Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #1576 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2006 Location: Karachi
Member: 388703 Status: Offline Sonork: sheerazi Thanks Meter: 182 | VOL_ is bootkey Var QMOBILE-Smart (Smart 3G DS S4001Q) at USB Auto Select [SPRD] {Reset FRP} BOOT: FDL1 and FDL2 from Default [Fdl] SC7731E_Qm_smrt_fdl Hold Vol+, Vol- and Insert Cable to Switched OFF Device FDLA: 50002E00, 9EFFFE00 FDLI: SA710B084548484436 FDLI: SA6D93B1BDD486274F SROM: SPRD3 FDL1: FDL2: Ok, 96, v1.1 Reset FRP Done in: 00:00.049 Restart Done, Disconnect Cable All Done in: 00:32.415 |
The Following User Says Thank You to kashif ali For This Useful Post: |
![]() | #1579 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: May 2014 Location: UGANDA
Member: 2185549 Status: Offline Thanks Meter: 529 ![]() | Var LAVA-R3 Note (R3 Note LTE DS LE9810) at AutoSelect Port [META] {Factory Def.} Insert Cable to Switched OFF Device BR USB Com: Vid_0e8d&Pid_2000 (Preloader) ME USB Com: Vid_0e8d&Pid_2007 (MAUI Meta) ME_MCUID: mt6765,S01 ME_MODEL: alps-mp-o1.mp7 ME_BLDAT: ME_METAX: Format Done, Restart Device |
![]() | #1580 (permalink) |
Member: 2185549 Status: Offline Thanks Meter: 529 ![]() | confirming reboot to meta from bromport Nokia TA-1047 (Nokia 1 LTE DS FRT) at AutoSelect Port [META] {Factory Def.} Insert Cable to Switched OFF Device BR USB Com: Vid_0e8d&Pid_0003 (BROM) BR ComPort: COM36 BR Asic Id: MT0717 [0000] Alias: MT6761 BR Asic Sw: 8A00 CA01 0200 0000 BR Secured: E1 [SBC] ME USB Com: Vid_0e8d&Pid_200E&MI_01 (MAUI Meta Adv) ME_MCUID: mt6761 ME_MODEL: 00WW_1_630 ME_BLDAT: Mon Sep 2 08:39:03 CST 2019 ME_METAX: Format Done, Restart Device |
![]() | #1581 (permalink) |
Member: 2185549 Status: Offline Thanks Meter: 529 ![]() | oppo a5s reset password done Var OPPO-A5s (A5s LTE DS CPH1909) at AutoSelect Port [META] {Factory Def.} Insert Cable to Switched OFF Device BR USB Com: Vid_0e8d&Pid_0003 (BROM) BR ComPort: COM34 BR Asic Id: MT0766 [0000] Alias: MT6765 BR Asic Sw: 8A00 CA00 0000 0000 BR Secured: E5 [SBC DAA] Auth File : Oppo_65_CF39_auth_sv5.auth Auth FiId : SA9ED9F65B2594DDD4 ME USB Com: Vid_0e8d&Pid_200E&MI_01 (MAUI Meta Adv) Cannot Enter META Mode: -2 Factory Defaults not Done Var OPPO-A5s (A5s LTE DS CPH1909) at AutoSelect Port [META] {Factory Def.} ME USB Com: Vid_0e8d&Pid_200E&MI_01 (MAUI Meta Adv) ME_MCUID: mt6765,S01 ME_MODEL: CPH1909_11_A.28_190916_34570289 ME_BLDAT: Mon Sep 16 23:18:23 CST 2019 ME_METAX: Format Done, Restart Device |
The Following 2 Users Say Thank You to ferouz kassim For This Useful Post: |
![]() | #1582 (permalink) |
