10-12-2017, 09:58 | #887 (permalink) |
Freak Poster Join Date: Apr 2013
Member: 1913632 Status: Offline Thanks Meter: 233 | mi 2014712 HM NOTE 1LTE flash in fastbootmode done https://i.imgur.com/qyTuzNr.png |
The Following User Says Thank You to pravakar333 For This Useful Post: |
10-13-2017, 08:38 | #889 (permalink) |
Member: 1913632 Status: Offline Thanks Meter: 233 | MicroMax A106 (Unite 2 3G DS) flashing and gereral setting done MicroMax A106 (Unite 2 3G DS) at USB Auto Select [MTK] {Write Flash} Scatter : MT6582_Android_scatter.txt BR USB Com: Vid_0e8d&Pid_2000 DA Agent : MTK_AllInOne_DA.bin BR ComPort: COM3 BR Asic Id: MT6582 [0000] BR Asic Sw: 8A00 CB00 0001 0000 DA Version: MTK_AllInOne_DA_v3.3001.00.00 PR MMC CID: 90014A4838473264040503A218CDA1E9 [H8G2d] PR Version: 4.2 [0x87] (5) MT6582 eMMC BOOT1: 0x0000000000400000 [4.194.304] eMMC BOOT2: 0x0000000000400000 [4.194.304] eMMC RPMB : 0x0000000000400000 [4.194.304] eMMC USER : 0x00000001D2000000 [7.818.182.656] eMMC CID : 90014A4838473264040503A218CDA1E9 [H8G2d] ERAM Size : 0x0000000040000000 [1.073.741.824] IRAM Size : 0x0000000000020000 [131.072] UNICAL ID : A71790A66C996E878DEE8E78BDE45C67 PMT (EBR) Found : 19 Partition Entries Partitions to Flash: 10 (3.02 GB) Write PRELOADER 12 MB, Skipped Write MBR 512 Bytes, Done in: 00:00.421 Write EBR1 512 Bytes, Done in: 00:00.265 Write PRO_INFO 3 MB, Skipped Write NVRAM 5 MB, Skipped Write PROTECT_F 10 MB, Skipped Write PROTECT_S 10 MB, Skipped Write SECCFG 128 KB, Skipped Write UBOOT 271.8 KB, Done in: 00:00.249 Write BOOTIMG 4.21 MB, Done in: 00:00.874 Write RECOVERY 4.86 MB, Done in: 00:00.704 Write SEC_RO 132 KB, Done in: 00:00.249 Write MISC 512 KB, Skipped Write LOGO 448.2 KB, Done in: 00:00.265 Write EXPDB 10 MB, Skipped Write ANDROID 1.54 GB, Done in: 04:48.734 Write CACHE 6.02 MB, Done in: 00:01.497 Write USRDATA 16.59 MB, Done in: 00:04.727 Write BMTPOOL 21 MB, Skipped Write Done in : 04:58.127 DA Shutdown Done, Disconnect Cable MicroMax A106 (Unite 2 3G DS) at META {Gen.Settings} Insert Cable to Switched OFF Device BR USB Com: Vid_0e8d&Pid_2000 ME USB Com: Vid_0e8d&Pid_2007 ME_MCUID: MT6582,S01 ME_MODEL: ALPS.L0.MP2.V1_TINNO6582.WT.L_P22 ME_BLDAT: Tue Aug 25 15:51:50 CST 2015 ME_CHIPS: MT6582, E01 ME_DSPFW: 2000.00.00 ME_DSPPT: 1.0 ME_BOARD: TINNO6582_WT_L_HSPA_HW ME_SWVER: MOLY.WR8.W1449.MD.WG.MP.V1.P3 ME_MLVER: Unknown ME_SERNR: Empty ME_IMEI1: --- ME_IMEI2: --- ME USB Com: Vid_0e8d&Pid_2007 Gen.Settings Write Done: 2 Item(s) ME USB Com: Vid_0e8d&Pid_2007 Gen.Settings Write Done: 2 Item(s) MicroMax A106 (Unite 2 3G DS) at META {Exit META} ME_METAX: Disconnected |
10-13-2017, 08:47 | #890 (permalink) |
No Life Poster Join Date: May 2014 Location: UGANDA
Member: 2185549 Status: Offline Thanks Meter: 535 | File: LS775ZV9_01.tot File Format: TOT Type FFFFFFFF Partitions (Chunks) to Flash: 21 (3.27 GB) LG LS775 (G Stylo 2 Sprint) at USB (COM252) [LG FLASH 5] {Write Flash} DL MODE : 6 DL REQM : 5 DL MODEL: LGLS775 DL SWVER: LS775ZV6 DL IMEI : 350305-26-000000-4 LF MODEL: LGLS775 LF SERNO: LGLS7753c65817 LF SWVER: K52010c_08 LF MINOS: MiniOS 3.0 LF OSVER: 6.0.1 LF IMEI : 355141-08-202354-3 LF DVPID: CT69S161212000563 LF SOCTY: msm8916 LF CABLE: 633A Writing Partition: PrimaryGPT Writing Partition: sbl1 Writing Partition: tz Writing Partition: hyp Writing Partition: rpm Writing Partition: aboot Writing Partition: sbl1bak Writing Partition: tzbak Writing Partition: hypbak Writing Partition: rpmbak Writing Partition: abootbak Writing Partition: persist Writing Partition: metadata Writing Partition: laf Writing Partition: boot Writing Partition: recovery Writing Partition: recoverybak Writing Partition: sec Writing Partition: factory Writing Partition: modem Writing Partition: system Flash Write Done in: 05:02.987 LF CLOSE: 0k RESTART : 2 |
The Following User Says Thank You to ferouz kassim For This Useful Post: |
10-14-2017, 08:01 | #891 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Colombia
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | Alcatel 5098O (Pixi 4-6 LTE) at Auto Select Flash Port [SAHARA] {Reset FRP} QDL USB Com: Vid_05c6&Pid_9008 (COM20) SAHARA VERS: 2.1 SAHARA PROG: prog_emmc_firehose_8909_alcH.mbn FHPROG SZFT: 4096 FHPROG SZTT: 16384 FHPROG SPTT: 16384 FHPROG XSIZ: 4096 FHPROG VERS: 1 FHPROG PLTF: 8909 FHPROG MEMT: eMMC FHINFO PAR0: 30777344 x 512 Sectors (14,68 GB) FHINFO PAR1: 8192 x 512 Sectors (4 MB) Default FHINFO PAR2: 8192 x 512 Sectors (4 MB) Default FHPROG PART: EFI GPT FHPROG PRTY: 5 FHREST DONE: Ok Reset FRP Done in: 00:26.639 (3) |
The Following User Says Thank You to jmr For This Useful Post: |
10-14-2017, 10:04 | #892 (permalink) |
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | Asus Z01BDC-ZC551KL (ZenFone 3 Laser LTE DS) at Auto Select Flash Port [SAHARA] {Reset FRP} QDL USB Com: Vid_05c6&Pid_9008 (COM20) SAHARA VERS: 2.1 SAHARA PROG: prog_emmc_firehose_8937_lite_asus.mbn FHPROG SZFT: 4096 FHPROG SZTT: 16384 FHPROG SPTT: 16384 FHPROG XSIZ: 4096 FHPROG VERS: 1 FHPROG PLTF: 8937 FHPROG MEMT: eMMC FHINFO PAR0: 61071360 x 512 Sectors (29,12 GB) FHINFO PAR1: 8192 x 512 Sectors (4 MB) FHINFO PAR2: 8192 x 512 Sectors (4 MB) FHPROG PART: EFI GPT FHPROG PRTY: 0 FHREST DONE: Ok Reset FRP Done in: 00:00.347 (1) |
10-15-2017, 15:35 | #893 (permalink) |
No Life Poster Join Date: May 2008 Location: On your Key-board Age: 37
