Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > UFST
Old 06-15-2017, 13:21   #781 (permalink)
Member: 2185549
Thanks Meter: 535
INFINIX X553 IMEI REPAIR DONE FAIL WITH OTHERS
None of Diags Ports Selected
Var INFINIX-X553-W82918-A1 (Hot 3 LTE DS) at USB [ADB] {ADB Info}
List of devices attached 5ef1cee3 device
BOOTSERN: 5ef1cee3
PRDBRAND: INFINIX
PRDMODEL: Infinix HOT 3 LTE
PRDNAME : INFINIX-X553
BLDVERS : 5.1.1
BLDDISID: X553-W82918-A2-L-20160604
BLDPROD : INFINIX-X553
PRODBRD : msm8916
BRDPLATF: msm8916
HARDWARE: qcom
USB CNFG: mtp,adb
MMC1 CID: 150100513832334d42005ef1cee33300
Superuser Permissions Denied
Var INFINIX-X553-W82918-A1 (Hot 3 LTE DS) at USB [ADB] {Enable Diags}
Normally to Enable Diags Need Root Rights, but Some (LG) works Without
Diags Enabled
BOOTSERN: 5ef1cee3
PRDBRAND: INFINIX
BLDVERS : 5.1.1
PRODBRD : msm8916
BRDPLATF: msm8916
HARDWARE: qcom
USB CNFG: mtp,adb
Superuser Permissions Granted (SU)
Diags Enabled
Var INFINIX-X553-W82918-A1 (Hot 3 LTE DS) at USB (COM117) [DIAGS] {Diags Info}
OFFLMODE: OK
MDMVERSN: Mar 10 201618:49:04Jan 07 201622:00:00FAAAANUZ
MDMBUILD: MPSS.DPM.2.0.2.c1.20-00005-M8936FAAAANUZM-1
NV IMEI1: 356603-07-229792-3
NV IMEI2: 356603-07-229793-1
NV BTID : A4441:6C9CDD
NV WIFI : DE9C:6C144A4
Var INFINIX-X553-W82918-A1 (Hot 3 LTE DS) at USB (COM117) [DIAGS] {Gen.Settings}
OFFLMODE: OK
Var INFINIX-X553-W82918-A1 (Hot 3 LTE DS) at USB (COM117) [DIAGS] {Factory Info}
OFFLMODE: OK
NV IMEI1: 359880-51-247951-2
NV IMEI2: 359880-51-247953-8
The Following 2 Users Say Thank You to ferouz kassim For This Useful Post:
Old 06-17-2017, 14:25   #782 (permalink)
bouali2009's Avatar
Member: 520537
Thanks Meter: 230
Thumbs up Vega tab - 4G Q8 4G_elink8735b flash done with UFS V1.0.5.5 Test5
UFS V1.0.5.5 Test5
The Following User Says Thank You to bouali2009 For This Useful Post:
Old 06-17-2017, 23:48   #783 (permalink)
profkefah's Avatar
Member: 2371500
Thanks Meter: 5,836
Samsubg A310f 6.0.1 frp remove done
hi
first flash phone with this firmware
COMBINATION_FAC_FA51_A310FXXU3AQC1_FAC3AQC1_CL6964 464_QB13042963_REV00_user_mid_noship.tar.md5
u will get factory binary
enable usb debug
a310FXXU3BQC2
then when phone show language list do fp reset adb mode by box
then phone will pass to application
enable oem unlock and do factory reset
specail thank to allumts
for guide
if post was useful press thanks bottun
The Following User Says Thank You to profkefah For This Useful Post:
Old 06-20-2017, 12:20   #784 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,377
LG E420 Flashing
File: LGE420AT-00-V10g-ESA-XX-DEC-16-2014+0.dz
File Format: TOT Type FFFFFFFF [LGE420]
Partitions (Chunks) to Flash: 12 (1 GB)
LG E420 (L1 II DS) at USB (COM63) [LG FLASH 1] {Write Flash}
DL MODE : 2
SW VERS : LGE420-00-V10b-ESA-XX-AUG-23-2013+0
