Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > UFST
Old 10-12-2013, 15:08   #106 (permalink)
Member: 6109
Sonork: 100.37432
Thanks Meter: 3,781
Samsung i589 Flash
Old 10-12-2013, 15:15   #107 (permalink)
Member: 6109
Sonork: 100.37432
Thanks Meter: 3,781
Samsung T959w Unlock
Old 10-23-2013, 01:15   #108 (permalink)
cellcarcol's Avatar
Member: 138781
Thanks Meter: 850
flashing samsung b3210
flash used B3210JBIL1_OJBIL1
Region: 1, 0x20000000-0x20000063, Length: 100 bytes
Region: 2, 0x2000C000-0x20011457, Length: 21592 bytes
Region: 3, 0x20016000-0x2001C59B, Length: 26012 bytes
Region: 4, 0x2001E000-0x2001E0B3, Length: 180 bytes
Region: 5, 0x2003803C-0x20056A57, Length: 125468 bytes
Region: 6, 0x20080000-0x20080037, Length: 56 bytes
Region: 7, 0x20080138-0x200849A3, Length: 18540 bytes
Region: 8, 0x200A0000-0x201B5697, Length: 1136280 bytes
Region: 9, 0x20300000-0x222380A7, Length: 32735400 bytes
1st:
1st:
1st Boot Ok, McuId: 00050015, Rom: 00050015, 13-1.2 (Vision X115E)
2nd Boot Ok, McuId: 00050015, Rom: 00050015, 7-2.0
Fll Boot Ok, Vers: 5.22, fl_sceptreeg_vx100_eval_v24_s06_t.sre
Flash1: Fl_Id: 00890000_88B00000 - Intel SIBLEY 1024
Flash2: Fl_Id: 00890000_88B00000 - Intel SIBLEY 1024
Baud Rate Set: 460800 bps
MCU File: B3210JBIL1.s3
Flashing NOR part...
Write Done, 34063708 byte(s), Time: 20:52
CTS File: B3210OJBIL1.csc
FS Formated (FDI)
FS Mounted (FDI)
Files Count: 271
FS Unmounted
FS Write Done, 11211111 byte(s), Time: 11:42
MSL3 CODE Mismatch, use [Repair MSL] not need to Write E2P or MCU !
S/N : RGBB787652
Using MSL S/N: RGBB787652
Read Done, St: 0x23FC0000, 262144 byte(s), Time: 00:09, 0
Write Done, 262160 byte(s), Time: 00:09
Old 10-23-2013, 08:07   #109 (permalink)
gagan_o5's Avatar
Member: 602830
Thanks Meter: 283
samsung s6102 patteren lock reset
Old 10-23-2013, 21:36   #110 (permalink)
cellcarcol's Avatar
Member: 138781
Thanks Meter: 850
unlock and repair imei b3210
Phone Must be with Battery and Powered On !
Software: B3210JBIL1
Regions : Vodacom - South Africa
Language: af,en,fr,pt,xh,zu (ar,de,es,it,nl,tr)
Release : 2009 December Rev: 1
CSC Vers: B3210OJBIL1
Hardware: MP 0.601
IMEI: 358628-03-000059-6
BT Address: f008f1-04dd7b
User Lock : 00000000
Lock Level: 01 [Locked]
Network Lock: 1. 26806 TMN, Portugal
MSL : Active
S/N : RGBB787652
MSL : Deactivated
PCK : 00000000 [#0141*00000000#]
NCK : 21900006 [#0111*21900006#]
SCK : 00000000 [#0121*00000000#]
SPCK: 00000000 [#0133*00000000#]
MCK : 63710081 [#0199*63710081#]
MSL : Active
S/N : RGBB787652
MSL : Deactivated
All Network Keys Reset to: 00000000, Time: 00:01
#0111*00000000#
#0121*00000000#
#0133*00000000#
#0141*00000000#
#0149*00000000#
#0151*00000000#
#0199*00000000#
Old 10-28-2013, 16:03   #111 (permalink)
