08-23-2017, 21:38 | #46 (permalink) | |
No Life Poster Join Date: May 2014 Location: UGANDA
Member: 2185549 Status: Offline Thanks Meter: 535 | Quote:
Sent from my m2 note using Tapatalk | |
08-26-2017, 15:16 | #47 (permalink) |
Member: 2185549 Status: Offline Thanks Meter: 535 | Huawei CUN-L01 (Y5 II LTE) at USB Auto Select [MTK] {Reset FRP} BR USB Com: Vid_0e8d&Pid_2000 DA Agent : DA_SWSEC_HUA_1.bin BR ComPort: COM15 BR Asic Id: MT0321 [0000] >> MT6735 BR Asic Sw: 8A00 CA00 0000 0000 DA Version: MTK_AllInOne_DA_v3.3001.00.00 PR MMC CID: 484A019061344738624FD432E35E7AAD [a4G8b] PR Version: 4.2 [0x93] (5) MT6735 eMMC BOOT1: 0x0000000000400000 [4.194.304] eMMC BOOT2: 0x0000000000400000 [4.194.304] eMMC RPMB : 0x0000000000400000 [4.194.304] eMMC USER : 0x00000001D2000000 [7.818.182.656] eMMC CID : 90014A483847346132D44F62AD7A24E3 [H8G4a2] ERAM Size : 0x0000000040000000 [1.073.741.824] IRAM Size : 0x0000000000020000 [131.072] UNICAL ID : 8946B66D2170A8E9B386FABDCBE5E8FD PMT (GPT) Found : 28 Partition Entries Reset FRP Done in: 00:03.342 DA Shutdown Done, Disconnect Cable |
The Following User Says Thank You to ferouz kassim For This Useful Post: |
08-28-2017, 13:30 | #49 (permalink) |
Product Supporter Join Date: Nov 2002 Location: usd Age: 64
Member: 17804 Status: Offline Sonork: 100.27310 Thanks Meter: 1,075 | Test23 Released and added XT1773, so please test it and post results |
The Following User Says Thank You to Sha For This Useful Post: |
08-31-2017, 18:40 | #50 (permalink) |
Member: 2185549 Status: Offline Thanks Meter: 535 | Sony E5533 (Xperia C5 Ultra Lavender DS) at USB Auto Select [S1] {Write Flash} Files to Flash: 12 USB DEV : SEMC [USB\VID_0FCE&PID_ADDE\5&f86e282&0&4] Last USB Exception: 0x001F A device attached to the system is not functioning. Can be Cable Problem or Battery Low ! with 60 percent battery but with flashtool ohkayyyy |
09-05-2017, 08:56 | #52 (permalink) |
Member: 2185549 Status: Offline Thanks Meter: 535 | y336-u02 imei repair plus flashing with firmware from support https://mega.nz/#!YpsSTSZD!wYl5lNZIv...VklY3nx57ueT-8 |
09-05-2017, 09:04 | #53 (permalink) |
Member: 2185549 Status: Offline Thanks Meter: 535 | No Info for: SCH-I535 (S3 VZW) No Info for: SCH-I535 (S3 VZW) No Info for: SCH-I535 (S3 VZW) No Info for: SCH-I535 (S3 VZW) Samsung SCH-I535 (S3 VZW) at Auto Select Flash Port [FLASH] Flashing not Supported for this Model |
09-05-2017, 18:23 | #54 (permalink) |
Member: 17804 Status: Offline Sonork: 100.27310 Thanks Meter: 1,075 | Please always add screenshots and (or) Log files because "not works" not gives any information about problem, thanx |
09-08-2017, 17:55 | #55 (permalink) |
Member: 2185549 Status: Offline Thanks Meter: 535 | MOST SONY MTK flashing gives eroor as below ufst flash log Sony E5553 (Xperia C5 Ultra Lavender) at USB Auto Select [S1] {Write Flash} Files to Flash: 1 Search for USB Device Time-Out: -1 All Done in 00:49.286 Sony E5506 (Xperia C5 Ultra Lavender) at USB Auto Select [S1] {Write Flash} Files to Flash: 1 USB DEV : SOMC [USB\VID_0FCE&PID_ADDE\5&868e399&0&4] Bad Port: \\.