DL VERS : BS/LGE420/7D
DL DLRQ : 2
DL IMEI1: 357675-05-042107-0
DL DVPID: CY13S130918002990
MEMPARMS: 3.61 GB in 512 Byte Blocks
Writing Partition 02: QCSBL
Writing Partition 03: OEMSBL
Writing Partition 04: EXT
Writing Partition 05: APPSSBL
Writing Partition 09: APPS
Writing Partition 12: MODEM
Writing Partition 13: MODEM_BACKUP
Writing Partition 14: SYSTEM
Writing Partition 15: PERSIST
Writing Partition 17: RECOVERY
Writing Partition 22: BOOT_LOGO_IMAGE
Writing Partition 25: CUST
RESTART : 2
Flash Write Done in: 05:36.719
Old 06-21-2017, 19:08   #785 (permalink)
Remco's Avatar
Member: 334
Thanks Meter: 120
Sony Z5 Compact FRP done
I try to remove the FRP lock from the Sony Z5 compact (E5823) and had succes!
TA FLVER: GENERIC_32.2.A.5.11
Loader Boot Done in 00:00.354
FL VERS : MSM8994_50
FL PKTSZ: 0x00400000
FL IMEI : 111111-07-932788-4
TA MODEL: E5823
TA DEVSN: CB5A2B1N85
TA CDVER: 1299-7245_R5C
TA SWVER: 1295-6639_32.2.A.5.11
TA S1VER: 1289-5620 S1_Boot_MSM8994_LA1.2.2_42B
AT PLFRT: F421B16FFDD52124A7107C2156B6C478355991BC9D88F0F868 2CD08F127A0FA5
AT OTLCK: LOCKED
AT OTDAT: 01000400
AT IDCOD: 109400E1
Writing File: userdata_S1-SW-LIVE-F936-PID1-0006-MMC.sin
File Write Done in 00:05.327 + 00:24.786
All Done in 00:43.130
Sony E5823 (Xperia Z5 Compact LTE Suzuran) at USB [ADB] {Reset FRP}
daemon started successfully * CB5A2B1N85 device
Goto "Backup and reset" Menu and make "Factory data reset"
I try to flash userdata file but this was not working and i found here a way to enable the ADB on this phone.
http://forum.gsmhosting.com/vbb/12419182-post1.html
I love this box!
The Following 5 Users Say Thank You to Remco For This Useful Post:
Old 06-29-2017, 10:17   #786 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,428
Huawei Y5-II CUN-L01 FRP removed !!
Hi like in topic frp removed without problem.
Huawei CUN-L01 (Y5 II LTE) at USB Auto Select [MTK] {Reset FRP}
BR USB Com: Vid_0e8d&Pid_2000
DA Agent : DA_SWSEC_HUA_1.bin
BR ComPort: COM8
BR Asic Id: MT0321 [0000] >> MT6735
BR Asic Sw: 8A00 CA00 0000 0000
DA Version: MTK_AllInOne_DA_v3.3001.00.00
PR MMC CID: 460001154D32314E65DB064239B2C9EE [M21Ne]
PR Version: 4.2 [0x93] (5) MT6735
eMMC BOOT1: 0x0000000000400000 [4.194.304]
eMMC BOOT2: 0x0000000000400000 [4.194.304]
eMMC RPMB : 0x0000000000080000 [524.288]
eMMC USER : 0x00000001D2000000 [7.818.182.656]
eMMC CID : 150100464E31324D4206DB65EEC99339 [FN12MB]
ERAM Size : 0x0000000040000000 [1.073.741.824]
IRAM Size : 0x0000000000020000 [131.072]
UNICAL ID : 938F55FB6187A41129A2CC75E5E3CBC1
PMT (GPT) Found : 28 Partition Entries
Reset FRP Done in: 00:03.160
DA Shutdown Done, Disconnect Cable
__________________
Please do not Personal Message me for help or troubleshooting. They will be ignored. Use the forums!
