Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > UFST
Old 11-07-2018, 08:52   #1351 (permalink)
VIJAY2U2's Avatar
Member: 1039903
Thanks Meter: 2,040
Arrow Motorola XT1902-2 Frp
Motorola XT1902-2 (Lenovo K8 Plus LTE DS Marino) at USB Auto Select [MTK] {Reset FRP}
MTK Flash Port not Found: Vid_0e8d&Pid_2000 Vid_0e8d&Pid_0003
BR USB Com: Vid_0e8d&Pid_2000 (Preloader)
DA Agent  : MTK_AllInOne_DA_57M1.bin
BR ComPort: COM53
BR Asic Id: MT0551 [0000] Alias: MT6757
BR Asic Sw: 8A00 CB00 0001 0000
BR Fuse Id: 00040100
BR Secured: 01  [SBC]
DA AgentId: SAF63091DF65613DBC
DA Version: MTK_AllInOne_DA_v3.3001.2017/03/20.13:19.
DA ProtVer: 4
PR DlagVer: 1.0
PR BootMod: preloader
DA Asic Id: MT0551 [8A00 CB00 0001 0001 0000]
eMMC BOOT1: 0x0000000000400000 [4.194.304] 4 MB
eMMC BOOT2: 0x0000000000400000 [4.194.304] 4 MB
eMMC RPMB : 0x0000000000400000 [4.194.304] 4 MB
eMMC USER : 0x0000000747C00000 [31.268.536.320] 29.12 GB
eMMC CID  : 150100475836424D4203046EAA5B5403 [GX6BMB]
ERAM Size : 0x0000000080000000 [2.147.483.648] 2 GB
IRAM Size : 0x0000000000040000 [262.144] 256 KB
UNICAL RID: 7983A598EF913A4FD05C31CA15269C70
DA USBconf: high-speed
PGPT Found: 37 Partition Entries
SGPT Found: 37 Partition Entries
Reset FRP Done in: 00:03.711 (2)
DA Shutdown Done, Disconnect Cable
The Following User Says Thank You to VIJAY2U2 For This Useful Post:
Old 11-07-2018, 11:09   #1352 (permalink)
VIJAY2U2's Avatar
Member: 1039903
Thanks Meter: 2,040
Arrow GIONEE-S6S Frp
Var GIONEE-S6S (S6S LTE DS) at USB Auto Select [MTK] {Reset FRP}
DA Agent  : MTK_AllInOne_DA.bin
BR ComPort: COM34
BR Asic Id: MT0337 [0000] Alias: MT6735
BR Asic Sw: 8A00 CA00 0000 0000
BR Fuse Id: 54000000
DA AgentId: SA86FBA18A078C6693
DA Version: MTK_AllInOne_DA_v3.3001.00.00.
DA ProtVer: 2
PR MMC CID: 150100525831424D4207F0D4C24D9341 [RX1BMB]
PR Version: 4.2 [0x9B] (5)     MT6735
eMMC CID  : 150100525831424D4207F0D4C24D7341 [RX1BMB]
ERAM Size : 0x00000000C0000000 [3.221.225.472] 3 GB
IRAM Size : 0x0000000000020000 [131.072] 128 KB
UNICAL RID: 373BC29499766BE1A027779AB49B4872
PMT (GPT) Found: 25 Partition Entries
Reset FRP Done in: 00:03.083 (0)
Old 11-12-2018, 11:58   #1353 (permalink)
Member: 2185549
Thanks Meter: 536
Var OPPO-F5 Youth (F5 Youth LTE DS CPH1725) at USB Auto Select [MTK] {Write Flash}
Scatter : MT6763_Android_scatter.txt
BR USB Com: Vid_0e8d&Pid_0003 (BROM)
DA Agent : DA_OPPO_F5_1.bin
BR ComPort: COM9
BR Asic Id: MT0690 [0000] Alias: MT6763
BR Asic Sw: 8A00 CA01 0001 0000
BR ME_ID : F64763523668FAB6D4D03CDB20E54D0F
BR Secured: E5 [SBC DAA]
DA AgentId: SAA91A0C4C83687559
DA Version: MTK_AllInOne_DA_v3.3001.2017/09/22.09:22.
