Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > UFST
Old 08-17-2017, 14:43   #826 (permalink)
Member: 2185549
Thanks Meter: 529
LENOVO A6000 IMEI REPAIR DONE FIRST ROOT WITH KINGROOT
Lenovo A6000 (A6000 LTE DS) at USB [ADB] {ADB Info}
daemon started successfully * b01049f6 unauthorized
BOOTSERN: b01049f6
PRDBRAND: Lenovo
PRDMODEL: Lenovo A6000
PRDNAME : Kraft-A6000
BLDVERS : 4.4.4
BLDDISID: Kraft-A6000_S042_151012
BLDPROD : Kraft-A6000
PRODBRD : msm8916
BRDPLATF: msm8916
HARDWARE: qcom
USB CNFG: mtp,adb
MMC1 CID: 90014a48384731650507b01049f6b200
Superuser Permissions Denied
Lenovo A6000 (A6000 LTE DS) at USB [ADB] {Enable Diags}
daemon started successfully * b01049f6 device
Normally to Enable Diags Need Root Rights, but Some (LG) works Without
Diags Enabled
BOOTSERN: b01049f6
PRDBRAND: Lenovo
BLDVERS : 4.4.4
PRODBRD : msm8916
BRDPLATF: msm8916
HARDWARE: qcom
USB CNFG: mtp,adb
Superuser Permissions Granted (SU)
Diags Enabled
Lenovo A6000 (A6000 LTE DS) at USB [ADB] {Read EFS}
Transfered: 5470 KB/s (1048576 bytes in 0.187s)
Saved as: A6000_LenovoA6000_b01049f6_EFS_ [2017_08_17_16_41_24].bin
Transfered: 1025 KB/s (16384 bytes in 0.015s)
Saved as: A6000_LenovoA6000_b01049f6_EF1_ [2017_08_17_16_41_24].bin
Transfered: 6153 KB/s (1572864 bytes in 0.249s)
Saved as: A6000_LenovoA6000_b01049f6_NV1_ [2017_08_17_16_41_24].bin
Transfered: 5791 KB/s (1572864 bytes in 0.265s)
Saved as: A6000_LenovoA6000_b01049f6_NV2_ [2017_08_17_16_41_24].bin
Saved as: A6000_LenovoA6000_b01049f6_NV3_ [2017_08_17_16_41_24].bin
Path: C:\Program Files\SarasSoft\UFS\UFS_SAMs\ANDROID_UFS_1055_Test 9\A6000\EFS\
Done in: 00:07.020
Lenovo A6000 (A6000 LTE DS) at USB (COM486) [DIAGS] {Factory Info}
OFFLMODE: OK
MDMVERSN: Mar 10 201512:02:03Feb 10 201512:00:00EAAAANUZ
MDMBUILD: DPM.1.0.c7.18-00021-M8916EAAAANUZM-S86518C1-V18
NV IMEI1: 866043-02-667387-4
NV IMEI2: 866043-02-667388-2
NV BTID : A032:99:8CB378
NV WIFI : 78B3:9E:9932A0
NV SERNR: Empty
Lenovo A6000 (A6000 LTE DS) at USB (COM486) [DIAGS] {Gen.Settings}
OFFLMODE: OK
NV SERNR: Empty
Gen.Settings Write Done: 2 Item(s)
OFFLMODE: OK
NV IMEI1: 351124-86-754037-2
NV IMEI2: 351124-86-754038-0
NV SERNR: Empty
The Following 2 Users Say Thank You to ferouz kassim For This Useful Post:
Old 08-17-2017, 19:16   #827 (permalink)
Member: 1242798
Thanks Meter: 8
XT1755 MOTO C FRP DONE IN UFST World's first
The Following User Says Thank You to aneeshmob For This Useful Post:
Old 08-18-2017, 14:00   #828 (permalink)
Member: 2185549
Thanks Meter: 529
Sony D5303 (Xperia T2 Ultra LTE Tianchi) at USB Auto Select [S1] {Write Flash}
Files to Flash: 14
USB DEV : SEMC [USB\VID_0FCE&PID_ADDE\5&f86e282&0&3]
