Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > UFST
Old 07-05-2018, 11:22   #1216 (permalink)
Member: 575256
Thanks Meter: 34
Originally Posted by gracy_elec View Post
SUCCESSFULLY REMOVE FRP (SAMSUNG SM-G570F J5 PRIME)USB
ONLY NEED TO ON ADB BY CAL APK
Samsung SM-G570F-DS (J5 Prime LTE DS) at USB (COM35) [MODEM] {Kies Info}
MODEMCON: OK
MODEL : SM-G570F
PRODCODE: INS
HIDVERS : G570FDDU1BQI6/G570FODD1BQJ1/G570FDDU1BQJ1/G570FDDU1BQI6
SERIALNR: XXXXXXXXX
CONNECT : AT,MTP
LOCKSTAT: NONE
UNICALID: CRX1035FBCE3493
SW VERS : G570FDDU1BQI6/G570FODD1BQJ1/G570FDDU1BQJ1/G570FDDU1BQI6
IMEI 1 : XXXXXXXXXXXXXXX
Samsung SM-G570F-DS (J5 Prime LTE DS) at USB [ADB] {Reset FRP}
daemon started successfully * 421035fbce3493d9 device
Goto "Backup and reset" Menu and make "Factory data reset"
THANKS UFST-BOX TEAM
step by step to work this brooo,,, pleaseee
Old 07-05-2018, 21:55   #1217 (permalink)
Member: 1596913
Thanks Meter: 108
Still need a first combination file to flash, and then the box is no longer needed!
Boxing without a future is a dead product!
It can't do anything anymore that can with USB cable + Google!
Old 07-11-2018, 16:34   #1218 (permalink)
Member: 2185549
Thanks Meter: 536
Var TECNO-KA7 (Spark 2 3G DS) at USB Auto Select [MTK] {Reset FRP}
BR USB Com: Vid_0e8d&Pid_2000 (Preloader)
DA Agent : DA_SWSEC_TC80.bin
BR ComPort: COM5
BR Asic Id: MT6580 [0000]
BR Asic Sw: 8A00 CA00 0000 0000
BR Fuse Id: 00001002
BR Secured: 5 [SBC DAA]
DA Version: MTK_AllInOne_DA_v3.3001.2017/12/29.10:21_396299.
DA ProtVer: 2
PR MMC CID: 150100464536324D42030DEC977A5519 [FE62MB]
PR Version: 4.2 [0x9C] (7) MT6580
eMMC BOOT1: 0x0000000000400000 [4.194.304] 4 MB
eMMC BOOT2: 0x0000000000400000 [4.194.304] 4 MB
eMMC RPMB : 0x0000000000400000 [4.194.304] 4 MB
eMMC USER : 0x00000003A3E00000 [15.634.268.160] 14.56 GB
eMMC CID : 150100464536324D42030DEC977A5519 [FE62MB]
ERAM Size : 0x0000000040000000 [1.073.741.824] 1024 MB
IRAM Size : 0x0000000000020000 [131.072] 128 KB
UNICAL ID : 213CF95117A19EADA28E86DE2DB8A5A2
PMT (GPT) Found: 28 Partition Entries
Reset FRP Done in: 00:05.081
DA Shutdown Done, Disconnect Cable
The Following User Says Thank You to ferouz kassim For This Useful Post:
Old 07-11-2018, 16:41   #1219 (permalink)
Member: 2185549
Thanks Meter: 536
Asus X00HD-ZC520KL-37 (ZenFone 4 Max LTE DS) at Auto Select Flash Port [SAHARA] {Reset FRP}
QDL USB Com: Vid_05c6&Pid_9008 (COM27)
SAHARA VERS: 2.1
SAHARA HWID: 0004F0E100000000 [MSM8937]
SAHARA HASH: 49D087CA08C6E2CA3D209C5697971E85D42A2F632592E68230 C7D780F7D5DC1F
SAHARA SERN: 515EF03A (1365176378)
SAHARA PROG: prog_emmc_firehose_8937_ddr_asus1.mbn.
