11-30-2017, 15:04 | #977 (permalink) |
Freak Poster Join Date: Nov 2006 Location: Karachi
Member: 388703 Status: Offline Sonork: sheerazi Thanks Meter: 183 | SM-J120A FRP DONE Samsung SM-J120A (J1 (2016) LTE ATT) at USB (COM130) [LOKE FLASH] {Write Flash} PLATF: LOKE 00020000 PIT Read Done: 00:00 PIT Backup Saved as: SM-J120A_Read.pit No Partition Info for Image: j1xlte_usa_att.pit, in COMBINATION_ATT_FA60_J120AUCU1APC1_ATTFAC_CL727480 7_QB9013492_REV00_user_mid_noship.tar.md5 Warning, Pit Image: j1xlte_usa_att.pit Skipped, Use [Re-Part.] Option with Pit Image File: COMBINATION_ATT_FA60_J120AUCU1APC1_ATTFAC_CL727480 7_QB9013492_REV00_user_mid_noship.tar.md5 Partition: BOOT, Image: boot.img, Size: 0x007A1120 (7.63 MB) Flash Write Done: 00:01.370 Restart Done Samsung SM-J120A (J1 (2016) LTE ATT) at USB [ADB] {Reset FRP} daemon started successfully * Goto "Backup and reset" Menu and make "Factory data reset" |
11-30-2017, 15:05 | #978 (permalink) |
Member: 388703 Status: Offline Sonork: sheerazi Thanks Meter: 183 | SM-N910W8 Unlock Done Samsung SM-N910W8 (Note4 CAN) at USB (COM130) [LOKE FLASH] {Write Flash} PLATF: LOKE 00020000 PIT Read Done: 00:00 PIT Backup Saved as: SM-N910W8_Read.pit File: Modem.bin Partition: MODEM, Image: modem.bin, Size: 0x039EE300 (57.93 MB) Flash Write Done: 00:03.395 Restart Done None of Diags Ports Selected Samsung SM-N910W8 (Note4 CAN) at USB (COM185) [DIAGS] {Unlock} OFFLMODE: OK Unlock Done in: 00:00.990 Samsung SM-N910W8 (Note4 CAN) at USB (COM130) [LOKE FLASH] {Write Flash} PLATF: LOKE 00020000 PIT Read Done: 00:00 PIT Backup Saved as: SM-N910W8_Read.pit File: N910W8VLS1DPK1_N910W8OYA1DPK1_N910W8VLS1DPK1_HOME. tar Partition: MODEM, Image: modem.bin, Size: 0x03A22300 (58.13 MB) Flash Write Done: 00:03.398 Restart Done |
11-30-2017, 16:21 | #979 (permalink) |
Member: 388703 Status: Offline Sonork: sheerazi Thanks Meter: 183 | LG VS985 Flash Done Code: File: VS98547A_01_0314_ARB01.kdz File Format: KDZ Type 2, Includes: VS98547A_01.dz Model: VS985 File: VS98547A_01 Partitions {Chunks): 42 RbId: user Partitions (Chunks) to Flash: 42 (2.28 GB) LG VS985 (G3 Verizon) at USB (COM191) [LG FLASH 5] {Write Flash} DL MODE : 2 DL REQM : 5 DL MODEL: VS985 4G DL SWVER: VS98510B DL IMEI : 352452-06-257832-0 LF MODEL: VS985 4G LF SERNO: VS9854G9793d995 LF SWVER: LGD855AT-00-V10n-GLOBAL-COM-OCT-22-2014-32GB+0 LF MINOS: MiniOS 3.0 LF OSVER: 4.4.2 LF IMEI : 352452-06-257832-0 LF DVPID: BS10S140704000561 LF SOCTY: msm8974 LF CABLE: VUSER Writing Partition: PrimaryGPT Writing Partition: modem Writing Partition: sbl1 Writing Partition: dbi Writing Partition: aboot Writing Partition: rpm Writing Partition: tz Writing Partition: boot Writing Partition: persist Writing Partition: recovery Writing Partition: rct Writing Partition: laf Writing Partition: factory Writing Partition: system Writing Partition: BackupGPT Flash Write Done in: 03:15.946 LF CLOSE: 0k RESTART : 2 |
The Following User Says Thank You to kashif ali For This Useful Post: |
12-01-2017, 11:13 | #980 (permalink) | |
