Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > UFST
Old 10-08-2016, 06:55   #556 (permalink)
Member: 2207555
Thanks Meter: 1,622
Smile
LG D325 KDZ Extract,Write Flash & Factory Reset Done-Android UFST Tool
KDZ File: D325_10f_00 INDIA.kdz, Type 2, Size: 957.356.473 Bytes
File: WX.dll, Size: 1.563.136 Bytes
Saved as: D325_10f_00 INDIA_WX.dll
File Description: LG-D325
File: D32510f, Size: 954.841.597 Bytes
Saved as: D325_10f_00 INDIA_D32510f.dz
KDZ Extract Done in: 00:30.266
File: D325_10f_00  INDIA_D32510f.dz
File Format: DZ Type 2
Model: LG-D325 File: D32510f Partitions {Chunks): 31
RbId: A1411471887-M1411471887-C1411477823-U1411477823-0 user
Partitions (Chunks) to Flash: 31 (1.47 GB)
LG D325 (L70 DS) at USB (COM66) [LG FLASH 5] {Write Flash}
DL MODE : 2
DL REQM : 5
DL MODEL: LG-D325
DL SWVER: D32510f
DL IMEI : 352270-06-225783-0
LF MODEL: LG-D325
LF SERNO: LGD325fb26caee
LF SWVER: LGD325AT-00-V10f-ESA-XX-SEP-23-2014+0
LF MINOS: unknown
LF OSVER: 4.4.2
LF IMEI : 352270-06-225783-0
LF DVPID: CT68S140403004656
LF SOCTY: msm8610
LF CABLE: 910K
Writing Partition: PrimaryGPT
Writing Partition: modem
Writing Partition: sbl1
Writing Partition: rpm
Writing Partition: tz
Writing Partition: sdi
Writing Partition: aboot
Writing Partition: rpmb
Writing Partition: tzb
Writing Partition: abootb
Writing Partition: persist
Writing Partition: laf
Writing Partition: boot
Writing Partition: recovery
Writing Partition: factory
Writing Partition: sbl1b
Writing Partition: cust
Writing Partition: system
Writing Partition: BackupGPT
Flash Write Done in: 04:57.857
LF CLOSE: 0k
RESTART : 2
LG D325 (L70 DS) at USB (COM67) [MODEM] {Factory Def.}
MODEMCON: OK
FACTORY RESET OK
Rehan
The Following User Says Thank You to rehansk8879 For This Useful Post:
Old 10-08-2016, 07:10   #557 (permalink)
4G Telecom's Avatar
Member: 2421242
Sonork: 100.1614558
Thanks Meter: 700
XOLO-A500 Club Flash Done By UFST
Logs.............................................. ..........................
Var XOLO-A500 Club (A500 Club 3G DS) at USB Auto Select [MTK] {Write Flash}
Scatter : MT6572_Android_scatter.txt
DA Agent : MTK_AllInOne_DA.bin
BR ComPort: COM23
BR Asic Id: MT6572 [0000]
BR Asic Sw: 8A00 CA01 0000 0000
DA Version: MTK_AllInOne_DA_v3.3001.00.00
PR MMC CID: 7001004D4D433034475810FAC82F31D7 [MMC04G]
PR Version: 4.2 [0x88] (7)
eMMC BOOT1: 0x0000000000200000 [2.097.152]
eMMC BOOT2: 0x0000000000200000 [2.097.152]
eMMC RPMB : 0x0000000000020000 [131.072]
eMMC USER : 0x00000000E6800000 [3.867.148.288]
eMMC CID : 7001004D4D433034475810FAC82F31D7 [MMC04G]
ERAM Size : 0x0000000020000000 [536.870.912]
IRAM Size : 0x0000000000020000 [131.072]
UNICAL ID : C17093D7B67BC8B691A6D423C6E87930