BL VERS : S1_Boot_MSM8x26_LA1.0_1014
BL PKTSZ: 0x00010000
BL IMEI : 352493-06-113283-4
BL ROOTS: ROOTABLE
TA MODEL: D5303
TA DEVSN: YT910U11A3
TA CDVER: 1280-3093_R4B
TA SWVER: 1276-5348_19.1.1.A.0.165
TA FLVER: GLOBAL-LTE_19.1.1.A.0.165
Loader Boot Done in 00:00.390
FL VERS : LOADER_RELEASE_MSM8X26_31_AID_4
FL PKTSZ: 0x00080000
FL IMEI : 352493-06-113283-4
TA MODEL: D5303
TA S1VER: 1274-7024 S1_Boot_MSM8x26_LA1.0_1014
AT PLFRT: 00000000000000000000000000000000000000000000000000 00000000000000
AT OTLCK: UNLOCKED
AT OTDAT: 00000000
AT IDCOD: 109180E1
S1 CNFIG: DEVELOPMENT(6)
Writing File: amss_fs_1.sin
File Write Done in 00:00.015 + 00:00.016
Writing File: amss_fs_2.sin
File Write Done in 00:00.009 + 00:00.016
Writing File: amss_fsg.sin
File Write Done in 00:00.124 + 00:00.158
Writing File: apps_log.sin
File Write Done in 00:00.305 + 00:00.268
Writing File: cache.sin
File Write Done in 00:00.844 + 00:00.784
Writing File: elabel-D5303-row_201405301410.1_19.4.A.0.182.sin
File Write Done in 00:02.052 + 00:01.989
Writing File: fotakernel.sin
File Write Done in 00:01.363 + 00:01.273
Writing File: kernel.sin
File Write Done in 00:01.263 + 00:01.255
Writing File: partition-image.sin
File Write Done in 00:00.016 + 00:00.000
Writing File: system.sin
File Write Done in 03:57.722 + 04:02.454
Writing File: userdata.sin
File Write Done in 00:11.358 + 00:10.589
Writing File: cust-reset.ta
File Write Done in 00:00.146
Writing File: fota-reset.ta
File Write Done in 00:00.103
Shut Down Ok
All Done in 08:45.454
The Following User Says Thank You to ferouz kassim For This Useful Post:
Old 08-18-2017, 14:25   #829 (permalink)
Member: 2185549
Thanks Meter: 529
UNBRICK H811 AFTER FLASHING WRONG FILE THEN COMES TO QLOAD FLASH IT VIA QC QUALCOM AUTO SAHARA AND BELOW IS FILE TO FLASH USE prog_emmc_firehose_8992_lite_lge1.MBN LOADER UNDER QUALCOM TAB AND FLASH BELOW FILE IT SHOULD BE ABLE TO BOOT TO DOWNLOAD MODE THEN FLASH COMPATIBLE .KDZ hope it gets added on support soon
Its so unfortunate that i double clicked and i couldnt get the log yet devices had already left qload mode this is usefull no need for jtaging make use of tool ufst is rich in functions only task is u the user how do u use ittttt
https://mega.nz/#!U1lFxAJb!D5fhxXNF-..._5HzOv0_q_-pKE
Old 08-18-2017, 14:37   #830 (permalink)
Member: 2185549
Thanks Meter: 529
now use p999 cable from octopus because with normal cable phone wont be detected and flash kdz(http://storagecow.eu/Xda/LG%20G4/T-M...H81110H_00.kdz) here is log
File: H81110H_00.kdz
File Format: KDZ Type 2, Includes: H81110h_00.dz
Model: LG-H811 File: H81110h
Partitions {Chunks): 67
RbId: user
Partitions (Chunks) to Flash: 67 (3.44 GB)