cellcarcol's Avatar
Member: 138781
Thanks Meter: 850
c2-02.1 usb rm-693
CPU: AuthenticAMD, Sp: 12
Platform: Windows NT 5.1 (Build 2600 Service Pack 3)
Versions: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30
Current Paths:
EXE : C:\Archivos de programa\Nokia\Phoenix
TESLA: C:\Wintesla\
DCT3 : C:\Archivos de programa\Nokia\Phoenix\Flash3\
DCT4 : C:\Archivos de programa\Nokia\Phoenix\Flash\
BB5 : C:\Archivos de programa\Nokia\Phoenix\Flash\
UFSx Devices not Found
UFST Boot v1.2 (c)SarasSoft 2012 Id: 54 4D 1 0
UFST Core v1.2 (c)SarasSoft 2012 Sn: 12748103
HID: D3FA12F842600060, HWK: A1.04-PRO1
SID: 76A71B7F34894855ABC3DF0AD46574C475972A4E
XID: 984DEF6637F12B0B14757CD3861D1D216C445C22
Licence: True
LogFile: .\_!_LOG\12748103_28102013_095434_LOG.txt
Insert USB Cable to Switched OFF Phone and Power ON
IF_USB: XGOLDxxx
IF_SBL: XGOLD213, Ok
IF_EBL: Quantum_Bootloader_10.46_M1S1 10.46, Mode: CC
FL_ID : EC001230, Samsung K5N1258ACM 512Mb
MCU FLASH BUNDLE: rm692__07.65.mcusw
Flash File: rm692__07.65.mcusw_ebl_psi.fls
Erase Area: 0x40000000 - 0x4001FFFE, Erased: 00:00
Write Area: 0x40000000 - 0x4001FFFE, Written: 00:00
Erase Area: 0x40040000 - 0x4005FFFE, Erased: 00:00
Write Area: 0x40040000 - 0x4005FFFE, Written: 00:00
Erase Area: 0x40060000 - 0x4015FFFE, Erased: 00:02
Write Area: 0x40060000 - 0x4015FFFE, Written: 00:01
Erase Area: 0x40280000 - 0x41DBFFFE, Erased: 00:55
Write Area: 0x40280000 - 0x41D3FFFE, Written: 00:34
Erase Area: 0x43E20000 - 0x43E5FFFE, Erased: 00:00
PPM FLASH BUNDLE: rm692__07.65.ppm_l
Flash File: package_l.ppm_ebl_psi.fls
Erase Area: 0x41DC0000 - 0x424BFFFE, Erased: 00:09
Write Area: 0x41DC0000 - 0x421A8856, Written: 00:04
CNT FLASH BUNDLE: rm693__07.65_007.image_l_claro_co_v4_9m697
Flash File: /ZWork_Area/rm693_sw_settings_28/temp/059M697/CONTENT_CONFIG/package_l_claro_co.image.fls
Erase Area: 0x424C0000 - 0x43E1FFFE, Erased: 00:47
Write Area: 0x424C0000 - 0x4317FFFE, Written: 00:14
Erase Area: 0x43E60000 - 0x43F3FFFE, Erased: 00:02
Flashing Done: 02:57
ShutDown Done
UI Defaults Ok, Time: 00:00
Set UI Factory Defaults ...
Set Full Factory Defaults ...
Set Security Ok, Time: 00:00
Set Software Upgrade Defaults Ok, Time: 00:00
Old 11-02-2013, 13:01   #112 (permalink)
Member: 6109
Sonork: 100.37432
Thanks Meter: 3,781
Samsung N7105 unlock
The Following User Says Thank You to mobileclinic For This Useful Post:
Old 11-11-2013, 06:07   #113 (permalink)
Member: 52362
Thanks Meter: 35
SAMSUNG S3600i unlock
Old 11-12-2013, 06:41   #114 (permalink)
Member: 52362
Thanks Meter: 35
SAMSUNG C3520 restart success flash
Old 11-12-2013, 16:08   #115 (permalink)
anwar.welltech's Avatar
Member: 952533
Sonork: 1001607366
Thanks Meter: 124
I9070 FLASH SUCCESS......