Member: 768985 Status: Offline Sonork: 100.1676685 Thanks Meter: 608 | Var CHERRY-Flare XL (Flare XL 3G DS) at USB Auto Select [MTK] {Reset FRP} BR USB Com: Vid_0e8d&Pid_2000 DA Agent : MTK_AllInOne_DA.bin BR ComPort: COM5 BR Asic Id: MT6592 [0000] BR Asic Sw: 8A00 CA00 0000 0000 DA Version: MTK_AllInOne_DA_v3.3001.00.00 PR MMC CID: 150100513832334D42004DB1EEB1134B [Q823MB] PR Version: 4.2 [0x8A] (7) MT6592 eMMC BOOT1: 0x0000000000400000 [4.194.304] eMMC BOOT2: 0x0000000000400000 [4.194.304] eMMC RPMB : 0x0000000000400000 [4.194.304] eMMC USER : 0x00000003A3E00000 [15.634.268.160] eMMC CID : 150100513832334D42004DB1EEB1134B [Q823MB] ERAM Size : 0x0000000080000000 [2.147.483.648] IRAM Size : 0x0000000000020000 [131.072] UNICAL ID : 5D06FF4D531277BCD7B0F6F26F293737 PMT (EBR) Found : 21 Partition Entries Reset FRP Done in: 00:05.318 DA Shutdown Done, Disconnect Cable |
10-17-2017, 12:38 | #895 (permalink) |
Member: 2185549 Status: Offline Thanks Meter: 535 | Lenovo A6020a40 MSM8929 (Vibe K5 LTE DS) at USB (COM322) [DIAGS] {Gen.Settings} OFFLMODE: OK MDMVERSN: Oct 14 201619:13:04Sep 02 201601:00:00FAAAANUZ MDMBUILD: MPSS.DPM.2.0.2.c1-00114-M8936FAAAANUZM-1.68259.1.69229.1 NV IMEI1: 868528-02-807847-6 NV IMEI2: 868528-02-807848-4 NV BTID : 4888:CA:B1057B NV WIFI : 7B05:B5:CA8848 NV SERNR: Empty Gen.Settings Write Done: 2 Item(s) Lenovo A6020a40 MSM8929 (Vibe K5 LTE DS) at USB (COM322) [DIAGS] {Factory Info} OFFLMODE: OK MDMVERSN: Oct 14 201619:13:04Sep 02 201601:00:00FAAAANUZ MDMBUILD: MPSS.DPM.2.0.2.c1-00114-M8936FAAAANUZM-1.68259.1.69229.1 NV IMEI1: 359889-90-896675-0 NV IMEI2: 359889-90-896600-8 NV BTID : 4888:CA:B1057B NV WIFI : 7B05:B5:CA8848 NV SERNR: Empty |
10-20-2017, 11:57 | #898 (permalink) |
Junior Member Join Date: Apr 2009
Member: 1019757 Status: Offline Sonork: [email protected] Thanks Meter: 9 | MTK MT6580 (eMMC) at USB Auto Select [MTK] {Format Flash} BR USB Com: Vid_0e8d&Pid_2000 DA Agent : MTK_AllInOne_DA.bin BR ComPort: COM87 BR Asic Id: MT6580 [0000] BR Asic Sw: 8A00 CA00 0000 0000 DA Version: MTK_AllInOne_DA_v3.3001.00.00 PR MMC CID: 90014A48384731650507304A54BF932B [H8G1e] PR Version: 4.2 [0x9C] (7) MT6580 eMMC BOOT1: 0x0000000000400000 [4.194.304] eMMC BOOT2: 0x0000000000400000 [4.194.304] eMMC RPMB : 0x0000000000400000 [4.194.304] eMMC USER : 0x00000001D2000000 [7.818.182.656] eMMC CID : 90014A48384731650507304A54BF932B [H8G1e] ERAM Size : 0x0000000040000000 [1.073.741.824] IRAM Size : 0x0000000000020000 [131.072] UNICAL ID : 745C2A9103ABA7DE79C83B3C89A3F842 PMT (GPT) Found : 23 Partition Entries Erasing: LinST: 0x00BA800000 Size: 0x0116780000 userdata Format Flash Done in: 00:07.591 DA Shutdown Done, Disconnect Cable Q mobile i6 metal one pattern remove done by formating userdata will more happy if read or reset pattren will be added to save mobile data |
