10-23-2013, 01:15 | #108 (permalink) |
No Life Poster Join Date: Apr 2005 Location: America
Member: 138781 Status: Offline Thanks Meter: 850 | flashing samsung b3210 flash used B3210JBIL1_OJBIL1 Region: 1, 0x20000000-0x20000063, Length: 100 bytes Region: 2, 0x2000C000-0x20011457, Length: 21592 bytes Region: 3, 0x20016000-0x2001C59B, Length: 26012 bytes Region: 4, 0x2001E000-0x2001E0B3, Length: 180 bytes Region: 5, 0x2003803C-0x20056A57, Length: 125468 bytes Region: 6, 0x20080000-0x20080037, Length: 56 bytes Region: 7, 0x20080138-0x200849A3, Length: 18540 bytes Region: 8, 0x200A0000-0x201B5697, Length: 1136280 bytes Region: 9, 0x20300000-0x222380A7, Length: 32735400 bytes 1st: 1st: 1st Boot Ok, McuId: 00050015, Rom: 00050015, 13-1.2 (Vision X115E) 2nd Boot Ok, McuId: 00050015, Rom: 00050015, 7-2.0 Fll Boot Ok, Vers: 5.22, fl_sceptreeg_vx100_eval_v24_s06_t.sre Flash1: Fl_Id: 00890000_88B00000 - Intel SIBLEY 1024 Flash2: Fl_Id: 00890000_88B00000 - Intel SIBLEY 1024 Baud Rate Set: 460800 bps MCU File: B3210JBIL1.s3 Flashing NOR part... Write Done, 34063708 byte(s), Time: 20:52 CTS File: B3210OJBIL1.csc FS Formated (FDI) FS Mounted (FDI) Files Count: 271 FS Unmounted FS Write Done, 11211111 byte(s), Time: 11:42 MSL3 CODE Mismatch, use [Repair MSL] not need to Write E2P or MCU ! S/N : RGBB787652 Using MSL S/N: RGBB787652 1st Boot Ok, McuId: 00050015, Rom: 00050015, 13-1.2 (Vision X115E) 2nd Boot Ok, McuId: 00050015, Rom: 00050015, 7-2.0 Fll Boot Ok, Vers: 5.22, fl_sceptreeg_vx100_eval_v24_s06_t.sre Flash1: Fl_Id: 00890000_88B00000 - Intel SIBLEY 1024 Flash2: Fl_Id: 00890000_88B00000 - Intel SIBLEY 1024 Baud Rate Set: 460800 bps Read Done, St: 0x23FC0000, 262144 byte(s), Time: 00:09, 0 Flashing NOR part... Write Done, 262160 byte(s), Time: 00:09 |
10-23-2013, 21:36 | #110 (permalink) |
Member: 138781 Status: Offline Thanks Meter: 850 | unlock and repair imei b3210 Phone Must be with Battery and Powered On ! Software: B3210JBIL1 Regions : Vodacom - South Africa Language: af,en,fr,pt,xh,zu (ar,de,es,it,nl,tr) Release : 2009 December Rev: 1 CSC Vers: B3210OJBIL1 Regions : Vodacom - South Africa Language: af,en,fr,pt,xh,zu (ar,de,es,it,nl,tr) Release : 2009 December Rev: 1 Hardware: MP 0.601 IMEI: 358628-03-000059-6 BT Address: f008f1-04dd7b User Lock : 00000000 Lock Level: 01 [Locked] Network Lock: 1. 26806 TMN, Portugal MSL : Active S/N : RGBB787652 MSL : Deactivated PCK : 00000000 [#0141*00000000#] NCK : 21900006 [#0111*21900006#] SCK : 00000000 [#0121*00000000#] SPCK: 00000000 [#0133*00000000#] MCK : 63710081 [#0199*63710081#] Phone Must be with Battery and Powered On ! MSL : Active S/N : RGBB787652 MSL : Deactivated All Network Keys Reset to: 00000000, Time: 00:01 #0111*00000000# #0121*00000000# #0133*00000000# #0141*00000000# #0149*00000000# #0151*00000000# #0199*00000000# |
10-28-2013, 16:03 | #111 (permalink) |
Member: 138781 Status: Offline Thanks Meter: 850 | c2-02.1 usb rm-693 CPU: AuthenticAMD, Sp: 12 Platform: Windows NT 5.1 (Build 2600 Service Pack 3) Versions: Ufs2xx.dll 3.2.7, Ufs2xx.sys 2.8.30 Current Paths: EXE : C:\Archivos de programa\Nokia\Phoenix TESLA: C:\Wintesla\ DCT3 : C:\Archivos de programa\Nokia\Phoenix\Flash3\ DCT4 : C:\Archivos de programa\Nokia\Phoenix\Flash\ BB5 : C:\Archivos de programa\Nokia\Phoenix\Flash\ UFSx Devices not Found UFSx Devices not Found UFST Boot v1.2 (c)SarasSoft 2012 Id: 54 4D 1 0 UFST Core v1.2 (c)SarasSoft 2012 Sn: 12748103 HID: D3FA12F842600060, HWK: A1.04-PRO1 SID: 76A71B7F34894855ABC3DF0AD46574C475972A4E XID: 984DEF6637F12B0B14757CD3861D1D216C445C22 Licence: True LogFile: .