To get Instant help use "search" & follow "sticky thread"..!!!
By respecting/following forum rules,You will be respected .!
The Following 4 Users Say Thank You to wgmmmx1 For This Useful Post:
Old 06-29-2017, 10:20   #787 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,428
Alcatel 5045X FRP removed without problem
Like in topic frp removed without any problem
Alcatel 5045X (Pixi 4-5 4G LTE) at USB Auto Select [MTK] {Reset FRP}
DA Agent : MTK_AllInOne_DA.bin
BR ComPort: COM8
BR Asic Id: MT0335 [0000] >> MT6735
PR MMC CID: 504E01FE35394A31F742124BA95041A9 [59J1]
PR Version: 4.2 [0x9B] (5) MT6737T
eMMC BOOT1: 0x0000000000200000 [2.097.152]
eMMC BOOT2: 0x0000000000200000 [2.097.152]
eMMC RPMB : 0x0000000000200000 [2.097.152]
eMMC USER : 0x00000001D3000000 [7.834.959.872]
eMMC CID : FE014E50314A39354B1242F7A94143A9 [P1J95K]
UNICAL ID : E951E9C4AD4C2A1D61B895962342BDC1
Reset FRP Done in: 00:06.357
__________________
The Following 2 Users Say Thank You to wgmmmx1 For This Useful Post:
Old 07-12-2017, 15:07   #788 (permalink)
ddilshod93's Avatar
Member: 2082192
Sonork: not
Thanks Meter: 1,119
HTC Desire 616 Dual sim Repair IMEI done!
MTK MT6592 (eMMC) at META {Gen.Settings}
ME USB Com: Vid_0e8d&Pid_2007
ME_MCUID: MT6592,S01
ME_MODEL: SW_G98518A2_V019_M10_HTC_V3DUG_ASIA_MP
ME_BLDAT: Tue Sep 23 21:02:23 CST 2014
ME_CHIPS: MT6592, E00
ME_DSPFW: 2000.00.00
ME_DSPPT: 1.0
ME_BOARD: WINGTECH92_WET_JB9_HSPA_HW
ME_SWVER: MOLY.WR8.W1315.MD.WG.MP.V21.P30
ME_MLVER: Unknown
ME_SERNR: Empty
ME_IMEI1: ---
ME_IMEI2: ---
Gen.Settings Write Done: 3 Item(s)
ME_DSPPT: 1.0
ME_MLVER: Unknown
ME_SERNR: R123456789SZ
ME_IMEI1: 357753-06-145894-2
ME_IMEI2: 357753-07-145894-0
MTK MT6592 (eMMC) at META {Exit META}
ME_METAX: Disconnected
The Following 3 Users Say Thank You to ddilshod93 For This Useful Post:
Old 07-13-2017, 13:22   #789 (permalink)
ddilshod93's Avatar
Member: 2082192
Sonork: not
Thanks Meter: 1,119
Lenovo TB2-X30L (Tab 2 A10-30 LTE) FRP Reset one sec done
Lenovo TB2-X30L (Tab 2 A10-30 LTE) at USB [ADB] {Reset FRP}
Lenovo TB2-X30L (Tab 2 A10-30 LTE) at USB [ADB] {ADB Info}
daemon started successfully * HA0MFXF9 device
BOOTSERN: caa3f2ee
PRDBRAND: Lenovo
PRDMODEL: Lenovo TB2-X30L
PRDNAME : TB2-X30L
BLDVERS : 5.1.1
BLDDISID: TB2-X30L_S000031_160720_ROW
BLDPROD : msm8909
PRODBRD : TB2-X30L
BRDPLATF: msm8909
HARDWARE: qcom
USB CNFG: mtp,adb
MMC1 CID: 150100513832334d4200caa3f2ee4300
The Following User Says Thank You to ddilshod93 For This Useful Post:
Old 07-26-2017, 10:37   #790 (permalink)
Member: 2185549
Thanks Meter: 535
OOTSERN: ZX1F23D87C
PRDBRAND: motorola
PRDMODEL: XT1254
PRDNAME : quark_verizon
BLDVERS : 6.0.1
BLDDISID: MCG24.251-5-5
BLDPROD : quark
PRODBRD : APQ8084
BRDPLATF: apq8084
HARDWARE: qcom
PROD CID: 0x2
USB CNFG: usbnet,adb
MMC1 CID: 1501004d42473447430ba6fcbe3f1200
Motorola XT1254 (Droid Turbo LTE Quark) at USB [ADB] {Reset FRP}
daemon started successfully * ZX1F23D87C device
used another tool to enable its adb and used ufst to reset frp used cm2 to enable adb if ufst could figure out a way to enable its own adb using its own interface it would be great tool cm2 enabled but couldnt reset frp so used two tools to get job done
The Following User Says Thank You to ferouz kassim For This Useful Post:
Old 07-27-2017, 11:06   #791 (permalink)
Member: 2185549
Thanks Meter: 535
Lenovo a6000 qualcom imei repair done by ufst
lenovo a6000 (a6000 lte ds) at usb [adb] {read efs}
daemon started successfully * 26675753 device
superuser permissions granted (su)
transfered: 5884 kb/s (1048576 bytes in 0.174s)
saved as: A6000_lenovoa6000_26675753_efs_ [2017_07_27_13_02_30].bin
transfered: 161 kb/s (16384 bytes in 0.099s)
saved as: A6000_lenovoa6000_26675753_ef1_ [2017_07_27_13_02_30].bin
transfered: 6046 kb/s (1572864 bytes in 0.254s)
saved as: A6000_lenovoa6000_26675753_nv1_ [2017_07_27_13_02_30].bin
transfered: 5930 kb/s (1572864 bytes in 0.259s)
saved as: A6000_lenovoa6000_26675753_nv2_ [2017_07_27_13_02_30].bin
transfered: 5752 kb/s (1572864 bytes in 0.267s)
saved as: A6000_lenovoa6000_26675753_nv3_ [2017_07_27_13_02_30].bin
path: C:\program files\sarassoft\ufs\ufs_sams\android_ufs_1055_test 9\a6000\efs\
done in: 00:06.526
lenovo a6000 (a6000 lte ds) at usb (com291) [diags] {read envm}
offlmode: Ok
set spc password: 000000, ok
mdmversn: Mar 10 201512:02:03feb 10 201512:00:00eaaaanuz
mdmbuild: Dpm.1.0.c7.18-00021-m8916eaaaanuzm-s86518c1-v18
nv imei1: 868143-02-814121-5
get names gn protected_node: /.efs_private
get names gn protected_node: /nvm
get names gn protected_node: /safe
efs2 read found: 806 file(s), 0 link(s)
efs2 read done : 806 file(s), time: 00:15.641
nvm_sim_2 read done: Start 0, 1 active item(s), time: 00:28.288
nvm_sim_1 read done: Start 0, 22 active item(s), time: 00:28.192
nvm read done: Start 0, 667 active item(s), time: 00:26.904
saved as: Lenovo_a6000_868143-02-814121-5_0f [2017_07_27_13_04_22].envm