PMT (EBR) Found : 20 Partition Entries
Partitions to Flash: 10 (2.48 GB)
Skipped: LinST: 0x0000000000 PRELOADER preloader_m1_xolo.bin
Writing: LinST: 0x0000600000 MBR MBR
Writing: LinST: 0x0000680000 EBR1 EBR1
Skipped: LinST: 0x0000700000 PRO_INFO NONE
Skipped: LinST: 0x0000A00000 NVRAM NONE
Skipped: LinST: 0x0000F00000 PROTECT_F NONE
Skipped: LinST: 0x0001900000 PROTECT_S NONE
Skipped: LinST: 0x0002300000 SECCFG NONE
Writing: LinST: 0x0002320000 UBOOT lk.bin
Writing: LinST: 0x0002380000 BOOTIMG boot.img
Writing: LinST: 0x0002980000 RECOVERY recovery.img
Writing: LinST: 0x0002F80000 SEC_RO secro.img
Skipped: LinST: 0x0002FC0000 MISC NONE
Writing: LinST: 0x0003040000 LOGO logo.bin
Skipped: LinST: 0x0003340000 EXPDB NONE
Writing: LinST: 0x0003D40000 ANDROID system.img
Writing: LinST: 0x0038F40000 CACHE cache.img
Writing: LinST: 0x0040140000 USRDATA userdata.img
Skipped: LinST: 0x00A1940000 FAT NONE
Skipped: LinST: 0x00FFFF00A8 BMTPOOL NONE
Write Done in : 02:49.404
DA Shutdown Done, Disconnect Cable
The Following 4 Users Say Thank You to 4G Telecom For This Useful Post:
Old 10-08-2016, 07:20   #558 (permalink)
ddilshod93's Avatar
Member: 2082192
Sonork: not
Thanks Meter: 1,119
SM-J200G/DD LTE Direct unlock done, without root
Samsung SM-J200G (J2 LTE) at USB (COM68) [MODEM] {Unlock}
MODEMCON: OK
Unlock Done in: 00:10.262, Reboot Product to See Changes
Samsung SM-J200G (J2 LTE) at USB [ADB] {ADB Reboot}
ADB Reboot Done
The Following 2 Users Say Thank You to ddilshod93 For This Useful Post:
Old 10-08-2016, 10:48   #559 (permalink)
4G Telecom's Avatar
Member: 2421242
Sonork: 100.1614558
Thanks Meter: 700
Motorola XT1022 Stuck on Moto M Logo solved By UFST
Motorola XT1022 (Moto E 3G DS Condor) at USB [FASTBOOT] {Write Flash}
Bundle: servicefile.xml
Model: condor_retaildsds
Version: condor_retaildsds-user 5.1 LPC23.13-34.2 2 release-keysMSM8610BP_18033.4614.45.00R
No.of Operations: 16
getvar max-sparse-size
268435456
oem fb_mode_set
Writing partition gpt.bin 32.768 Byte(s)
INFO Battery Low!!
Writing motoboot motoboot.img 1.709.056 Byte(s)
INFO flashing tz ...
INFO flashing rpm ...
INFO flashing sdi ...
INFO flashing aboot ...
INFO flashing sbl1 ...
Writing logo logo.bin 539.807 Byte(s)
Writing boot boot.img 10.444.800 Byte(s)
Writing recovery recovery.img 10.526.720 Byte(s)
Writing system system.img_sparsechunk.0 248.819.368 Byte(s)
Writing system system.img_sparsechunk.1 262.716.524 Byte(s)
Writing system system.img_sparsechunk.2 263.297.800 Byte(s)
Writing system system.img_sparsechunk.3 47.354.020 Byte(s)
Writing modem NON-HLOS.bin 47.341.568 Byte(s)
Erasing modemst1
Erasing modemst2
Writing fsg fsg.mbn 663.552 Byte(s)
INFO Battery Low!!
oem fb_mode_clear
All Done in 03:02.193
rebooting normally
The Following 3 Users Say Thank You to 4G Telecom For This Useful Post:
Old 10-09-2016, 12:52   #560 (permalink)
Member: 2470467
Sonork: QQ 2836977761
Thanks Meter: 51
Smile Nokia 105 ( RM-908 ) Write Flash done
Nokia 105 Write Flash done
Info :
MCU SW  : V 02.70 22-02-13 RM-908 (c) Nokia
PPM SW  : V 02.70 22-02-13 RM-908 (c) Nokia IJ
Platform: Infineon XG110
Prd.Code: 059R492
Bpr.Code: 059Q858
Prod.Sn : 228C3EBBH
HW Vers : 1001
UEM     : 1328
UPP     : 8850 [2292]
LCD Type: UNKWN: IDs: 00:00:00
IMEI    : 358347-05-445120-1
SL Conf : 001-01-00000000000
SL Prof : 000000000004000-2
SL Var  : 00003583470544512000
SL Aux  : 000B0000
HW Sig  : 5EB9ACFD9E443BE3
Box Id  : FFFFFFFFFFFFFFFF
BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
Provider: GSM Test Equipment
Write Flash :
If used non Auto-Ignition cable, press Power-On button
IF_SBL: XGOLD110, Ok
IF_EBL: Default_RAM_Bootloader 10.27, Mode: CC
BAUD_R: 3000000
FL_ID : EF001760, Winbond W25Q64DW 64Mb
MCU FLASH BUNDLE: rm908_02.700
Flash File: hw_b1_rm908_02.700.fls
Erase Area: 0x00800000 - 0x00A0FFFE, Erased: 00:09
Write Area: 0x00800000 - 0x00A0FFFE, Written: 00:16
Erase Area: 0x00C60000 - 0x00EAFFFE, Erased: 00:10
Write Area: 0x00C60000 - 0x00E8123E, Written: 00:17
Erase Area: 0x00FFC000 - 0x00FFFFFE, Erased: 00:00
Write Area: 0x00FFC000 - 0x00FFC03E, Written: 00:00
Warning, Checksum Mismatch: 8CA7 > 9FA5
PPM FLASH BUNDLE: rm908_02.70ij
Flash File: hw_b1_rm908_02.70ij.fls
Erase Area: 0x00210000 - 0x0045FFFE, Erased: 00:11
Write Area: 0x00210000 - 0x0039A33E, Written: 00:12
Warning, Checksum Mismatch: 6B15 > E996
CNT FLASH BUNDLE: rm908_nai02.70ij
Flash File: hw_b1_rm908_nai02.70ij.fls
Erase Area: 0x00EB0000 - 0x00F7FFFE, Erased: 00:04
Write Area: 0x00EB0000 - 0x00F161BE, Written: 00:03
Warning, Checksum Mismatch: 7E6F > FDA3
Flashing Done: 01:34
ShutDown Done
Real ASH
The Following User Says Thank You to Real ASH For This Useful Post:
Old 10-09-2016, 13:23   #561 (permalink)
Member: 1820874
Thanks Meter: 20
lg h818p FRP Done 5s
LG H818P (G4 DS) at USB (COM11) [LG FLASH 5] {Reset FRP}
DL MODE : 2
DL REQM : 5
DL MODEL: LG-H818P
DL SWVER: H81820e
DL IMEI : 35xxxx-xx-xxxxxx-x
LF DVPID: YE07S150523003459
LF MODEL: LG-H818P
LF SERNO: LGH8186a693135
LF SWVER: LGH818PAT-00-V20e-AME-XX-APR-28-2016+0
LF MINOS: MiniOS 3.0
LF OSVER: 6.0
LF IMEI : 35xxxx-xx-xxxxxx-x
LF SOCTY: msm8992
LF CABLE: 910K
Reset FRP Done in 00:09.871
The Following User Says Thank You to alf003 For This Useful Post:
Old 10-09-2016, 17:10   #562 (permalink)
profkefah's Avatar
Member: 2371500
Thanks Meter: 5,929
MT6735 sunny ss4g1 luna frp done first in world
hi i gt this phone with frp lock
other chinese box filed
only UFST did it
only connect switched off phone
then press frp reset from panel
  CPU: MT6735 SW:0000 Ver: CA00
v 6.0
  model SS4G1 Luna
  brand Sunny
  manufacturer:SUNNY
>>Done
The Following 3 Users Say Thank You to profkefah For This Useful Post:
Old 10-12-2016, 07:11   #563 (permalink)
4G Telecom's Avatar
Member: 2421242
Sonork: 100.1614558
Thanks Meter: 700
MicroMax A106 Flashing By UFST
MicroMax A106 (Unite 2 3G DS) at USB Auto Select [MTK] {Write Flash}
Scatter : MT6582_Android_scatter.txt
BR ComPort: COM33
BR Asic Id: MT6582 [0000]
BR Asic Sw: 8A00 CB00 0001 0000
PR MMC CID: 90014A4838473264040507A2CB79B10F [H8G2d]
PR Version: 4.2 [0x87] (5)
eMMC BOOT1: 0x0000000000400000 [4.194.304]
eMMC BOOT2: 0x0000000000400000 [4.194.304]
eMMC RPMB : 0x0000000000400000 [4.194.304]
eMMC USER : 0x00000001D2000000 [7.818.182.656]
eMMC CID : 90014A4838473264040507A2CB79B10F [H8G2d]
ERAM Size : 0x0000000040000000 [1.073.741.824]
UNICAL ID : CC26526DF19CC00173B6FD175AA6FE36
PMT (EBR) Found : 21 Partition Entries
Partitions to Flash: 11 (1.95 GB)
Skipped: LinST: 0x0000000000 PRELOADER preloader_s4700.bin
Writing: LinST: 0x0000C00000 MBR MBR
Writing: LinST: 0x0000C80000 EBR1 EBR1
Skipped: LinST: 0x0000D00000 PRO_INFO NONE
Skipped: LinST: 0x0001000000 NVRAM NONE
Skipped: LinST: 0x0001500000 PROTECT_F NONE
Skipped: LinST: 0x0001F00000 PROTECT_S NONE
Skipped: LinST: 0x0002900000 SECCFG NONE
Writing: LinST: 0x0002920000 UBOOT lk.bin
Writing: LinST: 0x0002980000 BOOTIMG boot.img
Writing: LinST: 0x0003980000 RECOVERY recovery.img
Writing: LinST: 0x0004980000 SEC_RO secro.img
Skipped: LinST: 0x0004F80000 MISC NONE
Writing: LinST: 0x0005000000 LOGO logo.bin
Writing: LinST: 0x0005300000 EBR2 EBR2
Skipped: LinST: 0x0005380000 EXPDB NONE
Writing: LinST: 0x0005D80000 ANDROID system.img
Writing: LinST: 0x003E180000 CACHE cache.img
Writing: LinST: 0x0045F80000 USRDATA userdata.img
Skipped: LinST: 0x007FB80000 FAT NONE
Write Done in : 02:56.843
Old 10-13-2016, 10:02   #564 (permalink)
4G Telecom's Avatar
Member: 2421242
Sonork: 100.1614558
Thanks Meter: 700
Sony C1904 Only Vibrator Solved BY UFST
PHP Code:
Sony C1904 (Xperia M 3G Niokiat USB Auto Select [S1] {Write Flash}
Files to Flash11
GGSOMC Drivers not Installed
-1Will try GGSEMC
BL VERS
S1_Boot_MSM_8227_5
BL PKTSZ
0x00010000
BL IMEI
358096-05-240782-8
BL ROOTS
ROOTABLE
TA MODEL
C1904
TA DEVSN
YT910FAD6Q
TA CDVER
1274-3899_R4C
TA SWVER
1272-2325_15.4.A.1.9
TA FLVER
WORLD-a_15.4.A.1.9
Loader Boot Done in 00
:00.050
FL VERS
loader_MSM8227_5
FL PKTSZ
0x00080000
FL IMEI
358096-05-240782-8
TA MODEL
C1904
TA DEVSN
YT910FAD6Q
TA CDVER
1274-3899_R4C
TA SWVER
TA FLVER
WORLD-a_15.4.A.1.9
TA S1VER
1271-1024 S1_Boot_MSM_8227_5
AT PLFRT
AT OTLCKLOCKED
AT OTDAT
01000100
AT IDCOD
207D00E1
Writing File
cache_S1-SW-LIVE-DBE9-PID1-0002-MMC.sin
File Write Done in 00
:00.499 00:00.874
Writing File
elabel-C1904-india_201307191100.1_15.4.A.1.9_S1-CUST-LIVE-DBE9-PID1-0001-MMC.sin
:01.295 00:01.685
Writing File
fotakernel_S1-SW-LIVE-DBE9-PID1-0002-MMC.sin
:00.608 00:01.139
Writing File
:00.562 00:00.967
Writing File
modem_fs1_S1-MODEMSW-LIVE-DBE9-PID1-0002-MMC.sin
:00.265 00:00.390
Writing File
modem_fs2_S1-MODEMSW-LIVE-DBE9-PID1-0002-MMC.sin
:00.249 00:00.390
Writing File
modem_S1-MODEMSW-LIVE-DBE9-PID1-0002-MMC.sin
:03.542 00:04.617
Writing File
partition-image_S1-SW-LIVE-DBE9-PID1-0002-MBR.sin
:00.047 00:00.000
Writing File
rpm_S1-RPMFW-LIVE-DBE9-PID1-0002-MMC.sin
:00.016 00:00.234
Writing File
system_S1-SW-LIVE-DBE9-PID1-0002-MMC.sin
File Write Done in 01
:46.314 01:21.589
Writing File
userdata_S1-SW-LIVE-DBE9-PID1-0002-MMC.sin
:03.853 00:04.274
All Done in 03
:50.328
Old 10-13-2016, 12:04   #565 (permalink)
Member: 597088
Thanks Meter: 13
Noa vivo se frp reset done
Superuser Permissions Denied
FRP Reset in ADB Mode need Root Rights
MTK MT6580 () at USB Auto Select [MTK] {Reset FRP}
BR ComPort: COM16
BR Asic Id: MT6580 [0000]
BR Asic Sw: 8A00 CA00 0000 0000
PR MMC CID: 700100563130303038501AF1A7E2B243 [V10008]
PR Version: 4.2 [0x94] (7)
eMMC USER : 0x00000001C3000000 [7.566.524.416]
eMMC CID : 700100563130303038501AF1A7E2B243 [V10008]
UNICAL ID : 6C73BB09D9F14B346CC9922C8CF691B6
PMT (GPT) Found : 23 Partition Entries
Reset FRP Done in: 00:05.120
Old 10-14-2016, 11:35   #566 (permalink)
4G Telecom's Avatar
Member: 2421242
Sonork: 100.1614558
Thanks Meter: 700
XIAOMI Model NOTE 1S Dead Boot Repair By GREAT TOOL UFST
Full Logs
Var XIAOMI-Redmi 2 HM2014811 (Redmi 2 LTE DS) at USB (COM83) [SAHARA] {Write Flash}
Flash Bundle: rawprogram0.xml
SAHARA VERS: 2
SAHARA PROG: prog_emmc_firehose_8916_none.mbn
FHPROG SZFT: 4096
FHPROG SZTT: 16384
FHPROG SPTT: 16384
FHPROG XSIZ: 4096
FHPROG VERS: 1
FHPROG PLTF: 8916
FHPROG MEMT: eMMC
FHINFO PAR0: 30777344 x 512 Sectors (14.68 GB)
FHINFO PAR1: 8192 x 512 Sectors (4 MB)
FHINFO PAR2: 8192 x 512 Sectors (4 MB)
Partitions to Write: 21 (1.48 GB)
FWRITE DONE: ST 0x0000000022 sbl1 246.43 KB
FWRITE DONE: ST 0x0000000422 sbl1bak 246.43 KB
FWRITE DONE: ST 0x0000000822 aboot 569.55 KB
FWRITE DONE: ST 0x0000001022 abootbak 569.55 KB
FWRITE DONE: ST 0x0000001822 rpm 141.52 KB
FWRITE DONE: ST 0x0000001C22 rpmbak 141.52 KB
