Samsung SM-J500FN (J5 LTE NFC) at USB (COM12) [LOKE FLASH] {Reset FRP}
Reset FRP Done in: 00:01.022
Restart Done
Flash Write Done: 06:06.086
Restart Done
Old 09-06-2017, 13:19   #852 (permalink)
Member: 2185549
Thanks Meter: 535
INFINIX SECUREBOOT FRP DONE
Var INFINIX-X521-J5088-A1 (Hot S LTE DS) at USB Auto Select [MTK] {Reset FRP}
BR ComPort: COM163
BR Asic Id: MT0337 [0000] >> MT6735
PR MMC CID: 45000170454341484E1D01418929A778 [pECAHN]
PR Version: 4.2 [0x9B] (5) MT6737T
eMMC CID : 700100454841434541011D4E78A78389 [EHACEA]
ERAM Size : 0x0000000080000000 [2.147.483.648]
UNICAL ID : 18DF1A22A5E2745978B19E0919845AFB
DA USB Com: Vid_0e8d&Pid_2001
PMT (GPT) Found : 25 Partition Entries
Reset FRP Done in: 00:08.734
Old 09-07-2017, 09:33   #853 (permalink)
Member: 2185549
Thanks Meter: 535
Alcatel 9007X (Pixi 3-7 LTE) at Auto Select Flash Port [SAHARA] {Reset FRP}
QDL USB Com: Vid_05c6&Pid_9008 (COM85)
SAHARA VERS: 2
SAHARA PROG: prog_emmc_firehose_8909_alc7.mbn
FHPROG SZFT: 4096
FHPROG SZTT: 16384
FHPROG SPTT: 16384
FHPROG XSIZ: 4096
FHPROG VERS: 1
FHPROG PLTF: 8909
FHPROG MEMT: eMMC
FHINFO PAR0: 15269888 x 512 Sectors (7.28 GB)
FHPROG PRTY: 1
FHREST DONE: Ok
Reset FRP Done in: 00:10.095 (2)
Old 09-08-2017, 10:54   #854 (permalink)
Member: 2185549
Thanks Meter: 535
G LS770 (G Stylo Sprint) at Auto Select Flash Port [LG FLASH 5] {Reset FRP}
DL MODE : 2
DL REQM : 5
DL MODEL: LGLS770
DL SWVER: LS770ZV5
DL IMEI : 350305-26-000000-4
LF MODEL: LGLS770
LF SERNO: LGLS77010900532
LF SWVER: LS770ZV5_16
LF OSVER: 5.1.1
LF IMEI : 357188-06-716074-9
LF DVPID: HD51S151020001427
LF SOCTY: msm8916
LF CABLE: SUSER
Reset FRP Done in 00:07.125
Old 09-09-2017, 12:06   #855 (permalink)
Member: 2185549
Thanks Meter: 535
LOCK REMOVE DONE FAILED WITH LATEST FLASHTOOL
Sony ST26i (Xperia J 3G JLo) at USB Auto Select [S1] {Write Flash}
Files to Flash: 1
USB DEV : SOMC [USB\VID_0FCE&PID_ADDE\5&868e399&0&4]
BL VERS : R10D030
BL IMEI : 354386-05-505945-0
BL ROOTS: ROOTABLE
TA MODEL: ST26i
TA DEVSN: YT9004QXV6
TA CDVER: 1271-1970_R3D
TA SWVER: 1263-8752_11.0.A.7.5
TA FLVER: WORLD-i_11.0.A.7.5
Loader Boot Done in 00:00.206
FL VERS : R5D030
FL PKTSZ: 0x00010000
FL IMEI : 354386-05-505945-0
TA MODEL: ST26i
TA S1VER: 1264-2299 R10D030
AT PLFRT:
AT OTLCK: LOCKED
AT OTDAT: 010C0000
AT IDCOD: 22060100
File Write Done in 00:02.567 + 00:01.206
Shut Down Ok
All Done in 00:15.887
Page generated in 0.28133 seconds with 10 queries
