Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > UFST
Old 10-11-2017, 10:18   #886 (permalink)
Member: 1913632
Thanks Meter: 233
q303 frp done
https://imgur.com/DjEC3Py
The Following 2 Users Say Thank You to pravakar333 For This Useful Post:
Old 10-12-2017, 09:58   #887 (permalink)
Member: 1913632
Thanks Meter: 233
mi 2014712 HM NOTE 1LTE flash in fastbootmode done
https://i.imgur.com/qyTuzNr.png
The Following User Says Thank You to pravakar333 For This Useful Post:
Old 10-13-2017, 07:17   #888 (permalink)
Member: 1913632
Thanks Meter: 233
micromax d303 flashing done
https://imageshack.com/i/pmLAEcRSp
Old 10-13-2017, 08:38   #889 (permalink)
Member: 1913632
Thanks Meter: 233
MicroMax A106 (Unite 2 3G DS) flashing and gereral setting done
MicroMax A106 (Unite 2 3G DS) at USB Auto Select [MTK] {Write Flash}
Scatter : MT6582_Android_scatter.txt
BR USB Com: Vid_0e8d&Pid_2000
DA Agent : MTK_AllInOne_DA.bin
BR ComPort: COM3
BR Asic Id: MT6582 [0000]
BR Asic Sw: 8A00 CB00 0001 0000
DA Version: MTK_AllInOne_DA_v3.3001.00.00
PR MMC CID: 90014A4838473264040503A218CDA1E9 [H8G2d]
PR Version: 4.2 [0x87] (5) MT6582
eMMC BOOT1: 0x0000000000400000 [4.194.304]
eMMC BOOT2: 0x0000000000400000 [4.194.304]
eMMC RPMB : 0x0000000000400000 [4.194.304]
eMMC USER : 0x00000001D2000000 [7.818.182.656]
eMMC CID : 90014A4838473264040503A218CDA1E9 [H8G2d]
ERAM Size : 0x0000000040000000 [1.073.741.824]
IRAM Size : 0x0000000000020000 [131.072]
UNICAL ID : A71790A66C996E878DEE8E78BDE45C67
PMT (EBR) Found : 19 Partition Entries
Partitions to Flash: 10 (3.02 GB)
Write PRELOADER 12 MB, Skipped
Write MBR 512 Bytes, Done in: 00:00.421
Write EBR1 512 Bytes, Done in: 00:00.265
Write PRO_INFO 3 MB, Skipped
Write NVRAM 5 MB, Skipped
Write PROTECT_F 10 MB, Skipped
Write PROTECT_S 10 MB, Skipped
Write SECCFG 128 KB, Skipped
Write UBOOT 271.8 KB, Done in: 00:00.249
Write BOOTIMG 4.21 MB, Done in: 00:00.874
Write RECOVERY 4.86 MB, Done in: 00:00.704
Write SEC_RO 132 KB, Done in: 00:00.249
Write MISC 512 KB, Skipped
Write LOGO 448.2 KB, Done in: 00:00.265
Write EXPDB 10 MB, Skipped
Write ANDROID 1.54 GB, Done in: 04:48.734
Write CACHE 6.02 MB, Done in: 00:01.497
Write USRDATA 16.59 MB, Done in: 00:04.727
Write BMTPOOL 21 MB, Skipped
Write Done in : 04:58.127
DA Shutdown Done, Disconnect Cable
MicroMax A106 (Unite 2 3G DS) at META {Gen.Settings}
Insert Cable to Switched OFF Device
ME USB Com: Vid_0e8d&Pid_2007
ME_MCUID: MT6582,S01
ME_MODEL: ALPS.L0.MP2.V1_TINNO6582.WT.L_P22
ME_BLDAT: Tue Aug 25 15:51:50 CST 2015
ME_CHIPS: MT6582, E01
ME_DSPFW: 2000.00.00
ME_DSPPT: 1.0
