![]() | #1098 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2014 Location: tripoli,libya Age: 37
Member: 2175357 Status: Offline Sonork: QQ:2157039171 Thanks Meter: 453 ![]() | ![]() nokia 1280 flashing done Code: Detected: V 07.00 11-09-12 RM-647 (c) Nokia If used non Auto-Ignition cable, press Power-On button IF_SBL: XGOLD110, Ok IF_EBL: Default_RAM_Bootloader 10.19, Mode: CC BAUD_R: 3000000 FL_ID : 2000C088, Numonyx M58WR064KU 64Mb MCU FLASH BUNDLE: rm647_007.000 Flash File: hw_b2_rm647_r07.000.fls Erase Area: 0x00800000 - 0x00A0FFFE, Erased: 00:25 Write Area: 0x00800000 - 0x00A0FFFE, Written: 00:16 Erase Area: 0x00C60000 - 0x00EAFFFE, Erased: 00:28 Write Area: 0x00C60000 - 0x00E5A37E, Written: 00:15 Erase Area: 0x00FFC000 - 0x00FFFFFE, Erased: 00:00 Write Area: 0x00FFC000 - 0x00FFC03E, Written: 00:00 PPM FLASH BUNDLE: rm647_007.00ic Flash File: hw_b2_rm647_007.00ic.fls Erase Area: 0x00210000 - 0x0045FFFE, Erased: 00:28 Write Area: 0x00210000 - 0x0034ED3E, Written: 00:09 CNT FLASH BUNDLE: rm6470_nai07.00ic Flash File: hw_b2_rm6470_nai07.00ic.fls Erase Area: 0x00EB0000 - 0x00F7FFFE, Erased: 00:10 Write Area: 0x00EB0000 - 0x00EFF7FE, Written: 00:02 Flashing Done: 02:29 ShutDown Done |
The Following 2 Users Say Thank You to helpo For This Useful Post: |
![]() | #1099 (permalink) |
Member: 2175357 Status: Offline Sonork: QQ:2157039171 Thanks Meter: 453 ![]() | nokia 1100 rest code done Code: MCU SW : V 8.11 19-06-06 RH-18 (c) NMP 1100 PPM SW : V 8.11 19-06-06 RH-18 (c) NMP 1100 IC Prd.Code: 0510227 Bpr.Code: 0510226 Prod.Sn : JC0633014 HW Vers : 0881 UEM : 1092 UPP : 4609 [1201] RFIC Ver: 0300 DSP Vers: PEU2.14-@ LCD Type: SAMSUNG 1 0 IMEI : 355689-00-785570-4 SL Conf : 001-01-00000000000 SL Prof : 000000000000000-2 SL Var : 00003556890078557000 SL Aux : 00020000 HW Sig : 588DCDC32A977A3A Box Id : 894FFFFFFFFFFFFF BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN MastCode: 25 51 71 24 61 Provider: GSM Test Equipment #pw+ 107 324 122 515 431 +1# #pw+ 499 547 611 767 454 +2# #pw+ 225 255 541 374 161 +3# #pw+ 457 327 676 565 031 +4# #pw+ 256 815 471 460 422 +5# #pw+ 728 220 540 674 630 +6# #pw+ 228 265 040 644 671 +7# IMEI: 355689-00-785570-4, ASIC: 2 SimLocks Initialized (NM Ok), Time: 00:00 UI Defaults Ok, Time: 00:02 Set UI Factory Defaults Ok, Time: 00:00 Set Full Factory Defaults Ok, Time: 00:00 Set Software Upgrade Defaults Ok, Time: 00:00 Set Security Ok, Time: 00:00 Init Normal Mode Ok, Time: 00:07 |
![]() | #1101 (permalink) |
Insane Poster ![]() ![]() ![]() Join Date: Jun 2012 Location: vasai, mumbai,india
Member: 1768108 Status: Offline Sonork: [email protected] Thanks Meter: 15 | karbonn aura note2 frp done with ufst (1) select model an da agent from flash file |
