12-08-2013, 09:24 | #1 (permalink) |
No Life Poster Join Date: Jul 2002 Location: Slovakia Age: 43
Member: 13922 Status: Offline Thanks Meter: 334 | S5220 flash update problem tried several times, same error Code: If used non Auto-Ignition cable, press Power-On button IF_SBL: XGOLD215, Ok IF_EBL: 2150_OD_KL1_3.1 3.1, Mode: BB BAUD_R: 3000000 FL_ID : EC003000, Samsung K5W1Gxxxx 1024+32Mb IFXFR_ERR_BAD_CMD ST_ERR_CERT: ShutDown Done now when I tried to flash by standard microUSB cable (it recognized only like UNKNOWN DEVICE) any idea? I need to return it to working condition as before |
12-08-2013, 13:14 | #2 (permalink) | |
Product Supporter Join Date: Sep 2001 Location: India
Member: 6109 Status: Offline Sonork: 100.37432 Thanks Meter: 3,781 | Quote:
select USB0 in Baud Rate insert cable to phone without battery. If not work then check your phone connector.This UNKNOWN DEVICE come due to bad connector normally. | |
12-14-2013, 16:50 | #5 (permalink) |
Member: 13922 Status: Offline Thanks Meter: 334 | finaly I solved my problem I just UNTICK these two options 1. use EBL from FLS PACK 2. erase user date and phone was flashed with RJ45 successfuly now is fully working again |
The Following User Says Thank You to SPUnlock_SK For This Useful Post: |
04-16-2014, 21:23 | #8 (permalink) |
Moderator Join Date: Oct 2009 Location: Poland Age: 42
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | I flashed from my last post about 100 pcs s5220 then I realy not know what problem you got. Just use box cable microUSB and phone with battery charged and must work 100% correct. |
04-16-2014, 21:31 | #9 (permalink) |
Banned Join Date: Jul 2006 Location: dword ptr [ebp-1C], edx
Member: 322417 Status: Offline Thanks Meter: 940 | Glad to hear that, Overhead with flashing. There can be allot of things. Maybe we use different flash or maybe our antivirus block something or driver problem. ACTUALLY I BELIEVE THAT PROBLEM CAN BE DIFFERENT FLASH THAT WE USE.. REGARDS Sent from my LG-E975 using Tapatalk |