path: C:\program files\sarassoft\ufs\ufs_sams\android_ufs_1055_test 9\a6000\nvm\
lenovo a6000 (a6000 lte ds) at usb (com291) [diags] {factory info}
offlmode: Ok
nv imei2: 868143-02-814122-3
nv btid : E02c:b2:e869b5
nv wifi : B569:f9:b22ce0
nv sernr: Empty
lenovo a6000 (a6000 lte ds) at usb (com291) [diags] {gen.settings}
offlmode: Ok
nv sernr: Empty
gen.settings write done: 2 item(s)
offlmode: Ok
nv imei1: 359880-05-124576-1
nv imei2: 359880-05-124576-1
nv sernr: Empty
The Following 3 Users Say Thank You to ferouz kassim For This Useful Post:
Old 07-27-2017, 12:03   #792 (permalink)
4G Telecom's Avatar
Member: 2421242
Sonork: 100.1614558
Thanks Meter: 700
Redmi 1S Dead flashing done
Var XIAOMI-Redmi 1s ****** (Redmi 1s LTE DS) at Auto Select Flashing Port [SAHARA] {Write Flash}
QDL USB Com: Vid_05c6&Pid_9008 (COM4)
Flash Bundle: rawprogram0.xml
SAHARA VERS: 2
SAHARA PROG: prog_emmc_firehose_8x26.mbn
FHPROG SZFT: 4096
FHPROG SZTT: 49152
FHPROG SPTT: 49152
FHPROG XSIZ: 4096
FHPROG VERS: 1
FHPROG PLTF: 8x26
FHPROG MEMT: eMMC
FHINFO PAR0: 0 x 512 Sectors (0 Bytes)
FHINFO PAR1: 8192 x 512 Sectors (4 MB) Default
FHINFO PAR2: 8192 x 512 Sectors (4 MB) Default
FHPROG PART: EFI GPT
FHPROG PRTY: 4
Partitions to Write: 18 (989.65 MB)
FWRITE DONE: ST 0x0000000022 sbl1 246.72 KB
FWRITE DONE: ST 0x0000001000 sbl1bak 246.72 KB
FWRITE DONE: ST 0x0000001FDE rpm 147.61 KB
FWRITE DONE: ST 0x00000027DE rpmbak 147.61 KB
FWRITE DONE: ST 0x0000002FDE tz 349.07 KB
FWRITE DONE: ST 0x00000037DE tzbak 349.07 KB
FWRITE DONE: ST 0x0000003FEE sdi 11.52 KB
FWRITE DONE: ST 0x0000004FEE aboot 1.11 MB
FWRITE DONE: ST 0x0000006FEE abootbak 1.11 MB
FWRITE DONE: ST 0x000000D7EE logo 8 KB
FWRITE DONE: ST 0x000005FFF6 modem 40.13 MB
FWRITE DONE: ST 0x000007FFF6 boot 12.09 MB
FWRITE DONE: ST 0x0000087FF6 recovery 14.05 MB
FWRITE DONE: ST 0x000009FFF6 system 800 MB (Unsparsed Size)
FWRITE DONE: ST 0x000022FFF6 cache 384 MB (Unsparsed Size)
FWRITE DONE: ST 0x00002EFFF6 userdata 512 MB (Unsparsed Size)
FWRITE DONE: ST 0x0000000000 PrimaryGPT 17 KB
FWRITE DONE: ST 0x0000000021 BackupGPT 16.5 KB
FPATCH DONE: 13
FHSETD DONE: Ok
FHREST DONE: Ok
Write Flash Done in: 04:14.703
The Following 2 Users Say Thank You to 4G Telecom For This Useful Post:
Old 07-28-2017, 17:56   #793 (permalink)
ddilshod93's Avatar
Member: 2082192
Sonork: not
Thanks Meter: 1,119
LG-K220ds (X Power LTE DS) KDZ Format Flashing done!
