07-25-2017, 05:01 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: On your Key-board Age: 37
Member: 768985 Status: Offline Sonork: 100.1676685 Thanks Meter: 608 | UFST and UFS Turbo Only. Test 19 v 1.0.5.5 --------- COMMON Minor Bug's Fixed in File and Model Selection. INI File Saving time decreased. [FPGM],[Re-Partition],[Use FastBoot] now Saving to Ini under Model Settings. Loging to File Added (Tick [Log] CheckBox in [Main Box Functions] Tab) Re-Tick of [Log] Will set New LogFile name (with Current Time Stamp) More Sophisticated USB Exceptions Handling with Tips where was a Problem. ALCATEL More Alcatel Models Added (Including QualComm Sahara): 6014D, 6014X, 6050A, 6050F, 6050W, 6050Y, 7043A, 7043E, 7043K, 7043Y, 7044A, 7044X, 7044Y, 7053D, 7053E, 7053J, VF-895N FASTBOOT Fixed Flashing of Devices with v0.4 fastboot core (Nvidia, Blackphone BP1) Reboot Mode Selector: Normal, Bootloader, EDL, Recovery (if Device Supports) Editable Commands Selector with Predefined (Most Used) Commands List. HUAWEI More Huawei Models Added: ATH-TL00, ATH-UL00, G620-L72, G620-L75, G629-UL00, G730-U30, H30-C00, S8-701U, SC-CL00, VNS-AL00 LENOVO More Lenovo Models Added: A8-50LC, A2016a40, A2016b30, A2016b31, A2800-D, A3860, A3910e70, A3910t30, A5890, A6010+, A6020a41, A6020L36, A6020L37, A6600a40, A6600d40, A7010a48, A7700, B8080-F, B8080-H, B8080-HV, K10a40, K10e70, K30-E, K30-TM, K31-T3, K50-T3s, K51c78, K910E, K910L, K910SS, PB2-650M, PB2-670M, PB2-690M, S1La40, S856, TB3-730F, TB3-730X, TB3-850F, TB3-850M, TB3-8703F, TB3-8703X, TB3-X70F, TB3-X70L, YT-X703F, YT-X703L, YT-X703X LG More LG Models Added: AS993, F770S, F820L, G600K, G600L, G600S, G600V, H870, H870DS, H870K, H870S, H870V, H871, H872, H873, K371, K373, LS450, LS775, LS993, M150, M151, M153, M154, M160, M160E, M250AR, M250F, M250H, M250I, M250K, M320, M320AR, M320DSN, M320F, M320H, M320K, M320N, M320TV, M320Y, M400DF, M400DK, M400DY, M400F, M400MT, M400N, M400Y, MP260, MS210, TP260, US997, VS501, VS835, VS988, X130G, X130J, X132, X135, X137, X145, X147, X150, X155, X160, X165, X165G, X170G, X210MB, X220DSH, X220DST, X220M, X220MB According New LAF Security, Flashing is Allowed Only of Factory Signed Files. We Improved KDZ Extraction Utility, It will Extract .dz and .sign Files, for Flashing Must [Add Files] .dz and then .sign File. Can Flash Directly Compatible .kdz File, then not need Extraction or sign. MICROMAX More Micromax Models Added: AQ4750, C1, E451, E453, E485, E491, E4820, P701, P702, P70221, P802, Q310, Q346+, Q354, Q402, Q453, Q3301, Q3501, Q3555, Q4202, Q4220, Q4251, Q4260, Q4310, V51 MOTOROLA More Motorola Models Added: XT1670, XT1671, XT1672, XT1675, XT1676, XT1677 (Moto G5 Cerdic) XT1680, XT1681, XT1683, XT1684, XT1685, XT1687 (Moto G5 Plus Potter) XT1750 (Moto C 3G Watson) Enabled [Reset FRP], Use [ADB Mode (via Menu...)], ADB Must be Enabled. To Enable ADB use Trick with *#*#4636#*#*, Aptoide and Test_dpc_smart_manager. MTK [Format Flash] Function Added. Format (Erase) Can be Done by Linear Address or Partition Name. [Read Flash] Preloader Analysis and Extraction (to SPFL Format) Added. Preloader now is saved as 2 Files: preloader_partition.bin (Whole Partition), Flashable by UFST and preloader_blabla.bin (Extracted SPFL File), Flashable by Original SPFL. Blocked Write of not Correct Preloader File (Must be in Partition Format) [Factory Info] will show Unlock Keys in