Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > UFST
Old 10-15-2016, 15:54   #571 (permalink)
profkefah's Avatar
Member: 2371500
Thanks Meter: 6,007
SAMSUNG G350E flashing done
COM159: SAMSUNG Mobile USB Modem #22
SM-G350E at USB (COM159) [LOKE]
PLATF: LOKE 00020000
PIT Read Done: 00:00
PIT Backup Saved as: SM-G350E_Read.pit
File: G350EXWU0ANF2_G350EOJV0ANF7_G350EXXU0ANF8_HOME.tar .md5
Partition: KERNEL, Image: boot.img, Size: 0x004DAC00 (5090304)
Partition: RECOVERY, Image: recovery.img, Size: 0x0061B400 (6403072)
Partition: system, Image: system.img, Size: 0x3590A9F0 (898673136)
Partition: modem, Image: sprdcp.img, Size: 0x003CECCC (3992780)
Partition: DSP, Image: sprddsp.img, Size: 0x001E0800 (1968128)
Partition: FIXNV2, Image: nvitem.bin, Size: 0x000292D4 (168660)
Partition: CSC, Image: cache.img, Size: 0x01D08110 (30441744)
Partition: HIDDEN, Image: hidden.img, Size: 0x007710F0 (7803120)
Flash Write Done: 03:47
Restart Done
The Following User Says Thank You to profkefah For This Useful Post:
Old 10-17-2016, 17:35   #572 (permalink)
Member: 2207555
Thanks Meter: 1,621
Smile
Samsung GT-B5512 Pattern Lock Removed Done Android UFST
Samsung GT-B5512 (Y Pro DS) at USB (COM84) [MODEM] {Factory Def.}
MODEMCON: OK
AT+FACTORST=0,0
+FACTORST:0
OK
Rehan
The Following User Says Thank You to rehansk8879 For This Useful Post:
Old 10-18-2016, 07:32   #573 (permalink)
4G Telecom's Avatar
Member: 2421242
Sonork: 100.1614558
Thanks Meter: 700
J500F Frp Reset Done
The Following 4 Users Say Thank You to 4G Telecom For This Useful Post:
Old 10-19-2016, 07:06   #574 (permalink)
4G Telecom's Avatar
Member: 2421242
Sonork: 100.1614558
Thanks Meter: 700
Lenovo A6000 Dead Boot Repair By UFST
The Following 3 Users Say Thank You to 4G Telecom For This Useful Post:
Old 10-19-2016, 07:24   #575 (permalink)
4G Telecom's Avatar
Member: 2421242
Sonork: 100.1614558
Thanks Meter: 700
Sony D2202 Flashing
Sony D2202 (Xperia E3 LTE Flamingo) at USB Auto Select [S1] {Write Flash}
Files to Flash: 12
GGSOMC Drivers not Installed -1, Will try GGSEMC
BL VERS : S1_Boot_MSM8x26_LA1.0_315
BL PKTSZ: 0x00010000
BL IMEI : 356044-06-033438-8
BL ROOTS: ROOTABLE
TA MODEL: D2202
TA DEVSN: MQ4815D26770
TA CDVER: 1287-4608_R7B
TA SWVER: 1286-1545_18.5.A.0.26
TA FLVER: GLOBAL-HSPA_18.5.A.0.26
Loader Boot Done in 00:00.827
FL VERS : LOADER_RELEASE_MSM8X26_32_AID_4
FL PKTSZ: 0x00080000
FL IMEI : 356044-06-033438-8
TA MODEL: D2202
TA S1VER: 1274-7024 S1_Boot_MSM8x26_LA1.0_315
AT PLFRT: B77943D5B24F7012CB12EB2FF857C69EAA6518C0E58957AA70 C0B0590E1F3BCA
AT OTLCK: LOCKED
AT OTDAT: 01000400
AT IDCOD: 108000E1
Writing File: amss_fs_1_S1-MODEMSW-LIVE-F82D-PID1-0005-MMC.sin
File Write Done in 00:00.359 + 00:00.484
Writing File: amss_fs_2_S1-MODEMSW-LIVE-F82D-PID1-0005-MMC.sin
File Write Done in 00:00.359 + 00:00.499
Writing File: amss_fsg_S1-MODEMSW-LIVE-F82D-PID1-0005-MMC.sin
File Write Done in 00:00.031 + 00:00.031
Writing File: cache_S1-SW-LIVE-F82D-PID1-0005-MMC.sin
File Write Done in 00:00.749 + 00:00.842
Writing File: elabel-D2202-row_201409051745.1_18.5.A.0.26_S1-ELABEL-LIVE-F82D-PID1-0004-MMC.sin
File Write Done in 00:02.122 + 00:02.168
Writing File: fotakernel_S1-SW-LIVE-F82D-PID1-0005-MMC.sin
File Write Done in 00:01.607 + 00:01.794
Writing File: kernel_S1-SW-LIVE-F82D-PID1-0005-MMC.sin
File Write Done in 00:01.622 + 00:01.950
Writing File: partition-image_S1-SW-LIVE-F82D-PID1-0005-MBR.sin
File Write Done in 00:00.031 + 00:00.015
Writing File: system_S1-SW-LIVE-F82D-PID1-0005-MMC.sin
File Write Done in 02:54.863 + 02:33.544
Writing File: userdata_S1-SW-LIVE-F82D-PID1-0005-MMC.sin
File Write Done in 00:16.865 + 00:15.785
Writing File: cust-reset.ta
File Write Done in 00:00.110
Writing File: fota-reset.ta
File Write Done in 00:00.078
All Done in 06:39.200
Old 10-24-2016, 06:26   #576 (permalink)
4G Telecom's Avatar
Member: 2421242
Sonork: 100.1614558
Thanks Meter: 700
J2 Unlock Done
The Following 2 Users Say Thank You to 4G Telecom For This Useful Post:
Old 10-24-2016, 08:31   #577 (permalink)
Member: 2298369
Thanks Meter: 441
J500f frp lock remove
J500F FRP LOCK REMOVE-
Samsung SM-J500F (J5 LTE) at USB (COM59) [LOKE FLASH] {Reset FRP}
Reset FRP Done in: 00:01.000
Restart Done
The Following 3 Users Say Thank You to galaxycompue For This Useful Post:
Old 10-24-2016, 15:22   #578 (permalink)
profkefah's Avatar
Member: 2371500
Thanks Meter: 6,007
Nokia 107 RM-961 RESET SCREEN LOCK DONE
HI
Nokia 107 RM-961
If used non Auto-Ignition cable, press Power-On button
IF_SBL: XGOLD110, Ok
IF_EBL: Default_RAM_Bootloader 10.24, Mode: CC
BAUD_R: 3000000
FL_ID : 20000488, Numonyx M36L0R7040U 128Mb
ShutDown Done
Rebooting Mobile
MCU SW : V 02.90 22-10-13 RM-961 (c) Nokia
PPM SW : V 02.90 22-10-13 RM-961 (c) Nokia IC
Platform: Infineon XG110
Prd.Code: 059T2B8
Bpr.Code: 059S7H7
Prod.Sn : F124F38BI
HW Vers : 2700
UEM : 1328
UPP : 8850 [2292]
LCD Type: WIN:BOHAIv93 NT39121
IMEI : 352360909000009090
SL Conf : 001-01-00000000000
SL Prof : 000000000004000-2
SL Var : 00003523600633619200
SL Aux : 000B0000
HW Sig : A0BD2FAAFFC0AC4B
Box Id : FFFFFFFFFFFFFFFF
BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
Provider: GSM Test Equipment
Set UI Defaults ...
UI Defaults Failed
Set UI Factory Defaults ...
Set UI Factory Defaults Failed
Init Local Mode Ok, Time: 00:24
Set Security 12345 ...
Set Security Ok, Time: 00:00
Set UI Defaults ...
UI Defaults Failed
Set Security Failed
Set Full Factory Defaults ...
Set Full Factory Defaults Ok, Time: 00:01
Set UI Factory Defaults Ok, Time: 00:00
Set UI Defaults ...
UI Defaults Ok, Time: 00:01
Old 10-25-2016, 11:10   #579 (permalink)
Member: 2470467
Sonork: QQ 2836977761
Thanks Meter: 51
Smile Sony Xperia E1 Pattern Lock Removed with UFST
Sony D2005 (Xperia E1 3G Falcon) at USB [FASTBOOT] {Read FB Info}
version: 0.5
version-bootloader: 1276-2682 S1_Boot_MSM8x10_0.45
version-baseband: 1277-8886_20.1.A.2.13
serialno: 6584cece
Sony D2005 (Xperia E1 3G Falcon) at USB Auto Select [S1] {Write Flash}
Files to Flash: 1
BL VERS : S1_Boot_MSM8x10_0.45
BL PKTSZ: 0x00080000
BL IMEI : 355628-06-162997-7
BL ROOTS: ROOTABLE
TA MODEL: D2005
TA DEVSN: 6584cece
TA CDVER: 1280-4646_R1B
TA SWVER: 1277-8886_20.1.A.2.13
TA FLVER: WORLD-i_20.1.A.2.13
Loader Boot Done in 00:00.555
FL VERS : MSM8X10_12
FL IMEI : 355628-06-162997-7
TA MODEL: D2005
TA DEVSN: 6584cece
TA S1VER: 1276-2682 S1_Boot_MSM8x10_0.45
TA FTIME: 2016-10-25 10:08:39
AT PLFRT: 5A93232B8EF5567752D0CB5554835215D1C473502E6F1052A78A6715B8B659AA
AT OTLCK: LOCKED
AT OTDAT: 01000400
AT IDCOD: 108110E1
Writing File: userdata.sin
File Write Done in 00:04.448 + 00:07.016
All Done in 00:34.748
Real ASH
The Following User Says Thank You to Real ASH For This Useful Post:
Old 10-25-2016, 12:13   #580 (permalink)
Member: 1625192
Sonork: 100.1657037
Thanks Meter: 256
Samsung SM-G928F (S6 Edge Plus)
Samsung S6 Edge Plus G928F Unlock Done By UFST
Without Root................
Samsung SM-G928F (S6 Edge Plus) at USB (COM39) [MODEM] {Unlock}
MODEMCON: OK
SERIALNR: R58H10JY76E
Unlock Done in: 00:02.902, Reboot Product to See Changes
By
ios.hasan
The Following 2 Users Say Thank You to hasan99 For This Useful Post:
Old 10-28-2016, 04:08   #581 (permalink)
dyo
dyo's Avatar
Member: 768985
Sonork: 100.1676685
Thanks Meter: 609
Kata i3l mt6735 FRP reset Done
The first phone I remove the FRP look here are the logs from UFSTurbo
MTK MT6735 () at USB Auto Select [MTK] {Reset FRP}
DA Agent : MTK_AllInOne_DA.bin
BR ComPort: COM52
BR Asic Id: MT0335 [0000] >> MT6735
BR Asic Sw: 8A00 CA00 0000 0000
DA Version: MTK_AllInOne_DA_v3.3001.00.00
PR MMC CID: 5100011541535838C41C064293B8E3DA [ASX8]
PR Version: 4.2 [0x93] (5)
eMMC BOOT1: 0x0000000000400000 [4.194.304]
eMMC BOOT2: 0x0000000000400000 [4.194.304]
eMMC RPMB : 0x0000000000400000 [4.194.304]
eMMC USER : 0x00000003A3E00000 [15.634.268.160]
eMMC CID : 150100513858534142061CC4DAE39293 [Q8XSAB]
ERAM Size : 0x0000000040000000 [1.073.741.824]
IRAM Size : 0x0000000000020000 [131.072]
UNICAL ID : D302CC7165D8625E2923459AFBF8021F
PMT (GPT) Found : 25 Partition Entries
Reset FRP Done in: 00:04.246
DA Shutdown Done, Disconnect Cable
Best Regards
Dyo
The Following User Says Thank You to dyo For This Useful Post:
Old 10-28-2016, 04:11   #582 (permalink)
dyo
dyo's Avatar
Member: 768985
Sonork: 100.1676685
Thanks Meter: 609
Kata i3l frp remove done
BR ComPort: COM52
Best regards and more power
Old 11-02-2016, 13:33   #583 (permalink)
Member: 2298369
Thanks Meter: 441
icromax yu-4711 flash sucessfully
yu-4711 flash very easy by ufst, it hang on logo=
Use [FH] Button to select Flash Program .xml
Var YU-YU4711 (Yunique LTE DS) at USB (COM59) [SAHARA] {Write Flash}
Flash Bundle: rawprogram0.xml
SAHARA VERS: 2
SAHARA PROG: prog_emmc_firehose_8916_yu.mbn
FHPROG SZFT: 0
FHPROG SZTT: 0
FHPROG SPTT: 0
FHPROG XSIZ: 0
FHPROG VERS:
FHPROG PLTF:
FHPROG MEMT:
Partitions to Write: 96 (1.43 GB)
FHPROG Write Fail: -1
FHREST DONE: Ok
SAHARA VERS: 2
SAHARA Config Fail: -2
SAHARA Connect Fail: -3
Qualcomm HS-USB QDLoader 9008 Port not Found: Vid_05c6&Pid_9008
Var YU-YU4711 (Yunique LTE DS) at USB (COM4) [SAHARA] {Write Flash}
SAHARA VERS: 2
FHPROG SZFT: 4096
FHPROG SZTT: 16384
FHPROG SPTT: 16384
FHPROG XSIZ: 4096
FHPROG VERS: 1
FHPROG PLTF: 8916
FHPROG MEMT: eMMC
FHINFO PAR0: 15269888 x 512 Sectors (7.28 GB)
FHINFO PAR1: 8192 x 512 Sectors (4 MB)
FHINFO PAR2: 8192 x 512 Sectors (4 MB)
FWRITE DONE: ST 0x0000020000 modem 50.81 MB
FWRITE DONE: ST 0x0000040012 sbl1 251.15 KB
FWRITE DONE: ST 0x0000040412 sbl1bak 251.15 KB
FWRITE DONE: ST 0x0000040812 rpm 151.47 KB
FWRITE DONE: ST 0x0000040C12 rpmbak 151.47 KB
FWRITE DONE: ST 0x0000041012 tz 476.31 KB
FWRITE DONE: ST 0x0000041412 tzbak 476.31 KB
FWRITE DONE: ST 0x0000041812 hyp 56 KB
FWRITE DONE: ST 0x0000041C12 hypbak 56 KB
FWRITE DONE: ST 0x0000043812 splash 2.64 MB
FWRITE DONE: ST 0x0000048812 persist 4.57 MB
FWRITE DONE: ST 0x0000060C60 aboot 486.13 KB
FWRITE DONE: ST 0x0000061460 abootbak 486.13 KB
FWRITE DONE: ST 0x0000061C60 boot 7.51 MB
FWRITE DONE: ST 0x0000071C60 recovery 8.36 MB
FWRITE DONE: ST 0x0000082460 system 128.01 MB
FWRITE DONE: ST 0x00000C2868 system 8 KB
FWRITE DONE: ST 0x00000C37B0 system 125.58 MB
FWRITE DONE: ST 0x0000102460 system 8 KB
FWRITE DONE: ST 0x00001033A8 system 126.09 MB
FWRITE DONE: ST 0x0000142460 system 8 KB
FWRITE DONE: ST 0x0000142868 system 8 KB
FWRITE DONE: ST 0x00001437B0 system 125.58 MB
FWRITE DONE: ST 0x0000182460 system 8 KB
FWRITE DONE: ST 0x00001833A8 system 126.09 MB
FWRITE DONE: ST 0x00001C2460 system 8 KB
FWRITE DONE: ST 0x00001C2868 system 8 KB
FWRITE DONE: ST 0x00001C37B0 system 125.58 MB
FWRITE DONE: ST 0x0000202460 system 8 KB
FWRITE DONE: ST 0x00002033A8 system 126.09 MB
FWRITE DONE: ST 0x0000242460 system 8 KB
FWRITE DONE: ST 0x0000242868 system 8 KB
FWRITE DONE: ST 0x00002437B0 system 125.58 MB
FWRITE DONE: ST 0x0000282460 system 8 KB
FWRITE DONE: ST 0x00002833A8 system 126.09 MB
FWRITE DONE: ST 0x00002C2460 system 8 KB
FWRITE DONE: ST 0x00002C2868 system 8 KB
FWRITE DONE: ST 0x00002C37B0 system 125.58 MB
FWRITE DONE: ST 0x0000302460 system 8 KB
FWRITE DONE: ST 0x00003033A8 system 26.33 MB
FWRITE DONE: ST 0x0000342460 system 8 KB
FWRITE DONE: ST 0x0000382460 system 8 KB
FWRITE DONE: ST 0x00003C2460 system 8 KB
FWRITE DONE: ST 0x0000402460 system 8 KB
FWRITE DONE: ST 0x0000442460 system 8 KB
FWRITE DONE: ST 0x00004433A8 system 23.09 MB
FWRITE DONE: ST 0x0000460000 cache 6.09 MB
FWRITE DONE: ST 0x00004A0000 cache 8 KB
FWRITE DONE: ST 0x00004A0088 cache 8 KB
FWRITE DONE: ST 0x00004E9000 config 512 KB
FWRITE DONE: ST 0x0000509400 userdata 73.4 MB
FWRITE DONE: ST 0x0000549400 userdata 8 KB
FWRITE DONE: ST 0x0000549D08 userdata 8 KB
FWRITE DONE: ST 0x0000589400 userdata 8 KB
FWRITE DONE: ST 0x00005C9400 userdata 8 KB
FWRITE DONE: ST 0x00005C9D08 userdata 8 KB
FWRITE DONE: ST 0x0000609400 userdata 8 KB
FWRITE DONE: ST 0x0000649400 userdata 8 KB
FWRITE DONE: ST 0x0000649D08 userdata 8 KB
FWRITE DONE: ST 0x0000689400 userdata 8 KB
FWRITE DONE: ST 0x00006C9400 userdata 8 KB
FWRITE DONE: ST 0x00006C9D08 userdata 8 KB
FWRITE DONE: ST 0x0000709400 userdata 8 KB
FWRITE DONE: ST 0x0000749400 userdata 8 KB
FWRITE DONE: ST 0x0000749D08 userdata 8 KB
FWRITE DONE: ST 0x0000789400 userdata 8 KB
FWRITE DONE: ST 0x00007C9400 userdata 8 KB
FWRITE DONE: ST 0x0000809400 userdata 8 KB
FWRITE DONE: ST 0x0000849400 userdata 8 KB
FWRITE DONE: ST 0x0000889400 userdata 8 KB
FWRITE DONE: ST 0x00008C9400 userdata 8 KB
FWRITE DONE: ST 0x0000909400 userdata 8 KB
FWRITE DONE: ST 0x0000949400 userdata 8 KB
FWRITE DONE: ST 0x0000989400 userdata 8 KB
FWRITE DONE: ST 0x00009C9400 userdata 8 KB
FWRITE DONE: ST 0x0000A09400 userdata 8 KB
FWRITE DONE: ST 0x0000A49400 userdata 8 KB
FWRITE DONE: ST 0x0000A89400 userdata 8 KB
FWRITE DONE: ST 0x0000AC9400 userdata 8 KB
FWRITE DONE: ST 0x0000B09400 userdata 8 KB
FWRITE DONE: ST 0x0000B49400 userdata 8 KB
FWRITE DONE: ST 0x0000B49D08 userdata 8 KB
FWRITE DONE: ST 0x0000B89400 userdata 8 KB
FWRITE DONE: ST 0x0000BC9400 userdata 8 KB
FWRITE DONE: ST 0x0000BC9D08 userdata 8 KB
FWRITE DONE: ST 0x0000C09400 userdata 8 KB
FWRITE DONE: ST 0x0000C49400 userdata 8 KB
FWRITE DONE: ST 0x0000C89400 userdata 8 KB
FWRITE DONE: ST 0x0000CC9400 userdata 8 KB
FWRITE DONE: ST 0x0000D09400 userdata 8 KB
FWRITE DONE: ST 0x0000D49400 userdata 8 KB