No Life Poster Join Date: Jul 2015 Location: India
Member: 2421242 Status: Offline Sonork: 100.1614558 Thanks Meter: 700 | Le tv X526 Read Firmware Done Quote:
The Following 2 Users Say Thank You to 4G Telecom For This Useful Post: |
12-01-2017, 14:34 | #981 (permalink) |
No Life Poster Join Date: May 2014 Location: UGANDA
Member: 2185549 Status: Offline Thanks Meter: 535 | Alcatel 5045D (Pixi 4-5 4G LTE DS) at USB Auto Select [MTK] {Reset FRP} BR USB Com: Vid_0e8d&Pid_2000 DA Agent : MTK_AllInOne_DA.bin BR ComPort: COM73 BR Asic Id: MT0335 [0000] >> MT6735 BR Asic Sw: 8A00 CB00 0000 0000 DA Version: MTK_AllInOne_DA_v3.3001.00.00 PR MMC CID: 504E01FE35394A312D32124BE938E180 [59J1-] PR Version: 4.2 [0x9B] (5) MT6735 eMMC BOOT1: 0x0000000000200000 [2.097.152] eMMC BOOT2: 0x0000000000200000 [2.097.152] eMMC RPMB : 0x0000000000200000 [2.097.152] eMMC USER : 0x00000001D3000000 [7.834.959.872] eMMC CID : FE014E50314A39354B12322D80E163E9 [P1J95K] ERAM Size : 0x0000000040000000 [1.073.741.824] IRAM Size : 0x0000000000020000 [131.072] UNICAL ID : B4043E545B2BAEA70DA01E68BF8B886B PMT (GPT) Found : 28 Partition Entries Reset FRP Done in: 00:09.471 DA Shutdown Done, Disconnect Cable |
The Following User Says Thank You to ferouz kassim For This Useful Post: |
12-01-2017, 14:35 | #982 (permalink) |
12-02-2017, 05:21 | #983 (permalink) |
Member: 2185549 Status: Offline Thanks Meter: 535 | Samsung SM-J700F (J7 LTE) at USB (COM30) [LOKE FLASH] {Write Flash} PLATF: LOKE 00020000 PIT Read Done: 00:00 PIT Backup Saved as: SM-J700F_Read.pit File: J700FXXU4BQE3_J700FODD4BQE1_J700FXXU4BQF4_HOME.tar .md5 Partition: BOOTLOADER, Image: sboot.bin, Size: 0x0018B110 (1.54 MB) Partition: CM, Image: cm.bin, Size: 0x00204110 (2.02 MB) Partition: BOOT, Image: boot.img, Size: 0x0123A120 (18.23 MB) Partition: RECOVERY, Image: recovery.img, Size: 0x01357120 (19.34 MB) Partition: SYSTEM, Image: system.img, Size: 0x73A685A0 (1.81 GB) Partition: RADIO, Image: modem.bin, Size: 0x0214C370 (33.3 MB) Partition: CACHE, Image: cache.img, Size: 0x06E7B120 (110.48 MB) Partition: HIDDEN, Image: hidden.img, Size: 0x02622100 (38.13 MB) Flash Write Done: 17:03.766 Restart Done |
12-02-2017, 05:23 | #984 (permalink) |
Member: 2185549 Status: Offline Thanks Meter: 535 | Var INFINIX-X554-T90918-A1 (Hot 3 3G DS) at USB Auto Select [MTK] {Write Flash} Scatter : MT6580_Android_scatter.txt BR USB Com: Vid_0e8d&Pid_0003 DA Agent : MTK_AllInOne_DA.bin BR ComPort: COM49 BR Asic Id: MT6580 [0000] BR Asic Sw: 8A00 CA00 0000 0000 DA Version: MTK_AllInOne_DA_v3.3001.00.00 PR MMC CID: 700100563130303136502759431B53D9 [V10016] PR Version: 4.2 [0x9C] (7) MT6580 DRAM Confg: 560001703130303159275036D9531B43 DRAM PreLd: preloader_t90918a2.bin DRAM ConVs: 21 DRAM Enabl: 02000000000040000000 eMMC BOOT1: 0x0000000000400000 [4.194.304] eMMC BOOT2: 0x0000000000400000 [4.194.304] eMMC RPMB : 0x0000000000400000 [4.194.304] eMMC USER : 0x0000000386000000 [15.133.048.832] eMMC CID : 700100563130303136502759431B53D9 [V10016] ERAM Size : 0x0000000040000000 [1.073.741.824] IRAM Size : 0x0000000000020000 [131.072] UNICAL ID : 7F2BFEDABC43CBB461F07A8C7DEF1C59 DA USB Com: Vid_0e8d&Pid_2001 Warning, PMT not Found (Flash Erased) Warning, MBR not Found Flashing Canceled DA Shutdown Done, Disconnect Cable Var INFINIX-X554-T90918-A1 (Hot 3 3G DS) at USB Auto Select [MTK] {Write Flash} Scatter : MT6580_Android_scatter.txt BR USB Com: Vid_0e8d&Pid_2000 DA Agent : MTK_AllInOne_DA.bin BR ComPort: COM48 BR Asic Id: MT6580 [0000] BR Asic Sw: 8A00 CA00 0000 0000 DA Version: MTK_AllInOne_DA_v3.3001.00.00 PR MMC CID: 700100563130303136502759431B53D9 [V10016] PR Version: 4.2 [0x9C] (7) MT6580 eMMC BOOT1: 0x0000000000400000 [4.194.304] eMMC BOOT2: 0x0000000000400000 [4.194.304] eMMC RPMB : 0x0000000000400000 [4.194.304] eMMC USER : 0x0000000386000000 [15.133.048.832] eMMC CID : 700100563130303136502759431B53D9 [V10016] ERAM Size : 0x0000000040000000 [1.073.741.824] IRAM Size : 0x0000000000020000 [131.072] UNICAL ID : 7F2BFEDABC43CBB461F07A8C7DEF1C59 Warning, PMT not Found (Flash Erased) Warning, MBR not Found Partitions to Flash: 8 (4.44 GB) Erasing: LinST: 0x0001CC0000 Size: 0x0000060000 lk Erasing: LinST: 0x0001D20000 Size: 0x0001000000 boot Erasing: LinST: 0x0002D20000 Size: 0x0001000000 recovery Erasing: LinST: 0x0003DA0000 Size: 0x0000800000 logo Erasing: LinST: 0x0009A00000 Size: 0x0000600000 secro Erasing: LinST: 0x000A800000 Size: 0x00A9000000 system Erasing: LinST: 0x00B3800000 Size: 0x0010000000 cache Erasing: LinST: 0x00C3800000 Size: 0x0060000000 userdata Format Done in: 00:01.463 Warning, PMT not Found (Flash Erased) Write PMT Done Write preloader 256 KB, Skipped Write pgpt 512 KB, Skipped Write proinfo 3 MB, Skipped Write nvram 5 MB, Skipped Write protect1 10 MB, Skipped Write protect2 10 MB, Skipped Write seccfg 256 KB, Skipped Write lk 289.29 KB, Done in: 00:00.099 Write boot 6.61 MB, Done in: 00:00.813 Write recovery 7.43 MB, Done in: 00:00.964 Write para 512 KB, Skipped Write logo 963.09 KB, Done in: 00:00.218 Write expdb 10 MB, Skipped Write frp 1024 KB, Skipped Write nvdata 32 MB, Skipped Write metadata 39.38 MB, Skipped Write oemkeystore 2 MB, Skipped Write secro 132 KB, Done in: 00:00.157 Write keystore 8 MB, Skipped Write system 2.27 GB, Done in: 04:20.312 Write cache 6.1 MB, Done in: 00:00.881 Write userdata 26.52 MB, Done in: 00:03.407 Write flashinfo 16 MB, Skipped Write sgpt 512 KB, Skipped Write Done in : 04:26.995 DA Shutdown Done, Disconnect Cable BROUGHT THE DEAD BACK TO LIFE BRICKED BY SPFLASHTOOL Last edited by ferouz kassim; 12-02-2017 at 05:23. Reason: BRICKED BY SPFLASHTOOL |
12-02-2017, 05:30 | #985 (permalink) |