FHPROG SZFT: 4096
FHPROG SZTT: 131072
FHPROG SPTT: 1048576
FHPROG XSIZ: 4096
FHPROG VERS: 1
FHPROG PLTF: 8937
FHPROG MEMT: eMMC
FHINFO DSK0: 61071360 x 512 Sectors (29.12 GB)
FHINFO DSK1: 8192 x 512 Sectors (4 MB)
FHINFO DSK2: 8192 x 512 Sectors (4 MB)
FHPROG PART: EFI GPT
FHPROG PRTY: 0
FHREST DONE: Ok
Reset FRP Done in: 00:00.775 (1)
Old 07-11-2018, 16:41   #1220 (permalink)
Member: 2185549
Thanks Meter: 536
sony z ultra password solved
Sony C6833 (Xperia Z Ultra LTE Togari) at USB Auto Select [S1] {Write Flash}
Files to Flash: 1
USB DEV : SEMC [USB\VID_0FCE&PID_ADDE\5&1b53c060&0&2]
BL VERS : S1_Boot_MSM8974_Rhine1.3.1_LA1.04_16
BL PKTSZ: 0x00010000
BL IMEI : 357656-05-062253-7
BL ROOTS: ROOTABLE
TA MODEL: C6802
TA DEVSN: EP7325KQC0
TA CDVER: 1275-7796_R1D
TA SWVER: 1271-5715_14.6.A.1.236
TA FLVER: GLOBAL-HSPA_14.6.A.1.236
Loader Boot Done in 00:00.075
FL VERS : LOADER_RELEASE_MSM8974_28_AID_4
FL PKTSZ: 0x00080000
FL IMEI : 357656-05-062253-7
TA MODEL: C6802
TA S1VER: 1270-3115 S1_Boot_MSM8974_Rhine1.3.1_LA1.04_16
TA FTIME: 2016-06-15 01:21:13
AT PLFRT:
AT OTLCK: LOCKED
AT OTDAT: 01000400
AT IDCOD: 607B00E1
Writing File: userdata.sin
File Write Done in 00:06.690 + 00:13.703
Shut Down Ok
All Done in 00:33.685
Old 07-11-2018, 17:19   #1221 (permalink)
Member: 2185549
Thanks Meter: 536
Nokia TA-1029 (Nokia 2 LTE DS) at Auto Select Flash Port [SAHARA] {Reset FRP}
SAHARA VERS: 2.1
SAHARA HWID: 009600E100000000 [MSM8909]
SAHARA HASH: F5F4192A33B2830974B400119BAB728CC9FE911011F928625C 2AED0DA441AC97
SAHARA SERN: 115AE984 (291170692)
SAHARA PROG: prog_emmc_firehose_8909_ddr_hmd.mbn.
FHPROG SZFT: 4096
FHPROG SZTT: 131072
FHPROG XSIZ: 4096
FHPROG VERS: 1
FHPROG PLTF: 8909
FHPROG MEMT: eMMC
FHINFO DSK0: 15269888 x 512 Sectors (7.28 GB)
FHPROG PRTY: 0
FHREST DONE: Ok
Reset FRP Done in: 00:00.190 (1)
Old 07-13-2018, 23:13   #1222 (permalink)
Member: 2185549
Thanks Meter: 536
ONE PLUS FLASHIMNG DONE FLASH PARTIALLY TILL JOB DONE
Var ONEPLUS-OnePlus 3T (OnePlus 3T LTE DS) at Auto Select Flash Port [SAHARA] {Write Flash}
Flash Bundle: rawprogram0.xml
SAHARA VERS: 2.1
SAHARA HWID: 0005F0E12A703DB9 [MSM8996PR]
SAHARA HASH: C0C66E278FE81226585252B851370EABF8D4192F0F335576C3 028190D49D14D4
SAHARA SERN: 56B68755 (1454802773)
SAHARA PROG: prog_ufs_firehose_8996_ddr_on3t.elf.