Meta Mode (If is Allowed) [Enter FacTst] Button added, to boot in Factory Test Mode. NOKIA More Nokia Models Added: Nokia 3 (NE1, TA-1020, TA-1028, TA-1032, TA-1038) RM-1013 Sahara Flashing. QC (QUALCOMM) Added Programer (FireHose) File Selection using [Add File] it will override Default or selected by [DA] File and allows to save into INI File. SAMSUNG [Add MSL] Function Added (To Store Factory MSL into Local DataBase) Fixed new models Failure while flashing HOME Files (meta-data) More Samsung Models Added: C5018, C7018, C701F, C9008, C900Y, G390Y, G891A, G930VL, G9500, G9508, G950F, G950N, G950U, G950U1, G950W, G9550, G955F, G955N, G955U, G955U1, G955W, J326AZ, J327A, J327AZ, J327R4, J327R6, J327R7, J327T, J327T1, J327U, J327V, J327VPP, J330F, J330FN, J330G, J530F, J530FM, J530G, J530GM, J530K, J530L, J530S, J530Y, J701F, J701M, J727A, J727R4, J727S, J727T, J727T1, J727U, J727V, J727VPP, J730F, J730FM, J730G, J730GM, J730K, N935K, N935L, N935S, S120VL, S320VL, S550TL, S820L, SC-02J, SC-03J, SC-04J, SCV35, SCV36, T825N0, T825Y, T827, T827R4, T827V SONY Increased Image Write time-out from 5mins to 10mins, to prevent error -2 at 99% for hughe (system) files. Fixed Flashing of Models without loader.sin files. Enabled [Reset FRP], Use [ADB Mode (via Menu...)], ADB Must be Enabled. To Enable ADB use Trick with QuickShortcutMaker.apk or other. More Sony Models Added: SO-02J (Xperia X Compact Kugo) SO-01J, SOV34, 601SO (Xperia XZ Kagura) G3112, G3116, G3121, G3123, G3125 (Xperia XA1 Hinoki) G3212, G3221, G3223, G3226 (Xperia XA1 Ultra Redwood) G3311, G3312, G3313 (Xperia L1 Pine) G8231, G8232, SO-03J, SOV35, 602SO (Xperia XZs Keyaki) SPRD (SPREADTRUM) More Sophistcated Boot Options: Now can Boot, by Selecting FDL1 and FDL2 Using [Add File] or [DA] Button, FDL Selection Order: PAC File, File from List [Add File] and Default by [DA] Choosing with [Add File] Allows save into INI (Individual for each model). Read Mode Selector Lets Auto-Read Files from Unknown Model. [Format Flash] Function Added. Format (Erase) Can be Done by Partition Name. VAR MTK ACER Models Added: Liquid Z6E, Liquid Zest 4G AMOI Models Added: L350, L760C ARK Models Added: Benefit M505, Benefit M506, Benefit M507, Benefit S503 BLACKVIEW Models Added: A5, A7, A8, A8 Max, A9, A9 Pro, Alife P1 Pro, Alife S1, Breeze, BV2000, BV2000s, BV5000, BV6000s, BV7000s, C1, E7, E7s, Heatwave, JK450, JK600, JK606, JK890, Omega Pro, P2 Lite, R6, R6 Lite, R6s, Ultra, Ultra Plus, V3 CONDOR Models Added: Griffe G4, Griffe G4+ CHERRY Models Added: Cosmos 3, Cubix Cube 3, Flare 4, Flare 5, Flare HD Max, Flare Infinity Lite, Flare J1 Plus, Flare J3, Flare J3 Plus, Flare J5, Flare J7, Flare P1, Flare P1 Plus, Flare S, Flare S4, Flare S4 Max, Flare S4 Plus, Flare S5, Flare S5 Plus, Flare S5 Power, Flare Selfie, Flare X, H7, Touch 2, Touch XL2 COOLPAD Models Added: 3503I (Mega 3), 3505I-S00 (Fancy 3), 8722-S00 (Roar Plus E570), 8722-U00 (Porto S E570), Y83-S00 (Sky 3 E502), Y83-U00 (Modena 2 E502) DISCOVERY Models Added: V8 DOOGEE Models Added: T3, T5, T5 Lite, T6, T6 Pro, X3, X5, X5 b, X5 Max, X5 Max Pro, X5 Max S, X5S, X6, X6 Pro, X6S, X7, X7 Pro, X7S, X9, X9 Pro, X9S, Y100X EVERTEK Models Added: EverAllure 2, EverFancy, EverFancy 3, EverGlory 2, EverGlory Plus, EverGlow D35, EverGlow D40, EverGlow D50, EverMellow D45, EverMellow D50, EverMiracle Mini, EverMiracle Nano, EverMiracle Plus, EverMiracle