Auth File : Oppo_F6_auth_sv5.auth
AuthFileId: SABE4D915BCF9C36BF
DA ProtVer: 4
PR DlagVer: 1.0
PR BootMod: brom
EMI PreLdr: preloader_oppo6763_17031.bin
EMI TagVer: 30
DA Asic Id: MT0690 [8A00 CA01 0001 0000 0000]
eMMC CID : 90014A484247346132A5211BA538B445 [HBG4a2]
UNICAL RID: 076E0E7416D95850019B69C000BE4D78
PGPT Found: 40 Partition Entries
SGPT Found: 40 Partition Entries
Partitions to Flash: 16 (28.75 GB)
Write preloader 250.8 KB, Done in: 00:00.793
Write pgpt 32 KB, Skipped
Write boot_para 1024 KB, Skipped
Write recovery 18.09 MB, Done in: 00:01.352
Write para 512 KB, Skipped
Write reserve1 2 MB, Skipped
Write reserve2 16 MB, Skipped
Write reserve3 2 MB, Skipped
Write reserve4 16 MB, Skipped
Write oppo_custom 1024 KB, Skipped
Write expdb 20 MB, Skipped
Write frp 1024 KB, Skipped
Write nvcfg 32 MB, Skipped
Write nvdata 64 MB, Skipped
Write metadata 32 MB, Skipped
Write protect1 8 MB, Skipped
Write protect2 12.47 MB, Skipped
Write seccfg 8 MB, Skipped
Write persist 48 MB, Skipped
Write sec1 2 MB, Skipped
Write proinfo 3 MB, Skipped
Write md1img 32.61 MB, Done in: 00:01.933
Write md1dsp 6 MB, Done in: 00:00.580
Write spmfw 39.31 KB, Done in: 00:00.124
Write sspm_1 348.08 KB, Done in: 00:00.138
Write sspm_2 348.08 KB, Done in: 00:00.136
Write gz1 16 MB, Skipped
Write gz2 16 MB, Skipped
Write nvram 64 MB, Skipped
Write lk 675.58 KB, Done in: 00:00.152
Write lk2 675.58 KB, Done in: 00:00.154
Write boot 11.12 MB, Done in: 00:00.815
Write logo 7.29 MB, Done in: 00:00.594
Write tee1 441.83 KB, Done in: 00:00.213
Write tee2 441.83 KB, Done in: 00:00.241
Write system 2.62 GB, Done in: 01:37.468 (Sparsed)
Write cache 8.63 MB, Done in: 00:00.683 (Sparsed)
Write userdata 3.47 GB, Done in: 01:53.584 (Sparsed)
Write flashinfo 16 MB, Skipped
Write sgpt 16.5 KB, Skipped
Write Done in : 03:40.143
The Following User Says Thank You to ferouz kassim For This Useful Post:
Old 11-12-2018, 12:19   #1354 (permalink)
Member: 2185549
Thanks Meter: 536
BR ComPort: COM9
DA ProtVer: 4
PR DlagVer: 1.0
PR BootMod: brom
EMI TagVer: 30
Old 11-12-2018, 16:29   #1355 (permalink)
Member: 142632
Sonork: 100.1589012
Thanks Meter: 460
ZTE Blade L110 Reset FRP OK !
