05-10-2016, 15:55 | #1 (permalink) |
No Life Poster Join Date: Nov 2014 Location: Lucknow
Member: 2298369 Status: Offline Thanks Meter: 440 | Lg d295 after flashing stuck on firmware update UFST Boot v1.2 (c)SarasSoft 2012, Id: 54 4D 1 0 UFST Core v1.3 (c)SarasSoft 2013, Sn: 15204687 HID: 0C3F925F406000BF, HWK: A1.04-PRO1 SID: EB2677E84064F1F1933AC5EA5E53D847639C4EAC XID: FE569B379D89BF830461DC1FE28304DCC3782FFD Licence: True File: D29510e_00_D29510n.dz File Format: DZ Type 2 Model: LG-D295 File: D29510n Partitions {Chunks): 30 RbId: A1445950722-M1445950722-C1445953792-U1445953792-0 user Partitions (Chunks) to Flash: 30 LG D295 (L Fino DS) at USB (COM22) [LG FLASH 5] {Write Flash} DL MODE : 2 DL REQM : 5 DL MODEL: LG-D295 DL SWVER: D29510a DL IMEI : 000000-00-000000-0 LF MODEL: LG-D295 LF SERNO: LGD2957a2dd6f LF SWVER: LGD295AT-00-V10a-IND-XX-AUG-27-2014+0 LF MINOS: unknown LF OSVER: 4.4.2 LF IMEI : 356274-06-461933-2 LF DVPID: CT69S141125003025 LF SOCTY: msm8610 LF CABLE: USER Writing Partition: PrimaryGPT Writing Partition: modem Writing Partition: sbl1 Writing Partition: rpm Writing Partition: tz Writing Partition: sdi Writing Partition: aboot Writing Partition: rpmb Writing Partition: tzb Writing Partition: abootb Writing Partition: persist Writing Partition: laf Writing Partition: boot Writing Partition: recovery Writing Partition: factory Writing Partition: sbl1b Writing Partition: cust Writing Partition: system Writing Partition: BackupGPT Flash Write Done in: 02:13.138 LF CLOSE: 0k RESTART : 2 WHAT IS THIS PROBLEM ? |
05-11-2016, 04:35 | #2 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Check whether you have downgrade it or not . post your imei so that i can check the right firmware for you , you can also check - go to file tab of LG - fill the imei - click on download Br - srinibas |
The Following User Says Thank You to srinibas For This Useful Post: |