FWRITE DONE: ST 0x0000D89400 userdata 8 KB
FWRITE DONE: ST 0x0000DC9400 userdata 8 KB
FWRITE DONE: ST 0x0000DCA3B0 userdata 108 KB
FWRITE DONE: ST 0x0000000000 PrimaryGPT 17 KB
FWRITE DONE: ST 0x0000000021 BackupGPT 16.5 KB
FPATCH DONE: 13
FHSETD DONE: Ok
FHREST DONE: Ok
Done in: 04:21.223
The Following 2 Users Say Thank You to galaxycompue For This Useful Post:
Old 11-03-2016, 06:49   #584 (permalink)
dyo
dyo's Avatar
Member: 768985
Sonork: 100.1676685
Thanks Meter: 609
Samsung J100 unlock done single click adb unlock logs
Samsung SM-J100ML (J1 3G DS) at USB (COM54) [MODEM] {Kies Info}
MODEMCON: OK
MODEL : SM-J100ML
PRODCODE: SM-J100MZWJXTE
HIDVERS : J100MLDXU0AOJ4/J100MLOLC0AOJ4/J100MLDXU0AOJ4/J100MLDXU0AOJ4
SERIALNR: R21G942MXDD
CONNECT : AT,MTP,MTP
LOCKSTAT: DEVICE
UNICALID: CNJ00B55EF2AA92
SW VERS : J100MLDXU0AOJ4/J100MLOLC0AOJ4/J100MLDXU0AOJ4/J100MLDXU0AOJ4
IMEI 1 : 358111-06-966DYO-7
Samsung SM-J100ML (J1 3G DS) at USB (COM54) [MODEM] {Unlock}
MODEMCON: OK
Lock Keys Reset to:
MCK : 12345678
NCK : 12345678
NSCK: 12345678
SPCK: 12345678
CPCK: 12345678
SIM : 12345678
Unlock Done in: 00:18.957
Old 11-03-2016, 13:51   #585 (permalink)
DZcondor's Avatar
Member: 2516015
Thanks Meter: 100
Flashing Done LG D851
KDZ File: D85120E_00.kdz, Type 2, Size: 1.286.137.756 Bytes
File: LGUP_8974.dll, Size: 1.568.256 Bytes
Saved as: D85120E_00_LGUP_8974.dll
File Description: LG-D851
File: D85120e, Size: 1.284.568.180 Bytes
Saved as: D85120E_00_D85120e.dz
KDZ Extract Done in: 00:24.105
File: D85120E_00_D85120e.dz
File Format: DZ Type 2
Model: LG-D851 File: D85120e Partitions {Chunks): 40
RbId: user
Partitions (Chunks) to Flash: 40 (1.94 GB)
LG D851 (G3) at USB (COM22) [LG FLASH 5] {Write Flash}
DL MODE : 2
DL REQM : 5
DL MODEL: LG-D851
DL SWVER: D85120g
DL IMEI : 014088-00-288342-8
LF MODEL: LG-D851
LF SERNO: LGD85198ea1605
LF SWVER: LGD851AT-00-V20g-TMO-US-AUG-15-2015+0
LF MINOS: MiniOS 3.0
LF OSVER: 5.0.1
LF IMEI : 014088-00-288342-8
LF DVPID: SM08S150131000581
LF SOCTY: msm8974
LF CABLE: USER
Writing Partition: PrimaryGPT
Writing Partition: modem
Writing Partition: sbl1
Writing Partition: dbi
Writing Partition: aboot
Writing Partition: rpm
Writing Partition: tz
Writing Partition: boot
Writing Partition: persist
Writing Partition: recovery
Writing Partition: rct
Writing Partition: laf
Writing Partition: factory
Writing Partition: system
Writing Partition: BackupGPT
Flash Write Done in: 02:30.382
LF CLOSE: 0k
RESTART : 2
The Following User Says Thank You to DZcondor For This Useful Post:
Page generated in 0.26670 seconds with 9 queries