Var ZTE-Blade L110 (Blade L110 3G DS) at USB Auto Select [SPRD] {Reset FRP}
BOOT: FDL1 and FDL2 from Default [DA] SC7731G_1_fdl
Hold Vol+, Vol- and Insert Cable to Switched OFF Device
SROM: SPRD3
FDL1: Spreadtrum Boot Block version 1.1
FDL2: Ok, 96
Reset FRP Done in: 00:00.133
Restart Done, Disconnect Cable
All Done in: 00:10.558
The Following 2 Users Say Thank You to Umbabaraumba For This Useful Post:
Old 11-18-2018, 06:33   #1356 (permalink)
ahmadge's Avatar
Member: 603971
Thanks Meter: 730
Alcatel 5098O Frp Done
here logo
Alcatel 5098O (Pixi 4-6 LTE) at Auto Select Flash Port [SAHARA] {Reset FRP}
QDL USB Com: Vid_05c6&Pid_9008 (COM104)
SAHARA VERS: 2.1
SAHARA HWID: 009600E100000000 [MSM8909]
SAHARA HASH: CC3153A80293939B90D02D3BF8B23E0292E452FEF662C74998 421ADAD42A380F
SAHARA SERN: 0A1F25B7 (169813431)
SAHARA PROG: prog_emmc_firehose_8909_alcH.mbn
SAHARA PRID: SAD6B0A32C5B20E79B
FHPROG SZFT: 4096
FHPROG SZTT: 16384
FHPROG SPTT: 16384
FHPROG XSIZ: 4096
FHPROG VERS: 1
FHPROG PLTF: 8909
FHPROG MEMT: eMMC
FHINFO DSK0: 30777344 x 512 Sectors (14.68 GB)
FHINFO DSK1: 8192 x 512 Sectors (4 MB) Default
FHINFO DSK2: 8192 x 512 Sectors (4 MB) Default
FHPROG PART: EFI GPT
FHPROG PRTY: 5
Reset FRP Done in: 00:01.767 (3)
Thnx UFST Team
{Ahmadge}
The Following User Says Thank You to ahmadge For This Useful Post:
Old 11-18-2018, 06:39   #1357 (permalink)
ahmadge's Avatar
Member: 603971
Thanks Meter: 730
Qmobile S2 frp Done
here logo
Var QMOBILE-S2 (Noir S2 3G DS) at USB Auto Select [MTK] {Reset FRP}
BR ComPort: COM20
BR Asic Id: MT6580 [0000]
BR Fuse Id: 00001002
DA ProtVer: 2
PR MMC CID: 90014A483847316505070FA96C0AB2E3 [H8G1e]
PR Version: 4.2 [0x9C] (7) MT6580
eMMC USER : 0x00000001D2000000 [7.818.182.656] 7.28 GB
eMMC CID : 90014A483847316505070FA96C0AB2E3 [H8G1e]
ERAM Size : 0x0000000040000000 [1.073.741.824] 1024 MB
UNICAL RID: E9D87D0E6F2929FAF8BF9BE840338E9C
PMT (GPT) Found: 23 Partition Entries
Reset FRP Done in: 00:04.473 (0)
Thnx UFST Team
{Ahmadge}
The Following 2 Users Say Thank You to ahmadge For This Useful Post:
Old 11-19-2018, 17:18   #1358 (permalink)
julius84's Avatar
Member: 2524486
Thanks Meter: 112
Sony C5303 Screen lock reset
Sony C5303 (Xperia SP LTE Huashan) at USB Auto Select [S1] {Write Flash}
Files to Flash: 1
USB DEV : SOMC [USB\VID_0FCE&PID_ADDE\6&b7eb83f&1&4]
BL VERS : R11B023
BL PKTSZ: 0x00010000
BL IMEI : 356604-05-098358-3
BL ROOTS: ROOTED
TA MODEL: C5303
TA DEVSN: CB51244KM4
TA CDVER: 1272-3346_R6A
TA SWVER: 1269-3538_12.0.A.2.245
TA FLVER: GLOBAL-LTE_12.0.A.2.245
Loader Boot Done in 00:00.071
FL VERS : R5G006
FL PKTSZ: 0x00010000
FL IMEI : 356604-05-098358-3
TA MODEL: C5303
TA S1VER: 1270-4027 R11B023
TA FTIME: 2015-10-06 21:13:42
AT PLFRT:
AT OTLCK: LOCKED
AT OTDAT: 01000100
AT IDCOD: 107E50E1
Writing File: userdata.sin
File Write Done in 00:12.085 + 00:08.424
Shut Down Ok
All Done in 00:33.048
The Following User Says Thank You to julius84 For This Useful Post:
Old 11-20-2018, 11:26   #1359 (permalink)
julius84's Avatar
Member: 2524486
Thanks Meter: 112
Samsung GT-P5100 Imei Repair Succes and emergency alls only fixed
GT-P5100 at USB (COM39) [MODEM]
ProdCode: GT-P5100ZWAXME
IMEI: 352816-0[
IMEI: Certificate OK
SKID: 0780
MSLA: RF1C63Z250
BTID: B8D9CE-ECE1FD
WiFi: B8D9CE-ECE1FE
SWVE: P5100XXDMD1
UNID: CMA07BA13C4C65F
HWVE: MP0.600
SERN: RF1C63Z250L
PREC: XME [Maxis - Malaysia]
PROV: NONE
S/N Rebuid Done, Reboot Device to See Changes
MSLA: RF1C63Z250
SERN: RF1C63Z250S
MCK : < CRYPTED >
NCK : < CRYPTED >
NSCK: < CRYPTED >
SPCK: < CRYPTED >
CPCK: < CRYPTED >
SIM : < CRYPTED >
Emergency Calls Fixed
GT-P5100 at USB [ADB]
List of devices attached
RILSN: RF1C63Z250S
RILMD: P5100
RILSW: P5100DXDMD1
PRNAM: espresso10rfxx
ANDRV: 4.1.2
ANDRB: JZO54K.P5100XXDMD1
BOSER: c1607ba13c4c65f
MODEL: GT-P5100
Superuser Permissions Granted
Transfered: 2182 KB/s (20971520 bytes in 9.384s)
List of devices attached c1607ba13c4c65f device
Transfered: 3180 KB/s (20971520 bytes in 6.440s)
Net Repair Done
ADB Reboot Done
The Following 2 Users Say Thank You to julius84 For This Useful Post:
Old 11-22-2018, 15:28   #1360 (permalink)
Member: 142632
Sonork: 100.1589012
Thanks Meter: 460
LG K120E unlock and reset FRP OK !
LG K120E (K4 LTE) at USB (COM163) [LG FLASH 69] {Unlock/Sec}
DL MODE : 6
DL REQM : 5
DL MODEL: LG-K120E
DL SWVER: K12010h
DL IMEI : 357137-xx-xxxxxx-0
LF MODEL: LG-K120E
LF SERNO: Z5DMMFDURW995DJB
LF SWVER: LGK120EAT-00-V10h-234-10-MAY-08-2018+0
LF MINOS: MiniOS 3.0
LF OSVER: 5.1.1
LF IMEI : 357137-xx-xxxxxx-x
LF DVPID: CB42S161010002351
LF SOCTY: mt6735m
LF CABLE: USER
SC SWVER: LG-K120E K12010h 5.1.1
SC DVPID: CB42S161010002351
SC IMEI1: 357137-xx-xxxxxx-x
SC BTID : 2C59:8A:E7B1B8
SC WIFI : 2C59:8A:1434B7
SC NTCOD: 0003
SC LTYPE: 0000 NONE
SC NCK : 3356 5939 8175 0023
SC SPCK : 0122 1065 4620 8938
SC NSCK : 2230 5919 8051 9719
SC CPCK : 9754 6136 8176 8358
SC PCK : 0115 7439 5205 0125
Security Read Done in: 00:01.435
Saved as: K120E_ST_00001C00_SZ_00004000_PT_misc2 [2018_11_22_15_53_32].bin
Path: C:\Program Files\SarasSoft\UFS\ANDROID_UFS_1057\K120E\SEC\
Unlock Done
RESTART : 2
LG K120E (K4 LTE) at Auto Select Flash Port [LG FLASH 69] {Reset FRP}
DL MODE : 6
DL REQM : 5
DL MODEL: LG-K120E
DL SWVER: K12010h
DL IMEI : 357137-xx-xxxxxx-x
LF MODEL: LG-K120E
LF OSVER: 5.1.1
LF SOCTY: mt6735m
LF CABLE: USER
Reset FRP Done in 00:07.141
LEAVE
LAF Command Interface Closed
Old 11-27-2018, 10:04   #1361 (permalink)
4G Telecom's Avatar
Member: 2421242
Sonork: 100.1614558
Thanks Meter: 700
Techno ID6 Reset google account done (First in the world)
Var TECNO-ID6 (Camon iClick 2 LTE DS) at USB Auto Select [MTK] {Reset FRP}
DA Agent : DA_INTC.bin
BR ComPort: COM3
BR Asic Id: MT0766 [0000] Alias: MT6765
BR Secured: 05 [SBC DAA]
DA AgentId: SAA79A0D8169C03239
DA Version: MTK_AllInOne_DA_v3.3001.2018/05/22.14:57_437806.