Old 11-13-2013, 10:40   #116 (permalink)
Abhinav kumar b's Avatar
Member: 1751950
Sonork: 100.1615788
Thanks Meter: 25
Successfully-unlocked-flashed-repaired-phones-By UFST
Samsung B5310 Flashing Done......................
Old 11-16-2013, 01:17   #117 (permalink)
cellcarcol's Avatar
Member: 138781
Thanks Meter: 850
flash samsung s7562L
COM13: SAMSUNG Mobile USB Modem #5
PLATF: LOKE 00020000
PIT Read Done: 00:00
PIT Backup Saved as: S7562L_Read.pit
File: S7562LVJAMH1_S7562LZTOAMH1_S7562LVJAMH1_HOME.tar
Partition: APPS, Image: boot.img, Size: 0x00415100 (4280576)
Partition: RECOVERY, Image: recovery.img, Size: 0x004BF100 (4976896)
Partition: SYSTEM, Image: system.img.ext4, Size: 0x339F63EC (866083820)
Partition: FAT, Image: fat.bin, Size: 0x01321500 (20059392)
Partition: CACHE, Image: cache.img.ext4, Size: 0x0239413C (37306684)
Partition: HIDDEN, Image: hidden.img.ext4, Size: 0x004D70A0 (5075104)
Flash Write Done: 08:13
Restart Done
Old 11-17-2013, 07:36   #118 (permalink)
Member: 1274135
Thanks Meter: 157
Samsung I9250 unlock complete
List of devices attached 014E3D830F00C008 device
S/N : 00000000000
R_MD: I9250
R_SW: I9250XXLA2
ANDR: 4.0.4
ANDR: IMM76D
Superuser Permissions Granted
Transfered: 5967 KB/s (2097152 bytes in 0.343s)
Saved as: i9250_00000000000_nv_data_0000.bin
Path: C:\Program Files\SarasSoft\UFS\UFS_SAMs\i9250\NV
PROV: 22003#
FLAG: 0100000000 [Locked]
MCK : < CRYPTED >
NCK : < CRYPTED >
NSCK: < CRYPTED >
SPCK: < CRYPTED >
CPCK: < CRYPTED >
SIM : < CRYPTED >
S/N : 00000000000
R_MD: I9250
R_SW: I9250XXLA2
ANDR: 4.0.4
ANDR: IMM76D
Transfered: 5707 KB/s (2097152 bytes in 0.358s)
Transfered: 0 KB/s (32 bytes in 1.000s)
Unlock Done, Reboot Product to See Changes
Old 11-18-2013, 23:58   #119 (permalink)
cellcarcol's Avatar
Member: 138781
Thanks Meter: 850
s5830L imei
COM110: SAMSUNG Android USB Modem #6
COM111: SAMSUNG Android USB Diagnostic Serial Port (WDM) (COM111)
PING: OK, COM111 - QCDI
Software: S5830LUBKPL/S5830LCHTKP4
Regions : Orange - Polland
Language: cs,de,en,fr,hu,it,pl,sl
Release : December Rev:
Hardware: REV1.0
IMEI: 359079-04-421007-9
BTID: E7D1:97:8A4574
S/N : R21C93S2Q6
PRID: GT-S5830D
CSID: TLS
SWID: S5830DTLKI4_TLSKI4
DATE: 2011-09-15
UNID: 30140000169043
FLID: KAT007012B(S5830)
Hardware: REV1.0
S/N : R21C93S2Q6
MAGIC: 0191CD48
IMEI: 359079-04-400007-4
IMEI Rebuild Done, Reboot Device to See Changes
Reboot Done
Old 11-19-2013, 12:36   #120 (permalink)
cellcarcol's Avatar
Member: 138781
Thanks Meter: 850
flashing samsung i8190L
write flash
PIT Backup Saved as: i8190L_Read.pit
File: final.tar.md5
Partition: SYSTEM, Image: system.img, Size: 0x36564168 (911622504)
Flash Write Done: 06:19
Restart Done
Write param
File: PARAM_I8190.tar.md5
Partition: PARAM, Image: param.lfs, Size: 0x01000000 (16777216)
Flash Write Done: 00:12
Restart Done
Page generated in 0.25906 seconds with 10 queries