ME_BOARD: TINNO6582_WT_L_HSPA_HW
ME_SWVER: MOLY.WR8.W1449.MD.WG.MP.V1.P3
ME_MLVER: Unknown
ME_SERNR: Empty
ME_IMEI1: ---
ME_IMEI2: ---
Gen.Settings Write Done: 2 Item(s)
MicroMax A106 (Unite 2 3G DS) at META {Exit META}
ME_METAX: Disconnected
Old 10-13-2017, 08:47   #890 (permalink)
Member: 2185549
Thanks Meter: 535
File: LS775ZV9_01.tot
File Format: TOT Type FFFFFFFF
Partitions (Chunks) to Flash: 21 (3.27 GB)
LG LS775 (G Stylo 2 Sprint) at USB (COM252) [LG FLASH 5] {Write Flash}
DL MODE : 6
DL REQM : 5
DL MODEL: LGLS775
DL SWVER: LS775ZV6
DL IMEI : 350305-26-000000-4
LF MODEL: LGLS775
LF SERNO: LGLS7753c65817
LF SWVER: K52010c_08
LF MINOS: MiniOS 3.0
LF OSVER: 6.0.1
LF IMEI : 355141-08-202354-3
LF DVPID: CT69S161212000563
LF SOCTY: msm8916
LF CABLE: 633A
Writing Partition: PrimaryGPT
Writing Partition: sbl1
Writing Partition: tz
Writing Partition: hyp
Writing Partition: rpm
Writing Partition: aboot
Writing Partition: sbl1bak
Writing Partition: tzbak
Writing Partition: hypbak
Writing Partition: rpmbak
Writing Partition: abootbak
Writing Partition: persist
Writing Partition: metadata
Writing Partition: laf
Writing Partition: boot
Writing Partition: recovery
Writing Partition: recoverybak
Writing Partition: sec
Writing Partition: factory
Writing Partition: modem
Writing Partition: system
Flash Write Done in: 05:02.987
LF CLOSE: 0k
RESTART : 2
The Following User Says Thank You to ferouz kassim For This Useful Post:
Old 10-14-2017, 08:01   #891 (permalink)
jmr
Member: 614683
Sonork: 100.1605379
Thanks Meter: 370
Alcatel 5098O (Pixi 4-6 LTE) at Auto Select Flash Port [SAHARA] {Reset FRP}
QDL USB Com: Vid_05c6&Pid_9008 (COM20)
SAHARA VERS: 2.1
SAHARA PROG: prog_emmc_firehose_8909_alcH.mbn
FHPROG SZFT: 4096
FHPROG SZTT: 16384
FHPROG SPTT: 16384
FHPROG XSIZ: 4096
FHPROG VERS: 1
FHPROG PLTF: 8909
FHPROG MEMT: eMMC
FHINFO PAR0: 30777344 x 512 Sectors (14,68 GB)
FHINFO PAR1: 8192 x 512 Sectors (4 MB) Default
FHINFO PAR2: 8192 x 512 Sectors (4 MB) Default
FHPROG PART: EFI GPT
FHPROG PRTY: 5
FHREST DONE: Ok
Reset FRP Done in: 00:26.639 (3)
The Following User Says Thank You to jmr For This Useful Post:
Old 10-14-2017, 10:04   #892 (permalink)
jmr
Member: 614683
Sonork: 100.1605379
Thanks Meter: 370
Asus Z01BDC-ZC551KL (ZenFone 3 Laser LTE DS) at Auto Select Flash Port [SAHARA] {Reset FRP}
SAHARA VERS: 2.1
SAHARA PROG: prog_emmc_firehose_8937_lite_asus.mbn
FHPROG SZFT: 4096
FHPROG SZTT: 16384
FHPROG SPTT: 16384
FHPROG XSIZ: 4096
FHPROG VERS: 1
FHPROG PLTF: 8937
FHPROG MEMT: eMMC
FHINFO PAR0: 61071360 x 512 Sectors (29,12 GB)
FHPROG PRTY: 0
FHREST DONE: Ok