Authentication Need BROM Boot (With Vol Keys)
DA ProtVer: 4
PR DlagVer: 1.0
DA Asic Id: MT0766 [8A00 CA00 0000 0000 0000]
eMMC USER : 0x0000000E8F800000 [62.537.072.640] 58.24 GB
eMMC CID : 150100444836444D4205BDFFDCAB64A9 [DH6DMB]
ERAM Size : 0x0000000100000000 [4.294.967.296] 4 GB
UNICAL RID: F15E4B2054BAC13C97CF2E3C39FC8D90
Reset FRP Done in: 00:02.977 (3)
The Following 4 Users Say Thank You to 4G Telecom For This Useful Post:
Old 12-01-2018, 16:31   #1362 (permalink)
gracy_elec's Avatar
Member: 118520
Thanks Meter: 3,551
Smile MI XIAOMI REDMI NOTE 5 PRO [SDM636] BRUSH MI ACCOUNT & FRP Done
SUCCESSFULLY BRUSH MI ACCOUNT & FRP(MI XIAOMI REDMI NOTE 5 PRO [SDM636])USB
Var XIAOMI-Redmi Note 5 Pro Whyred (Note 5 Pro LTE DS) at Auto Select Flash Port [SAHARA] {Write Flash}
QDL USB Com: Vid_05c6&Pid_9008 (COM50)
SAHARA VERS: 2.1
SAHARA HWID: 000CC0E100000000 [SDM636]
SAHARA HASH: A7B8B82545A98ECA23D6E9105FB464568D1B5828264903441B DEF0CD57E3C370
SAHARA SERN: 60D75EF6 (1624727286)
SAHARA PROG: prog_emmc_firehose_Sdm660_ddr_xiaomi1_s_rb4.elf
SAHARA PRID: SA3C8BB6D282905415
FHPROG SZFT: 4096
FHPROG SZTT: 32768
FHPROG SPTT: 32768
FHPROG XSIZ: 4096
FHPROG VERS: 1
FHPROG PLTF: MSM8996
FHPROG CHSN: 0xFFFBFFFF
FHPROG MEMT: eMMC
FHINFO DSK0: 122142720 x 3468558848 Sectors (376.28 PB)
FHPROG PRTY: 16
Flash Bundle: rawprogram0.xml
Partitions to Write: 2 (5.09 MB)
FWRITE DONE: DSK0 ST 0x0000000C00 frp 512 KB
FWRITE DONE: DSK0 ST 0x0000080000 persist 32 MB (Unsparsed Size)
FPATCH DONE: 13, Used: patch0.xml
FHSETD DONE: Ok (Boot Disk: 0)
Write Flash Done in: 00:02.560
THANKS UFST-BOX TEAM
The Following 3 Users Say Thank You to gracy_elec For This Useful Post:
Old 12-04-2018, 10:56   #1363 (permalink)
ahmadge's Avatar
Member: 603971
Thanks Meter: 730
OppO F3 frp done
here logo
Var OPPO-F3 (F3 LTE DS CPH1609) at USB Auto Select [MTK] {Reset FRP}
DA Agent : DA_OPPO_F3_1.bin
BR ComPort: COM52
BR Asic Id: MT0326 [0000] Alias: MT6755
BR Fuse Id: 00001441
BR ME_ID : E6D5B514BA8F67E8709D637E880885B3
DA AgentId: SAE2C0245350269729
Auth File : Oppo_F3_auth_sv5.auth
AuthFileId: SAEEFB00B757BA95C1
DA ProtVer: 4
PR DlagVer: 1.0
PR BootMod: brom
EMI PreLdr: preloader_oppo6750_16391.bin
EMI TagVer: 22
DA Asic Id: MT6750 [8A00 CB00 0001 0000 0000]
eMMC CID : 150100524836344D4205F3EBD63C348F [RH64MB]
UNICAL RID: F50B1D22E5B55F2454B37A1F539ECEC1
DA USB Com: Vid_0e8d&Pid_2001 (DA HighSpeed)
PGPT Found: 39 Partition Entries
SGPT Found: 39 Partition Entries
Reset FRP Done in: 00:06.257 (1)
Thnx Ufst Team
{Ahmadge}
Old 12-06-2018, 08:04   #1364 (permalink)
4G Telecom's Avatar
Member: 2421242
Sonork: 100.1614558
Thanks Meter: 700
Comio C1 Google account remove done
Var COMIO-C1 (C1 LTE DS) at USB Auto Select [MTK] {Reset FRP}
DA Agent : MTK_AllInOne_DA_MMP.bin
BR ComPort: COM442
BR Asic Id: MT0335 [0000] Alias: MT6735
BR Fuse Id: A4010000
BR ME_ID : D3133315A8CA9A6B455589B817CE7D6A
DA AgentId: SA794EE574CDC25FE4
DA ProtVer: 2
PR MMC CID: 45010044463430333201166D9A3C8FF3 [DF4032]
DRAM Confg: 45010044463430333201166D9A3C8FF3
EMI PreLdr: preloader_top6737m_35_a_n_comC1.bin
EMI TagVer: 20
DRAM Warn.: No Settings for Device: DF4032
DRAM Enabl: 02000000000040000000
eMMC CID : 45010044463430333201166D9A3C15F3 [DF4032]
UNICAL RID: D83500606D0F26C3937F65DE0CCC5084
PMT (GPT) Found: 26 Partition Entries
Reset FRP Done in: 00:07.311 (0)
The Following 3 Users Say Thank You to 4G Telecom For This Useful Post:
Old 12-06-2018, 11:16   #1365 (permalink)
Member: 142632
Sonork: 100.1589012
Thanks Meter: 460
Remove FRP HUAWEI Y5 II CUN-L21
Huawei CUN-L21 (Y5 II LTE DS) at USB Auto Select [MTK] {Reset FRP}
DA Agent : DA_SWSEC_HUA_1.bin
BR ComPort: COM10
BR Asic Id: MT0321 [0000] Alias: MT6735
BR Fuse Id: 28000000
DA AgentId: SA1DFCEE0A0FD0EBCC
DA ProtVer: 2
PR MMC CID: 150100464E58324D42062904EE058185 [FNX2MB]
PR Version: 4.2 [0x93] (5) MT8735
eMMC RPMB : 0x0000000000080000 [524.288] 512 KB
eMMC USER : 0x00000001D2000000 [7.818.182.656] 7,28 GB
eMMC CID : 150100464E58324D42062904EE052485 [FNX2MB]
UNICAL RID: 48B87F394B7EE21328C904D91CE1D421
PMT (GPT) Found: 28 Partition Entries
Reset FRP Done in: 00:03.151 (0)
Page generated in 0.28759 seconds with 9 queries
