![]() | #1081 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: May 2014 Location: UGANDA
Member: 2185549 Status: Offline Thanks Meter: 536 ![]() | Nokia TA-1033 (Nokia 6 LTE DS) at Auto Select Flash Port [SAHARA] {Write Flash} QDL USB Com: Vid_05c6&Pid_9008 (COM221) Flash Bundle: Rawprogram0_sparsed.xml SAHARA VERS: 2.1 SAHARA HWID: 0004F0E100000000 [MSM8937] SAHARA HASH: F5F4192A33B2830974B400119BAB728CC9FE911011F928625C 2AED0DA441AC97 SAHARA SERN: A154EB14 (2706696980) SAHARA PROG: prog_emmc_firehose_8937_lite_hmd.mbn FHPROG SZFT: 4096 FHPROG SZTT: 16384 FHPROG SPTT: 16384 FHPROG XSIZ: 4096 FHPROG VERS: 1 FHPROG PLTF: 8937 FHPROG MEMT: eMMC FHINFO PAR0: 30535680 x 512 Sectors (14.56 GB) FHINFO PAR1: 8192 x 512 Sectors (4 MB) FHINFO PAR2: 8192 x 512 Sectors (4 MB) FHPROG PART: EFI GPT FHPROG PRTY: 0 Partitions to Write: 34 (4.41 GB) FWRITE DONE: ST 0x0000060010 sbl1 512 KB FWRITE DONE: ST 0x0000060810 rpm 512 KB FWRITE DONE: ST 0x0000061010 tz 2 MB FWRITE DONE: ST 0x0000063010 devcfg 256 KB FWRITE DONE: ST 0x0000063210 devcfgbak 256 KB FWRITE DONE: ST 0x0000063410 dsp 16 MB FWRITE DONE: ST 0x0000080040 sec 16 KB FWRITE DONE: ST 0x00000A0000 splash 11 MB FWRITE DONE: ST 0x00000C0000 aboot 1024 KB FWRITE DONE: ST 0x00000C1000 boot 24.68 MB FWRITE DONE: ST 0x00000E1000 recovery 30.41 MB FWRITE DONE: ST 0x0000120000 reserved 16 MB FWRITE DONE: ST 0x0000128000 ftmboot 64 MB FWRITE DONE: ST 0x0000148000 cust_nv 2 MB FWRITE DONE: ST 0x0000149000 default_nv 2 MB FWRITE DONE: ST 0x000014A000 hwcfg 1024 KB FWRITE DONE: ST 0x000014A800 sutinfo 1024 Byte FWRITE DONE: ST 0x000014A802 systeminfo 256 KB FWRITE DONE: ST 0x000014AA02 ftmlog 32 MB FWRITE DONE: ST 0x000015AA02 box 8 MB FWRITE DONE: ST 0x000015EA02 multi_splash 16 MB FWRITE DONE: ST 0x0000166A02 hidden 40 MB FWRITE DONE: ST 0x000017AA02 cda 6.08 MB FWRITE DONE: ST 0x000017EA02 reserved_bak 16 MB FWRITE DONE: ST 0x0000186A02 persist 32 MB FWRITE DONE: ST 0x0000240C00 mdtp 32 MB FWRITE DONE: ST 0x0000260000 cmnlib 256 KB FWRITE DONE: ST 0x0000260400 cmnlib64 256 KB FWRITE DONE: ST 0x0000260800 keymaster 256 KB FWRITE DONE: ST 0x0000260A00 keymasterbak 256 KB FWRITE DONE: ST 0x00002A0000 system 4 GB FWRITE DONE: ST 0x0000AA0000 cache 255.98 MB (Unsparsed Size) FWRITE DONE: ST 0x0000B20000 logdump 64 MB FWRITE DONE: ST 0x0000000000 PrimaryGPT 17 KB FPATCH DONE: 13 FHSETD DONE: Ok FHREST DONE: Ok Write Flash Done in: 14:03.732 |
![]() | #1082 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2016 Location: Noitacol Age: 38
Member: 2532428 Status: Offline Thanks Meter: 41 | LG G Pad III 8.0-V521-SIM UNLOCK DONE ! T-MOBILE SIM UNLOCK DONE WITH UFST !!! LG V521 (G Pad 3 8.0 LTE) at USB (COM44) [DIAGS] {Unlock} OFFLMODE: OK Item Delete Failed: 00000001 Item Delete Failed: 00000001 Unlock Failed: DL FILE ITEM RESPONSE: 12. 0000000000002F6E766D2F6E 00 Unlock Using Modem EFS Wipe LG V521 (G Pad 3 8.0 LTE) at USB (COM44) [DIAGS] {Read ENVM} OFFLMODE: OK Set SPC Password: 000000, OK MDMVERSN: Apr 17 201615:03:37Jan 19 201610:00:008952.gen MDMBUILD: MPSS.TA.1.0.c3-00055-8952_GEN_PACK-1 NV IMEI1: 356286-07-207847-5 Get Names GN PROTECTED_NODE: /.efs_private Get Names GN PROTECTED_NODE: /nvm Get Names GN PROTECTED_NODE: /safe EFS2 Read Found: 955 File(s), 0 Link(s) EFS2 Read Done : 955 File(s), Time: 00:29.827 NVM_SIM_1 Read Done: Start 0, 3 Active Item(s), Time: 00:38.021 NVM Read Done: Start 0, 764 Active Item(s), Time: 00:38.900 Saved as: LG_V521_356286-07-207847-5_07 [2018_01_27_12_50_35].envm Path: C:\Program Files (x86)\SarasSoft\UFS\UFS_SAMs\V521\BACKUP\ LG V521 (G Pad 3 8.0 LTE) at USB (COM44) {Clear NVM} DL MODE : 13 DL_DLRQ Failed: -4 Device not in Flash Mode, will Switch now OFFLMODE: OK FLASHMOD: OK DL MODE : 2 DL REQM : 5 DL MODEL: LG-V521 DL SWVER: V52110b DL IMEI : 000000-00-000000-0 LF MODEL: LG-V521 LF SERNO: LGV521d4376273 LF SWVER: LGV521AT-01-V10b-310-260-APR-17-2016-ARB00+0 LF MINOS: MiniOS 3.0 LF OSVER: 6.0.1 LF IMEI : 356286-07-207847-5 LF DVPID: CW85S161012005035 LF SOCTY: msm8952 LF CABLE: 633E Flash Read Start: 0x00014000 Count: 0x00000C00 (Blocks) modemst1 Flash Read Start: 0x00014C00 Count: 0x00000C00 (Blocks) modemst2 Flash Read Start: 0x000D8000 Count: 0x00000C00 (Blocks) fsg Saved as: LG_V521_356286-07-207847-5_07 [2018_01_27_12_50_35].tot Path: C:\Program Files (x86)\SarasSoft\UFS\UFS_SAMs\V521\BACKUP\ RESTART : 2 Clear NVM Done in: 00:30.661 Wait, Restarting LG V521 (G Pad 3 8.0 LTE) at USB (COM44) [DIAGS] {Write ENVM} OFFLMODE: OK Set SPC Password: 000000, OK ENVM Image: LG_V521_356286-07-207847-5_07 [2018_01_27_12_50_35].envm Image Version: 100 Image DEVICE_INFO: LG_V521_356286-07-207847-5 Image MDM_VERSION: MPSS.TA.1.0.c3-00055-8952_GEN_PACK-1 Directory Created: /selfcal/modem/adc.dat Directory Created: /gnss/cfg/sdp/private Item Write Failed: 00000001 Item Write Failed: 00000001 Item Write Failed: 00000001 Directory Created: /nv/reg_files/modem/lte/rrc/asf/csg_db Directory Created: /nv/reg_files/modem/lte/rrc/csp/acq_db NVM SIM_1 IMEI: 356286-07-207847-5 NEW SIM_1 IMEI: 356286-07-207847-5 NVM SIM_1 Write Done: 3 Item(s), Time: 00:02.275 Cannot Write NVM Item: 0x0001, Write Protected NVM IMEI: 356286-07-207847-5 NEW IMEI: 356286-07-207847-5 Cannot Write NVM Item: 0x0CB4, NACK: 14 Cannot Write NVM Item: 0x15DD, Write Protected Cannot Write NVM Item: 0x15DE, Write Protected NVM Write Done: 760 Item(s), Time: 00:03.885 ENVM Write Done: 957 File(s), Time: 01:41.076 LG V521 (G Pad 3 8.0 LTE) at USB (COM44) [DIAGS] {Restart} OFFLMODE: OK RESTART : OK UFST BEST the BEST !!!! |
The Following User Says Thank You to BootYa For This Useful Post: |
![]() | #1084 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2015 Location: India
Member: 2421242 Status: Offline Sonork: 100.1614558 Thanks Meter: 700 ![]() | Sony E2363 Flashing................. Quote:
![]() | #1085 (permalink) |