FHPROG SZFT: 4096
FHPROG SZTT: 32768
FHPROG SPTT: 32768
FHPROG XSIZ: 4096
FHPROG VERS: 1
FHPROG PLTF: MSM8996
FHPROG MEMT: UFS
FHPROG PART: UNKNOWN
FHPROG PRTY: 16
Partitions to Write: 13 (410.22 MB)
FWRITE DONE: ST 0x0000000008 persist 32 MB (Unsparsed Size)
FWRITE DONE: ST 0x0000002008 cache 256 MB (Unsparsed Size)
FWRITE DONE: ST 0x0000012188 devcfg 50.2 KB
FWRITE DONE: ST 0x00000121A8 devcfgbak 50.2 KB
FWRITE DONE: ST 0x0000012248 oem_dycnvbk 1.78 MB
FWRITE DONE: ST 0x0000012C48 oem_stanvbk 492 KB
FWRITE DONE: ST 0x0000013648 param 1024 KB
FWRITE DONE: ST 0x0000013748 reserve1 7.91 MB
FWRITE DONE: ST 0x0000013F30 reserve2 15.81 MB
FWRITE DONE: ST 0x0000014F00 config 512 KB
FWRITE DONE: ST 0x0000014F80 userdata 53.49 GB (Unsparsed Size)
FWRITE DONE: ST 0x0000000000 PrimaryGPT 24 KB
FWRITE DONE: ST 0x0000000005 BackupGPT 20 KB
FPATCH DONE: 13
FHREST DONE: Ok
Write Flash Done in: 55:09.619
Flash Bundle: rawprogram1.xml
SAHARA VERS: 2.1
FHPROG SZFT: 4096
FHPROG SZTT: 32768
FHPROG SPTT: 32768
FHPROG XSIZ: 4096
FHPROG VERS: 1
FHPROG MEMT: UFS
FHINFO MEMN: SAMSUNG KLUCG4J1CB-B0B1 0800
FHINFO LUCN: 6
FHPROG PRTY: 16
Partitions to Write: 3 (1.79 MB)
FWRITE DONE: DK 1 ST 0x0000000006 xbl 1.74 MB
FWRITE DONE: DK 1 ST 0x0000000000 PrimaryGPT 24 KB
FWRITE DONE: DK 1 ST 0x0000000005 BackupGPT 20 KB
FPATCH DONE: 13
FHREST DONE: Ok
Write Flash Done in: 00:00.469
Flash Bundle: rawprogram2.xml
SAHARA VERS: 2.1
FHPROG SZFT: 4096
FHPROG SZTT: 32768
FHPROG SPTT: 32768
FHPROG XSIZ: 4096
FHPROG VERS: 1
FHPROG MEMT: UFS
FHINFO LUCN: 6
FHPROG PRTY: 16
FWRITE DONE: DK 2 ST 0x0000000006 xblbak 1.74 MB
FWRITE DONE: DK 2 ST 0x0000000000 PrimaryGPT 24 KB
FWRITE DONE: DK 2 ST 0x0000000005 BackupGPT 20 KB
FPATCH DONE: 13
FHREST DONE: Ok
Write Flash Done in: 00:00.313
Flash Bundle: rawprogram3.xml
SAHARA VERS: 2.1
FHPROG SZFT: 4096
FHPROG SZTT: 32768
FHPROG SPTT: 32768
FHPROG XSIZ: 4096
FHPROG VERS: 1
FHPROG MEMT: UFS
FHINFO LUCN: 6
FHPROG PRTY: 16
Partitions to Write: 2 (44 KB)
FWRITE DONE: DK 3 ST 0x0000000000 PrimaryGPT 24 KB
FWRITE DONE: DK 3 ST 0x0000000005 BackupGPT 20 KB
FPATCH DONE: 13
FHREST DONE: Ok
Write Flash Done in: 00:00.094
Flash Bundle: rawprogram4.xml
SAHARA VERS: 2.1
FHPROG SZFT: 4096
FHPROG SZTT: 32768
FHPROG SPTT: 32768
FHPROG XSIZ: 4096
FHPROG VERS: 1
FHPROG MEMT: UFS
FHINFO LUCN: 6
FHPROG PRTY: 16
Partitions to Write: 30 (2.93 GB)
FWRITE DONE: DK 4 ST 0x0000000006 rpm 224.04 KB
FWRITE DONE: DK 4 ST 0x0000000086 rpmbak 224.04 KB
FWRITE DONE: DK 4 ST 0x0000000106 tz 1.57 MB
FWRITE DONE: DK 4 ST 0x0000000306 tzbak 1.57 MB
FWRITE DONE: DK 4 ST 0x0000000506 hyp 253.49 KB
FWRITE DONE: DK 4 ST 0x0000000586 hypbak 253.49 KB
FWRITE DONE: DK 4 ST 0x0000000806 sec 436 Byte
FWRITE DONE: DK 4 ST 0x000000080A pmic 41.84 KB
FWRITE DONE: DK 4 ST 0x000000088A pmicbak 41.84 KB