LG H811 (G4) at USB (COM411) [LG FLASH 5] {Write Flash}
DL MODE : 2
DL REQM : 5
DL MODEL: LG-H811
DL SWVER: H81110n
DL IMEI : 359105-06-745782-4
LF MODEL: LG-H811
LF SERNO: LGLS991c6c036cf
LF SWVER: LGH811AT-00-V10n-COM-US-SEP-10-2015-ARB02+0
LF MINOS: MiniOS 3.0
LF OSVER: 5.1
LF IMEI : 359105-06-745782-4
LF DVPID: SM07S150518000579
LF SOCTY: msm8992
LF CABLE: 910K
Writing Partition: PrimaryGPT
Writing Partition: modem
Writing Partition: pmic
Writing Partition: sbl1
Writing Partition: tz
Writing Partition: sdi
Writing Partition: hyp
Writing Partition: rpm
Writing Partition: aboot
Writing Partition: sbl1bak
Writing Partition: pmicbak
Writing Partition: tzbak
Writing Partition: hypbak
Writing Partition: rpmbak
Writing Partition: abootbak
Writing Partition: sdibak
Writing Partition: persist
Writing Partition: sec
Writing Partition: rct
Writing Partition: laf
Writing Partition: boot
Writing Partition: recovery
Writing Partition: raw_resources
Writing Partition: raw_resourcesbak
Writing Partition: factory
Writing Partition: system
Writing Partition: BackupGPT
Flash Write Done in: 06:35.861
LF CLOSE: 0k
RESTART : 2
Old 08-18-2017, 14:42   #831 (permalink)
Member: 2185549
Thanks Meter: 529
QC MSM8992 (eMMC) at Auto Select Flash Port [SAHARA] {Write Flash}
QDL USB Com: Vid_05c6&Pid_9008 (COM112)
Flash Bundle: rawprogram0.xml
SAHARA VERS: 2
SAHARA PROG: prog_emmc_firehose_8992_lite_lge1.mbn
FHPROG SZFT: 1024
FHPROG SZTT: 8192
FHPROG SPTT: 8192
FHPROG XSIZ: 4096
FHPROG VERS: 1
FHPROG PLTF: 8992
FHPROG CHSN: 0x005C3E46
FHPROG MEMT: eMMC
FHINFO PAR0: 61071360 x 512 Sectors (29.12 GB)
FHINFO PAR1: 8192 x 512 Sectors (4 MB)
FHINFO PAR2: 8192 x 512 Sectors (4 MB)
FHPROG PART: EFI GPT
FHPROG PRTY: 0
Partitions to Write: 10 (39.71 MB)
FWRITE DONE: ST 0x0000038000 pmic 36.73 KB
FWRITE DONE: ST 0x0000038400 sbl1 575.5 KB
FWRITE DONE: ST 0x0000038C00 tz 560.2 KB
FWRITE DONE: ST 0x0000039400 sdi 27.88 KB
FWRITE DONE: ST 0x0000039800 hyp 92.3 KB
FWRITE DONE: ST 0x0000039C00 rpm 187.04 KB
FWRITE DONE: ST 0x000003A000 aboot 635.64 KB
FWRITE DONE: ST 0x0000060000 laf 37.62 MB
FWRITE DONE: ST 0x0000000000 PrimaryGPT 17 KB
FWRITE DONE: ST 0x0000000021 BackupGPT 16.5 KB
FPATCH DONE: 13
FHSETD DONE: Ok
FHREST DONE: Ok
Write Flash Done in: 00:14.187
here is log just got another second piece and also dne
Old 08-18-2017, 15:05   #832 (permalink)
Member: 2185549
Thanks Meter: 529
Samsung SM-J700T1 (J7 LTE TMK) at USB (COM75) [LOKE FLASH] {Reset FRP}
PLATF: LOKE 00020000
PIT Read Done: 00:00
Error: persistent.partition
Comm Error Flash Write: Cannot Write: 0
Flash Write Failed
Comm Error LOKE Close: Cannot Write: 0
Last USB Exception: 0x0005 Access is denied.
Samsung SM-J700T1 (J7 LTE TMK) at USB (COM75) [LOKE FLASH] {Read PIT}
Saved as: SM-J700T1_PIT [2017_08_18_16_54_27].pit
Path: C:\Users\ferouz\Desktop\
Restart Done
None of Modem Ports Selected
Samsung SM-J700T1 (J7 LTE TMK) at USB (COM493) [MODEM] {Enter Flash}
MODEMCON: OK
FLASHMOD: OK
Samsung SM-J700T1 (J7 LTE TMK) at USB (COM75) [LOKE FLASH] {Write Flash}
PIT Backup Saved as: SM-J700T1_Read.pit
File: j700t1 adb boot.tar
Partition: BOOT, Image: boot.img, Size: 0x00FF7120 (15.97 MB)
Flash Write Done: 00:01.503
Restart Done
Samsung SM-J700T1 (J7 LTE TMK) at USB [ADB] {Reset FRP}
daemon started successfully * 3300ad7bc029a3cb device
Goto "Backup and reset" Menu and make "Factory data reset"
here is adb boot link
https://mega.nz/#!55kBhIbT!vZfizFlZ4...u7cdqGuYe5kYb8
Old 08-18-2017, 20:30   #833 (permalink)
julius84's Avatar
Member: 2524486
Thanks Meter: 112
Hi guys were can I get Samsung UART on usb with 523kom rid cable?
Old 08-19-2017, 00:55   #834 (permalink)
Sha
Sha's Avatar
Member: 17804
Sonork: 100.27310
Thanks Meter: 1,075
UFST Original Cable have
UART with RID, EDL functions Build in
Old 08-19-2017, 04:44   #835 (permalink)
Member: 2185549
Thanks Meter: 529
i dint knw that the same cable had edl function inbiutl now wherr is switch a think a need lecture on how to use this cable
Sent from my Redmi 3S using Tapatalk
Old 08-19-2017, 05:03   #836 (permalink)
Sha
Sha's Avatar
Member: 17804
Sonork: 100.27310
Thanks Meter: 1,075
Have [EDL Cable] Option to Tick.
Make some Flash function [Read, Write, ..]
Insert Cable to switched Off phone
Press [OK] then Pop-Up comes
The Following User Says Thank You to Sha For This Useful Post:
Old 08-19-2017, 10:35   #837 (permalink)
Member: 2185549
Thanks Meter: 529
Y625-U32 FLASHING DONE(FIRMWARE FRM SUPPORT)
well most of u are wondering how to soft unrbick this model through edl the trick most of the times is to boot to edl through edl iff phone is softbrikced (hang on logo) and adb wasnt enabled before u have to open phone and short these points on mother board after wards if the phone is entering qload mode u release test oints below is the testpoint picture and log
https://mega.nz/#!E1tDiBLT!nzXwc-zx3...1NUWCDDrdT3qQk
Huawei Y625-U32 (Huawei Y625 3G DS) at Auto Select Flash Port [SAHARA] {Write Flash}
SAHARA VERS: 2
SAHARA PROG: prog_emmc_firehose_8x10_hua.mbn
FHPROG SZFT: 4096
FHPROG SZTT: 49152
FHPROG SPTT: 49152
FHPROG XSIZ: 4096
FHPROG VERS: 1
FHPROG PLTF: 8x10
FHPROG MEMT: eMMC