Power, EverMiracle S, EverMiracle S2, EverShine 2, EverShine Plus, EverSlim Nano, EverSolo, EverStar D40, EverStar Nano, EverStar Pro, EverStar Pro V2, EverStar Q40, EverStar Q50, EverStar S, EverTrendy, EverTrendy Plus 3G, EverTrendy Plus 4G, EverVivid Q47, F1, V1 Mini GIONEE Models Added: Elife S Plus, F103, F103B, F103BL, F103L, F105, F301, F303, F306, F306L, GN3003L, GN5001L, GN5001S, GN5002, M3 Mini, M5 Plus L, M5 Mini, S6, S6S INNJOO Models Added: Fire 3G, Fire 2 3G, Fire 2 LTE, Fire 2 Plus LTE, Fire 3 LTE, Fire 3 Air LTE, Fire Plus LTE, Fire Pro LTE, Halo LTE, Halo 2 LTE, Halo Plus, i1, i1k, i1s, Max, Max 2 3G, Max 2 Plus 3G, Max 3 3G, Max 3 LTE, Max 3 Pro, Note, Note E, Note Pro, One HD LTE, Pro, Two LTE INTEX Models Added: Aqua HD 5.5, Aqua Play, Aqua Ring, Aqua S7, Aqua Shine 4G, Aqua Power Pro, Aqua Pride, Prime 4G, Aqua Strong 5.1, Aqua Strong 5.2, Aqua Supreme+, Aqua Trend Lite, Aqua View, Aqua Y2 Pro, Cloud Q11 KARBONN Models Added: K9 Smart 4G LAVA Models Added: A2, A3, Iris 820 MX, Z10 LYF Models Added: LS-5506 Water 9, LS-5507 Water 7 PHILIPS Models Added: S226M, S309, S318, S388, S396, S398, S616, V377, V387, V526, V586, V787, X586 QMOBILE Models Added: Z10, Z12, Z12 Pro, Z9 Plus TEXET Models Added: TM-4071, TM-4072, TM-4082, TM-4083, TM-4172, TM-4182, TM-4272, TM-4510, TM-4513, TM-4515, TM-4572, TM-4672, TM-4772, TM-4782, TM-4872, TM-4972, TM-4982, TM-5003, TM-5005, TM-5009, TM-5010, TM-5011, TM-5017, TM-5072, TM-5082, TM-5172, TM-5503, TM-5505, TM-5508, TM-5513, TM-5577, TM-6003 VODAFONE Models Added: VFD300, VFD301, VFD500, VFD501, VFD502 ZTE Models Added: Blade L3 Lite, Blade V7 Lite, Blade X7, Nubia N1 Lite, S158, T520, Voyage 4S VAR QUALCOMM BLACKPHONE Models Added: BP2 COOLPAD Models Added: 3600I (Note 5), 8297-A, 8297-W00 (Dazen F2), A8-930, A8-I01 (Max A8), SK3-S00 (Fancy E561), SK3-U00 (Torino S E561), Y76-I01 (Sky E501), Y76-U00 (Modena E501), Y90-G00 (Shine R106), Y91-I00 (Note 3S), Y91-U00 (Torino R108) INTEX Models Added: Aqua 4G, Aqua Fish, Elit-E1 HAIER Models Added: Esteem L50, L61, Leisure L7 LYF Models Added: LS-5005 Water 4, LS-5007 Water 5, LS-5502 Wind 3, LS-5505 Water F1 OPPO Models Added: A11, A57, R8000, R9s, R9s Plus, X9000 VODAFONE Models Added: VFD900 XIAOMI Models Added: Mi Max 2 Oxygen VAR SPRD ARCHOS Models Added: 40 Neon, 50C Platinum, 50D Titanium CHERRY Models Added: Flare J1, Flare J1S, Flare Lite 2, Flare Lite Quad, Flare P1 Mini, Flare P1 Lite, Flare S5 Mini, Omega Lite 2, Touch HD EVERTEK Models Added: V1 Nano INNJOO Models Added: Halo 3G, Halo 2 3G, Halo Plus, Halo X INTEX Models Added: Aqua 4.0 3G, Aqua 4.0 4G, Aqua 4.5 Pro, Aqua 4G Mini, Aqua_Amaze+, Aqua Craze 2, Aqua Lions 4G, Aqua Q7N Pro, Aqua Pro 4G, Aqua Raze 2, Aqua S3, Aqua Selfie, Aqua Strong 5.1+, Aqua Style 3, Y2 Power, Cloud 4G Smart, Cloud M5 II, Cloud Matte, Cloud Scan FP, Cloud String HD LAVA Models Added: A50, A55 PHILIPS Models Added: S326, S337 TEXET Models Added: TM-4003, TM-4503, TM-5006, TM-5007, TM-5016 official 4shared link here |
The Following 7 Users Say Thank You to dyo For This Useful Post: |
07-25-2017, 11:11 | #4 (permalink) | ||
Member: 768985 Status: Offline Sonork: 100.1676685 Thanks Meter: 608 | Cloudfone flash error Quote:
The Following User Says Thank You to dyo For This Useful Post: |
07-25-2017, 11:17 | #5 (permalink) |
No Life Poster Join Date: May 2014 Location: UGANDA
Member: 2185549 Status: Offline Thanks Meter: 535 | |