![]() | #1102 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: May 2014 Location: UGANDA
Member: 2185549 Status: Offline Thanks Meter: 536 ![]() | Var INFINIX-X603-H575-A (Zero 5 LTE DS) at USB Auto Select [MTK] {Write Flash} Scatter : MT6757_Android_scatter.txt BR USB Com: Vid_0e8d&Pid_0003 (BROM) DA Agent : MTK_AllInTwo_DA.bin BR ComPort: COM30 BR Asic Id: MT0551 [0000] Alias: MT6757 BR Asic Sw: 8A00 CB00 0001 0000 BR Fuse Id: 00000100 DA Version: MTK_AllInOne_DA_v3.3001.2017-12-29.16:29_398885 DA ProtVer: 4 PR BootMod: brom EMI PreLdr: preloader_rlk6757_66_n.bin EMI TagVer: 25 DA Asic Id: MT0551 [8A00 CB00 0001] eMMC BOOT1: 0x0000000000400000 [4.194.304] 4 MB eMMC BOOT2: 0x0000000000400000 [4.194.304] 4 MB eMMC RPMB : 0x0000000001000000 [16.777.216] 16 MB eMMC USER : 0x0000001D1EC00000 [125.069.950.976] 116.48 GB eMMC CID : 150100335636434D42029672C8D29453 [3V6CMB] ERAM Size : 0x0000000180000000 [6.442.450.944] 6 GB IRAM Size : 0x0000000000040000 [262.144] 256 KB UNICAL ID : 1F64443A61C4ECD582428CE48ADD107C DA USB Com: Vid_0e8d&Pid_2001 (DA HighSpeed) DL_GET_PGPT Error: -2 DL_GET_SGPT Error: -2 Partitions to Flash: 14 (116.34 GB) DL_GET_PGPT Error: -2 GPT Build Not Done Write PGPT 32 KB, Done in: 00:00.042 GPT Build Not Done Write SGPT 16.5 KB, Done in: 00:00.032 GPT Repair from Scatter Done Write preloader 256 KB, Skipped Write pgpt 32 KB, Skipped Write boot_para 1024 KB, Skipped Write recovery 12.88 MB, Done in: 00:01.323 Write para 512 KB, Skipped Write expdb 20 MB, Skipped Write frp 1024 KB, Skipped Write nvcfg 8 MB, Skipped Write nvdata 32 MB, Skipped Write metadata 32 MB, Skipped Write protect1 8 MB, Skipped Write protect2 9.47 MB, Skipped Write seccfg 8 MB, Skipped Write sec1 2 MB, Skipped Write proinfo 3 MB, Skipped Write md1img 17.19 MB, Done in: 00:01.704 Write md1dsp 965.28 KB, Done in: 00:00.187 Write md1arm7 192.63 KB, Done in: 00:00.165 Write md3img 528 Byte, Done in: 00:00.078 Write nvram 5 MB, Skipped Write lk 570.33 KB, Done in: 00:00.211 Write lk2 570.33 KB, Done in: 00:00.124 Write boot 10.27 MB, Done in: 00:00.997 Write logo 1.81 MB, Done in: 00:00.293 Write tee1 167 KB, Done in: 00:00.093 Write tee2 167 KB, Done in: 00:00.093 Write system 2.62 GB, Done in: 02:31.787 (Sparsed) Write cache 56.29 KB, Done in: 00:00.145 (Sparsed) Write userdata 32 MB, Done in: 00:03.183 Write flashinfo 16 MB, Skipped Write sgpt 16.5 KB, Skipped Write Done in : 02:40.832 DA Shutdown Done, Disconnect Cable |
The Following User Says Thank You to ferouz kassim For This Useful Post: |
![]() | #1103 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2015 Location: India
Member: 2421242 Status: Offline Sonork: 100.1614558 Thanks Meter: 700 ![]() | Micromax Q4311 Flashing Done Quote:
The Following User Says Thank You to 4G Telecom For This Useful Post: |
![]() | #1104 (permalink) |
Member: 2185549 Status: Offline Thanks Meter: 536 ![]() | ASUS_Z010D FRP RESET DONE Asus Z010D-ZC550KL (ZenFone Max LTE DS) at Auto Select Flash Port [SAHARA] {Reset FRP} Cable Configured: EDL QDL USB Com: Vid_05c6&Pid_9008 (COM111) SAHARA VERS: 2.1 SAHARA HWID: 007050E10029001E [MSM8916] SAHARA HASH: CC3153A80293939B90D02D3BF8B23E0292E452FEF662C74998 421ADAD42A380F SAHARA SERN: 0C220763 (203556707) SAHARA PROG: prog_emmc_firehose_8916_asus1.mbn FHPROG SZFT: 4096 FHPROG SZTT: 16384 FHPROG SPTT: 16384 FHPROG XSIZ: 4096 FHPROG VERS: 1 FHPROG PLTF: 8916 FHPROG MEMT: eMMC FHINFO PAR0: 30785536 x 512 Sectors (14.68 GB) FHINFO PAR1: 8192 x 512 Sectors (4 MB) FHINFO PAR2: 8192 x 512 Sectors (4 MB) FHPROG PART: EFI GPT FHPROG PRTY: 0 FHREST DONE: Ok Reset FRP Done in: 00:00.526 (2) |
![]() | #1105 (permalink) |
Member: 2185549 Status: Offline Thanks Meter: 536 ![]() | LENOVO K53A48 IMEI REPAIR DONE Lenovo K53a48 (K6 Note LTE DS) at USB (COM134) [DIAGS] {Gen.Settings} OFFLMODE: OK MDMVERSN: Nov 15 201609:30:52Aug 24 201602:00:008937.gen MDMBUILD: MPSS.JO.1.2.c2-00099-8937_GENNS_PACK-1 NV IMEI1: 864001-03-416051-8 NV IMEI2: 864001-03-416052-6 NV BTID : 7C46:85:3C1F5A NV WIFI : 5A1F:40:85467C NV SERNR: Empty Gen.Settings Write Done: 2 Item(s) Lenovo K53a48 (K6 Note LTE DS) at USB (COM134) [DIAGS] {Factory Info} OFFLMODE: OK MDMVERSN: Nov 15 201609:30:52Aug 24 201602:00:008937.gen MDMBUILD: MPSS.JO.1.2.c2-00099-8937_GENNS_PACK-1 NV IMEI1: 359807-68-986765-8 NV IMEI2: 359800-98-966576-5 NV BTID : 7C46:85:3C1F5A NV WIFI : 5A1F:40:85467C NV SERNR: Empty |
![]() | #1106 (permalink) | |
Member: 2421242 Status: Offline Sonork: 100.1614558 Thanks Meter: 700 ![]() | Huawei L22 Google Account Remove Done Quote:
![]() | #1107 (permalink) | |
Member: 2421242 Status: Offline Sonork: 100.1614558 Thanks Meter: 700 ![]() | Sony C5302 Pattern lock Remove Done Quote:
![]() | #1108 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2008 Location: PhP Age: 43
Member: 757799 Status: Offline Thanks Meter: 786 | TEST 1 Mtk6592 flashing done MTK MT6592 (eMMC) at USB Auto Select [MTK] {Write Flash} Scatter : MT6592_Android_scatter_emmc.txt BR USB Com: Vid_0e8d&Pid_2000 (Preloader) DA Agent : MTK_AllInOne_DA.bin BR ComPort: COM13 BR Asic Id: MT6592 [0000] BR Asic Sw: 8A00 CA00 0000 0000 BR Fuse Id: 00070380 DA Version: MTK_AllInOne_DA_v3.3001.00.00 DA ProtVer: 2 PR MMC CID: 1501004B3758564D42014939D02EA1EB [K7XVMB] PR Version: 4.2 [0x8A] (7) MT6592 eMMC BOOT1: 0x0000000000400000 [4.194.304] 4 MB eMMC BOOT2: 0x0000000000400000 [4.194.304] 4 MB eMMC RPMB : 0x0000000000080000 [524.288] 512 KB eMMC USER : 0x00000001D2000000 [7.818.182.656] 7.28 GB eMMC CID : 