FHINFO PAR0: 15269888 x 512 Sectors (0 Bytes) Default
FHINFO PAR1: 8192 x 512 Sectors (4 MB) Default
FHINFO PAR2: 8192 x 512 Sectors (4 MB) Default
Partitions to Write: 58 (1.25 GB)
FWRITE DONE: ST 0x0000000022 sbl1 239.44 KB
FWRITE DONE: ST 0x0000000422 sdi 10.35 KB
FWRITE DONE: ST 0x0000000522 aboot 199.5 KB
FWRITE DONE: ST 0x0000000922 rpm 143.79 KB
FWRITE DONE: ST 0x0000000D0A tz 331.04 KB
FWRITE DONE: ST 0x0000020000 modem 31.16 MB
FWRITE DONE: ST 0x0000040040 boot 6.55 MB
FWRITE DONE: ST 0x0000045040 system 128.01 MB
FWRITE DONE: ST 0x0000085308 system 8 KB
FWRITE DONE: ST 0x0000086308 system 125.65 MB
FWRITE DONE: ST 0x00000C5040 system 8 KB
FWRITE DONE: ST 0x00000C6040 system 126 MB
FWRITE DONE: ST 0x0000105040 system 8 KB
FWRITE DONE: ST 0x0000105308 system 8 KB
FWRITE DONE: ST 0x0000106308 system 125.65 MB
FWRITE DONE: ST 0x0000145040 system 8 KB
FWRITE DONE: ST 0x0000146040 system 126 MB
FWRITE DONE: ST 0x0000185040 system 8 KB
FWRITE DONE: ST 0x0000185308 system 8 KB
FWRITE DONE: ST 0x0000186308 system 125.65 MB
FWRITE DONE: ST 0x00001C5040 system 8 KB
FWRITE DONE: ST 0x00001C6040 system 126 MB
FWRITE DONE: ST 0x0000205040 system 8 KB
FWRITE DONE: ST 0x0000205308 system 8 KB
FWRITE DONE: ST 0x0000206308 system 125.65 MB
FWRITE DONE: ST 0x0000245040 system 8 KB
FWRITE DONE: ST 0x0000246040 system 126 MB
FWRITE DONE: ST 0x0000285040 system 8 KB
FWRITE DONE: ST 0x0000285308 system 8 KB
FWRITE DONE: ST 0x0000286308 system 28.41 MB
FWRITE DONE: ST 0x00002C5040 system 8 KB
FWRITE DONE: ST 0x0000301040 persist 4.14 MB
FWRITE DONE: ST 0x0000311040 cache 5.64 MB
FWRITE DONE: ST 0x0000343D0C recovery 7.58 MB
FWRITE DONE: ST 0x0000348D0C logo 1.17 MB
FWRITE DONE: ST 0x000034C90C userdata 58.44 MB
FWRITE DONE: ST 0x000038C90C userdata 8 KB
FWRITE DONE: ST 0x000038CD14 userdata 8 KB
FWRITE DONE: ST 0x00003CC90C userdata 8 KB
FWRITE DONE: ST 0x000040C90C userdata 8 KB
FWRITE DONE: ST 0x000040CD14 userdata 8 KB
FWRITE DONE: ST 0x000044C90C userdata 8 KB
FWRITE DONE: ST 0x000048C90C userdata 8 KB
FWRITE DONE: ST 0x000048CD14 userdata 8 KB
FWRITE DONE: ST 0x00004CC90C userdata 8 KB
FWRITE DONE: ST 0x000050C90C userdata 8 KB
FWRITE DONE: ST 0x000050CD14 userdata 8 KB
FWRITE DONE: ST 0x000054C90C userdata 8 KB
FWRITE DONE: ST 0x000058C90C userdata 8 KB
FWRITE DONE: ST 0x000058CD14 userdata 8 KB
FWRITE DONE: ST 0x00005CC90C userdata 8 KB
FWRITE DONE: ST 0x000060C90C userdata 8 KB
FWRITE DONE: ST 0x000064C90C userdata 8 KB
FWRITE DONE: ST 0x000068C90C userdata 8 KB