Member: 2185549 Status: Offline Thanks Meter: 536 ![]() | Var WIKO-V2600 (Sunny2 Plus 3G DS) at USB Auto Select [MTK] {Reset FRP} BR USB Com: Vid_0e8d&Pid_2000 (Preloader) DA Agent : DA_SWSEC_1640_TRUNK_01.bin BR ComPort: COM3 BR Asic Id: MT6580 [0000] BR Asic Sw: 8A00 CA00 0000 0000 BR Fuse Id: 40001002 BR Secured: 1 [SBC] DA Version: MTK_AllInOne_DA_v3.3001.00.00 DA ProtVer: 2 PR MMC CID: 90014A483847346132A5345449635409 [H8G4a2] PR Version: 4.2 [0x9C] (7) MT6580 eMMC BOOT1: 0x0000000000400000 [4.194.304] 4 MB eMMC BOOT2: 0x0000000000400000 [4.194.304] 4 MB eMMC RPMB : 0x0000000000400000 [4.194.304] 4 MB eMMC USER : 0x00000001D2000000 [7.818.182.656] 7.28 GB eMMC CID : 90014A483847346132A5345449635409 [H8G4a2] ERAM Size : 0x0000000040000000 [1.073.741.824] 1024 MB IRAM Size : 0x0000000000020000 [131.072] 128 KB UNICAL ID : E23A4E25FC720AAFC846860D953050B9 PMT (GPT) Found: 25 Partition Entries Reset FRP Done in: 00:04.306 DA Shutdown Done, Disconnect Cable |
![]() | #1086 (permalink) |
![]() | #1087 (permalink) |
Member: 2185549 Status: Offline Thanks Meter: 536 ![]() | Var XIAOMI-Redmi 4X Santoni (Redmi 4X LTE DS) at USB (COM374) [DIAGS] {Gen.Settings} OFFLMODE: OK MDMVERSN: Jun 16 201720:24:26Jul 27 201602:00:008937.gen MDMBUILD: MPSS.JO.1.2.c2-00092-8937_GENNS_PACK-1.101402.2.103461.1_V043 NV IMEI1: 000000-00-000000-0 NV IMEI2: 000000-00-000000-0 NV BTID : 64CC:2E:F003F6 NV WIFI : F703:F0:2ECC64 Gen.Settings Write Done: 2 Item(s) Var XIAOMI-Redmi 4X Santoni (Redmi 4X LTE DS) at USB (COM374) [DIAGS] {Factory Info} OFFLMODE: OK MDMVERSN: Jun 16 201720:24:26Jul 27 201602:00:008937.gen MDMBUILD: MPSS.JO.1.2.c2-00092-8937_GENNS_PACK-1.101402.2.103461.1_V043 NV IMEI1: 359880-09-765565-0 NV IMEI2: 359800-90-887867-1 NV BTID : 64CC:2E:F003F6 NV WIFI : F703:F0:2ECC64 |
![]() | #1088 (permalink) |
![]() | #1090 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2013 Location: Uzbekistan/Tashkent
Member: 2082192 Status: Offline Sonork: not Thanks Meter: 1,119 ![]() | Huawei CUN-U29 Repair IMEI done ! Code: Huawei CUN-U29 (Y5 II 3G DS) at META {Gen.Settings} Insert Cable to Switched OFF Device BR USB Com: Vid_0e8d&Pid_2000 (Preloader) ME USB Com: Vid_0e8d&Pid_2007 (MAUI Meta) ME_MCUID: mt6582,S01 ME_MODEL: CUN-U29C567B127 ME_BLDAT: Fri Aug 5 20:49:05 CST 2016 ME_CHIPS: MT6582, E01 ME_DSPFW: 2000.00.00 ME_DSPPT: 1.0 ME_BOARD: HQ6582_WE_B1B_L1_HSPA_HW ME_SWVER: MOLY.WR8.W1449.MD.WG.MP.V29.5.P5 ME_MLVER: Unknown ME_SERNR: Empty ME_IMEI1: --- ME_IMEI2: --- ME USB Com: Vid_0e8d&Pid_2007 (MAUI Meta) Gen.Settings Write Done: 3 Item(s) ME USB Com: Vid_0e8d&Pid_2007 (MAUI Meta) ME_MCUID: mt6582,S01 ME_MODEL: CUN-U29C567B127 ME_BLDAT: Fri Aug 5 20:49:05 CST 2016 ME_CHIPS: MT6582, E01 ME_DSPFW: 2000.00.00 ME_DSPPT: 1.0 ME_BOARD: HQ6582_WE_B1B_L1_HSPA_HW ME_SWVER: MOLY.WR8.W1449.MD.WG.MP.V29.5.P5 ME_MLVER: Unknown ME_SERNR: CCMBBCB6C0813888 ME_IMEI1: 864098-03-569767-0 ME_IMEI2: 864098-03-571798-1 Huawei CUN-U29 (Y5 II 3G DS) at META {Exit META} ME_METAX: Disconnected |
The Following User Says Thank You to ddilshod93 For This Useful Post: |