\USB#VID_0FCE&PID_ADDE#5&868e399&0&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed} sony flashtool log 08/051/2017 19:51:45 - INFO - Current device : E5533 - WUJ01MH6G4 - 1296-8544_R3B - 1295-8225_29.2.B.0.129 - GENERIC_29.2.B.0.129 08/051/2017 19:51:45 - INFO - Closing TA partition 08/051/2017 19:51:45 - INFO - Start Flashing 08/051/2017 19:51:45 - INFO - Processing loader.sin 08/051/2017 19:51:45 - INFO - Checking header 08/051/2017 19:51:45 - INFO - Flashing data 08/051/2017 19:51:46 - INFO - Loader : S1_Root_4154 - Version : MT67X2_19 / Boot version : S1_Boot_MT6752_TC9SP_208 / Bootloader status : ROOTABLE 08/051/2017 19:51:46 - INFO - Max packet size set to 8M 08/051/2017 19:51:46 - INFO - USB buffer size set to 512K 08/051/2017 19:51:56 - INFO - Found a template session. Using it : C:\Users\LG\.flashTool\devices\E55XX\default.fsc 08/051/2017 19:51:56 - INFO - Set loader configuration : [00 01 00 00 00 0C] 08/051/2017 19:51:56 - INFO - Opening TA partition 2 08/051/2017 19:51:56 - INFO - Writing TA unit 00002774. Value : 01 08/051/2017 19:51:56 - INFO - Closing TA partition 08/051/2017 19:51:56 - WARN - partitions is excluded from bundle 08/051/2017 19:51:56 - INFO - Set loader configuration : [00 01 00 00 00 0D] 08/051/2017 19:51:56 - INFO - Set loader configuration : [00 01 00 00 00 0F] 08/051/2017 19:51:56 - WARN - preloader_s1sbl is excluded from bundle 08/051/2017 19:51:56 - INFO - Set loader configuration : [00 01 00 00 00 0D] 08/051/2017 19:51:56 - WARN - secro is excluded from bundle 08/051/2017 19:51:56 - INFO - Set loader configuration : [00 01 00 00 00 0C] 08/051/2017 19:51:56 - INFO - Opening TA partition 2 08/051/2017 19:51:57 - INFO - Closing TA partition 08/051/2017 19:51:57 - INFO - Opening TA partition 2 08/051/2017 19:51:57 - WARN - Unit 2127 not found in bundle 08/051/2017 19:51:57 - WARN - Unit 2301 not found in bundle 08/051/2017 19:51:57 - INFO - Closing TA partition 08/051/2017 19:51:57 - INFO - Opening TA partition 2 08/051/2017 19:51:57 - WARN - lk is excluded from bundle 08/051/2017 19:51:57 - WARN - logo is excluded from bundle 08/051/2017 19:51:57 - WARN - tee1 is excluded from bundle 08/051/2017 19:51:57 - WARN - tee2 is excluded from bundle 08/051/2017 19:51:57 - INFO - Closing TA partition 08/051/2017 19:51:57 - INFO - Opening TA partition 2 08/051/2017 19:51:57 - WARN - cache is excluded from bundle 08/051/2017 19:51:57 - WARN - apps_log is excluded from bundle 08/051/2017 19:51:57 - WARN - boot is excluded from bundle 08/051/2017 19:51:57 - WARN - fotakernel is excluded from bundle 08/051/2017 19:51:57 - WARN - system is excluded from bundle 08/051/2017 19:51:57 - INFO - Closing TA partition 08/051/2017 19:51:57 - INFO - Opening TA partition 2 08/051/2017 19:51:57 - INFO - Processing userdata.sin 08/051/2017 19:51:57 - INFO - Checking header 08/051/2017 19:51:57 - INFO - Flashing data 08/052/2017 19:52:42 - WARN - oem is excluded from bundle 08/052/2017 19:52:42 - INFO - Closing TA partition 08/052/2017 19:52:43 - INFO - Opening TA partition 2 08/052/2017 19:52:43 - WARN - Unit 2212 not found in bundle 08/052/2017 19:52:43 - INFO - Closing TA partition 08/052/2017 19:52:43 - INFO - Opening TA partition 2 08/052/2017 19:52:43 - WARN - Unit 2311 not found in bundle 08/052/2017 19:52:43 - INFO - Closing TA partition 08/052/2017 19:52:43 - INFO - Opening TA partition 2 08/052/2017 