FWRITE DONE: ST 0x0000002022 tz 402.45 KB
FWRITE DONE: ST 0x0000002422 tzbak 402.45 KB
FWRITE DONE: ST 0x0000002822 hyp 19.96 KB
FWRITE DONE: ST 0x0000002C22 hypbak 19.96 KB
FWRITE DONE: ST 0x0000005834 splash 5.27 MB
FWRITE DONE: ST 0x0000040040 modem 44.52 MB
FWRITE DONE: ST 0x0000060C40 sec 80 Bytes
FWRITE DONE: ST 0x0000060C60 boot 9.95 MB
FWRITE DONE: ST 0x0000070C60 system 1.5 GB (Unsparsed Size)
FWRITE DONE: ST 0x0000370C60 persist 32 MB (Unsparsed Size)
FWRITE DONE: ST 0x0000380C60 cache 384 MB (Unsparsed Size)
FWRITE DONE: ST 0x0000440C60 recovery 11.47 MB
FWRITE DONE: ST 0x0000450C60 userdata 5.06 GB (Unsparsed Size)
FWRITE DONE: ST 0x0000000000 PrimaryGPT 17 KB
FWRITE DONE: ST 0x0000000021 BackupGPT 16.5 KB
FPATCH DONE: 13
FHSETD DONE: Ok
FHREST DONE: Ok
Done in: 11:50.113
Old 10-14-2016, 12:42   #567 (permalink)
4G Telecom's Avatar
Member: 2421242
Sonork: 100.1614558
Thanks Meter: 700
Motorola XT1022 Stuck On Motorola logo Solved By UFST
268435456
oem fb_mode_set
INFO Battery Low!!
Erasing modemst1
Erasing modemst2
INFO Battery Low!!
oem fb_mode_clear
All Done in 03:17.167
rebooting normally
Old 10-15-2016, 06:51   #568 (permalink)
profkefah's Avatar
Member: 2371500
Thanks Meter: 5,929
samsung SGH-T999L stuck on logo done by flashing
COM159: SAMSUNG Mobile USB Modem #22
SGH-T999L at USB (COM159) [LOKE]
PLATF: LOKE 00020000
PIT Read Done: 00:00
PIT Backup Saved as: SGH-T999L_Read.pit
File: T999LUVUBNC1_T999LTMBBNC1_T999LUVUBNC1_HOME.tar.md5
Partition: SBL2, Image: sbl2.mbn, Size: 0x0001FDC8 (130504)
Partition: SBL3, Image: sbl3.mbn, Size: 0x0004754C (292172)
Partition: ABOOT, Image: aboot.mbn, Size: 0x000D36D0 (866000)
Partition: RPM, Image: rpm.mbn, Size: 0x00021654 (136788)
Partition: TZ, Image: tz.mbn, Size: 0x0002FB40 (195392)
Partition: BOOT, Image: boot.img, Size: 0x0064F110 (6615312)
Partition: RECOVERY, Image: recovery.img, Size: 0x007B5110 (8081680)
Partition: SYSTEM, Image: system.img.ext4, Size: 0x54D5609C (1423270044)
Partition: MODEM, Image: non-hlos.bin, Size: 0x02A24700 (44189440)
Partition: CACHE, Image: cache.img.ext4, Size: 0x02D0D178 (47239544)
Flash Write Done: 15:23
Restart Done
The Following User Says Thank You to profkefah For This Useful Post:
Old 10-15-2016, 10:53   #569 (permalink)
Odia The Ultimate's Avatar
Member: 4042
Thanks Meter: 24,046
Before flashing, you should try wipe cache and data (factory reset) from phones recovery menu for stuck on logo problem.
Old 10-15-2016, 14:10   #570 (permalink)
profkefah's Avatar
Member: 2371500
Thanks Meter: 5,929
already did
same problem
stuck on logo
Page generated in 0.30846 seconds with 9 queries