![]() | #1091 (permalink) |
Member: 2185549 Status: Offline Thanks Meter: 536 ![]() | OLD IS GOLD LOOK AT WAT IT DID TO D880 MCU File: D880JPHC2_Master.cla CRC32: 2FA7A8B2 Regions : Arabic Language: ar,en,fr(fa,ur) Release : 2008 March Rev: 2 TFS File: D880JPHC2_Slave.tfs CRC32: B4293435 CFG File: D880JPHC2_Slave.cfg 465 byte(s) TFS File: D880JPHC2_Master.tfs CRC32: 01CAEFFB CFG File: D880JPHC2_Master.cfg 205315 byte(s) MCU File: D880JPHC2_Master.cla CRC32: 2FA7A8B2 TFS File: D880JPHC2_Master.tfs CRC32: 01CAEFFB CFG File: D880JPHC2_Master.cfg 205315 byte(s) MCU Id: 3541, PNX5230/31 Preloader Ok, 921600 Baud Flsloader Ok, 1625000 Baud FLASH Id: 00EC2206000100000034, Samsung KAP29WG00M [NAND 1G] NAND Format Complete, Time: 00:09 File CRC: 0x2FA7A8B2 MCU Write Done, 27069520 byte(s), Time: 04:27 File CRC: 0x01CAEFFB TFS Initialised: 1 TFS Version: TFS4.0_CORONA_01 Directories: 162 Max_Files : 2689 Files_Count: 2689/2689 TFS Unmounted TFS Write Done, 51252420 byte(s), Time: 13:56 |
![]() | #1092 (permalink) |
![]() | #1093 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jun 2008 Location: COLOMBIA
Member: 789804 Status: Offline Sonork: 100.1591611 Thanks Meter: 147 | HUAWEI CRO-L23 FULL REMOVED FRP Huawei CRO-L23 (Y5 2017 LTE DS) at USB Auto Select [MTK] {Reset FRP} BR USB Com: Vid_0e8d&Pid_2000 (Preloader) DA Agent : DA_PL_CR.bin BR ComPort: COM15 BR Asic Id: MT0335 [0000] Alias: MT6735 BR Asic Sw: 8A00 CA00 0000 0000 BR Fuse Id: 94010000 BR Secured: 5 [SBC DAA] DA Version: MTK_AllInOne_DA_v3.3001.00.00 DA ProtVer: 2 PR MMC CID: 484A019061344738990ED432CD41045D [a4G8] PR Version: 4.2 [0x93] (5) MT8735 eMMC BOOT1: 0x0000000000400000 [4.194.304] 4 MB eMMC BOOT2: 0x0000000000400000 [4.194.304] 4 MB eMMC RPMB : 0x0000000000400000 [4.194.304] 4 MB eMMC USER : 0x00000001D2000000 [7.818.182.656] 7,28 GB eMMC CID : 90014A483847346132D40E995D0474CD [H8G4a2] ERAM Size : 0x0000000040000000 [1.073.741.824] 1024 MB IRAM Size : 0x0000000000020000 [131.072] 128 KB UNICAL ID : 89EE886C552EF8D8BA4B85A1B0D8D2A3 PMT (GPT) Found: 29 Partition Entries Reset FRP Done in: 00:02.905 DA Shutdown Done, Disconnect Cable Br. Unlocker84 |
![]() | #1094 (permalink) |
Member: 2185549 Status: Offline Thanks Meter: 536 ![]() | Var XIAOMI-Redmi 4 Prime Markw (Redmi 4 Prime LTE DS) at USB (COM9) [DIAGS] {Gen.Settings} OFFLMODE: OK MDMVERSN: Jun 21 201705:15:25Apr 29 201606:00:008953.gen MDMBUILD: MPSS.TA.2.2.c1-00063-8953_GEN_PACK-1.97777.1.98470.1_V047 NV IMEI1: 000000-00-000000-0 NV IMEI2: 000000-00-000000-0 NV BTID : 00EC:0A:AE57C2 NV WIFI : C257:C6:0AEC00 Gen.Settings Write Done: 2 Item(s) Var XIAOMI-Redmi 4 Prime Markw (Redmi 4 Prime LTE DS) at USB (COM9) [DIAGS] {Factory Info} OFFLMODE: OK MDMVERSN: Jun 21 201705:15:25Apr 29 201606:00:008953.gen MDMBUILD: MPSS.TA.2.2.c1-00063-8953_GEN_PACK-1.97777.1.98470.1_V047 NV IMEI1: 359800-90-563653-6 NV IMEI2: 359806-67-554325-7 NV BTID : 00EC:0A:AE57C2 NV WIFI : C257:C6:0AEC00 |
![]() | #1095 (permalink) |
