Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Wholesale Unlock ★ | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #1696 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2008 Location: -=Europ-Cellulare Zone-EGYPT=-
Member: 762055 Status: Offline Sonork: -=664053=- Thanks Meter: 775 ![]() | Quote:
BR, -=MR_GSM=- | |
![]() | #1698 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2015 Location: India
Member: 2421242 Status: Offline Sonork: 100.1614558 Thanks Meter: 699 ![]() | LYF-F211S Stuck on logo Recovered done Quote:
![]() | #1699 (permalink) | |
Member: 762055 Status: Offline Sonork: -=664053=- Thanks Meter: 775 ![]() | {Write Flash} Quote:
BR, -=MR_GSM=- | |
The Following User Says Thank You to -=MR_Gsm=- For This Useful Post: |
![]() | #1700 (permalink) | |
Member: 2421242 Status: Offline Sonork: 100.1614558 Thanks Meter: 699 ![]() | MicroMax Q4002 Format User area Done Quote:
![]() | #1701 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2018 Location: Congo Brazzaville
Member: 2809120 Status: Offline Thanks Meter: 81 | Lenovo K53a48 (K6 Note LTE DS) Successfuly remove FRP with UFST keep it up please Lenovo K53a48 (K6 Note LTE DS) at Auto Select Flash Port [SAHARA] {Reset FRP} Qualcomm HS-USB QDLoader 9008 Port not Found: Vid_05c6&Pid_9008 Bad Port: SAHARA Connect Fail: -1 Reset FRP Failed Lenovo K53a48 (K6 Note LTE DS) at Auto Select Flash Port [SAHARA] {Reset FRP} QDL USB Com: Vid_05c6&Pid_9008 (COM94) SAHARA VERS: 2.1 SAHARA HWID: 0004F0E100007A2A [MSM8937] SAHARA HASH: 99C8C13E374C34D8F9AFB065EA4C733E6B1B21CBC5A78705F0 41EB24ACDD5FE5 SAHARA SERN: 00375A14 (3627540) SAHARA PROG: prog_emmc_firehose_8937_ddr_lenovo.mbn SAHARA PRID: SA88AC5A628B1AF367 FHPROG SZFT: 4096 FHPROG SZTT: 131072 FHPROG SPTT: 1048576 FHPROG XSIZ: 4096 FHPROG VERS: 1 FHPROG PLTF: 8937 FHPROG MEMT: eMMC FHINFO DSK0: 61071360 x 512 Sectors (29,12 GB) FHINFO DSK1: 8192 x 512 Sectors (4 MB) FHINFO DSK2: 8192 x 512 Sectors (4 MB) FHINFO MENM: RX1BMB FHINFO MESN: AC6BAA55 (2892737109) FHPROG PART: EFI GPT FHPROG PRTY: 0 Reset FRP Done in: 00:00.231 (1) we need more support phone u are the best |
![]() | #1703 (permalink) | |
Member: 2421242 Status: Offline Sonork: 100.1614558 Thanks Meter: 699 ![]() | INFINIX-X5515I-H398I FRP Done.................. Quote:
![]() | #1704 (permalink) |
Member: 2809120 Status: Offline Thanks Meter: 81 | ITEL S32 FRP remove successfuly Var ITEL-S32 (S32 3G DS I805) at USB Auto Select [MTK] {Reset FRP} MTK Flash Port not Found: Vid_0e8d&Pid_2000 Vid_0e8d&Pid_0003 Var ITEL-S32 (S32 3G DS I805) at USB Auto Select [MTK] {Reset FRP} MTK Flash Port not Found: Vid_0e8d&Pid_2000 Vid_0e8d&Pid_0003 Var ITEL-S32 (S32 3G DS I805) at USB Auto Select [MTK] {Reset FRP} <<< STOP >>> Var ITEL-S32 (S32 3G DS I805) at USB Auto Select [MTK] {Reset FRP} MTK