1501004B3758564D42014939D02EA1EB [K7XVMB] ERAM Size : 0x0000000040000000 [1.073.741.824] 1024 MB IRAM Size : 0x0000000000020000 [131.072] 128 KB UNICAL ID : 40C7C6CE38130C594FBE1ABAC1ED907C PMT (EBR) Found: 21 Partition Entries Partitions to Flash: 12 (7.22 GB) Write PRELOADER 256 KB, Skipped Write MBR 512 Byte, Done in: 00:02.846 Write EBR1 512 Byte, Done in: 00:01.542 Write PRO_INFO 3 MB, Skipped Write NVRAM 5 MB, Skipped Write PROTECT_F 10 MB, Skipped Write PROTECT_S 10 MB, Skipped Write SECCFG 256 KB, Skipped Write UBOOT 384 KB, Done in: 00:02.547 Write BOOTIMG 10 MB, Done in: 00:01.004 Write RECOVERY 10 MB, Done in: 00:01.001 Write SEC_RO 6 MB, Done in: 00:00.664 Write MISC 512 KB, Skipped Write LOGO 8 MB, Done in: 00:01.829 Write EBR2 512 Byte, Done in: 00:00.512 Write EXPDB 15.38 MB, Skipped Write ANDROID 904 MB, Done in: 03:21.912 Write CACHE 127 MB, Done in: 00:36.251 Write USRDATA 8.01 MB, Done in: 00:03.434 Write FAT 16 MB, Done in: 00:06.006 Write BMTPOOL 21 MB, Skipped Write Done in : 04:19.716 DA Shutdown Done, Disconnect Cable |
The Following User Says Thank You to trio1 For This Useful Post: |
![]() | #1109 (permalink) |
Member: 2185549 Status: Offline Thanks Meter: 536 ![]() | LG K350N (K8 LTE) at Auto Select Flash Port [LG FLASH 69] {Reset FRP} DL MODE : 2 DL REQM : 5 DL MODEL: LG-K350n DL SWVER: K35010e DL IMEI : 357823-07-307541-2 LF MODEL: LG-K350n LF SERNO: LGK350KFI7PJUC LF SWVER: LGK350nAT-00-V10e-EUR-XX-JUN-30-2016+0 LF MINOS: MiniOS 3.0 LF OSVER: 6.0 LF IMEI : 357823-07-307541-2 LF DVPID: CT67S160522001541 LF SOCTY: mt6735 LF CABLE: USER Reset FRP Done in 00:07. |
The Following 2 Users Say Thank You to ferouz kassim For This Useful Post: |
![]() | #1110 (permalink) |
Member: 757799 Status: Offline Thanks Meter: 786 | Test 2 Mtk 6592 frp Var CLOUDFONE-Excite Prime (Excite Prime 3G DS) at USB Auto Select [MTK] {Reset FRP} BR USB Com: Vid_0e8d&Pid_2000 (Preloader) DA Agent : MTK_AllInOne_DA.bin BR ComPort: COM13 BR Asic Id: MT6592 [0000] BR Asic Sw: 8A00 CA00 0000 0000 BR Fuse Id: 00000380 DA Version: MTK_AllInOne_DA_v3.3001.00.00 DA ProtVer: 2 PR MMC CID: 90014A484147326505073540AD8973E5 [HAG2e] PR Version: 4.2 [0x8A] (7) MT6592 eMMC BOOT1: 0x0000000000400000 [4.194.304] 4 MB eMMC BOOT2: 0x0000000000400000 [4.194.304] 4 MB eMMC RPMB : 0x0000000000400000 [4.194.304] 4 MB eMMC USER : 0x00000003AB800000 [15.762.194.432] 14.68 GB eMMC CID : 90014A484147326505073540AD8973E5 [HAG2e] ERAM Size : 0x0000000080000000 [2.147.483.648] 2 GB IRAM Size : 0x0000000000020000 [131.072] 128 KB UNICAL ID : D2EE087014B40374F8A0C4A3B86D2867 PMT (EBR) Found: 21 Partition Entries Reset FRP Done in: 00:07.365 DA Shutdown Done, Disconnect Cable |
The Following 2 Users Say Thank You to trio1 For This Useful Post: |
