Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > Smart Watches > Samsung Smart Watches
Samsung Smart Watches Samsung Galaxy Gear 1 and 2 , Samsung Gear Live , Samsung Galaxy Gear Fit , Samsung Gear S
Old 01-07-2014, 20:49   #1 (permalink)
Member: 1849224
Sonork: no ida
Thanks Meter: 5
Samsung Galaxy Gear SM-V700 Firmware Version Via Odin3 program
Needed Downloads For Updating Samsung Galaxy Gear SM-V700 Firmware:
- Samsung Galaxy Gear SM-V700 Stock Firmware Package.
- Odin Flasher.
- Samsung Galaxy Gear SM-V700 USB Drivers.
Needed Tools For Updating Samsung Galaxy Gear SM-V700 Firmware:
- Suitable USB cable.
- A stable computer running Windows OS.
Important Notice: We provide this guide for help purpose only, And we hold no responsibility at all, So keep in mind that your are doing this at your own RISK.
Preparation:
After downloading the needed files you should extract the zipped ones, And install the USB drivers (Restart your PC after installing).
Samsung Galaxy Gear SM-V700 Firmware Update Steps:
- Open Odin3.ini file using the Notepad program, You can find this file inside Odin3 folder.
- Scroll down until you get this section:
[ButtonOption]
Bootloader=1
PDA=1
Phone=1
CSC=1
UMS/PATCH=0
- Set (UMS/PATCH) to (1) instead of (0), Then save the file.
- Run Odin3.exe program.
- Check these options: Re-Partition (If you have PIT file only), Auto Reboot, F.Reset Time.
- Click PIT button to select: ls02.pit
- Firmware files selection:
Click Bootloader button to select: BOOTLOADER_V700xxxxxxx_..._REV03_user_low_ship.tar .md5
Click PDA button to select: CODE_V700xxxxxxx_..._REV03_user_low_ship.tar.md5
Click CSC button to select: CSC_Oxx_V700Oxxxxxx_..._REV03_user_low_ship.tar.md 5
Click UMS button to select: GANG_V700xxxxxxx_..._REV03_user_low_ship.tar.md5
- Entering the Download Mode:
Press the Power key for 7 seconds and then Press the Power Key 1 more time after display changed, Select
the Download mode ( Press and release the Power key for 0.5 sec to move and press it for 1.6 sec to select).
- Insert the Smartwatch into the charging-dock And lock it.
- Use the USB cable to connect your device to the computer, Don't use any USB-HUB for connecting, And use only main USB slots.
- Wait until Windows detects the connected device and installs its suitable USB drivers.
- In case everything is OK, Then Odin program will detect your connected device (0:[COMxx]).
- Click on Start button.
- Odin program will start installing the new firmware files into your device, So wait until the device reboots.
- If the update was successfully done, Then you will notice PASS! Word at Odin program.
- Disconnect the USB cable.
- Wait for the Smartwatch to be fully on.
- Now you can customize your device after installing the new firmware version.
Notice: When you get one big file inside the firmware package, Then it should be selected as a PDA file only, And do not check Re-Partition option or use PIT file at all.
Page generated in 0.16679 seconds with 9 queries