Flash Port not Found: Vid_0e8d&Pid_2000 Vid_0e8d&Pid_0003 Var ITEL-S32 (S32 3G DS I805) at USB Auto Select [MTK] {Reset FRP} BR USB Com: Vid_0e8d&Pid_2000 (Preloader) DA Agent : MTK_AllInOne_DA.bin BR ComPort: COM20 BR Asic Id: MT6580 [0000] BR Asic Sw: 8A00 CA00 0000 0000 BR Fuse Id: 00001002 DA AgentId: SABAB1470D512FC946 DA Version: MTK_AllInOne_DA_v3.3001.2019-11-06.22:49_491164. DA ProtVer: 2 PR MMC CID: 150100464536324D42037CC9D638C41F [FE62MB] PR Version: 4.2 [0x9C] (7) MT6580 eMMC BOOT1: 0x0000000000400000 [4.194.304] 4 MB eMMC BOOT2: 0x0000000000400000 [4.194.304] 4 MB eMMC RPMB : 0x0000000000400000 [4.194.304] 4 MB eMMC USER : 0x00000003A3E00000 [15.634.268.160] 14,56 GB eMMC CID : 150100464536324D42037CC9D638C41F [FE62MB] ERAM Size : 0x0000000040000000 [1.073.741.824] 1024 MB IRAM Size : 0x0000000000020000 [131.072] 128 KB UNICAL RID: AE514FB328891F7EADA8D285D6590B7F PMT (GPT) Found: 23 Partition Entries Reset FRP Done in: 00:06.540 (0) DA Shutdown Done, Disconnect Cable ![]() |
![]() | #1705 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2006 Location: Karachi
Member: 388703 Status: Online Sonork: sheerazi Thanks Meter: 182 | QMOBILE-QInfinityB FRP Reset Done Var QMOBILE-QInfinityB (Q Infinity B 3G DS) at USB Auto Select [SPRD] {Reset FRP} BOOT: FDL1 and FDL2 from Default [Fdl] SC7731C_5_fdl Hold Vol+, Vol- and Insert Cable to Switched OFF Device FDLA: 50000000, 9F000000 FDLI: SA03616CA812D7EA3F FDLI: SA46A6F7DB0727CD48 SROM: SPRD3 FDL1: FDL2: Ok, 96 Reset FRP Done in: 00:00.140 Restart Done, Disconnect Cable All Done in: 00:38.189 |
![]() | #1706 (permalink) |
Member: 388703 Status: Online Sonork: sheerazi Thanks Meter: 182 | QMOBILE-i8i 2019 Pattern & FRP Done Var QMOBILE-i8i 2019 (i8i 2019 3G DS) at AutoSelect Port [CAL] {Factory Def.} Insert Cable to Switched OFF Device CAL_MODE: FE8E CAL_DEVT: SP09 Factory Default Done: OK Var QMOBILE-i8i 2019 (i8i 2019 3G DS) at USB Auto Select [SPRD] {Reset FRP} BOOT: FDL1 and FDL2 from Default [Fdl] SC7731E_Symph_V94_fdl Hold Vol+, Vol- and Insert Cable to Switched OFF Device FDLA: 50002E00, 9EFFFE00 FDLI: SAC7F8CA03DED78300 FDLI: SA8787ABCC7F539507 SROM: SPRD3 FDL1: Spreadtrum Boot Block version 1.1 FDL2: Ok, 96, v1.1 Reset FRP Done in: 00:00.060 Restart Done, Disconnect Cable All Done in: 00:10.806 |
![]() | #1707 (permalink) | |
BR, -=MR_GSM=- | |
![]() | #1708 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2017 Location: on google.com
Member: 2771307 Status: Online Thanks Meter: 741 | Lenovo TB-7104i 3G FRP reset without problem Where other box can't do this software can everything Quote:
![]() | #1709 (permalink) | |
Member: 762055 Status: Offline Sonork: -=664053=- Thanks Meter: 775 ![]() | {Write Flash} {Write Flash} Quote:
BR, -=MR_GSM=- | |
![]() | #1710 (permalink) | |
-=MR_GSM=- | |