Member: 2185549 Status: Offline Thanks Meter: 529 ![]() | LAVA IRIS 60 FRP RESET DONE Var LAVA-Iris 60 ( Iris 60 LTE DS) at USB Auto Select [MTK] {Reset FRP} BR USB Com: Vid_0e8d&Pid_0003 (BROM) DA Agent : MTK_AllInOne_DA.bin BR ComPort: COM152 BR Asic Id: MT0335 [0000] Alias: MT6735 BR Asic Sw: 8A00 CB00 0000 0000 BR Fuse Id: 94020000 BR ME_ID : 0BE566070D445BE79F454051714F441D DA AgentId: SAD2E7BC8BF7418BCA DA Version: MTK_AllInOne_DA_v3.3001.2019-04-24.11:20_472770. DA ProtVer: 2 PR MMC CID: 150100464E58324D4206E8C3681E079D [FNX2MB] PR Version: 4.2 [0x9B] (5) MT6735 EMI Confg : 150100464E58324D4206E8C3681E079D EMI PreLdr: preloader_sr6580_weg_n_tecF2.bin EMI TagVer: 21 EMI Config: 02000000000040000000 eMMC BOOT1: 0x0000000000400000 [4.194.304] 4 MB eMMC BOOT2: 0x0000000000400000 [4.194.304] 4 MB eMMC RPMB : 0x0000000000080000 [524.288] 512 KB eMMC USER : 0x00000001D2000000 [7.818.182.656] 7.28 GB eMMC CID : 150100464E58324D4206E8C3681E649D [FNX2MB] ERAM Size : 0x0000000040000000 [1.073.741.824] 1024 MB IRAM Size : 0x0000000000020000 [131.072] 128 KB UNICAL RID: E72A6DB926BC055986372303D8898753 DA USB Com: Vid_0e8d&Pid_2001 (DA HighSpeed) PMT (GPT) Found: 25 Partition Entries Reset FRP Done in: 00:09.892 (0) DA Shutdown Done, Disconnect Cable |
![]() | #1583 (permalink) |
Member: 388703 Status: Offline Sonork: sheerazi Thanks Meter: 182 | Lenovo L38011 (K5 Play Sim not work Done Lenovo L38011 (K5 Play LTE DS) at Auto Select Flash Port [SAHARA] {Write Flash} QDL USB Com: Vid_05c6&Pid_9008 (COM13) SAHARA VERS: 2.1 SAHARA HWID: 0004F0E100000000 [MSM8937] SAHARA HASH: CAB02552DC28F562E8C5BEFA75BC4A97B90AAB1C91A3C186EC 51F3D3D7D6A1C7 SAHARA SERN: AAB41EF6 (2863931126) SAHARA PROG: prog_emmc_firehose_8937_ddr_lenzuk.mbn SAHARA PRID: SA0DDA90179CB2320B FHPROG SZFT: 4096 FHPROG SZTT: 131072 FHPROG SPTT: 1048576 FHPROG XSIZ: 4096 FHPROG VERS: 1 FHPROG PLTF: 8937 FHPROG MEMT: eMMC FHINFO DSK0: 61071360 x 512 Sectors (29.12 GB) FHINFO DSK1: 8192 x 512 Sectors (4 MB) FHINFO DSK2: 8192 x 512 Sectors (4 MB) FHINFO MENM: GD6BMB FHINFO MESN: 718F9670 (1905235568) FHPROG PART: EFI GPT FHPROG PRTY: 0 Flash Bundle: Rawprogram0_sparsed.xml Partitions to Write: 1 (84 MB) FWRITE DONE: DSK0 ST 0x0000020000 modem 84 MB FPATCH DONE: 13, Used: patch0.xml FHSETD DONE: Ok (Boot Disk: 0) Write Flash Done in: 00:04.060 |
![]() | #1586 (permalink) |
Member: 2185549 Status: Offline Thanks Meter: 529 ![]() | oppo a5s reset password withour emmc soldering or jtagging fst fast job Var OPPO-A5s (A5s LTE DS CPH1909) at AutoSelect Port [META] {Factory Def.} Insert Cable to Switched OFF Device BR USB Com: Vid_0e8d&Pid_0003 (BROM) BR ComPort: COM34 BR Asic Id: MT0766 [0000] Alias: MT6765 BR Asic Sw: 8A00 CA00 0000 0000 BR Secured: E5 [SBC DAA] Auth File : Oppo_65_CF39_auth_sv5.auth Auth FiId : SA9ED9F65B2594DDD4 ME USB Com: Vid_0e8d&Pid_200E&MI_01 (MAUI Meta Adv) ME_MCUID: mt6765,S01 ME_MODEL: CPH1909_11_A.21_190416_bd9d0a85 ME_BLDAT: Tue Apr 16 23:34:53 CST 2019 ME_METAX: Format Done, Restart Device |
