Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > Smart Watches > Samsung Smart Watches
Samsung Smart Watches Samsung Galaxy Gear 1 and 2 , Samsung Gear Live , Samsung Galaxy Gear Fit , Samsung Gear S
Old 01-15-2020, 00:55   #31 (permalink)
Member: 420658
Thanks Meter: 211
USB Pinout is in Service Manual from SM-R820 / SM-R830...
A--->Ground
B--->DATA+
C--->DATA-
D--------------
E--------------
F->VCC/+5V
Only idea... maybe wrong. UNTESTED!
A->TP_GND
B->TP_USB_DM
C->TP_USB_DP
D->TP_POGO_V_BATTERY
E->TP_USB_ID
F->TP_V_BUS_5V
Names taken from Service Manual.... ABCDEF is on my Photo...
Best Regards
The Following User Says Thank You to adfree For This Useful Post:
Old 01-16-2020, 18:21   #32 (permalink)
Member: 2943638
Thanks Meter: 2
It could be similar to SM-R800!
I tested SM-R500 with the USB and it gave me this msg (the last USB device you connected to this computer malfunctioned and Windows does not recognize it)
Old 01-21-2020, 07:41   #33 (permalink)
Member: 420658
Thanks Meter: 211
Tested successfully.
SM-R820 / SM-R830 USB Pinout
If Windows Device Manager detect unknown device, try again with green and white cable switched...
About SM-R500... Still no idea...
I found no Service Manual nor I have this device...
SM-R600... Pinout seems in Service Manual...
2 wires on left side of board... 2 wires on the other side... something like this...
Best Regards
Old 01-21-2020, 11:33   #34 (permalink)
Registered User
Member: 246072
Thanks Meter: 96
Originally Posted by adfree View Post
Oh, seems 6 Pins is not sooo new...
Here Photos from SM-R500 GWA...
Öhm... new year new attempt.
Somebody knows the USB Pinout from SM-R500?
Please.
Thanx in advance.
Best Regards
Check if this helps you
https://imgur.com/a/pB22GMx
The Following User Says Thank You to SpoOnx For This Useful Post:
Old 01-22-2020, 17:08   #35 (permalink)
Member: 2943638
Thanks Meter: 2
[QUOTE=SpoOnx;13980338]Check if this helps you
Thank you so much for this image. I tested it and it works
The Following User Says Thank You to Rooot For This Useful Post:
Old 01-22-2020, 22:19   #36 (permalink)
Member: 420658
Thanks Meter: 211
@Rooot
You soldered wires?
Or found other way to attach wires?
Can you check please this Picture?
Or you have green cable and white switched?
Thanx in advance.
Best Regards
Old 01-27-2020, 20:58   #37 (permalink)
Member: 2943638
Thanks Meter: 2
Rooot
You soldered wires?
Thanx in advance.
Best Regards
adfree
you need to switch green and white.
So it will be black, white, green, blank, blank and then red.
You can solder the wire if you want for me. I made a USB interface compatible with this situation.
Regards,
Old 02-10-2020, 19:56   #38 (permalink)
Member: 575293
Thanks Meter: 40
I used a pin port from an old charger cradle to connect to the S3 that worked just fine for me, I forgot which one it was though.
Old 11-01-2021, 01:46   #39 (permalink)
Member: 303976
Thanks Meter: 6
Attachment 383527Thanks f9r the pics.
This ks the pin layout for the Samsunf R895F. Which i think should be the same with the rlprevious watches, since there is no service manual available, if anyone could help would be much appreciated.
The Following User Says Thank You to tids2k For This Useful Post:
Old 11-01-2021, 02:00   #40 (permalink)
Member: 303976
Thanks Meter: 6
Old 12-21-2021, 23:06   #41 (permalink)
Member: 420658
Thanks Meter: 211
SM-R860 have 5 more golden TP?
https://forum.gsmhosting.com/vbb/14494973-post156.html
Please I need USB Pinout for GW4.
Who can help?
Its Xmas time.
Thanx in advance.
Best Regards
Old 05-17-2022, 14:46   #42 (permalink)
Member: 420658
Thanks Meter: 211
User confirmed SM-R860 USB Pinout.
He was able to use RDX Tool for Upload Mode...
summary.html
auto_comment
extra_info
debug_history
boot_reset
acpm_dump
header
kernel
platform
kevents
s2d
arrdumpreset
arrdumppanic
MFC-log-mem
MFC-sfr-dmp0
LPD-log-mem
LPD-srm-dmp
I was to lazy to write from Screenshots...
Only as info.
Best Regards
Old 05-21-2022, 20:50   #43 (permalink)
Member: 575293
Thanks Meter: 40
Heres a video I made showing the board from one of the watch charging cradles will connect to port pins and load in Odin
https://*********/h3m5mkccbwg&fs=1" width="644" height="390">https://*********/h3m5mkccbwg&fs=1" />https://*********/h3m5mkccbwg">http://www.youtube.com/watch?v=https://*********/h3m5mkccbwg
For other watches you might have to solder wires to contacts to get it to work
Old 06-04-2022, 01:41   #44 (permalink)
Member: 420658
Thanks Meter: 211
@cellfonepimp
Sorry I can not see your Youtube Video.
If it is GW4 related can you please help to fix my problem?
I wrote PM to you but got no feedback...
Thanx in advance.
Best Regards
Old 06-10-2022, 16:08   #45 (permalink)
Member: 575293
Thanks Meter: 40
https://*********/h3m5mkccbwg&fs=1&hd=1" width="858" height="508">https://*********/h3m5mkccbwg&fs=1&hd=1" />https://*********/h3m5mkccbwg">http://www.youtube.com/watch?v=https://*********/h3m5mkccbwg
Page generated in 0.26325 seconds with 10 queries