Reset FRP Done in: 00:00.347 (1)
The Following 2 Users Say Thank You to jmr For This Useful Post:
Old 10-15-2017, 15:35   #893 (permalink)
dyo
dyo's Avatar
Member: 768985
Sonork: 100.1676685
Thanks Meter: 608
Var CHERRY-Flare XL (Flare XL 3G DS) at USB Auto Select [MTK] {Reset FRP}
BR ComPort: COM5
BR Asic Id: MT6592 [0000]
BR Asic Sw: 8A00 CA00 0000 0000
PR MMC CID: 150100513832334D42004DB1EEB1134B [Q823MB]
PR Version: 4.2 [0x8A] (7) MT6592
eMMC USER : 0x00000003A3E00000 [15.634.268.160]
eMMC CID : 150100513832334D42004DB1EEB1134B [Q823MB]
ERAM Size : 0x0000000080000000 [2.147.483.648]
UNICAL ID : 5D06FF4D531277BCD7B0F6F26F293737
PMT (EBR) Found : 21 Partition Entries
Reset FRP Done in: 00:05.318
The Following 2 Users Say Thank You to dyo For This Useful Post:
Old 10-16-2017, 10:10   #894 (permalink)
Member: 1913632
Thanks Meter: 233
Old 10-17-2017, 12:38   #895 (permalink)
Member: 2185549
Thanks Meter: 535
Lenovo A6020a40 MSM8929 (Vibe K5 LTE DS) at USB (COM322) [DIAGS] {Gen.Settings}
OFFLMODE: OK
MDMVERSN: Oct 14 201619:13:04Sep 02 201601:00:00FAAAANUZ
MDMBUILD: MPSS.DPM.2.0.2.c1-00114-M8936FAAAANUZM-1.68259.1.69229.1
NV IMEI1: 868528-02-807847-6
NV IMEI2: 868528-02-807848-4
NV BTID : 4888:CA:B1057B
NV WIFI : 7B05:B5:CA8848
NV SERNR: Empty
Lenovo A6020a40 MSM8929 (Vibe K5 LTE DS) at USB (COM322) [DIAGS] {Factory Info}
OFFLMODE: OK
NV IMEI1: 359889-90-896675-0
NV IMEI2: 359889-90-896600-8
NV SERNR: Empty
Old 10-18-2017, 10:19   #896 (permalink)
Member: 1913632
Thanks Meter: 233
intex aqua 3g imei repair done
Old 10-18-2017, 10:21   #897 (permalink)
Member: 1913632
Thanks Meter: 233
lyf ls 4505 frp done
Old 10-20-2017, 11:57   #898 (permalink)
Member: 1019757
Thanks Meter: 9
MTK MT6580 (eMMC) at USB Auto Select [MTK] {Format Flash}
BR ComPort: COM87
BR Asic Id: MT6580 [0000]
PR MMC CID: 90014A48384731650507304A54BF932B [H8G1e]
PR Version: 4.2 [0x9C] (7) MT6580
eMMC CID : 90014A48384731650507304A54BF932B [H8G1e]
UNICAL ID : 745C2A9103ABA7DE79C83B3C89A3F842
PMT (GPT) Found : 23 Partition Entries
Erasing: LinST: 0x00BA800000 Size: 0x0116780000 userdata
Format Flash Done in: 00:07.591
Q mobile i6 metal one pattern remove done by formating userdata will more happy if read or reset pattren will be added to save mobile data
The Following 2 Users Say Thank You to chsaleem5 For This Useful Post:
Old 10-22-2017, 09:00   #899 (permalink)
Member: 1913632
Thanks Meter: 233
micromax e352 frp done
Old 10-22-2017, 11:49   #900 (permalink)
Member: 1913632
Thanks Meter: 233
mi 1s flash done
Page generated in 0.23920 seconds with 9 queries