![]() | #1587 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2015 Location: India
Member: 2421242 Status: Offline Sonork: 100.1614558 Thanks Meter: 697 ![]() | Itel L6005 Operations Quote:
![]() | #1588 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2008 Location: -=Europ-Cellulare Zone-EGYPT=-
Member: 762055 Status: Offline Sonork: -=664053=- Thanks Meter: 771 ![]() | Samsung SM-G950F (S8)--- {Write Flash} DONE Quote:
BR, -=MR_Gsm=- | |
![]() | #1589 (permalink) |
Member: 388703 Status: Offline Sonork: sheerazi Thanks Meter: 182 | Motorola XT1762 hang logo & FRP Done Code: Motorola XT1762 (Moto E4 LTE DS Woods) at USB Auto Select [MTK] {Write Flash} Scatter: F:\Files\MOTO\XT-1762\WOODS_NMA26.42-142_subsidy-UNLOCKED_model-EMEADS_CFC_SVC.xml\MT6737M_Android_scatter.txt BR USB Com: Vid_0e8d&Pid_2000 (Preloader) DA Agent : MTK_AllInOne_DA_1712.bin BR ComPort: COM270 BR Asic Id: MT0335 [0000] Alias: MT6735 BR Asic Sw: 8A00 CB00 0000 0000 BR Fuse Id: A4020000 BR Secured: 01 [SBC] DA AgentId: SA33793325C1DBB593 DA Version: MTK_AllInOne_DA_v3.3001.00.00. DA ProtVer: 2 PR MMC CID: 150100514536334D42039BC5D49425F9 [QE63MB] PR Version: 4.2 [0x9B] (5) MT6735 eMMC BOOT1: 0x0000000000400000 [4.194.304] 4 MB eMMC BOOT2: 0x0000000000400000 [4.194.304] 4 MB eMMC RPMB : 0x0000000000400000 [4.194.304] 4 MB eMMC USER : 0x00000003A3E00000 [15.634.268.160] 14.56 GB eMMC CID : 150100514536334D42039BC5D49474F9 [QE63MB] ERAM Size : 0x0000000080000000 [2.147.483.648] 2 GB IRAM Size : 0x0000000000020000 [131.072] 128 KB UNICAL RID: 2B6C15B6021CB19F70A143B9AA232D73 PMT (GPT) Found: 31 Partition Entries Partitions to Flash: 3 (4.89 GB) Signatures Set: 3/3 Write system 2.56 GB, Done in: 04:04.346 (Signed) Write cache 8.04 MB, Done in: 00:00.940 (Signed) Write userdata 48.83 MB, Done in: 00:03.891 (Signed) Write Done in : 04:09.207 Signatures Updated: Ok DA Shutdown Done, Disconnect Cable Motorola XT1762 (Moto E4 LTE DS Woods) at USB Auto Select [MTK] {Reset FRP} BR USB Com: Vid_0e8d&Pid_2000 (Preloader) DA Agent : MTK_AllInOne_DA_1712.bin BR ComPort: COM270 BR Asic Id: MT0335 [0000] Alias: MT6735 BR Asic Sw: 8A00 CB00 0000 0000 BR Fuse Id: A4020000 BR Secured: 01 [SBC] DA AgentId: SA33793325C1DBB593 DA Version: MTK_AllInOne_DA_v3.3001.00.00. DA ProtVer: 2 PR MMC CID: 150100514536334D42039BC5D49425F9 [QE63MB] PR Version: 4.2 [0x9B] (5) MT6735 eMMC BOOT1: 0x0000000000400000 [4.194.304] 4 MB eMMC BOOT2: 0x0000000000400000 [4.194.304] 4 MB eMMC RPMB : 0x0000000000400000 [4.194.304] 4 MB eMMC USER : 0x00000003A3E00000 [15.634.268.160] 14.56 GB eMMC CID : 150100514536334D42039BC5D49474F9 [QE63MB] ERAM Size : 0x0000000080000000 [2.147.483.648] 2 GB IRAM Size : 0x0000000000020000 [131.072] 128 KB UNICAL RID: 2B6C15B6021CB19F70A143B9AA232D73 PMT (GPT) Found: 31 Partition Entries Reset FRP Done in: 00:02.846 (0) DA Shutdown Done, Disconnect Cable |