FWRITE DONE: DK 4 ST 0x000000090A modem 82.7 MB
FWRITE DONE: DK 4 ST 0x000000680A dsp 16 MB
FWRITE DONE: DK 4 ST 0x000000790A mdtp 7.9 MB
FWRITE DONE: DK 4 ST 0x000000990A aboot 1.38 MB
FWRITE DONE: DK 4 ST 0x000000A10A abootbak 1.38 MB
FWRITE DONE: DK 4 ST 0x000000A90A LOGO 768 KB
FWRITE DONE: DK 4 ST 0x000000B90A boot 14.26 MB
FWRITE DONE: DK 4 ST 0x000000F90A boot_aging 17.14 MB
FWRITE DONE: DK 4 ST 0x000001390A system 2.94 GB (Unsparsed Size)
FWRITE DONE: DK 4 ST 0x00000CF90A recovery 21.69 MB
FWRITE DONE: DK 4 ST 0x00000D390B bluetooth 396 KB
FWRITE DONE: DK 4 ST 0x00000D3A0B keymaster 348.89 KB
FWRITE DONE: DK 4 ST 0x00000D3A8B keymasterbak 348.89 KB
FWRITE DONE: DK 4 ST 0x00000D3B0B cmnlib 200.66 KB
FWRITE DONE: DK 4 ST 0x00000D3B4B cmnlibbak 200.66 KB
FWRITE DONE: DK 4 ST 0x00000D3B8B cmnlib64 254.22 KB
FWRITE DONE: DK 4 ST 0x00000D3BCB cmnlib64bak 254.22 KB
FWRITE DONE: DK 4 ST 0x00000D3C0B apdp 12.94 KB
FWRITE DONE: DK 4 ST 0x00000D3C4B msadp 256 KB
FWRITE DONE: DK 4 ST 0x0000000000 PrimaryGPT 24 KB
FWRITE DONE: DK 4 ST 0x0000000005 BackupGPT 20 KB
FPATCH DONE: 13
FHREST DONE: Ok
Write Flash Done in: 03:47.318
Flash Bundle: rawprogram5.xml
SAHARA VERS: 2.1
FHPROG SZFT: 4096
FHPROG SZTT: 32768
FHPROG SPTT: 32768
FHPROG XSIZ: 4096
FHPROG VERS: 1
FHPROG MEMT: UFS
FHINFO LUCN: 6
FHPROG PRTY: 16
Partitions to Write: 3 (556 KB)
FWRITE DONE: DK 5 ST 0x0000000407 md5 512 KB
FWRITE DONE: DK 5 ST 0x0000000000 PrimaryGPT 24 KB
FWRITE DONE: DK 5 ST 0x0000000005 BackupGPT 20 KB
FPATCH DONE: 13
FHREST DONE: Ok
Write Flash Done in: 00:00.250
Old 07-14-2018, 10:39   #1223 (permalink)
profkefah's Avatar
Member: 2371500
Thanks Meter: 5,922
nokia 106 RM-962 local mode solved by flashing
If used non Auto-Ignition cable, press Power-On button
IF_SBL: XGOLD110, Ok
IF_EBL: Default_RAM_Bootloader 10.27, Mode: CC
BAUD_R: 3000000
FL_ID : EF001760, Winbond W25Q64DW 64Mb
ShutDown Done
Rebooting Mobile
MCU SW : V 03.10 28-10-13 RM-962 (c) Nokia
PPM SW : V 02.90 21-08-13 RM-962 (c) Nokia IC
Platform: Infineon XG110
Prd.Code: 059W4L6
Bpr.Code: 059V5H8
Prod.Sn : 7A1D060AU
HW Vers : 3500
UEM : 1328
UPP : 8850 [2292]
LCD Type: TINAMA:BARACOAv8F NT39121
IMEI : 357141-06-901591-6
SL Conf : 001-01-00000000000
SL Prof : 000000000004000-2
SL Var : 00003571410690159100
SL Aux : 000B0000
HW Sig : AFCC2B1F85E4C2CA
Box Id : FFFFFFFFFFFFFFFF
BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
Provider: GSM Test Equipment
Init Normal Mode Ok, Time: 00:02
BAUD_R: 3000000
PPM FLASH BUNDLE: rm962_02.90ic
Flash File: hw_b1_rm962_02.90ic.fls
Erase Area: 0x00210000 - 0x0045FFFE, Erased: 00:08
Write Area: 0x00210000 - 0x0039A33E, Written: 00:11
Warning, Checksum Mismatch: 6B15 > 8A7D
CNT FLASH BUNDLE: rm962_nai02.90ic
Flash File: hw_b1_rm962_nai02.90ic.fls