The Following User Says Thank You to ferouz kassim For This Useful Post: |
07-25-2017, 12:19 | #6 (permalink) |
Product Supporter Join Date: Nov 2002 Location: usd Age: 64
Member: 17804 Status: Offline Sonork: 100.27310 Thanks Meter: 1,075 | @Dyo File: lk.bin not Exists Yes, true it not exists in that package ... Solutions: 1. Unselect it in flash setup menu (wil be bypassed) 2. Read it from good phone 3. Take it from other firmware package |
The Following User Says Thank You to Sha For This Useful Post: |
07-25-2017, 12:51 | #7 (permalink) | |
Member: 768985 Status: Offline Sonork: 100.1676685 Thanks Meter: 608 | Flash done after uncheck Quote:
07-25-2017, 13:35 | #9 (permalink) |
Member: 768985 Status: Offline Sonork: 100.1676685 Thanks Meter: 608 | Factory test boot done Var CLOUDFONE-Excite 502q (Excite 502q 3G DS) at BOOT {Enter FacTst} Insert Cable to Switched OFF Device BR USB Com: Vid_0e8d&Pid_2000 Factory Mode Entered |
07-25-2017, 14:04 | #10 (permalink) |
Member: 17804 Status: Offline Sonork: 100.27310 Thanks Meter: 1,075 | if have problem on Win10, here is new link: https://www.4shared.com/s/fCaza5L0pei also on server: ANDROID_UFS_1055_Test19_w10fix.7z soon will be released next one with PIT fix it happens on Qualcomm phones with UFST memory thanx to: ferouz kassim for found and report |
The Following 3 Users Say Thank You to Sha For This Useful Post: |
07-25-2017, 14:53 | #11 (permalink) |
Member: 2185549 Status: Offline Thanks Meter: 535 | mr sha please also fix the factory info button in the qualcom module it doesnot respond whereas in mtk its fucntioning |
07-25-2017, 16:35 | #13 (permalink) |
No Life Poster Join Date: Mar 2002 Location: Samsung
Member: 10028 Status: Offline Sonork: n/a Thanks Meter: 840 | @Sha in QC tab: when i select MSM8909 for example and select loader 8909 from QC_BOOT folder but get this error in software: Code: QC MSM8909 (eMMC) at Auto Select Flashing Port [SAHARA] {Reset FRP} Select FireHose File Using [DA] Button ! whever i click on Reset FRP BR |
07-25-2017, 16:37 | #14 (permalink) |
Member: 2185549 Status: Offline Thanks Meter: 535 | None of Diags Ports Selected Huawei Y625-U32 (Huawei Y625 3G DS) at USB (COM50) [DIAGS] {Factory Info} <<< STOP >>> Comms Failed: -1 (No Response) Huawei Y625-U32 (Huawei Y625 3G DS) at USB (COM260) [DIAGS] {Factory Info} OFFLMODE: OK MDMVERSN: Mar 7 201511:54:14Mar 04 201522:00:00BAAAANWZ MDMBUILD: 8x10_PL190335_20141120 NV IMEI1: 000000-00-000000-0 NV IMEI2: 000000-00-000000-0 NV BTID : 0000:00:000000 Huawei Y625-U32 (Huawei Y625 3G DS) at USB (COM260) [DIAGS] {Gen.Settings} OFFLMODE: OK MDMVERSN: Mar 7 201511:54:14Mar 04 201522:00:00BAAAANWZ MDMBUILD: 8x10_PL190335_20141120 NV IMEI1: 000000-00-000000-0 NV IMEI2: 000000-00-000000-0 NV BTID : 0000:00:000000 NV WIFI : 0000:00:000000 Gen.Settings Write Done: 2 Item(s) Huawei Y625-U32 (Huawei Y625 3G DS) at USB (COM260) [DIAGS] {Factory Info} OFFLMODE: OK MDMVERSN: Mar 7 201511:54:14Mar 04 201522:00:00BAAAANWZ MDMBUILD: 8x10_PL190335_20141120 NV IMEI1: 867948-02-856460-9 NV IMEI2: 867948-02-856460-9 NV BTID : 0000:00:000000 |
07-25-2017, 16:52 | #15 (permalink) |
Member: 2185549 Status: Offline Thanks Meter: 535 | mr. sha fix the buttons for restart pcinfo and factory defaults in huawei tab(for qualcom based devices for mtk deivces are ohkay) the rest of tabs ohkay except that in huawei tab |
