05-10-2018, 14:34 | #1186 (permalink) |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | SAMSUNG SM-J701F (J7 CORE DS) FRP REMOVE Done ONLY NEED TO ON ADB BY CAL APK THANKS UFST-BOX TEAM |
The Following 3 Users Say Thank You to gracy_elec For This Useful Post: |
05-10-2018, 19:12 | #1188 (permalink) |
Freak Poster Join Date: Jun 2011
Member: 1596913 Status: Offline Thanks Meter: 108 | What is the point of Boxing? It cannot switch to ADB! And if itself switched, through a command line it is easier to make! There are new models, methods and principles of unlocking, and the support team ran away! In this position the box in a few months you can throw! |
05-11-2018, 08:22 | #1189 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | SAMSUNG SM-G531F GRAND PRIME FLASH AND RECOVER HANG ON LOGO Done SUCCESSFULLY FLASH AND RECOVER HANG ON LOGO(SAMSUNG SM-G531F GRAND PRIME)USB THANKS UFST-BOX TEAM |
05-12-2018, 07:34 | #1191 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | MICROMAX D320 FLASH AND DEAD RECOVER Done SUCCESSFULLY FLASH AND DEAD RECOVER (MICROMAX D320)USB THANKS UST-BOX TEAM |
05-12-2018, 07:44 | #1192 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | LENOVO A7010A48 VIBE K4 NOTE FLASH AND RECOVER Done SUCCESSFULLY FLASH AND RECOVER(LENOVO A7010A48 VIBE K4 NOTE)USB THANKS UST-BOX TEAM |
05-12-2018, 08:02 | #1193 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | MICROMAX AQ5001 CANVAS JUICE2 FLASH AND SLOVED GOOGLE ERROR Done SUCCESSFULLY FLASH AND SLOVED GOOGLE ERROR(MICROMAX AQ5001 CANVAS JUICE2)USB THANKS UFST-BOX TEAM |
05-19-2018, 09:10 | #1194 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | SAMSUNG SM-G570F J5 PRIME FRP REMOVE Done SUCCESSFULLY REMOVE FRP(SAMSUNG SM-G570F J5 PRIME)USB NEED TO USE FIRST CAL APK TO ON ADB THANKS UFST-BOX TEAM |
05-19-2018, 09:17 | #1195 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | SAMSUNG J701F J7 CORE FRP REMOVE Done SUCCESSFULLY REMOVE FRP(SAMSUNG J701F J7 CORE)USB NEED TO USE FIRST CAL APK TO ON ADB THANKS UFST-BOX TEAM |
05-19-2018, 09:26 | #1196 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | SAMSUNG SM-T116IR TAB 3 7.0 IRIS FRP REMOVE Done SUCCESSFULLY REMOVE FRP(SAMSUNG SM-T116IR TAB 3 7.0 IRIS)USB NEED TO USE FIRST CAL APK TO ON ADB THANKS UFST-BOX TEAM |
05-19-2018, 09:42 | #1198 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | SAMSUNG SM-G610F J7 PRIME FRP REMOVE Done SUCCESSFULLY REMOVE FRP(SAMSUNG SM-G610F J7 PRIME)USB NEED TO USE FIRST CAL APK TO ON ADB THANKS UFST-BOX TEAM |
05-21-2018, 18:04 | #1200 (permalink) | |
No Life Poster Join Date: Apr 2005 Age: 44
Member: 136052 Status: Offline Thanks Meter: 75 | Nokia TA-1029 (Nokia 2) FAQ connect wifi Enable talk back option on vision settings Swipe 'L' shape then open talk back settings Disable Explore by touch option Serch getvioce in help and feedback Play youtube tutoiral video and share it Now you tube app will be open then try to share again Share that link on text massage to 112 Tap call button dail pad *#*#372733#*#* Now FQC menu will be open then tap on Resiver test option Now you will get ADB enable Select Nokia TA-1028 (Nokia 3 LTE LA) Quote:
