09-11-2018, 08:21 | #1 (permalink) |
No Life Poster Join Date: May 2014 Location: UGANDA
Member: 2185549 Status: Offline Thanks Meter: 535 | For ufst and ufsturbo only patch a9 for UFST and UFS Turbo Only. v 1.0.5.7a Patch --------- Revised [ADB] Operations: More Info, Fixed Minor Bugs. Revised MTK Protocol: Fixed Bugs on some Models Boot, More Secured DA Added. Revised QC Flashing: Now can select all necessary RawprogramN.xml using [Add File] button, so not need to Flash few times new MultiDisk Models. With [Add File] button can also select Firehose from Flash Pack (if need) Notes: This Option will not pop-up Selection Form or Ask about Patch permission if [Selective Flash] not ticked. Patch will done auto if PatchX.xml is found. Files Selected with [FH] button always will pop-up File Selection Form. Added Oppo .OFP Files [Extract Img.] for QC Models, Use [Conver GPT] to make Correct Rawprogram and Patch Files. With gpt_main2 choose Right CDT file from Avalaible (Example: oppo16027.bin, Auto will be Select First from List) Added / Modified Models: ADVAN: B5, i45 ARCHOS: 101C Helium, 40 Power, 50 Diamond, 50 Platinum 4G, 50C Oxygen, 50D Neon, 50F Helium Lite, 55 Diamond Plus, 55B Cobalt Lite, 59 Xenon, 70 Helium, 70 Xenon, 70B Neon, 80 Oxygen, 97C Platinum, Access 55 3G, Diamond S ASUS: A009-V500KL (V Live) AVVIO: Models Added. BLACKVIEW: A20 Pro, A30, BV5800, BV5800 Pro BLU: A030U, A230Q, A270a, D600, S0350WW, S0390WW, S0410UU, S0450WW CHERRY: Flare J1 Lite, Flare S7 Deluxe, Flare S7 Lite, Omega Lite 4 CLOUDFONE: Thrill Boost 2, Thrill Plus, Thrill Power N, Thrill View CONDOR: Models Added. COOLPAD: 1851, 1861 Note 8 DEXP: BL250, BS450, T155, Z250 DOOGEE: BL5500 Lite, BL9000, S55, T5S, X55 ELEPHONE: P8 3D FERO: A4501, Pace 2 HAIER: A41, A6, P10, T51, T53P HISENSE: L695, M20T, M30T HUAWEI: CAG-XX, CRO-XX, DRA-XX (SBC Only), JMM-XX, MYA-XX, NCE-XX, TIT-XX iDROID: Royal V7 INFINIX: X5514 Smart 2 Pro, X5515 Smart 2, X606/X606B Hot 6, X608 Hot 6 Pro IRBIS: SP401, SP453, SP511, SP517, SP552 ITEL: A15, IT1460, P32 KARBON: K9 Viraat 4G LAVA: R3, Z60S, Z61, Z91W LEAGOO: Lead 1, 2, 2S, 3, 4, 5, 6, M9 Pro, Power 2, S9 LENOVO: Z5 (ZUI) MEIZU: 15-M1881, 15 Lite-M1871, M8C-M1810 MOBICEL: Berry, Dandy, Fever, Pure+, Pure Mini, R1, R2, Switch, Zen MOBIISTAR: E Selfie, Zumbo J2, Zumbo S, Zumbo S2 MYPHONE: Models Added. NOKIA: 6.1, X5, X6 OPPO: A3s, A31, A57, A59st, A59t, A71, A83, F3, F5, R9 OUKITEL: C9, OK6000 Plus, U18 PANASONIC: Eluga i7 QIKU: N4 QMOBILE: Noir X1S SHARP: Aquos M1, Aquos S2 High, Aquos S3, Aquos S3 High, Aquos S3 Mini, Z3 SYMPHONY: i75, V44, V92 TECNO: F4, F4 Pro, IA5, IN1, C9 Pro, F2, F2 LTE, F5, R8S, SA1 ULEFONE: Armor5, S1 VIVO: 1606, X6 Plus, X6A, X6D, Y75S WIKO: C201 (Tommy 3), C300 (View Lite), K300 (Jerry 3), K400 (Lenny 5), K600 (Tommy 3), P130 (View Go), P200 (View Max) XBO: Models Added. XIAOMI: Mi6X Wayne, Mi Max3 Nitrogen, Mi Pad4 Clover, Redmi Note5 Pro Whyred XOLO: Era 1X Pro, Era 2X 4SHARED LINK https://www.4shared.com/archive/aZQL..._Patch_A9.html |
The Following 18 Users Say Thank You to ferouz kassim For This Useful Post: |
09-11-2018, 13:38 | #4 (permalink) | |
No Life Poster Join Date: Sep 2012 Location: Mahoba
Member: 1810159 Status: Offline Thanks Meter: 256 | Quote:
Thnx Sandeep Kumar | |
The Following User Says Thank You to sktamrkar For This Useful Post: |
09-11-2018, 13:55 | #5 (permalink) | |
Member: 2185549 Status: Offline Thanks Meter: 535 | Quote:
The Following 4 Users Say Thank You to ferouz kassim For This Useful Post: |
09-12-2018, 11:10 | #9 (permalink) |
No Life Poster Join Date: Dec 2013 Location: Poland
Member: 2085623 Status: Offline Thanks Meter: 221 | Just check selective flash option and after tap write flash and phone detect software will ask what write to phone and there you can select only persist partition. |
09-12-2018, 12:25 | #10 (permalink) | |
Freak Poster Join Date: Apr 2013 Location: Android
Member: 1916900 Status: Offline Sonork: .::NIGAM::. Thanks Meter: 81 | Quote:
can u help me now which partition i have to flash now i cant see persist partition which partition i have to select for remove mi account ?? | |
The Following User Says Thank You to .::NIGAM::. For This Useful Post: |
09-12-2018, 13:05 | #11 (permalink) |
Freak Poster Join Date: Jun 2011
Member: 1596913 Status: Offline Thanks Meter: 107 | 1. read flash (choose persist only) 2. format flash > persist 3. in the folder where read flash change persist from firmware 4. flash persist specifying xml from the read flash folder |
The Following User Says Thank You to vaterpahk For This Useful Post: |
09-13-2018, 17:38 | #14 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,804 | media fire link ANDROID_UFS_1057_Patch_A9 |
The Following User Says Thank You to profkefah For This Useful Post: |