19:52:43 - WARN - Unit 2330 not found in bundle 08/052/2017 19:52:43 - INFO - Closing TA partition 08/052/2017 19:52:43 - INFO - Opening TA partition 2 08/052/2017 19:52:43 - WARN - Unit 2404 not found in bundle 08/052/2017 19:52:43 - INFO - Closing TA partition 08/052/2017 19:52:43 - INFO - Opening TA partition 2 08/052/2017 19:52:43 - WARN - elabel is excluded from bundle 08/052/2017 19:52:43 - INFO - Closing TA partition 08/052/2017 19:52:43 - INFO - Opening TA partition 2 08/052/2017 19:52:43 - INFO - Writing TA unit 00002725. Value : 32 30 31 37 2D 30 39 2D 30 38 20 31 39 3A 35 32 3A 34 33 00 08/052/2017 19:52:43 - INFO - Writing TA unit 00002774. Value : 00 08/052/2017 19:52:43 - INFO - Closing TA partition 08/052/2017 19:52:44 - INFO - Ending flash session 08/052/2017 19:52:44 - INFO - Flashing finished. 08/052/2017 19:52:44 - INFO - Please unplug and start your phone 08/052/2017 19:52:44 - INFO - For flashtool, Unknown Sources and Debugging must be checked in phone settings |
09-09-2017, 04:13 | #56 (permalink) |
No Life Poster Join Date: Sep 2013 Location: INSIDE YOUR MIND
Member: 2025428 Status: Offline Thanks Meter: 445 | PLEASE ADD MORE ASUS MTK SECURED MODELS LIKE ASUS_X008DC ASUS_X008D ASUS_X008 ASUS_X008D _1 ASUS_ZC500TG ASUS_500TG ASUS_ZC520TL ASUS_Z00VD U CAN ADD MORE MODELS WITH SECURE BOOT.. SEE FEW LOGS OF PHONE MTK MT6737T (eMMC) at USB Auto Select [MTK] {Reset FRP} BR USB Com: Vid_0e8d&Pid_2000 DA Agent : DA_SWSEC_1712.bin BR ComPort: COM17 BR Asic Id: MT0335 [0000] >> MT6735 BR Asic Sw: 8A00 CB00 0000 0000 BR Secured: 1 [SBC] DA Version: MTK_AllInOne_DA_v3.3001.2017-03-30.16:56 BR_RUN_D5 Error: -1 Possible not Valid DA Agent BR_BOOT Error: -14 Reset FRP Failed: -14 DA_SHUTDOWN Error: -2 Last USB Exception: 0x001F A device attached to the system is not functioning. Can be Cable Problem or Battery Low ! Var ACER-Z160 (Liquid Z4 3G DS) at USB Auto Select [MTK] {Reset FRP} BR USB Com: Vid_0e8d&Pid_2000 DA Agent : DA_SWSEC_CRYPTO20_BirdA.bin BR ComPort: COM17 BR Asic Id: MT0335 [0000] >> MT6735 BR Asic Sw: 8A00 CB00 0000 0000 BR Secured: 1 [SBC] DA Version: MTK_AllInOne_DA_v3.3001.2015-06-17.09:51 BR_RUN_D5 Error: -1 Possible not Valid DA Agent BR_BOOT Error: -14 Reset FRP Failed: -14 DA_SHUTDOWN Error: -2 Last USB Exception: 0x001F A device attached to the system is not functioning. Can be Cable Problem or Battery Low ! |
The Following 2 Users Say Thank You to johnoroo37 For This Useful Post: |
09-09-2017, 05:30 | #57 (permalink) |
Member: 17804 Status: Offline Sonork: 100.27310 Thanks Meter: 1,075 | Try to use DA_PL download agent for Asus models and say results. DA_PL select with [DA] button |
09-09-2017, 13:20 | #58 (permalink) |
Member: 2185549 Status: Offline Thanks Meter: 535 | FIX HUAWEI TIT-U02 ALL OPERATIONS TRIED WITH ALL THE HUA DA AGENTS FOR FRP RESET BUT FAILED Huawei TIT-U02 (Y6 Pro 3G DS) at USB Auto Select [MTK] {Reset FRP} BR USB Com: Vid_0e8d&Pid_2000 DA Agent : DA_SWSEC_HUA_5.bin BR ComPort: COM28 BR Asic Id: MT6582 [0000] BR Asic Sw: 8A00 CA01 0001 0000 DA Version: MTK_AllInOne_DA_v3.3001.00.00 BR_RUN_D5 Error: -1 Possible not Valid DA Agent BR_BOOT Error: -14 Reset FRP Failed: -14 DA_SHUTDOWN Error: -2 Huawei TIT-U02 (Y6 Pro 3G DS) at USB Auto Select [MTK] {Reset FRP} BR USB Com: Vid_0e8d&Pid_2000 DA Agent : DA_SWSEC_HUA_6.bin BR ComPort: COM28 BR Asic Id: MT6582 [0000] BR Asic Sw: 8A00 CA01 0001 0000 DA Version: MTK_AllInOne_DA_v3.3001.00.00 BR_RUN_D5 Error: -1 Possible not Valid DA Agent BR_BOOT Error: -14 Reset FRP Failed: -14 DA_SHUTDOWN Error: -2 Huawei TIT-U02 (Y6 Pro 3G DS) at USB Auto Select [MTK] {Reset FRP} BR USB Com: Vid_0e8d&Pid_2000 DA Agent : DA_SWSEC_HUA_4.bin BR ComPort: COM28 BR Asic Id: MT6582 [0000] BR Asic Sw: 8A00 CA01 0001 0000 DA Version: MTK_AllInOne_DA_v3.3001.00.00 BR_RUN_D5 Error: -1 Possible not Valid DA Agent BR_BOOT Error: -14 Reset FRP Failed: -14 DA_SHUTDOWN Error: -2 Huawei TIT-U02 (Y6 Pro 3G DS) at USB Auto Select [MTK] {Reset FRP} BR USB Com: Vid_0e8d&Pid_2000 DA Agent : DA_SWSEC_HUA_3.bin BR ComPort: COM28 BR Asic Id: MT6582 [0000] BR Asic Sw: 8A00 CA01 0001 0000 DA Version: MTK_AllInOne_DA_v3.3001.00.00 BR_RUN_D5 Error: -1 Possible not Valid DA Agent BR_BOOT Error: -14 Reset FRP Failed: -14 DA_SHUTDOWN Error: -2 Huawei TIT-U02 (Y6 Pro 3G DS) at USB Auto Select [MTK] {Reset FRP} BR USB Com: Vid_0e8d&Pid_2000 DA Agent : DA_SWSEC_HUA_2.bin BR ComPort: COM28 BR Asic Id: MT6582 [0000] BR Asic Sw: 8A00 CA01 0001 0000 DA Version: MTK_AllInOne_DA_v3.3001.00.00 BR_RUN_D5 Error: -1 Possible not Valid DA Agent BR_BOOT Error: -14 Reset FRP Failed: -14 DA_SHUTDOWN Error: -2 Huawei TIT-U02 (Y6 Pro 3G DS) at USB Auto Select [MTK] {Reset FRP} BR USB Com: Vid_0e8d&Pid_2000 DA Agent : DA_SWSEC_HUA_1.bin BR ComPort: COM28 BR Asic Id: MT6582 [0000] BR Asic Sw: 8A00 CA01 0001 0000 DA Version: MTK_AllInOne_DA_v3.3001.00.00 BR_RUN_D5 Error: -1 Possible not Valid DA Agent BR_BOOT Error: -14 Reset FRP Failed: -14 DA_SHUTDOWN Error: -2 |
09-09-2017, 16:26 | #59 (permalink) | |
Member: 2025428 Status: Offline Thanks Meter: 445 | Quote:
SAME ERROR FOR ASUS_Z00VD Var ACER-Z160 (Liquid Z4 3G DS) at USB Auto Select [MTK] {Reset FRP} BR USB Com: Vid_0e8d&Pid_2000 DA Agent : DA_PL.bin BR ComPort: COM17 BR Asic Id: MT6580 [0000] BR Asic Sw: 8A00 CA00 0000 0000 DA Version: MTK_AllInOne_DA_v3.3001.2017-06-20.15:46 BR_RUN_D5 Error: -1 Possible not Valid DA Agent BR_BOOT Error: -14 Reset FRP Failed: -14 DA_SHUTDOWN Error: -2 Last USB Exception: 0x001F A device attached to the system is not functioning. Can be Cable Problem or Battery Low ! ASUS_Z00VD SAME ERROR | |
The Following User Says Thank You to johnoroo37 For This Useful Post: |
09-10-2017, 14:45 | #60 (permalink) |
No Life Poster Join Date: Aug 2003 Location: Jo Age: 45
Member: 36706 Status: Offline Sonork: 100.58560 Thanks Meter: 122 | i have this error with version 1.0.5.5 test 23 / nokia TA-1032 (nokia 3) frp unlock Nokia TA-1032 (Nokia 3 LTE DS) at USB Auto Select [MTK] {Reset FRP} BR USB Com: Vid_0e8d&Pid_2000 DA Agent : MTK_AllInOne_DA.bin BR ComPort: COM34 BR Asic Id: MT0335 [0000] >> MT6735 BR Asic Sw: 8A00 CB00 0000 0000 BR Secured: 5 [SBC DAA] DA Version: MTK_AllInOne_DA_v3.3001.00.00 BR_RUN_D5 Error: -1 Possible not Valid DA Agent BR_BOOT Error: -14 Reset FRP Failed: -14 DA_SHUTDOWN Error: -2 Last USB Exception: 0x0002 The system cannot find the file specified. |
The Following 2 Users Say Thank You to RedeYeS For This Useful Post: |