Member: 2185549 Status: Offline Thanks Meter: 535 | IMEI REPAIR DONE GUARANTEEED EVEN AFETR HARDRESET STILL ON INFINIX-X554-T90918-A1 (Hot 3 3G DS) at META {Gen.Settings} Insert Cable to Switched OFF Device BR USB Com: Vid_0e8d&Pid_2000 ME USB Com: Vid_0e8d&Pid_2007 ME_MCUID: mt6580,S01 ME_MODEL: ALPS.L1.MP6.V2.19_WT6580.WE.XIAN.L_P28 ME_BLDAT: 2016 08 01 18:21:01 CST ME_CHIPS: MT6580, E01 ME_DSPFW: 2000.00.00 ME_DSPPT: 1.0 ME_BOARD: WT6580_WE_XIAN_L_HSPA_HW ME_SWVER: MOLY.WR8.W1449.MD.WG.MP.V23 ME_MLVER: Unknown ME_SERNR: Empty ME_IMEI1: --- ME_IMEI2: --- ME USB Com: Vid_0e8d&Pid_2007 Gen.Settings Write Done: 2 Item(s) Var INFINIX-X554-T90918-A1 (Hot 3 3G DS) at META {Factory Info} ME USB Com: Vid_0e8d&Pid_2007 ME_MCUID: mt6580,S01 ME_MODEL: ALPS.L1.MP6.V2.19_WT6580.WE.XIAN.L_P28 ME_BLDAT: 2016 08 01 18:21:01 CST ME_CHIPS: MT6580, E01 ME_DSPFW: 2000.00.00 ME_DSPPT: 1.0 ME_BOARD: WT6580_WE_XIAN_L_HSPA_HW ME_SWVER: MOLY.WR8.W1449.MD.WG.MP.V23 ME_MLVER: Unknown ME_SERNR: Empty ME_IMEI1: 351103-08-564859-7 ME_IMEI2: 351103-08-564859-7 ME_SIML1: NCK : 1234 5678 NSCK: 5678 1234 SPCK: 1111 2222 CCK : 3333 4444 SIM : 5555 6666 ME_SIML2: NCK : 1234 5678 NSCK: 5678 1234 SPCK: 1111 2222 CCK : 3333 4444 SIM : 5555 6666 |
12-02-2017, 09:22 | #987 (permalink) | |||
Member: 2421242 Status: Offline Sonork: 100.1614558 Thanks Meter: 700 | Spice Xlife-425 G Flashing Quote:
The Following User Says Thank You to 4G Telecom For This Useful Post: |
12-02-2017, 13:22 | #988 (permalink) |
Member: 388703 Status: Offline Sonork: sheerazi Thanks Meter: 183 | LG VS985 Flash Done Code: File: VS98547A_01_0314_ARB01.kdz File Format: KDZ Type 2, Includes: VS98547A_01.dz Model: VS985 File: VS98547A_01 Partitions {Chunks): 42 RbId: user Partitions (Chunks) to Flash: 42 (2.28 GB) LG VS985 (G3 Verizon) at USB (COM200) [LG FLASH 5] {Write Flash} DL MODE : 2 DL REQM : 5 DL MODEL: Unknown DL SWVER: LGD851-V10z DL IMEI : 352452-06-440377-4 LF MODEL: LG-D851 LF SERNO: VS9854Gd8b570a7 LF SWVER: LGD851AT-00-V10z-GLOBAL-COM-OCT-22-2014-32GB+0 LF MINOS: MiniOS 3.0 LF OSVER: 4.4.2 LF IMEI : 352452-06-440377-4 LF DVPID: BS10S140720000294 LF SOCTY: msm8974 LF CABLE: VUSER Writing Partition: PrimaryGPT Writing Partition: modem Writing Partition: sbl1 Writing Partition: dbi Writing Partition: aboot Writing Partition: rpm Writing Partition: tz Writing Partition: boot Writing Partition: persist Writing Partition: recovery Writing Partition: rct Writing Partition: laf Writing Partition: factory Writing Partition: system Writing Partition: BackupGPT Flash Write Done in: 03:36.029 LF CLOSE: 0k RESTART : 2 |
12-02-2017, 13:26 | #989 (permalink) |
Member: 388703 Status: Offline Sonork: sheerazi Thanks Meter: 183 | SYMPHONY TAB READ FLASH DONE Code: MTK MT6572 (eMMC) at USB Auto Select [MTK] {Read Flash} BR USB Com: Vid_0e8d&Pid_2000 DA Agent : MTK_AllInOne_DA.bin BR ComPort: COM126 BR Asic Id: MT6572 [0000] BR Asic Sw: 8A00 CA01 0000 0000 DA Version: MTK_AllInOne_DA_v3.3001.00.00 PR MMC CID: F301F3424152554E2002B913E28C73E3 [BARUN ] PR Version: 4.2 [0x88] (7) MT6572 eMMC BOOT1: 0x0000000000400000 [4.194.304] eMMC BOOT2: 0x0000000000400000 [4.194.304] eMMC RPMB : 0x0000000000080000 [524.288] eMMC USER : 0x00000001CCD80000 [7.731.675.136] eMMC CID : F301F3424152554E2002B913E28C73E3 [BARUN ] ERAM Size : 0x0000000020000000 [536.870.912] IRAM Size : 0x0000000000020000 [131.072] UNICAL