Erase Area: 0x00EB0000 - 0x00F7FFFE, Erased: 00:03
Write Area: 0x00EB0000 - 0x00F161BE, Written: 00:03
Warning, Checksum Mismatch: 7E6F > 7A1C
Flashing Done: 00:33
ShutDown Done
The Following User Says Thank You to profkefah For This Useful Post:
Old 07-17-2018, 09:53   #1224 (permalink)
Member: 2185549
Thanks Meter: 536
FERO-Pace2 (Pace 2 3G DS) at USB Auto Select [MTK] {Reset FRP}
DA Agent : DA_SWSEC_580_N.bin
BR ComPort: COM20
DA AgentId: SA6B1EC25E16CD4357
DA Version: MTK_AllInOne_DA_v3.3001.00.00.
DA ProtVer: 2
PR MMC CID: 150100464531324D420DD810CE218427 [FE12MB]
PR Version: 4.2 [0x94] (7) MT8591
eMMC CID : 150100464531324D420DD810CE218427 [FE12MB]
UNICAL ID : BA9A0E7795DF80B4FEDD7ACC003125E5
PMT (GPT) Found: 23 Partition Entries
Reset FRP Done in: 00:04.782
Old 07-17-2018, 10:49   #1225 (permalink)
Member: 2185549
Thanks Meter: 536
Var INFINIX-X606B (Hot 6 3G DS) at USB Auto Select [MTK] {Reset FRP}
BR ComPort: COM20
DA AgentId: SAD21B0835C3004C67
DA ProtVer: 2
PR MMC CID: 150100464536324D420388A2D4693591 [FE62MB]
eMMC CID : 150100464536324D420388A2D4693591 [FE62MB]
UNICAL ID : 7B60CC73F6D51E6A7A2B90A79949B915
Reset FRP Done in: 00:04.574
Old 07-17-2018, 11:05   #1226 (permalink)
Member: 2185549
Thanks Meter: 536
sonny pasword solved by flashing only userdata
Sony E6833 (Xperia Z5 Premium LTE DS Satsuki) at USB Auto Select [S1] {Write Flash}
Files to Flash: 1
USB DEV : SOMC [USB\VID_0FCE&PID_ADDE\7&25d50505&0&3]
BL VERS : S1_Boot_MSM8994_LA1.2.2_38
BL PKTSZ: 0x00080000
BL IMEI : 352188-07-077875-5
BL ROOTS: ROOTABLE
TA MODEL: E6833
TA DEVSN: CB5A2A4TB2
TA CDVER: 1299-1308_R8C
TA SWVER: 1296-2454_32.1.A.1.163
TA FLVER: GENERIC_32.1.A.1.163
Loader Boot Done in 00:00.365
FL VERS : MSM8994_50
FL PKTSZ: 0x00400000
FL IMEI : 352188-07-077875-5
TA MODEL: E6833
TA S1VER: 1289-5620 S1_Boot_MSM8994_LA1.2.2_38
AT PLFRT: F421B16FFDD52124A7107C2156B6C478355991BC9D88F0F868 2CD08F127A0FA5
AT OTLCK: LOCKED
AT OTDAT: 01000400
AT IDCOD: 109400E1
File Write Done in 00:08.764 + 00:23.267
Shut Down Ok
All Done in 00:33.823
Old 07-21-2018, 08:10   #1227 (permalink)
Member: 2185549
Thanks Meter: 536
Huawei MYA-U29 (Y5 2017 3G DS Maya) at USB Auto Select [MTK] {Reset FRP}
DA Agent : DA_SWSEC_MYAU29.bin
BR ComPort: COM15
BR Secured: 1 [SBC]
DA AgentId: SA156E61200748FFB0
DA ProtVer: 2
PR MMC CID: 150100514531334D420DFE0D680974D5 [QE13MB]
eMMC CID : 150100514531334D420DFE0D680974D5 [QE13MB]
ERAM Size : 0x0000000080000000 [2.147.483.648] 2 GB
UNICAL ID : 0915501BF152B486B7BCBC220D23BC90
PMT (GPT) Found: 29 Partition Entries
Reset FRP Done in: 00:04.955
The Following 2 Users Say Thank You to ferouz kassim For This Useful Post:
Old 07-29-2018, 10:22   #1228 (permalink)
ddilshod93's Avatar
Member: 2082192
Sonork: not
Thanks Meter: 1,119
XIAOMI-Mi Mix 2S Polaris (Mi Mix 2S LTE DS) FRP Rest Done!
