08-04-2017, 10:10 | #1 (permalink) |
No Life Poster Join Date: May 2014 Location: UGANDA
Member: 2185549 Status: Offline Thanks Meter: 535 | Ufst errors to be fixed and request for adding devices NOTE:This is not intended for copy paster This thread is meant to make ufst better for better services For improvement in bugs of ufst test versions and beta releases To improve things like qualcom loaders mtk da agents and so on FOR BETTER RESULTS FOLLOW THESE Show version of software and specific bug Show screen shot if possible if not show errror log Do not post ur serial number keep it safe whle posting |
The Following 3 Users Say Thank You to ferouz kassim For This Useful Post: |
08-04-2017, 10:12 | #2 (permalink) |
Member: 2185549 Status: Offline Thanks Meter: 535 | Blu r00300u(r1-hd lte) HERE NOTHING SEEMS TO WORK not frp read flash format everything is not workingggn Var BLU-R0030UU (R1 HD LTE DS) at USB Auto Select [MTK] {Reset FRP} BR USB Com: Vid_0e8d&Pid_2000 DA Agent : MTK_AllInOne_DA.bin BR ComPort: COM135 BR Asic Id: MT0321 [0000] >> MT6735 BR Asic Sw: 8A00 CA00 0000 0000 DA Version: MTK_AllInOne_DA_v3.3001.00.00 BR_RUN_D5 Error: -1 Possible not Valid DA Agent BR_BOOT Error: -14 Reset FRP Failed: -14 DA_SHUTDOWN Error: -2 Last USB Exception: 0x0002 The system cannot find the file specified. Var BLU-R0030UU (R1 HD LTE DS) at USB Auto Select [MTK] {Read Flash} BR USB Com: Vid_0e8d&Pid_2000 DA Agent : MTK_AllInOne_DA.bin BR ComPort: COM135 BR Asic Id: MT0321 [0000] >> MT6735 BR Asic Sw: 8A00 CA00 0000 0000 DA Version: MTK_AllInOne_DA_v3.3001.00.00 BR_RUN_D5 Error: -1 Possible not Valid DA Agent BR_BOOT Error: -14 DA_SHUTDOWN Error: -2 Last USB Exception: 0x0002 The system cannot find the file specified. |
08-04-2017, 10:27 | #3 (permalink) |
Member: 2185549 Status: Offline Thanks Meter: 535 | REDMI 3S LAND THESE INSTURCTIONS DO NOT ENABLE QC DIAGS QFIL (Sahara) Download Mode: Vol+ and Vol- and Insert Cable QFIL (Sahara) Download Mode: Tick [EDL Cable] Insert Cable to OFF Device FastBoot Download Mode: Vol- and Insert Cable or Power On Recovery Mode: Vol+ and Power On Diag Port Enable: *#*#717717#*#* INSTEAD INSTRUCTIONS ARE just type *#*#13491#*#* to enable qualcomm diag port |
08-04-2017, 16:27 | #4 (permalink) |
Member: 2185549 Status: Offline Thanks Meter: 535 | samsung SM-G531F (Grand Prime Ve LTE) at USB (COM35) [LOKE FLASH] {Write Flash} PLATF: LOKE 00020000 PIT Read Done: 00:00 PIT Backup Saved as: SM-G531F_Read.pit No Partition Info for Image: grandprimevelte_eur_open.pit, in COMBINATION_OXA_FA51_G531FXXU1APC1_OXA1APC1_CL9065 38_QB9111160_REV01_user_mid_noship.tar.md5 Warning, Pit Image: grandprimevelte_eur_open.pit Skipped, Use [Re-Part.] Option with Pit Image File: COMBINATION_OXA_FA51_G531FXXU1APC1_OXA1APC1_CL9065 