\_!_LOG\12748103_28102013_095434_LOG.txt Insert USB Cable to Switched OFF Phone and Power ON Insert USB Cable to Switched OFF Phone and Power ON IF_USB: XGOLDxxx IF_SBL: XGOLD213, Ok IF_EBL: Quantum_Bootloader_10.46_M1S1 10.46, Mode: CC FL_ID : EC001230, Samsung K5N1258ACM 512Mb MCU FLASH BUNDLE: rm692__07.65.mcusw Flash File: rm692__07.65.mcusw_ebl_psi.fls Erase Area: 0x40000000 - 0x4001FFFE, Erased: 00:00 Write Area: 0x40000000 - 0x4001FFFE, Written: 00:00 Erase Area: 0x40040000 - 0x4005FFFE, Erased: 00:00 Write Area: 0x40040000 - 0x4005FFFE, Written: 00:00 Erase Area: 0x40060000 - 0x4015FFFE, Erased: 00:02 Write Area: 0x40060000 - 0x4015FFFE, Written: 00:01 Erase Area: 0x40280000 - 0x41DBFFFE, Erased: 00:55 Write Area: 0x40280000 - 0x41D3FFFE, Written: 00:34 Erase Area: 0x43E20000 - 0x43E5FFFE, Erased: 00:00 PPM FLASH BUNDLE: rm692__07.65.ppm_l Flash File: package_l.ppm_ebl_psi.fls Erase Area: 0x41DC0000 - 0x424BFFFE, Erased: 00:09 Write Area: 0x41DC0000 - 0x421A8856, Written: 00:04 CNT FLASH BUNDLE: rm693__07.65_007.image_l_claro_co_v4_9m697 Flash File: /ZWork_Area/rm693_sw_settings_28/temp/059M697/CONTENT_CONFIG/package_l_claro_co.image.fls Erase Area: 0x424C0000 - 0x43E1FFFE, Erased: 00:47 Write Area: 0x424C0000 - 0x4317FFFE, Written: 00:14 Erase Area: 0x43E60000 - 0x43F3FFFE, Erased: 00:02 Flashing Done: 02:57 ShutDown Done UI Defaults Ok, Time: 00:00 Set UI Factory Defaults ... Set Full Factory Defaults ... Set Full Factory Defaults ... Set Security Ok, Time: 00:00 Set Software Upgrade Defaults Ok, Time: 00:00 Set Full Factory Defaults ... |
11-16-2013, 01:17 | #117 (permalink) | |
Member: 138781 Status: Offline Thanks Meter: 850 | flash samsung s7562L Quote:
11-17-2013, 07:36 | #118 (permalink) |
No Life Poster Join Date: Mar 2010
Member: 1274135 Status: Offline Thanks Meter: 157 | Samsung I9250 unlock complete List of devices attached 014E3D830F00C008 device S/N : 00000000000 R_MD: I9250 R_SW: I9250XXLA2 ANDR: 4.0.4 ANDR: IMM76D Superuser Permissions Granted Transfered: 5967 KB/s (2097152 bytes in 0.343s) Saved as: i9250_00000000000_nv_data_0000.bin Path: C:\Program Files\SarasSoft\UFS\UFS_SAMs\i9250\NV PROV: 22003# FLAG: 0100000000 [Locked] MCK : < CRYPTED > NCK : < CRYPTED > NSCK: < CRYPTED > SPCK: < CRYPTED > CPCK: < CRYPTED > SIM : < CRYPTED > List of devices attached 014E3D830F00C008 device S/N : 00000000000 R_MD: I9250 R_SW: I9250XXLA2 ANDR: 4.0.4 ANDR: IMM76D Superuser Permissions Granted Transfered: 5707 KB/s (2097152 bytes in 0.358s) Transfered: 0 KB/s (32 bytes in 1.000s) Superuser Permissions Granted Unlock Done, Reboot Product to See Changes |
11-18-2013, 23:58 | #119 (permalink) |
Member: 138781 Status: Offline Thanks Meter: 850 | s5830L imei COM110: SAMSUNG Android USB Modem #6 COM111: SAMSUNG Android USB Diagnostic Serial Port (WDM) (COM111) PING: OK, COM111 - QCDI Software: S5830LUBKPL/S5830LCHTKP4 Software: S5830LUBKPL Regions : Orange - Polland Language: cs,de,en,fr,hu,it,pl,sl Release : December Rev: Hardware: REV1.0 IMEI: 359079-04-421007-9 BTID: E7D1:97:8A4574 S/N : R21C93S2Q6 PRID: GT-S5830D CSID: TLS SWID: S5830DTLKI4_TLSKI4 DATE: 2011-09-15 UNID: 30140000169043 FLID: KAT007012B(S5830) PING: OK, COM111 - QCDI Software: S5830LUBKPL/S5830LCHTKP4 Software: S5830LUBKPL Hardware: REV1.0 IMEI: 359079-04-421007-9 S/N : R21C93S2Q6 MAGIC: 0191CD48 IMEI: 359079-04-400007-4 IMEI Rebuild Done, Reboot Device to See Changes Reboot Done |
11-19-2013, 12:36 | #120 (permalink) | ||
Member: 138781 Status: Offline Thanks Meter: 850 | flashing samsung i8190L write flash Quote:
Write param Quote:
