You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. Only registered members may post questions, contact other members or search our database of over 8 million posts.
Samsung Galaxy Gear gets first custom ROM, includes native app installation and full-
FEATURES
MK7 BASE
ROOTED
SUPERUSER
COMPLETELY DEODEXED
NOVALAUNCHER INCLUDED
HOMEBUTTON FIX / POWER BUTTON LOCKS SCREEN WHEN USING CUSTOM LAUNCHERS.
NO WIPE BASE
WEATHER WIDGET / REMOVED STATIC "WEATHER" TEXT
DISABLED SAMSUNG SIGNATURE VERIFICATION
NATIVE APK INSTALLATION
INCREASED VIDEO RECORDING LIMIT TO 60 SECONDS
VPN ENABLED
CM10.2 BROWSER
WALLPAPER SUPPORT
LIVE WALLPAPER SUPPORT
CM10.2 GALLERY
THIRD PARTY CONTACT WIDGET & APP CRASH FIX
SETTINGS / FULL SETTINGS DIALOG
MTP SUPPORT / ENABLED IN STORAGE SETTINGS
BLUETOOTH TETHERING
MULTIPLE BLUETOOTH DEVICE PAIRING
NATIVE EMAIL CLIENT
NAVIGATION BAR
FAQ / IT DOESNT WORK ! WAH
INTERNET ACCESS
GO INTO "FULL SETTINGS -> BLUETOOTH -> SELECT YOUR PHONE SETTING ICON (ON THE RIGHT OF PHONE NAME) -> TICK INTERNET ACCESS".
ENSURE BLUETOOTH TETHERING IS ENABLED ON YOUR PHONE BEFORE HAND OBVIOUSLY.
*NOTE* ENSURE YOUR MOBILE DEVICE SUPPORTS TETHERING, US VARIANT PHONES HAVE RESTRICTIONS INPLACE.
*NOTE 2* BLUETOOTH TETHERING DOES NOT AUTO RECONNECT, INSTALL THIS THIRDPARTY SOLUTION ON YOUR GEAR TO ENABLE AUTO RECONNECT.
HOW DO I FULL WIPE?
BOOT INTO RECOVERY MODE AND SELECT THE "RECOVERY" OPTION. DO THIS AFTER FLASHING THE ROM
SCREEN FLICKERING/GITTERING
THIS IS CAUSED BY THE INITIAL BOOTUP, REBUILDING THE CACHE AND INITIALIZING ALL THE APPS. GIVE YOUR GEAR A FEW MINUTES TO SETUP AND RESTART.
SCREEN UNLOCKS TO NOVALAUNCHER PAGE PREVIEW?
GO INTO "NOVA SETTINGS -> GESTURES -> HOME BUTTON -> NONE".
USB DEBUG
GO INTO "SETTINGS -> GEAR INFO -> ABOUT GEAR", TAP SOFTWARE VERSION 10 TIMES.
ENABLE UNKNOWN SOURCE APK INSTALLATION
GO INTO "FULL SETTINGS -> SECURITY -> TICK UNKNOWN SOURCES".
ENABLE MTP
GO INTO "FULL SETTINGS -> STORAGE -> MENU BUTTON (TOP RIGHT OF SCREEN) -> USB COMPUTER CONNECTION -> MEDIA DEVICE (MTP)".
WATCH STYLER NOT WORKING
ENSURE ITS SELECTED AS THE DEFAULT WATCHFACE IN GEAR MANAGER.
IF CLOCK FACE DOES NOT UPDATE UPON CHANGING, RESTART GEAR.
DOUBLE CLICK HOME BUTTON DOESNT WORK ON TOUCHWIZ LAUNCHER !
*NOTE* DO NOT DO THE FOLLOWING IF YOU ARE USING NOVALAUNCHER, YOU WILL NOT BE ABLE TO MANUALLY LOCK YOUR GEAR.
NAVIGATE/PULL THE FOLLOWING FILE FROM YOUR GEAR: /SYSTEM/USR/KEYLAYOUT/GPIO-KEYS.XML
EDIT IN A TEXT EDITOR SO IT LOOKS LIKE THE BELOW:
key 115 VOLUME_UP WAKE
key 114 VOLUME_DOWN WAKE
key 116 POWER WAKE
key 172 HOME WAKE