38_QB9111160_REV01_user_mid_noship.tar.md5 Partition: SBOOT, Image: sboot.bin, Size: 0x003FF940 (4 MB) Partition: SBOOT2, Image: recovery_sboot.bin, Size: 0x003FF940 (4 MB) Partition: LOKE2ND, Image: loke_recovery.bin, Size: 0x001C0140 (1.75 MB) Partition: LOKE1ST, Image: loke_primary.bin, Size: 0x001C0140 (1.75 MB) Partition: PARAM, Image: param.bin, Size: 0x000BE000 (760 KB) Partition: KERNEL, Image: boot.img, Size: 0x00745110 (7.27 MB) Partition: RECOVERY, Image: recovery.img, Size: 0x0082F110 (8.18 MB) Partition: SYSTEM, Image: system.img, Size: 0x2180D2A0 (536.05 MB) Error: system.img Error: Flash Write: 8, FFFFFFFF, FFFFFFFF [Common Failure] Flash Write Failed even with full battery |
08-04-2017, 23:33 | #5 (permalink) |
Product Supporter Join Date: Nov 2002 Location: usd Age: 64
Member: 17804 Status: Offline Sonork: 100.27310 Thanks Meter: 1,075 | @ferouz kassim thanx a lot for your reports "Var BLU-R0030UU (R1 HD LTE DS) at USB Auto Select [MTK] {Read Flash} BR USB Com: Vid_0e8d&Pid_2000 DA Agent : MTK_AllInOne_DA.bin BR ComPort: COM135 BR Asic Id: MT0321 [0000] >> MT6735 BR Asic Sw: 8A00 CA00 0000 0000 DA Version: MTK_AllInOne_DA_v3.3001.00.00 BR_RUN_D5 Error: -1 Possible not Valid DA Agent" Can you try here other DA Agents (Select Using [DA] button) for example DA_PL, DA_SWSEC, ... Last edited by Sha; 08-05-2017 at 02:37. |
The Following User Says Thank You to Sha For This Useful Post: |
08-05-2017, 06:03 | #6 (permalink) | |
Member: 2185549 Status: Offline Thanks Meter: 535 | Quote:
Sent from my Nexus 5 using Tapatalk | |
08-05-2017, 08:13 | #7 (permalink) |
Member: 2185549 Status: Offline Thanks Meter: 535 | SAMSUNG DEVICE OPERATIONS LIKE UNLOCKING IT IS A GREAT TROUBLE COMMUNICATING WITH DEVICES THROUGH MODEM /RJ45 IF SOME OPPERATIONS COULD BE DONE UNDER ADB WE WOULD BE REALLY THANKFUL Samsung SM-T337A (Tab4 8.0 LTE ATT) at RJ45 (UART) [MODEM] {Fact.Unlock} Comms Failed: 0 (No Response) Samsung SM-T337A (Tab4 8.0 LTE ATT) at RJ45 (UART) [MODEM] {Fact.Unlock} Comms Failed: 0 (No Response) Samsung SM-T337A (Tab4 8.0 LTE ATT) at RJ45 (UART) [MODEM] {Factory Info} Comms Failed: 0 (No Response) Samsung SM-T337A (Tab4 8.0 LTE ATT) at USB (COM381) [MODEM] {Fact.Unlock} MODEMCON: OK Last USB Exception: 0x0005 Access is denied. Samsung SM-T337A (Tab4 8.0 LTE ATT) at USB (COM381) [MODEM] {Fact.Unlock} MODEMCON: OK SERIALNR: R52J31HBFLY,170327, MSL ADDR: R52J31HBFL Use [Reset MSL] to Bypass MSL Security Product not Authenticated Samsung SM-T337A (Tab4 8.0 LTE ATT) at USB [ADB] {ADB Info} daemon started successfully * 52036fe6fa06149d unauthorized BOOTSERN: 52036fe6fa06149d RILSERN : R52J31HBFLY RILMODEL: QB5100645 RILSWVER: T377AUCU2APJ2 RILCSCVER:T377AATT2APJ2 RILPRCODE:SM-T377AZKAATT PRDBRAND: samsung PRDMODEL: SAMSUNG-SM-T377A PRDNAME : gteslteuc BLDVERS : 6.0.1 BLDDISID: MMB29K.T377AUCU2APJ2 BLDPROD : gteslteatt PRODBRD : universal3475 BRDPLATF: exynos3 HARDWARE: universal3475 RILMODEM: SHANNON308 USB CNFG: mtp,adb MMC1 CID: 150100414a4e423352036fe6fa06149d Superuser Permissions Denied |