Var XIAOMI-Mi Mix 2S Polaris (Mi Mix 2S LTE DS) at USB [ADB] {ADB Info}
daemon started successfully * 8b8ee72 device
BOOTSERN: 8b8ee72
PRDBRAND: Xiaomi
PRDMODEL: Mi MIX 2S
PRDNAME : polaris
BLDVERS : 8.0.0
BLDDISID: OPR1.170623.032
BLDPROD : polaris
PRODBRD : sdm845
BRDPLATF: sdm845
HARDWARE: qcom
USB CNFG: mtp,adb
Superuser Permissions Denied
Var XIAOMI-Mi Mix 2S Polaris (Mi Mix 2S LTE DS) at USB [ADB] {Reset FRP}
The Following 2 Users Say Thank You to ddilshod93 For This Useful Post:
Old 07-31-2018, 09:23   #1229 (permalink)
Member: 142632
Sonork: 100.1589012
Thanks Meter: 460
WIKO VIEW Reset FRP OK
QC MSM8917 (eMMC) at Auto Select Flash Port [SAHARA] {Reset FRP}
QDL USB Com: Vid_05c6&Pid_9008 (COM12)
SAHARA VERS: 2.1
SAHARA HWID: 000560E100007705 [MSM8917]
SAHARA HASH: ADCB7C0B68663755FD192E25C3158C7B13C234483A91460BF8 1F98219DE35F4D
SAHARA SERN: CBE217F4 (3420592116)
SAHARA PROG: prog_emmc_firehose_8917_ddr_wik.mbn.
FHPROG SZFT: 4096
FHPROG SZTT: 131072
FHPROG XSIZ: 4096
FHPROG VERS: 1
FHPROG PLTF: 8917
FHPROG MEMT: eMMC
FHINFO DSK0: 61071360 x 512 Sectors (29,12 GB)
FHPROG PRTY: 0
FHREST DONE: Ok
Reset FRP Done in: 00:00.140 (1)
The Following 2 Users Say Thank You to Umbabaraumba For This Useful Post:
Old 07-31-2018, 14:37   #1230 (permalink)
Member: 2185549
Thanks Meter: 536
Lenovo TB3-730X (Tab 3 A7-30 LTE) at USB [ADB] {Factory Info}
daemon started successfully * 5PQGCANJWSLV75QO device
Superuser Permissions Granted (SU)
MD_CHIPS: MT6735, E00
MD_BOARD: WT8735_6TTB_M_HW
MD_SWVER: MOLY.LR9.W1444.MD.LWTG.MP.V79.P9
MD_SERNR: 8S3200094051WT8575D03ZQ HZC7RZVB
MD_IMEI1: 869432-02-892855-9
Lenovo TB3-730X (Tab 3 A7-30 LTE) at USB [ADB] {Gen.Settings}
MD_IMEI2: 869432-02-892856-7
Gen.Settings Write Done: 2 Item(s)
MD_IMEI1: 359880-99-565656-0
MD_IMEI2: 359808-98-656565-6
lenovo tb3 imei repair done in adb
Page generated in 0.26424 seconds with 9 queries