FWRITE DONE: ST 0x00006CC90C userdata 8 KB
FWRITE DONE: ST 0x000070C90C userdata 8 KB
FPATCH DONE: 13
FHSETD DONE: Ok
FHREST DONE: Ok
Write Flash Done in: 03:30.664
Old 08-21-2017, 15:51   #838 (permalink)
Member: 2185549
Thanks Meter: 529
LENOVO PB1-750M IMEI REPAIR DONE
Lenovo PB1-750M (Phab LTE DS) at USB (COM515) [DIAGS] {Factory Info}
OFFLMODE: OK
MDMVERSN: Sep 29 201514:56:47Sep 21 201501:00:00FAAAANUZ
MDMBUILD: MPSS.DPM.2.0.c12-00037-M8936FAAAANUZM-1.29909.1
NV IMEI1: 867007-02-377717-7
NV IMEI2: 867007-02-377718-5
NV BTID : A032:99D6946
NV WIFI : A032:99:EE5EA6
NV SERNR: Empty
Lenovo PB1-750M (Phab LTE DS) at USB (COM515) [DIAGS] {Gen.Settings}
OFFLMODE: OK
NV SERNR: Empty
OFFLMODE: OK
NV IMEI1: 351132-47-654986-6
NV IMEI2: 351132-47-654986-6
NV SERNR: Empty
Old 08-21-2017, 17:43   #839 (permalink)
Member: 2214802
Sonork: 100.112534
Thanks Meter: 28
Y3II
Huawei LUA-U22 (Y3c II 3G DS) at USB Auto Select [MTK] {Reset FRP}
BR USB Com: Vid_0e8d&Pid_2000
DA Agent : DA_LUNA_KEY.bin
BR ComPort: COM63
BR Asic Id: MT6582 [0000]
BR Asic Sw: 8A00 CA01 0001 0000
DA Version: MTK_AllInOne_DA_v3.3001.00.00
PR MMC CID: 150100464E31324D4206F905E44F9343 [FN12MB]
PR Version: 4.2 [0x87] (5) MT6582
eMMC BOOT1: 0x0000000000400000 [4.194.304]
eMMC BOOT2: 0x0000000000400000 [4.194.304]
eMMC RPMB : 0x0000000000080000 [524.288]
eMMC USER : 0x00000001D2000000 [7.818.182.656]
eMMC CID : 150100464E31324D4206F905E44F9343 [FN12MB]
ERAM Size : 0x0000000040000000 [1.073.741.824]
IRAM Size : 0x0000000000020000 [131.072]
UNICAL ID : 558DB42E585B5C756B2146490E274AA7
PMT (EBR) Found : 23 Partition Entries
Reset FRP Done in: 00:02.441
DA Shutdown Done, Disconnect Cable
The Following 3 Users Say Thank You to gsm4soltan3 For This Useful Post:
Old 08-22-2017, 09:23   #840 (permalink)
Member: 142632
Sonork: 100.1589012
Thanks Meter: 442
REVO PEARL Reset FRP OK !
MTK MT6737 (eMMC) at USB Auto Select [MTK] {Reset FRP}
DA Agent : MTK_AllInOne_DA.bin
BR ComPort: COM6
BR Asic Id: MT0335 [0000] >> MT6735
BR Asic Sw: 8A00 CB00 0000 0000
PR MMC CID: 422201F46E697769000010202DA5954A [niwi]
PR Version: 4.2 [0x9B] (5) MT6737T
eMMC RPMB : 0x0000000000400000 [4.194.304]
eMMC USER : 0x00000001CD000000 [7.734.296.576]
eMMC CID : F40122426977696E201000004A95832D [Biwin ]
UNICAL ID : 00CD33344421663F7B6BA7E331705284
PMT (GPT) Found : 25 Partition Entries
Reset FRP Done in: 00:04.110
THANKS !!!
The Following User Says Thank You to Umbabaraumba For This Useful Post:
Page generated in 0.26882 seconds with 9 queries