ID : 1CC37796CCF705452CCC25FAFF9EDF9E PMT (EBR) Found : 20 Partition Entries Scatter Saved as: MT6572_Scatter_MT6572_B913E28C73E3.txt Path: C:\Users\kashif ali\Desktop\MT6572_Scatter_MT6572_B913E28C73E3.txt\ PMT Saved as: MT6572_PMT_Binary.bin Partitions to Read: 18 (2.63 GB) Read PRELOADER 64 MB, Done in: 00:13.429 Preloader Size: 0x000184D0 Preloader Vers: MTK_BLOADER_INFO_v11 Preloader Name: preloader_w706.bin Supported Memd: 00 00 00 00 00 00 00 00 00 Preloader Extracted to: preloader_w706.bin Read MBR 512 KB, Done in: 00:00.106 Read EBR1 512 KB, Done in: 00:00.141 Read PRO_INFO 3 MB, Done in: 00:00.623 Read NVRAM 5 MB, Done in: 00:01.061 Read PROTECT_F 10 MB, Done in: 00:02.097 Read PROTECT_S 10 MB, Done in: 00:02.084 Read SECCFG 128 KB, Done in: 00:00.029 Read UBOOT 384 KB, Done in: 00:00.081 Read BOOTIMG 6 MB, Done in: 00:01.256 Read RECOVERY 6 MB, Done in: 00:01.342 Read SEC_RO 256 KB, Done in: 00:00.055 Read MISC 512 KB, Done in: 00:00.107 Read LOGO 3 MB, Done in: 00:01.703 Read EXPDB 10 MB, Done in: 00:02.096 Read ANDROID 1024 MB, Done in: 03:37.875 Read CACHE 226 MB, Done in: 00:47.265 Sparsed: 1.03 MB Read USRDATA 1.29 GB, Done in: 04:36.653 Sparsed: 17.09 MB Read by Scatter Done in: 09:29.959 Path: C:\Users\kashif ali\Desktop\MT6572_Scatter_MT6572_B913E28C73E3.txt\ DA Shutdown Done, Disconnect Cable |
12-02-2017, 17:05 | #990 (permalink) |
Member: 388703 Status: Offline Sonork: sheerazi Thanks Meter: 183 | LENOVO A319 Flash Done Code: Lenovo A319 (A319 3G) at USB Auto Select [MTK] {Write Flash} Scatter : MT6572_Android_scatter.txt BR USB Com: Vid_0e8d&Pid_2000 DA Agent : MTK_AllInOne_DA.bin BR ComPort: COM126 BR Asic Id: MT6572 [0000] BR Asic Sw: 8A00 CA01 0000 0000 DA Version: MTK_AllInOne_DA_v3.3001.00.00 PR MMC CID: 90014A483447326111014566E493929D [H4G2a] PR Version: 4.2 [0x88] (7) MT6572 eMMC BOOT1: 0x0000000000400000 [4.194.304] eMMC BOOT2: 0x0000000000400000 [4.194.304] eMMC RPMB : 0x0000000000400000 [4.194.304] eMMC USER : 0x00000000E9000000 [3.909.091.328] eMMC CID : 90014A483447326111014566E493929D [H4G2a] ERAM Size : 0x0000000020000000 [536.870.912] IRAM Size : 0x0000000000020000 [131.072] UNICAL ID : 0E5DC791F6A34252D4938C0328CA793A PMT (EBR) Found : 19 Partition Entries Partitions to Flash: 11 (2.32 GB) Write PRELOADER 98.51 KB, Done in: 00:00.327 Write MBR 512 Bytes, Done in: 00:00.071 Write EBR1 512 Bytes, Done in: 00:00.071 Write PRO_INFO 3 MB, Skipped Write NVRAM 5 MB, Skipped Write PROTECT_F 10 MB, Skipped Write PROTECT_S 10 MB, Skipped Write SECCFG 128 KB, Skipped Write UBOOT 259.12 KB, Done in: 00:00.216 Write BOOTIMG 4.08 MB, Done in: 00:00.807 Write RECOVERY 4.45 MB, Done in: 00:00.852 Write SEC_RO 132 KB, Done in: 00:00.091 Write MISC 512 KB, Skipped Write LOGO 226.02 KB, Done in: 00:00.106 Write EXPDB 10 MB, Skipped Write ANDROID 1.25 GB, Done in: 04:55.427 Write CACHE 5.87 MB, Done in: 00:01.556 Write USRDATA 11.92 MB, Done in: 00:03.849 Write BMTPOOL 21 MB, Skipped Write Done in : 05:03.511 DA Shutdown Done, Disconnect Cable |