File: K220ds10C_00_OPEN_CIS_DS_OP_0729.kdz
File Format: KDZ Type 2, Includes: K22010c_00.dz
Model: LG-K220 File: LGK220AT-00-V10c-GLOBAL-COM-JUL-29-2016+0
Partitions {Chunks): 50
RbId: A1469773866-M1469773866-C1469778752-U1469778752-0 user
Warning, Excluded Partition: preloader
Warning, Excluded Partition: sgpt
Partitions (Chunks) to Flash: 48 (2.92 GB)
LG K220DS (X Power LTE DS) at USB (COM12) [LG FLASH 69] {Write Flash}
DL MODE : 2
DL REQM : 5
DL MODEL: LG-K220ds
DL SWVER: K22010c
DL IMEI : 35xxxx-07-xxxxxx-1
LF MODEL: LG-K220ds
LF SERNO: LGK2204TDIPFYP
LF SWVER: LGK220dsAT-00-V10c-CIS-XX-JUL-29-2016+0
LF MINOS: MiniOS 3.0
LF OSVER: 6.0.1
LF IMEI : 35xxxx-07-xxxxxxx-1
LF DVPID: CD22S170327001190
LF SOCTY: mt6735
LF CABLE: USER
Skipped Partition: preloader
Writing Partition: pgpt
Writing Partition: lk
Writing Partition: lkbak
Writing Partition: laf
Writing Partition: boot
Writing Partition: recovery
Writing Partition: logo
Writing Partition: lo_bak_go
Writing Partition: secro
Writing Partition: tee1
Writing Partition: tee2
Writing Partition: cust
Writing Partition: rct
Writing Partition: factory
Writing Partition: efuse
Writing Partition: lafbak
Writing Partition: system
Skipped Partition: sgpt
Writing Partition: OP_T
Flash Write Done in: 03:11.285
LF CLOSE: 0k
RESTART : 2
The Following 2 Users Say Thank You to ddilshod93 For This Useful Post:
Old 07-29-2017, 12:54   #794 (permalink)
ddilshod93's Avatar
Member: 2082192
Sonork: not
Thanks Meter: 1,119
LG-D325 KDZ Format Flashing done!
File: D32510g_00.kdz
File Format: KDZ Type 2, Includes: D32510g_0.dz
Model: LG-D325 File: D32510g
Partitions {Chunks): 30
RbId: A1441761192-M1441761192-C1441763961-U1441763961-0 user
Partitions (Chunks) to Flash: 30 (1.48 GB)
LG D325 (L70 DS) at USB (COM40) [LG FLASH 5] {Write Flash}
DL MODE : 2
DL REQM : 5
DL MODEL: LG-D325
DL SWVER: D32510d
DL IMEI : 35XXXX-06-XXXXXX-6
LF MODEL: LG-D325
LF SERNO: LGD3259a1eb1a
LF SWVER: LGD325AT-00-V10f-CIS-XX-NOV-05-2014+0
LF MINOS: unknown
LF OSVER: 4.4.2
LF IMEI : 35XXXX-06-XXXXXX-6
LF DVPID: CT66S140914001440
LF SOCTY: msm8610
LF CABLE: USER
Writing Partition: PrimaryGPT
Writing Partition: modem
Writing Partition: sbl1
Writing Partition: rpm
Writing Partition: tz
Writing Partition: sdi
Writing Partition: aboot
Writing Partition: rpmb
Writing Partition: tzb
Writing Partition: abootb
Writing Partition: persist
Writing Partition: sbl1b
Writing Partition: BackupGPT
Flash Write Done in: 03:02.951
LF CLOSE: 0k
RESTART : 2
Old 07-31-2017, 10:06   #795 (permalink)
Member: 2185549
Thanks Meter: 535
LG US992 (G5 USC) at Auto Select Flash Port [LG FLASH 69] {Reset FRP}
DL MODE : 6
DL REQM : 5
DL MODEL: LGUS992
DL SWVER: US99223a
DL IMEI : 355602-07-189528-2
LF MODEL: LGUS992
LF SERNO: LGUS992620f1f56
LF SWVER: US99223a_03
LF OSVER: 7.0
LF IMEI : 355602-07-189528-2
LF DVPID: PT02S160420003412
LF SOCTY: msm8996
LF CABLE: 633A
Reset FRP Done in 00:09.766
Page generated in 0.26435 seconds with 9 queries