08-05-2017, 15:32 | #8 (permalink) |
Member: 2185549 Status: Offline Thanks Meter: 535 | addd 6039y alacatel diag instructions as ###2324# Alcatel 6039Y (Idol 3-4.7 LTE DS) at USB (COM392) [DIAGS] {Factory Info} OFFLMODE: OK MDMVERSN: Dec 31 201514:09:44Sep 28 201511:00:00EAAAANVZ MDMBUILD: MPSS.DPM.2.0.2.c1.6-00033-M8936FAAAANUZM-1 NV IMEI1: 867025-02-068695-1 NV IMEI2: 000000-00-000000-0 NV BTID : 0000:00:000000 NV WIFI : 0000:00:000000 Alcatel 6039Y (Idol 3-4.7 LTE DS) at USB (COM392) [DIAGS] {Gen.Settings} OFFLMODE: OK MDMVERSN: Dec 31 201514:09:44Sep 28 201511:00:00EAAAANVZ MDMBUILD: MPSS.DPM.2.0.2.c1.6-00033-M8936FAAAANUZM-1 NV IMEI1: 867025-02-068695-1 NV IMEI2: 000000-00-000000-0 NV BTID : 0000:00:000000 NV WIFI : 0000:00:000000 Gen.Settings Write Done: 1 Item(s) Alcatel 6039Y (Idol 3-4.7 LTE DS) at USB (COM392) [DIAGS] {Factory Info} OFFLMODE: OK MDMVERSN: Dec 31 201514:09:44Sep 28 201511:00:00EAAAANVZ MDMBUILD: MPSS.DPM.2.0.2.c1.6-00033-M8936FAAAANUZM-1 NV IMEI1: 867025-02-068695-1 NV IMEI2: 000000-00-000000-0 NV BTID : 0000:00:000000 NV WIFI : 0000:00:000000 |
The Following User Says Thank You to ferouz kassim For This Useful Post: |
08-06-2017, 06:38 | #11 (permalink) |
Member: 17804 Status: Offline Sonork: 100.27310 Thanks Meter: 1,075 | I cannot add MTK samsung, it not exists in my country is only in India and Russia, so sorry |
08-06-2017, 07:19 | #12 (permalink) |
No Life Poster Join Date: May 2008 Location: On your Key-board Age: 37
Member: 768985 Status: Offline Sonork: 100.1676685 Thanks Meter: 608 | I have just return mine last day I will contact customer and borrow unit again what do you want from it? http://forum.gsmhosting.com/vbb/f863...sible-2250802/ this is an MTK samsung device |
The Following User Says Thank You to dyo For This Useful Post: |
08-07-2017, 18:49 | #13 (permalink) |
Member: 2185549 Status: Offline Thanks Meter: 535 | kindly add mi cloud/account remove this is so rampamt in mi devices actually ave neva seen a mi with google frp Var XIAOMI-Redmi 3s Prime Land (Redmi 3s Prime LTE DS) at Auto Select Flash Port [SAHARA] {Reset FRP} QDL USB Com: Vid_05c6&Pid_9008 (COM117) SAHARA VERS: 2 SAHARA PROG: prog_emmc_firehose_8937_ddr_xiaomi.mbn FHPROG SZFT: 4096 FHPROG SZTT: 131072 FHPROG SPTT: 1048576 FHPROG XSIZ: 4096 FHPROG VERS: 1 FHPROG PLTF: 8937 FHPROG MEMT: eMMC FHINFO PAR0: 61071360 x 512 Sectors (29.12 GB) FHINFO PAR1: 8192 x 512 Sectors (4 MB) FHINFO PAR2: 8192 x 512 Sectors (4 MB) FHPROG PART: EFI GPT FHPROG PRTY: 0 FHREST DONE: Ok Reset FRP Done in: 00:09.125 |
