10-27-2013, 00:27 | #1 (permalink) |
No Life Poster Join Date: Feb 2003 Location: www.X-SIM.me Age: 45
Member: 22955 Status: Offline Sonork: 67574 - Not use it Thanks Meter: 584 | Chunk Explanation For Sl3 Breaker Client CHUNK = Part of the complete phone hash When add phone to Queue (add for calculation) you can chose the chunk size. 0,1% Chunk is set by default. This means the system will split the complete HASH into 1000 chunks and deliver it to all available PC-s. So any PC will calculate only 0,1% of complete hash. After finish calculating 0,1% of HASH (in case the client did not find the code) the system will right away send another part of the HASH(another CHUNK) to such PC. When any client find the code in part of the HASH (CHUNK) it got to calculate it will right away inform the system the code is found and the system will right away send part's of new HASH (new phone's CHUNKS) to all available Clients (BF PC-s). Now, in Cpanel application you can chose CHUNKS with following sizes: Chunk size: 0,1% (mean the complete hash has been divided to 1000 parts, CHUNKS) Chunk size: 0,2% (mean the complete hash has been divided to 500 parts, CHUNKS) Chunk size: 0,25% (mean the complete hash has been divided to 400 parts, CHUNKS) Chunk size: 0,5% (mean the complete hash has been divided to 200 parts, CHUNKS) Chunk size: 1% (mean the complete hash has been divided to 100 parts, CHUNKS) For the system with slower PC-s such as are PC configurations with 2x5850, 2x6950 or similar we suggest you to use 0,1% or 0,2% chunk size. Simple said statistics learned us this is the most optimized setting for such system usage. For the system with stronger PC-s such as are PC configurations with 2x6990, 2x5870 or similar we suggest you to use 0,25% or 0,5% chunk size. Simple said statistics learned us this is the most optimized setting for such system usage. For the system with HIGH speed PC-s such as are PC configurations with 3x6990, 3x5970, 4x6990 or similar we suggest you to use 0,5% or 1% chunk size. Simple said statistics learned us this is the most optimized setting for such system usage. Also, the Calculator(Icon right from chunk size window) will show you how many seconds(estimated) is needed your PC to calculate 'chosen' Chunk. All you need to do is chose the CHUNK size, enter your PC speed (for example 2x5850 should be around 3200MH/sec, 2x6990 around 7800 MH/sec ...). Last edited by mobileland; 10-27-2013 at 01:24. |
