Help unlock nokia 6600 Please help me unlock my new 6600 from TMobile IMEI: 353384000195074 Thanks |
DCT4 #pw+348456777616455+1# #pw+305256433304357+2# #pw+416927642441023+3# #pw+112154442063357+4# #pw+203865137170062+5# #pw+137224566514226+6# #pw+823011754152512+7# |
I am sorry I tried the first line and get "code error." Should I enter all seven lines of code? Also should I use asterisk key for 'p' and 'w'? I am also assuming that the sim card needs to be removed while entering these codes. Thanks |
I saw Dr. Mobiles instructions for how to unlock DCT4 codes and tried line 7 also but get same error. |
PLEASE DO NOT TRY ALL CODES How To Enter The Unlocking Code press: #pw + xxxxxxxxxxxxxxx + # (P: press "*" three times) (w: press "*" four times) (+: press "*" two times) Type"pw+CODE+x" into the locked phone with no SIM card in phone. To access button "+" you have to press twice "*" within less than a second. To access "p" just press "*" three times within one second. To access "w" press "*" four times within one second. If you can contactme at [email protected] Bye......B.R. |
I have followed the instructions and get "code error" for code 1 and code 7. |
anyways..your calculated codes are not correct... :D :D :D BR |
we all once upon a time were newbies #pw+ 78 82 10 41 36 64 61 2 +1# #pw+ 04 31 43 57 71 23 14 1 +2# #pw+ 08 73 53 31 75 45 35 4 +3# #pw+ 42 33 27 55 51 15 62 0 +4# #pw+ 87 34 11 40 41 46 71 6 +5# #pw+ 38 43 06 11 42 45 70 4 +6# #pw+ 32 44 06 15 32 46 20 3 +7# we all once upon a time start as newbies!!! R.F. |
Use code from ricardo net lif or use: Model: Nokia (6600 ) IMEI: 353384000195074 Network: 31020000 #pw+79 82 00 41 36 64 61 2+1# #pw+05 31 33 57 71 23 14 1+2# #pw+09 73 43 31 75 45 35 4+3# #pw+43 33 17 55 51 15 62 0+4# #pw+88 34 01 40 41 46 71 6+5# #pw+39 43 96 11 42 45 70 4+6# #pw+33 44 96 15 32 46 20 3+7# if they work, I don't know. Use only 1 and 7 row. Good luck |
@ricardo_net_lif and tigertrn: don't give to member with no enough posts read the rules :( :( :( |
OK I will not give any codes to people who has no enough posts, but I to have no enough posts :) |
#pw+ 32 44 06 15 32 46 20 3 +7# |
There is an site called http://www.***********.com/, which helps to get the unlocking code and instructions for your mboile.You can also use this for unlocking. |
you can try this Unlock Code: #pw+799720413664612+1# i got this code at unlock- free. com |
